Author Topic: GON's KeyboardWorks - Questions and Answers  (Read 837268 times)
Offline minho
  • i'm kind of back
Re: Questions and Answers
« Reply #150 on: Thu, 12 June 2014, 14:31:05 »
Cross posted from another thread about the NerD because I'm not sure if GON was following that one.
If buying a acrylic case and nerd pcb, do you need to purchase the SMD and LEDs and other components separately? (I see them for sale on the website as separate parts, but not sure if included in PCB order or not).
Offline pmh1410
« Reply #151 on: Sat, 14 June 2014, 01:47:05 »
Hi Gon, pls check your email ;)
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
« Reply #152 on: Tue, 17 June 2014, 06:44:30 »
Sorry, I will check it. ;)
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline redskull
« Reply #153 on: Wed, 18 June 2014, 01:01:30 »
hi GON, whats the update on my small order?
Offline GON
    • GONsKeyboardWorks
« Reply #154 on: Sat, 21 June 2014, 06:29:04 »
Will be shipped next week. ;)
(They are already packed and waiting for pick up. ;))
So Ironical!
Offline redskull
« Reply #155 on: Sat, 21 June 2014, 07:21:21 »
w00t! w00t! cant wait!  ;D ;D ;D
Offline redskull
« Reply #156 on: Tue, 24 June 2014, 04:14:17 »
hi GON,
after you ship my items, should i receive any notification in my e-mail? maybe from paypal?
Offline GON
    • GONsKeyboardWorks
« Reply #157 on: Thu, 26 June 2014, 06:19:51 »
hi GON,
Either from paypal or at www.GONsKeyboardworks.com orderstatus. ;)
So Ironical!
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #158 on: Thu, 26 June 2014, 06:28:24 »
Hello, GON!
What are the chances of getting a LEEKU 1800 pcb from your shop?
Offline GON
    • GONsKeyboardWorks
« Reply #159 on: Thu, 26 June 2014, 06:37:11 »
Hello, GON!
Sorry I don't have them in stock. ;)
So Ironical!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #160 on: Thu, 26 June 2014, 07:28:52 »
Hello, GON!
Is it something you could get in the future?
Offline GON
    • GONsKeyboardWorks
« Reply #161 on: Thu, 26 June 2014, 07:41:44 »
Hello, GON!
Maybe not, sorry...
So Ironical!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #162 on: Thu, 26 June 2014, 09:41:10 »
Hello, GON!
Maybe not, sorry...
no worries GON! just thought I'd check.
Offline GeorgeK
« Reply #163 on: Fri, 27 June 2014, 09:22:22 »
Offline GON
    • GONsKeyboardWorks
« Reply #164 on: Fri, 27 June 2014, 12:17:14 »
So Ironical!
Offline GeorgeK
« Reply #165 on: Fri, 27 June 2014, 12:27:57 »
Damn...
Offline GeorgeK
« Reply #166 on: Wed, 09 July 2014, 10:47:22 »
Couple more quick questions:
1) Have you stopped doing the GON NS 87 case with semi-glare?
2) Are you going to be discontinuing them at any point?
Offline GON
    • GONsKeyboardWorks
« Reply #167 on: Wed, 09 July 2014, 11:38:55 »
1) Semi-Glare is not available anymore...
2) Yes, it will be soon discontinued.
So Ironical!
Offline GeorgeK
« Reply #168 on: Wed, 09 July 2014, 16:10:13 »
OK - how long do I have to order one?
Offline GON
    • GONsKeyboardWorks
« Reply #169 on: Thu, 10 July 2014, 05:42:26 »
I think I have one Mid-part left. And I don't know whether I will make  more or not...
AL plates are not difficult to machine, but its mid parts are not... so I usually have mid-parts in stock as many as I need.
Now, I have one left.
So Ironical!
Offline GeorgeK
« Reply #170 on: Thu, 10 July 2014, 07:35:32 »
Could you put it aside for me?  I just need to test something and then I'll order (by Sunday at the latest)
Thanks
GK
Offline GON
    • GONsKeyboardWorks
« Reply #171 on: Fri, 11 July 2014, 13:16:27 »
Thanks
GK
OK, No problem. ;)
So Ironical!
Offline GeorgeK
« Reply #172 on: Fri, 11 July 2014, 16:52:47 »
Cheers mate - will definitely get back to you in the next day or two :)
GK
Offline GeorgeK
« Reply #173 on: Thu, 17 July 2014, 02:18:02 »
Hmm - looks like there are some issues with my A.87 pcb that I can't iron out myself in a hurry...
Seeing as a NerD TKL PCB and one of the acrylic cases is actually less money than one of the A.87 compatible cases - a couple of questions about the NerD TKL if I may:
1) Is there a reason that orange LEDs aren't available?  I have some of these which have a forward voltage of 1.8 - 2.2v so I'm guessing the 680 ohm resistors would be best if the board supports them.
2) I see on the product page for the PCB that the keymap editor isn't available yet.  As standard, does it support this layout:
3) If it does support that layout, which key/s are the fn keys and what is the fn layer?
That's it for now!
Thanks again GON - most appreciated :)
GK
Offline GON
    • GONsKeyboardWorks
« Reply #174 on: Thu, 17 July 2014, 07:31:44 »
That's it for now!
GK
1) There is little demand for Orange LEDs because they are too similar with REDs. So I don't stock them. But you can apply them to the PCB if you want.
2)3) Refer to the following links. Keymap editor is not a problem anymore, it will be released at around the end of this month.
http://geekhack.org/index.php?topic=50577.0
http://www.gonskeyboardworks.com/housingscases/82-acrylic-housing-for-nerd-tkl.html
So Ironical!
Offline GeorgeK
« Reply #175 on: Thu, 17 July 2014, 07:34:55 »
Thanks for getting back to me.  So with a Winkey layout (1.5 - 1 - 1.5 - 7 - 1.5 - 1 - 1.5) does the right-hand 'windows' key (the 1x key) act as the fn key?  Does the board come pre-programmed with this layout or another layout (a 6.25 spacebar for example)
Thanks again
GK
Offline GON
    • GONsKeyboardWorks
« Reply #176 on: Sat, 19 July 2014, 01:16:12 »
Thanks again
GK
Keymap is no more problem, GUI is almost developed and will be released at the end of this month.
So Ironical!
Offline GeorgeK
« Reply #177 on: Sat, 19 July 2014, 03:36:01 »
Great - thanks again.
Last question - I'm trying to decide on what colours to go for in terms of the case.  Do you have any pictures of the "Orange (Transparent)" acrylic that is available for either the plate or the mid section? (http://www.gonskeyboardworks.com/housingscases/82-acrylic-housing-for-nerd-tkl.html)
Cheers
GK
Offline GON
    • GONsKeyboardWorks
« Reply #178 on: Sat, 19 July 2014, 08:26:02 »
Cheers
GK
Unfortunately, no... I don't have pictures for Acrylics.
So Ironical!
Offline GeorgeK
« Reply #179 on: Sat, 19 July 2014, 13:11:47 »
OK thanks.  Fairly certain I'm going to go for black top and bottom.  Just need to decide on either orange plate and mid or transparent orange top and mid.
Would the orange that isn't transparent let any light through?  If not then I might have made my decision :)
Offline GON
    • GONsKeyboardWorks
« Reply #180 on: Sun, 20 July 2014, 01:48:20 »
I don't recommend non-transparent parts for mid if you like beautiful Side LEDs. ;)
So Ironical!
Offline GeorgeK
« Reply #181 on: Sun, 20 July 2014, 03:47:19 »
Fair enough :)
How does a black top and bottom and transparent orange mid and plate sound to you? (With orange switch and side LEDs)
Offline GeorgeK
« Reply #182 on: Fri, 25 July 2014, 07:25:31 »
Hi GON
One last question (I hope)
On the NerD PCB page at the bottom of the page it gives the option for side LED colour.  Does this mean that they are included in the price of the PCB or would they need ordering separately?  (i.e If I selected Orange would I actually receive 33 orange SMD LEDs or not?)
Thanks
George
Offline GON
    • GONsKeyboardWorks
« Reply #183 on: Fri, 25 July 2014, 07:40:59 »
Hi GON
Thanks
George
If you want to solder SMD LEDs yourself, you can order them at Accessories Category.
If you want me to solder SMD LEDs, you have to choose "Optional Soldering = Side LEDs and resistors for them" which charges you extra fee.
So Ironical!
Offline GeorgeK
« Reply #184 on: Fri, 25 July 2014, 07:42:05 »
I'll be doing them (well margo will but same thing)
What is the drop-down on the page for?
Offline domoaligato
« Reply #185 on: Thu, 31 July 2014, 20:05:56 »
has information about the Gon NerD Ergo been released? I saw this in the NerD Gui youtube videos and was very interested.
Offline GON
    • GONsKeyboardWorks
« Reply #186 on: Thu, 31 July 2014, 20:30:11 »
Someday... but not developed yet. ;)
So Ironical!
Offline Lastpilot
  • Power stance
« Reply #187 on: Fri, 08 August 2014, 14:02:34 »
What resistors are recommended to use for white LED's on the PS2AVR mx-miniU? In-switch square 2x3x4 white led's will be used.
I want them to be extra bright!
« Last Edit: Fri, 08 August 2014, 14:16:39 by Lastpilot »
Offline GON
    • GONsKeyboardWorks
« Reply #188 on: Sat, 09 August 2014, 03:41:09 »
If you don't connect it to PS/2 but only to USB, 470R will do.
So Ironical!
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #189 on: Mon, 11 August 2014, 07:17:32 »
Hello GON,
Can you make your 60% acrylic case support ISO? or is that not possible?
Margo
PS. The nerdy gui is amazing.
« Last Edit: Mon, 11 August 2014, 07:20:12 by margo baggins »
I got boards.
Offline GON
    • GONsKeyboardWorks
« Reply #190 on: Mon, 11 August 2014, 08:08:35 »
Hello GON,
Margo
Hi margo,
Well... I can if I feel I need to.
It's just a matter of priority.... I don't have enough time to do everything... ;)
So... I do first what many people want or would want.
Just to make one, I have to sample it.
Acrylics are not suitable to make multi-layout supporting plate...
How many want ISO only layout? ;)
P.S. I considered all about NerD - Physical PCB design, Functions, Firmware and GUI - at the very beginning of its development. ;)
So Ironical!
  • Dungeon Dweller
  • Get back to work!
« Reply #191 on: Tue, 12 August 2014, 04:28:15 »
I don't think very many :)
Plus I realised the GON [CTRL]ALT 60 supports ISO, so I will just use that. I just wanted to build a little ISO board :)
I got boards.
Offline GON
    • GONsKeyboardWorks
« Reply #192 on: Tue, 12 August 2014, 05:03:48 »
Yes, that KBD supports almost all kinds of layouts. ;)
So Ironical!
Offline cseng
« Reply #193 on: Tue, 19 August 2014, 06:10:26 »
hi GON,
Wait... so that means my order hasn't been shipped yet?! My payment was accepted 15th May and it's 19 August today....
Btw I sent you a mail asking the same question...
« Last Edit: Tue, 19 August 2014, 08:46:32 by cseng »
Offline GON
    • GONsKeyboardWorks
« Reply #194 on: Tue, 19 August 2014, 14:12:59 »
hi GON,
Sorry for delay...
NerDy GUI took more time than I expected this spring....
But I shipped your NerD today, and you can check your tracking number at your order status.
You will need a couple of days till you can track with that number.
Thanks for your patience, ;)
GON
So Ironical!
Offline cseng
« Reply #195 on: Tue, 19 August 2014, 14:24:11 »
Ye but latest version 1.2 was released like 3rd August...
Oh well 1-2 more weeks then.
« Last Edit: Tue, 19 August 2014, 14:41:17 by cseng »
Offline archer
« Reply #196 on: Tue, 19 August 2014, 15:38:00 »
Not sure where you're located.. but when I got my tracking number from Gon, the kbd was at my house on my doorstep in 3 or 4 days. You might not have to wait as long as you think!
Offline cseng
« Reply #197 on: Tue, 19 August 2014, 17:34:04 »
I'm in Sweden and I hope that applies to me as well lol.
Offline GON
    • GONsKeyboardWorks
« Reply #198 on: Tue, 19 August 2014, 19:35:39 »
Sorry... I had to spend almost a whole month in developing... Which means, I could not assemble for the time being....
So Ironical!
Offline uns211
« Reply #199 on: Fri, 22 August 2014, 15:53:59 »
Are these resistors suitible for the GON NerD 60/ [CTRL]ALT 60?
