Author Topic: GON's KeyboardWorks - Questions and Answers  (Read 852585 times)
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
Re: Questions and Answers
« Reply #250 on: Mon, 29 September 2014, 13:44:42 »
Hi i'm planning to change one of my MX switches using this guide:
Since my GON Nerd TKL has LED's attached on each switch, am i breaking something by removing the switches the same way as he did?
You have to desolder the switch as well as its in-switch LED.
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline GL1TCH3D
« Reply #251 on: Wed, 01 October 2014, 21:15:55 »
Is there any way to decrease the inclination of my GoN Crystal TKL? (Are the feet removable?)
Offline GON
    • GONsKeyboardWorks
« Reply #252 on: Wed, 01 October 2014, 23:57:01 »
You can remove the feet with H2 Hexa wrench. ;)
You have to be careful when fastening the bolts again.
So Ironical!
Offline GL1TCH3D
« Reply #253 on: Thu, 02 October 2014, 16:27:26 »
I'm trying really hard to figure out how to connect my keyboard via bluetooth o.o
I set the keys for bluetooth toggle and connect
EDIT: Figured it out.... I think xD
I have both dip switches up and I press the connect key then search for it on my android device but for whatever reason it wasn't showing up for me
« Last Edit: Thu, 02 October 2014, 16:43:10 by GL1TCH3D »
Offline GON
    • GONsKeyboardWorks
« Reply #254 on: Thu, 02 October 2014, 16:48:28 »
Try Off and On again with your phone. And Off and On again with your NerD. Then try again. ;)
I also use NEXUS5 and I'm 100% sure it works. ;)
By default, BT Connect is "Fn2 + C", BT/USB Toggle is "Fn2 + B"
So Ironical!
Offline Spelly
« Reply #255 on: Thu, 02 October 2014, 17:45:51 »
GON:
I heard about your keyboards on /r/MechanicalKeyboards a while back, and have been doing some research to find out more.  I love your NerD boards, and saw on your site that you offer a fully built NerD 60%.  I was wondering if there are any pictures of the 60% and what kind of layout the board uses.  Thanks for the help!
Offline GON
    • GONsKeyboardWorks
« Reply #256 on: Thu, 02 October 2014, 19:30:11 »
GON:
Sorry I could not take many pictures due to time limit. T.T
But you can find out what layouts NerD 60 supports
http://www.gonskeyboardworks.com/custom-kbds-w-assembly/101-gon-ns-nerd-60-w-tuningassembly.html
As you see in the options, NerD 60 as well as other NerD PCBs supports almost all kind of standard layouts including ANSI, ISO and etc...
So Ironical!
Offline GL1TCH3D
« Reply #257 on: Thu, 02 October 2014, 20:31:15 »
Yea I got it working right after making the post xD
I had to switch the dip switches down and back up then it was working!
Offline Spelly
« Reply #258 on: Fri, 03 October 2014, 15:24:51 »
Thanks for the quick answers, and sorry for asking a question with such an obviously available answer! When I was looking at the customization options, I saw that you could mod the springs on any of the switches down to 50g, but I was wondering if it would be possible to go down to 45g upon request to get a more "ergo clear" type switch? Ive been interested in this type of switch and have been looking for a way to get my hands on a board with them.  Once again, thanks for the quick responses!  :)
Offline GON
    • GONsKeyboardWorks
« Reply #259 on: Sat, 04 October 2014, 00:06:31 »
Clears /w 45g springs will not work properly. 55 is the minimum for Clears, in fact.
So Ironical!
« Reply #260 on: Sat, 04 October 2014, 20:58:05 »
do you know anything about this guy?
Second guy from the top. Saw this on bigdaddy's stream earlier today.
http://www.twitch.tv/bigdaddy/b/574816629?t=151m5s
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #261 on: Sun, 05 October 2014, 06:42:01 »
Will the Clears work with 120g springs?  If not, what maximum spring strength (don't know what else to call it) are you able to use with any Clear Cherry Switches?
Offline GON
    • GONsKeyboardWorks
« Reply #262 on: Sun, 05 October 2014, 07:35:26 »
Heavier Springs never make problem, but "Light" ones only does. ;)
If you want heavier springs, I would recommend springs from Grey stem switches. ;)
So Ironical!
« Reply #263 on: Sun, 05 October 2014, 09:36:57 »
You will lose some of the tactile feedback with heavier springs.
Offline GON
    • GONsKeyboardWorks
« Reply #264 on: Sun, 05 October 2014, 10:02:02 »
Right that should be taken into consideration. ;)
So Ironical!
Offline nebo
« Reply #265 on: Mon, 06 October 2014, 16:49:07 »
Hey GON, is it possible to get any non-acrylic cases in white? Also, any chance of the HHKB case coming back into stock?
« Last Edit: Mon, 06 October 2014, 17:23:52 by nebo »
« Reply #266 on: Mon, 06 October 2014, 16:55:14 »
Hey GON, is it possible to get any cases in white? Also, any chance of the HHKB case coming back into stock?
the acrylic case comes in white
Offline nebo
« Reply #267 on: Mon, 06 October 2014, 17:24:06 »
Guess I should have specified, edited my post.
Offline GON
    • GONsKeyboardWorks
« Reply #268 on: Tue, 07 October 2014, 03:17:13 »
I also have an MOQ for CNC-machining... So.. would you do an IC? If there is more than 5, I will make HHKB housing. ;)
So Ironical!
Offline nebo
« Reply #269 on: Tue, 07 October 2014, 11:04:25 »
Awesome. For the IC, would they all have to be the same color and shipped to the same person who would then distribute them?
Offline GON
    • GONsKeyboardWorks
« Reply #270 on: Tue, 07 October 2014, 14:03:00 »
No they will place their own orders at my website.
They will directly make their payment to me.
I will ship the items directly to them.
Each of them can choose their own color.
They can pick other items to combine shipping. ;)
5 of moq is just because of CNC-machining not because of anodizing. ;)
So Ironical!
Offline GL1TCH3D
« Reply #271 on: Wed, 08 October 2014, 09:40:45 »
What are the dimensions of the mobik?
Trying to get a custom hard case done for it before it arrives so I don't damage it early on from bringing it around
Offline nebo
« Reply #272 on: Wed, 08 October 2014, 11:02:20 »
I think I love you. :)
Offline kitsun8
  • In need of some cash
« Reply #273 on: Thu, 16 October 2014, 01:29:43 »
Do i use the left or the right for a 6.25 spacebar? and for the right alt and fn1 key its the middle slots for 1.25 yeah? I've never been given so many options before :o
Offline GON
    • GONsKeyboardWorks
« Reply #274 on: Thu, 16 October 2014, 08:14:28 »
Look at the back of the PCB, there would be silk print for it.
Left one is for Filco position, and the right is for CHERRY position.
So Ironical!
Offline kitsun8
« Reply #275 on: Thu, 16 October 2014, 08:22:44 »
Are poker and filco spacebar the same?
Offline ceflame
« Reply #276 on: Fri, 17 October 2014, 01:33:24 »
Hey GON, just wondering if my order has shipped yet: EAWTSVEQJ
You told me initially it would be last week, and then either Monday or Tuesday this week, but I haven't heard back from you yet about shipping.
Sorry to keep bugging you about it if you're busy with other things or something isn't ready yet. Thanks!
Offline GON
    • GONsKeyboardWorks
« Reply #277 on: Fri, 17 October 2014, 05:43:54 »
UPS let me know the tracking number today. I updated your order. It is scheduled to arrive you on Monday.
So Ironical!
Offline ceflame
« Reply #278 on: Fri, 17 October 2014, 05:51:16 »
Alright thanks GON :D
« Last Edit: Sat, 18 October 2014, 13:33:00 by ceflame »
Offline Chedda7
« Reply #279 on: Sat, 18 October 2014, 07:49:02 »
GON, I am also curious about my order - YODBMIZWC.
Has it shipped yet?
Offline GON
    • GONsKeyboardWorks
« Reply #280 on: Sat, 18 October 2014, 10:06:39 »
Has it shipped yet?
As I had to sample the new TOP plate, I needed some more time.
(I tried once, but I made a mistake in modding the design for HHKB....)
I corrected the drawing and placed an order again, your order will be shipped as soon as the new housing arrives. ;)
Sorry for delay...
So Ironical!
Offline Elocutive
« Reply #281 on: Sat, 18 October 2014, 13:27:20 »
Hey GON,
Will you ever make a high profile, full aluminum case?
LZCE- Black, red, ergo clears
Wanting Skeldon
Offline Chedda7
« Reply #282 on: Sat, 18 October 2014, 13:45:50 »
Has it shipped yet?
Sorry for delay...
All good, no rush.  I just wanted to make sure you hadn't forgot about me  :D
Offline yicaoyimu
« Reply #283 on: Wed, 22 October 2014, 23:37:46 »
Can I still order NerD TKL PCB for KMAC and plate?
Offline GON
    • GONsKeyboardWorks
« Reply #284 on: Thu, 23 October 2014, 04:05:32 »
Yes, I have 3 pcs in stock. ;)
So Ironical!
Offline chickenNwaffles
« Reply #285 on: Thu, 23 October 2014, 16:49:55 »
Hello,
I was wondering if the White NerD 60 PCB is able to support the case and layout of the KBT Pure pro. Also, does the PCB come with the diodes and other components already soldered on? I am looking for a 60% pcb that I can just solder switches into and go.
Offline GON
    • GONsKeyboardWorks
« Reply #286 on: Fri, 24 October 2014, 15:01:08 »
Hello,
Hi,
NerD 60 PCB is compatible with most 3rd party Poker housings.
But I can't give you an answer to your layout question because I don't know the exact layout of Pure pro.
The PCB will be shipped /w controller SMD parts soldered and pre-flashed.
You will have to add optional soldering for diodes.
So Ironical!
« Reply #287 on: Fri, 24 October 2014, 15:19:07 »
Hello,
Hi,
This the pure pro layout:
http://img.alibaba.com/img/pb/926/624/794/794624926_158.jpg
Thanks for the quick answer, probably going to pick myself up one.
« Reply #288 on: Fri, 24 October 2014, 15:25:32 »
it's not compatible with pure pro layout
« Reply #289 on: Fri, 24 October 2014, 15:36:08 »
Hmm, wonder if pure case is the same as the poker, if so, I will just use that layout. If all else fails, I will just have to wire everything myself.
« Reply #290 on: Fri, 24 October 2014, 17:45:21 »
pure and poker cases are in fact the same
Offline UberStinus
« Reply #291 on: Sat, 25 October 2014, 06:48:48 »
Hi GON,
I intend to build myself a NerD 60 with a nice clear acrylic case, problem is I live in the netherlands(EU).
as the Customs Tariffs from outside the EU are incredibly steep I was wondering whether you have any resellers in the EU e.g. Germany or the UK?
my main concern is that over a purchase of around 200$ I would have to pay 39$ for shipping and as soon as it hits the dutch borders,
A backpay on VAT ((21%) over the entirity), customs fare (again over the entirity). so If you would have a reseller of any kind in Europe that would be of epic help to me!:)
I am very much looking forward to your reply,
regards, Stinus
Offline GON
    • GONsKeyboardWorks
« Reply #292 on: Sat, 25 October 2014, 10:45:51 »
Hi GON,
regards, Stinus
Hi UberStinus,
I don't declare full-value when shipping out the items, if the buyer told me to cover his items with insurance.
This is why I don't include invoices and don't use Logo-marked box.
I just ship in a flat(light brown) box /without any invoice, and declare it as a GIFT.
This will not make any problem to you. ;)
Contact me if you need any further help.
Thanks,
GON
So Ironical!
Offline UberStinus
« Reply #293 on: Sat, 25 October 2014, 11:27:41 »
Hi GON,
regards, Stinus
Hi UberStinus,
Thanks,
GON
I'm very glad to hear that, then I'm off to the second hurdle.
what exactly would I need to build the NerD 60, fully backlit and also with the led's on the sides?
EDIT: meaning LED Diode and resistor wise...
« Last Edit: Sat, 25 October 2014, 11:35:39 by UberStinus »
Offline GON
    • GONsKeyboardWorks
« Reply #294 on: Sat, 25 October 2014, 11:44:06 »
Hi GON,
regards, Stinus
Hi UberStinus,
Thanks,
GON
Parts needed for a Custom KBD...
You can refer to this link
http://www.gonskeyboardworks.com/manuals/137-parts-needed-for-a-kbd.html
So Ironical!
Offline UberStinus
« Reply #295 on: Sat, 25 October 2014, 12:34:00 »
So I would be good like this?
« Reply #296 on: Sat, 25 October 2014, 13:30:35 »
You'll need keycaps and a cable too, but GON doesn't source those.
and get yourself some 62g springs and lube in those clears
Offline UberStinus
« Reply #297 on: Sat, 25 October 2014, 13:35:07 »
That I am aware of but there are standard springs in those clears right?
Offline GL1TCH3D
« Reply #298 on: Sat, 25 October 2014, 18:50:32 »
Well... 62g korean springs are different than the 65g cherry mx springs that are stock in the clears
Offline GON
    • GONsKeyboardWorks
« Reply #299 on: Sun, 26 October 2014, 05:44:09 »
Many guys have asked me for optional springs to be sold separately.
So I recently made enough springs - 55g / 58.5g / 62g are available at the webstore.
So far 62g springs are the most popular. These are not like stock Black springs or Clear springs.
If adjusted to the same measure method, stock black springs will be heavier than 75g and stock clears will be heavier than 80g.
Now you can order standard black 1.8M USB cables too. ;)
So Ironical!
