Author Topic: GON's KeyboardWorks - Questions and Answers  (Read 837271 times)
Offline Wraul
Re: Questions and Answers
« Reply #50 on: Tue, 04 June 2013, 11:48:21 »
In the picture... most of them are semi-glare.
And red on, the third from the GON NS 38GT Pink is non-glare, and the red one /w red bolts is a glare one.
But its hard to distinguish in the picture...
And, even though you choose semi-glare, it sometimes comes out more like non-glare or full-glare.
Anodizing is very hard to make all the same at anytime...
But this little arbitrariness makes my customers' cases Unique. ;)
(Hard to find exactly the same ones...)
Your cases are amazing.
I hope they will be available for a while, so I can save enough money to buy one.
I have one question.
That black 38GT in the middle column.
It must have a special purpose. May I ask what it's for?
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
« Reply #51 on: Tue, 04 June 2013, 13:31:44 »
Well, that question should be asked to my customer, not me. ;)
I think he would use it as a specialized gaming controller.
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline SmallFry
« Reply #52 on: Tue, 04 June 2013, 13:35:07 »
. Nevermind.
Offline Wraul
« Reply #53 on: Tue, 04 June 2013, 14:06:44 »
Ok I see. Thank you.
It looks very interesting.
Offline emptythecache
  • out.
« Reply #54 on: Wed, 05 June 2013, 10:42:25 »
what is the blue 75% housing in the bottom left? It looks like it may be for a MX-Mini, but the modifier row has weird wide holes.
Offline GON
    • GONsKeyboardWorks
« Reply #55 on: Wed, 05 June 2013, 20:34:36 »
Yes that's for MX-MINI.
The bottom holes for compatibility.
This housing can fit MX-MINI Winkeyless and PS2AVR MX-MINI(Winkey/winkeyless Combo).
The bottoms hole design is due to "one-fits-all" purpose.
GON
So Ironical!
Offline WhiteFireDragon
    • youtube
« Reply #56 on: Thu, 06 June 2013, 02:23:36 »
How do we program your PCBs?
One thing I can't do for custom keyboards is programming from scratch. I think you'll have to make a guide on this since it seems more people are starting to get more of your PCBs/housing. Anyone on GH (excluding GON of course) have a fully built ps2avr that can comment, or am I the first?
  • out.
« Reply #57 on: Thu, 06 June 2013, 05:11:45 »
nope, but I will need to know too! I think sifo has one on order as well, maybe he knows.
Offline Wraul
« Reply #58 on: Thu, 06 June 2013, 06:39:11 »
I have not had time too look into this yet.
But I assume you would use the ISP header and a compatible programmer.
Not sure which firmware you should use though.
Would be cool if GON can provide a little info concerning this.
Offline GON
    • GONsKeyboardWorks
« Reply #59 on: Thu, 06 June 2013, 09:42:49 »
I think you would be the first one who build a keyboard with that PCB.
I can give you a link. But the explanation is in Korean.
You have to encode a keymap/firmware file and write it with ISP loader.
http://www.kbdmania.net/xe/data/5953500
And that is not my PCB but 괴수가면 designed it.
So Ironical!
    • youtube
« Reply #60 on: Thu, 06 June 2013, 12:07:28 »
Thanks for the link. It shows the maxtrix and has precompiled firmware to download. But how do I flash the firmware onto the controller using the ISP header?
Offline GON
    • GONsKeyboardWorks
« Reply #61 on: Thu, 06 June 2013, 12:22:24 »
It depends on your ISP loader.
You will have to study to use it. ;)
So Ironical!
Offline SmallFry
« Reply #62 on: Thu, 06 June 2013, 19:18:42 »
Which ISP loader do you have WFD?
Offline Hades
« Reply #63 on: Wed, 12 June 2013, 22:35:38 »
Can a 38GT support a winkeyless setup, i.e., a "1.5 / 1 / 1.5 / 7 / 1.5 / 1 / 1.5" bottom row?
Offline GON
    • GONsKeyboardWorks
« Reply #64 on: Wed, 12 June 2013, 22:56:58 »
No, only standard winkey layout is supported at the bottom row. ;)
So Ironical!
Offline Sai
« Reply #65 on: Thu, 13 June 2013, 09:08:19 »
GON, is this just your personal one ?
http://ysymidi.blog.me/10127492530
i saw in Zenuty's thread.
Offline GON
    • GONsKeyboardWorks
« Reply #66 on: Thu, 13 June 2013, 12:34:51 »
That's not mine.
I tuned it up on order. ;)
Some guy may be using that keyboard. ;)
So Ironical!
Offline Sai
« Reply #67 on: Thu, 13 June 2013, 20:51:38 »
oh i see. thanks.
Offline MKULTRA
  • telling it how it is
« Reply #68 on: Tue, 18 June 2013, 03:32:59 »
Do the PCB's we buy from you come with the firmware flashed?
« Reply #69 on: Tue, 18 June 2013, 03:41:25 »
GON will do all the basic SMD components and have the stock firmware loaded.
Offline MKULTRA
« Reply #70 on: Tue, 18 June 2013, 04:10:22 »
Sweet.  Can't wait to get one of these.  Gonna be my first custom!
    • youtube
« Reply #71 on: Tue, 18 June 2013, 04:22:07 »
What resistor package size do we get for the switch LEDs?
Also can I buy a preflashed loose atmega controller chip from you?
Offline GON
    • GONsKeyboardWorks
« Reply #72 on: Tue, 18 June 2013, 23:55:52 »
Most frequently used SMD size in Korean CUSTOM is 2012(metric).
Answer to the second question depends on which preflashed Controller chips you need. ;)
So Ironical!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #73 on: Wed, 19 June 2013, 00:04:43 »
You may not know, but I bought an A.87 with nothing soldered to it (similar to WFD), how to I get it to work since I'm not sure I can just plug it in and load firmware to it like a phantom. I'm not very good with software stuff :(
Offline GON
    • GONsKeyboardWorks
« Reply #74 on: Wed, 19 June 2013, 02:03:17 »
The paradox lying here is....
Even though I burn chips with firmware, shipping is at least $24 to the US... too high just for a chip.... ;(
So Ironical!
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #75 on: Wed, 19 June 2013, 19:53:14 »
I know it's a fixed shipping rate like everywhere else so does it mean he has to purchase something else to help make that $24.00USD more palatable?
I would get an extra pcb and/or plate bundled with that chip...... just my own personnel 'stupid' recommendation here.
Offline GON
    • GONsKeyboardWorks
« Reply #76 on: Wed, 19 June 2013, 21:44:12 »
Yes, I think $24 shipping just for "x"g small chip is too high for a buyer.
For me, it doesn't matter, but for a buyer, I think, it matters...
So Ironical!
Offline Poom
« Reply #77 on: Tue, 25 June 2013, 07:19:17 »
Hi Gon,
I am looking to try Ergo clear switches, but im a noob with modding and stuff.
How does it work? I send you all the stuff? or I can buy stuff from you, stuff as in springs, switches, boards etc.
i am also looking to get a new board, not modding mine own ones. how do i start? you have any recommendations? maybe you have board for sale, switches and all the rest? just not a full size.
My girlfriend is in Seoul, so shipping stuff isnt a problem.
Thanks, Poom
Offline GON
    • GONsKeyboardWorks
« Reply #78 on: Tue, 25 June 2013, 07:42:24 »
Hi Gon,
Thanks, Poom
You can buy from me almost everything you need to build a keyboard yourself. ;)
PM me for further discussion.
Thanks,
GON
So Ironical!
Offline zoolzoo
« Reply #79 on: Sun, 24 November 2013, 14:53:21 »
Is the GON Skinny housing likely to slide around on my wooden desk? I cant find any reviews or comments from anyone who owns one. That being said, I am interested in one.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline Patchwrks
« Reply #80 on: Mon, 25 November 2013, 12:42:42 »
is it possible to get a NS 38 with 1.5/1/1.5 7 1.5/1/1.5 bottom row?
(´・ω・`)denko-chan~~~내 스레드
Offline pmh1410
« Reply #81 on: Wed, 27 November 2013, 06:36:59 »
Gon was answer about this problem :)
« Last Edit: Wed, 27 November 2013, 06:38:39 by pmh1410 »
Offline Patchwrks
« Reply #82 on: Thu, 28 November 2013, 00:51:32 »
yes after reading i felt dumb :P
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #83 on: Fri, 27 December 2013, 05:43:04 »
Dear GON
I would like to ask:
1) How could I reprogram 38GT PCB? I am new to this board and so lost with many found results on this forum
2) Would you be able to design a board with SMD LED instead of normal LED?
Really appreciate if you could reply. Thanks
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline Jokrik
« Reply #84 on: Tue, 07 January 2014, 00:21:30 »
Does anyone know where is GON?
I've been looking for him :(
Offline nuclearsandwich
« Reply #85 on: Tue, 07 January 2014, 00:48:40 »
Dear GON
Yo Joneslee, I just went through the programming a couple of days ago with help from codyeatsworld. I'll PM you the relevant bits of the skype conversation or if you want realtime PM me your skype info and timezone.
Offline Jokrik
« Reply #86 on: Fri, 10 January 2014, 08:46:33 »
Seriously,
does anyone know where has he gone?
I've a project which he hold and I haven't heard back from him for a while
« Reply #87 on: Fri, 10 January 2014, 11:52:43 »
I guess you could say he's...
GON
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #88 on: Fri, 10 January 2014, 12:32:12 »
GON
Seriously,
Looks like GON posted on OTD not too long ago, [url]http://www.otd.kr/bbs/board.php?bo_table=album&wr_id=181239[url]
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #89 on: Fri, 10 January 2014, 12:32:33 »
oops, double post
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #90 on: Fri, 10 January 2014, 15:17:50 »
He usually takes a day or two to respond to a pm, but he did respond to mine a couple weeks back, fwiw.
Offline Jokrik
« Reply #91 on: Sat, 11 January 2014, 20:57:41 »
Been trying to reach him since the start of the year
Hope he's all fine...
Offline GON
    • GONsKeyboardWorks
« Reply #92 on: Mon, 13 January 2014, 17:27:12 »
Sorry guys. I made you worried.
I was too busy these days. So I could not even reply PMs.
But don't worry. All is fine with me. ;;)
So Ironical!
Offline Neal
  • Skype: iNewbcake
« Reply #93 on: Sun, 19 January 2014, 17:47:58 »
Hey Gon, no question just want to say I love you and your work! :thumb:
Offline jufa
« Reply #94 on: Sun, 19 January 2014, 18:11:53 »
yeah he's been very busy lol
Offline Moosecraft
  • HHKB Pro
« Reply #95 on: Fri, 31 January 2014, 09:41:34 »
Do you have pcb mounted switches?
Offline GON
    • GONsKeyboardWorks
« Reply #96 on: Sun, 02 February 2014, 08:20:52 »
Stop by my website
www.GONsKeyboardworks.com
You may be able to find them there. ;)
So Ironical!
Offline 1pq
  • Hipster Doofus
« Reply #97 on: Sun, 02 February 2014, 13:25:26 »
If I sent you used clear stems, would you use those instead of new clear stems for a custom board?
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline Moosecraft
  • HHKB Pro
« Reply #98 on: Sun, 02 February 2014, 14:32:11 »
How would I do for ordering a different switch for spacebar?
Offline GON
    • GONsKeyboardWorks
« Reply #99 on: Sun, 02 February 2014, 22:26:12 »
Add a comment when you place an order at my website. ;)
So Ironical!
