Author Topic: GON's KeyboardWorks - Questions and Answers  (Read 837291 times)
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
Re: Questions and Answers
« Reply #300 on: Sun, 26 October 2014, 05:48:50 »
So I would be good like this?
If you don't lub/tune your switches, you seem to have got all the items needed in the cart. ;)
If you want to have your switches tuned, you will need springs, switch stickers, lub for sliders(krytox), and lub for springs(not available at my webstore).
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #301 on: Sun, 26 October 2014, 07:35:05 »
For newbs (which I am one) I would rather give GON the task of tuning and supplying the springs and switch stickers because the keyboard works way better when he adds his famous touch to it.
Rest of the gear like lube can easily be bought off [CTRL]ALT or Ebay.
Offline mathiasn
« Reply #302 on: Fri, 31 October 2014, 16:15:01 »
Hi GON,
any chance there'll be a winkeyless TKL ISO plate / case?
The aluminum / acrylic case is (nearly) exactly what I'm after.
Best
Mathias
Offline GON
    • GONsKeyboardWorks
« Reply #303 on: Sat, 01 November 2014, 13:25:40 »
Thanks Elrick ;)
So Ironical!
Offline GON
    • GONsKeyboardWorks
« Reply #304 on: Sat, 01 November 2014, 13:29:06 »
Hi GON,
Best
Mathias
GON NS NerD TKL already supports the layout you want. ;)
You can see it here.
http://www.gonskeyboardworks.com/custom-kbds-w-assembly/66-gon-ns-nerd-tkl-w-tuningassembly.html
Of course, you can order the parts only not including assembly. ;)
Thanks,
GON
P.S. The mid part of NS Housings is not Acrylic but Polycarbornate which is more durable(even though they cost more...). ;)
So Ironical!
Offline mathiasn
« Reply #305 on: Mon, 03 November 2014, 01:16:35 »
Yeah, sure, the PCB / plate does support that, but I'd hate the holes in the (top / key-) plate, when I choose a
  1.5 / (1.0) / 1.5 / 7.0 / 1.5 / (1.0) / 1.5
bottom row layout, not installing the win-keys (marked (1.0) above).
So any chance you'll have a plate produced for that?
btw: I'd most probably order a kit ;D
Offline pasph
« Reply #306 on: Mon, 03 November 2014, 03:53:12 »
With the NS NerD MX-MINI is the product line complete or you have other surprises (for this year)?
Alps maybe?
« Reply #307 on: Mon, 03 November 2014, 15:50:03 »
Just get some blockers. It's a lot more economical to produce a plate and then source blockers elsewhere.
Or maybe GON can source them for you?
Offline yicaoyimu
« Reply #308 on: Mon, 03 November 2014, 18:12:37 »
Alps maybe?
I asked Gon about NerD MX-mini before. He told me he could totally produce those PCB if there is enough demand. I think the MOQ is 50?
Offline kitsun8
  • In need of some cash
« Reply #309 on: Mon, 03 November 2014, 23:08:57 »
Alps maybe?
maybe the MOQ will be lowered to 24 like his other ones :P
Offline kitsun8
« Reply #310 on: Mon, 03 November 2014, 23:10:39 »
Hey Sprit I ordered some LEDs and since my PCB hasn't shipped yet, could you combine the 2 orders and remove the shipping on the LEDs?
20 dollars for a small pack of LED's is really expensive after all  :p
Offline mathiasn
« Reply #311 on: Tue, 04 November 2014, 01:00:57 »
Sorry, no way!
You think I cough up some $400 for a keyboard and then have it uglified by blockers?
It's all about style!
(You're right, it's more economical; but the looks - yuck!)
GON, can you get me a quote for such plates (3 anodized in the same color, or 3 anodized in different colors).
« Last Edit: Tue, 04 November 2014, 01:11:17 by mathiasn »
Offline whentheclouds
« Reply #312 on: Tue, 04 November 2014, 01:04:41 »
Alps maybe?
you can already order one off his website. i didn't even know he started producing them until i read pasph's post
« Reply #313 on: Tue, 04 November 2014, 07:26:25 »
Sprit?
Offline GL1TCH3D
« Reply #314 on: Tue, 04 November 2014, 08:14:56 »
How are the Mobiks coming along? =S
I'm guessing they're still delayed?
Offline pasph
« Reply #315 on: Tue, 04 November 2014, 09:37:03 »
Alps maybe?
Not yet in production, those are pre-orders
Offline GON
    • GONsKeyboardWorks
« Reply #316 on: Tue, 04 November 2014, 12:20:26 »
Hi members,
I'm developing NerD MX-mini PCB now. ;)
It will take about 1-2 months for me to finish developing.
The order is open on my website.
But what I need now is, MOQ.....
I need at least 36+ demads to produce white PCBs. ;)
Would you plz let GH members know this? ;)
IC will be good. ;)
The price of mx-mini is not decided but it will be between 55-60 ;)
Spec is NerD mx-mini will be the same as NerD TKL Ver2.0 only except for its physical layout.
So Ironical!
Offline AuRinBei
« Reply #317 on: Tue, 04 November 2014, 19:05:18 »
Is dark grey hard anodizing not an option anymore? I'm see it listed under anodizing type, but not under anodizing color.
87u || Poker 2
Offline GON
    • GONsKeyboardWorks
« Reply #318 on: Thu, 06 November 2014, 06:56:45 »
Dark Grey is no more available, but Grey is still available. ;)
So Ironical!
Offline azhdar
  • Praise the AZERTY god
« Reply #319 on: Thu, 06 November 2014, 07:38:03 »
Hello GON,
I finished soldering the nerd60 PCB but i can't make this key work :
Should I send you a picture of the soldered PCB so you can see if something is missing ?
Also , you're not using skype anymore ?
Azerty Propagandiste
Offline GON
    • GONsKeyboardWorks
« Reply #320 on: Thu, 06 November 2014, 11:24:41 »
Hello GON,
You seem to have dropped soldering a diode located between "]" and "\(1.5x)".
The diode is "Horizontal" not vertical as others. ;)
Check it.
I use skype. But Even though it says I'm online, I might not be at the computer...
I just seldom turn off my computer... ;)
So Ironical!
Offline MrMen
« Reply #321 on: Thu, 06 November 2014, 12:03:30 »
Hi Gon,
I have a nerd60 pcb, and I'm happy with it but not my bios.
I can't use it there. It seems that I can toggle n/6 kro with Fn+U, but no more succeed. Is it the right shortcut ? Or am I doing something wrong ?
By the way, can I see which is the current kro state ?
Thanks.
PS : you pcb is awesome ^^
Offline azhdar
« Reply #322 on: Thu, 06 November 2014, 13:09:13 »
Hello GON,
Check it.
Thanks , it was indeed that i didnt looked for horizontal diodes u_u typing on it right now . Loving it , looking up for your upcoming wireless projects !!!
Offline GON
    • GONsKeyboardWorks
« Reply #323 on: Fri, 07 November 2014, 01:55:49 »
Hello GON,
Check it.
Pleased to hear that you've resolved the issue. ;)
So Ironical!
Offline DanielT
« Reply #324 on: Fri, 07 November 2014, 05:54:47 »
Hi GON,
Where can I find more details about the command line configuration tool for the NerD60 ?
I'm also a heavy Linux user and at home I have only Linux so I would like to know how to use also the command line.
Offline Fnzzy
« Reply #325 on: Fri, 07 November 2014, 10:21:30 »
Hello!
EDIT: Nevermind, I found what I looked for :))
Also, is it possible to do custom orders? I was thinking about getting a crystal MX Mini in the (far?) future, but I already have tons of switches at my house and I thought I could save some money that way.
On the other hand you have more experience than me with tuning the switches. I am not horrible but I bet you can do a better job ;)
So scratch all that. No questions anymore!
« Last Edit: Sat, 08 November 2014, 05:44:13 by Fnzzy »
Offline MrMen
« Reply #326 on: Sat, 08 November 2014, 07:41:25 »
Hi Gon,
Thanks.
Actually, I'm partly wrong : the keyboard is working in BIOS but not with GRUB. I think I'm missing one module or something like that.
Does anyone already face this problem ?
Edit : it's really a GRUB problem : with syslinux everything is fine.
And about the 6kro, to veriny I used aquakey to verify and it's ok.
« Last Edit: Sat, 08 November 2014, 17:59:59 by MrMen »
Offline radio_killah
  • Chinchillin'
« Reply #327 on: Thu, 13 November 2014, 14:47:12 »
How long does shipping usually take from Korea to the US?
« Reply #328 on: Thu, 13 November 2014, 16:49:36 »
If nothing gets stopped at customs, a week or so for something keyboard size. It's mostly just expensive.
Offline GL1TCH3D
« Reply #329 on: Thu, 13 November 2014, 18:04:33 »
Any updates on the CNC case for the MobiK? =[
Offline paobit
« Reply #330 on: Tue, 18 November 2014, 21:47:28 »
Hey guys I played around with nerd_config on my new GON and i don't really know what I did. I was messing around with the leds and now the side and inswitch leds light up only when i press the Fn key? I'd like to switch it back to being on the whole time.
Also how would i exactly change the layout of the keyboard? I know..I'm a big noob when it come to this.
Offline GON
    • GONsKeyboardWorks
« Reply #331 on: Tue, 18 November 2014, 22:21:11 »
Would you refer to these video manuals? ;)
http://www.gonskeyboardworks.com/manuals/110-nerdy-gui.html
So Ironical!
Offline paobit
« Reply #332 on: Tue, 18 November 2014, 22:34:12 »
Hey GON! really nice keyboard! hmm I seem to have the nerd 2.0.0 I believe and when I run the nerdy GUI It kinda stays stuck on the "press any nerd keyboard/pad to configure" screen. I think it says I need need Nerdy GUI 1.3? Would I need that?
Offline paobit
« Reply #333 on: Tue, 18 November 2014, 22:37:00 »
lol my bad I got it to work! I forgot to UNZIP!
Offline azhdar
« Reply #334 on: Sun, 23 November 2014, 07:20:55 »
Hello GON , getting back to you now that I have time working back onto the keyboard .
There's still fews keys I can't make work , only speaking about the bottom row here .
Here is a small album showing you the soldering , also I can't activate the keys with a tool (like shown in picture 2 ).
http://imgur.com/a/03iKH
Offline MrMen
« Reply #335 on: Sun, 23 November 2014, 07:56:37 »
Did you also check diode ? I had the same issue. make a short over it to verify.
Offline azhdar
« Reply #336 on: Sun, 23 November 2014, 08:29:33 »
I know very little about electronics , could you be more specific ?
Offline MrMen
« Reply #337 on: Sun, 23 November 2014, 11:25:48 »
You seem to be in France so let's try :
la diode n'est peut etre pas bonne. Pour tester tu fait un pont avec un outil metallique entre les deux bornes. (ce que tu fais au noveau du switch) et tu refait ta manip avec le switch. Normalement ca doit marcher dans ce cas. Si c'est bon tu change la diode et tu retestes.
Offline GON
    • GONsKeyboardWorks
« Reply #338 on: Sun, 23 November 2014, 12:20:29 »
Thanks MrMen ;)
As he told, I think this would be a matter of Diodes or Switches themselves.
PCBs are all passed BBT test when producing, so no error would be there...
Take a picture of the back of your PCB near the non-working switches if the issue is not solved even with the advice from MrMen.
So Ironical!
Offline azhdar
« Reply #339 on: Sun, 23 November 2014, 12:27:57 »
Checked diodes , I can't seem to find a problem , however if It can help you to understand the problem whenever I do a contact between the points circled in red :
It doesn't trigger alt but spacebar while it's still configured as rAlt and lAlt on the nerdyGui .
Offline MrMen
« Reply #340 on: Sun, 23 November 2014, 12:54:41 »
Yes but here you still have a diode.
You have to use a metalic wire between + and - of the diode also.
If you diode is not working, you won't have anything with this method.
Offline jorgenslee
« Reply #341 on: Thu, 27 November 2014, 00:40:35 »
How's the battery life for the 60% Nerdd V2 PCB if on wireless mode? Does it use bluetooth or another usb dongle?
Offline GON
    • GONsKeyboardWorks
« Reply #342 on: Thu, 27 November 2014, 07:19:25 »
I think you'd better check solder joints of L-ALT and R-Alt. Reinforce them with a soldering iron.
So Ironical!
Offline GON
    • GONsKeyboardWorks
« Reply #343 on: Thu, 27 November 2014, 07:20:00 »
Bluetooth.
Generally runs more than 24 hours. ;)
So Ironical!
Offline ninjadoc
« Reply #344 on: Thu, 27 November 2014, 08:10:12 »
I had a similar problem with a KMAC. After I replaced the switches it was fine. I had changed diodes, resoldered - didn't work. Double checked with a multimeter and everything seemed fine and the switch seemed to conduct as it should. I even removed the switch, cleaned the pads, and resoldered it since it tested OK with the multimeter.Finally changed switches - success!
Offline azhdar
« Reply #345 on: Thu, 27 November 2014, 08:14:17 »
Hey guys thanks for the answers , I'll work on it this week-end and let you know .
Offline argcargv
  • tempting the banhammer
« Reply #346 on: Fri, 28 November 2014, 13:08:12 »
Hi Gon, I made an order with Nerd PCB 2.0 last week, when do you think my order will be shipped?
Offline azhdar
« Reply #347 on: Sun, 30 November 2014, 10:43:02 »
Well I worked on it today , no pictures for the moment , but I changed some of the diodes aswell as switches , still the same 5 keys not registering .
I have some solder points that are way worse than that , and they work just fine .
What pictures can I provide you so you can help me ?
Offline Dreamre
    • kbdlife
« Reply #348 on: Sun, 30 November 2014, 18:44:51 »
Try remapping the keys - those keys may be registered as something else.
Offline azhdar
« Reply #349 on: Mon, 01 December 2014, 01:42:36 »
Already tried that , changed nothing
