Author Topic: Duck Mini2 GB  (Read 18650 times)
Offline TrueCustom
    • kbd4u
Duck Mini2 GB
« on: Sun, 14 July 2013, 09:46:35 »
Update July 22, 2013
I made a new thread in GB.
Please use it(http://geekhack.org/index.php?topic=46060.0) instead of this thread.
Thanks.
______________________________________________________________________________
Update July 21, 2013
Duck0113 decided that he makes a hall for Poker dip switch in Duckmini2 case. Now, you may use Poker 1 PCB, and if the shape of Poker 2 PCB is the same as Poker 1, you may use Poker 2 PCB too. However, since the dip switch hall is not through out the case, you need to detach PCB from the case to adjust dip switch mode.
Duck0113 opens a GB form for Geekhack. You may use it to order. He is going to accept order for a week(by July 29, 2003).
http://duck0113.tistory.com/37
https://docs.google.com/forms/d/1mY9rhcbbBxJsILAYhgd-eQ1ik3q1v8x_Q3NerqACexg/viewform
Duckmini V2 is in production, and the quantity is limit. I think, 5~8 sets are allowed for Geekhack.
He is expecting that he will be able to ship the items by the end of August. However, the schedule might be delayed if something goes wrong.
Please feel free to contact me if you have any question about Duckmini2 V2.
Thanks.
Duck0113 started Duck Mini2 GB. I would like to introduce some imformation about it.
Group buy items
- Duck Mini2 Basic set : $245(without taxes and delivery fee)
   1 Aluminum hosuing.
   1 Aseembled PCB without switches.
   1 Frame for cherry switch.
   1 Frame for Alps switch.
- Duck Dummy(Option) : $62(without taxes and delivery fee)
   1 Duck Dummy for adjusting Duck Mini2 housing angle from 7 degree to 11 degree.
Specs.
- Aluminum Housing
   Made of Aluminum 6061-T6
   You can choose silver, red or black color.
   You can adjust housing angle from 7 degree to 11 degree with Duck Dummy(optional)
   You cannot use your Pocker PCB because the dip switch conflicts housing.
   Now, you may use Poker PCB, but the hall is not through out the case you need to detach PCB to adjust dip switch mode.
- PCB
  All parts are installed by SMT machine except switches.
  You can install switches with/without frame.
  You can install Cherry or Alps switches.
  Support keymapping.(The keymap program is based on text and command,so you need a little bit knowledge of XML and command)
  Support full led.
  Support Macro.(TBD)
- Cherry frame
  Frame for Cherry switches.
  1.5T SUS
- Alps Frame
  Frame for Alps switches.
  1.2T SUS
- Duck Dummy
28123-0
28125-1
28127-2
28129-3
28131-4
28133-5
28135-6
28139-8
28141-9
28143-10
28145-11
28147-12
http://duck0113.tistory.com/35
« Last Edit: Thu, 16 June 2022, 14:03:06 by TrueCustom »
Offline Dubsgalore
Re: Duck Mini2 GB
« Reply #1 on: Sun, 14 July 2013, 09:52:52 »
Of all times to be broke ..
this has been on my wishlist for a while
time to start selling!
Offline Ultratude
    • Ultratude's Blog
Re: Duck Mini2 GB
« Reply #2 on: Sun, 14 July 2013, 09:53:29 »
Thanks for the info.
Offline kaiserreich
  • HHKB Elite
Re: Duck Mini2 GB
« Reply #3 on: Sun, 14 July 2013, 10:34:41 »
The Duck casing is very very well made.
Don't miss it.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: Duck Mini2 GB
« Reply #4 on: Sun, 14 July 2013, 10:38:06 »
But i like duck 1than it
Re: Duck Mini2 GB
« Reply #5 on: Sun, 14 July 2013, 10:40:38 »
ALPS! Nice!
Re: Duck Mini2 GB
« Reply #6 on: Sun, 14 July 2013, 10:45:39 »
Hmm was just reading about this on kbd. I don't think I'll be getting one though it looks amazing.
Offline naokira
  • The King in the North
Re: Duck Mini2 GB
« Reply #7 on: Sun, 14 July 2013, 10:45:47 »
That is one sick case. Too bad, cant afford it :)
FaceW in LZ-CE
Re: Duck Mini2 GB
« Reply #8 on: Sun, 14 July 2013, 11:20:34 »
What caps/stabilizers will fit on the Alps variant?
Edit: This should also be in the GB or IC forum. And upon closer inspection, those caps look like Apple AEK caps. So does the Alps variant take the stabs/caps from the Apple AEK?
« Last Edit: Sun, 14 July 2013, 11:40:56 by CPTBadAss »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: Duck Mini2 GB
« Reply #9 on: Sun, 14 July 2013, 11:34:06 »
they do not seem to accept international orders though...
Re: Duck Mini2 GB
« Reply #10 on: Sun, 14 July 2013, 11:45:11 »
According to this page, they're doing shipping to the US so I think they might do other international locations?
Offline phetto
  • HHKB JP
Re: Duck Mini2 GB
« Reply #11 on: Sun, 14 July 2013, 11:49:25 »
Finally keyboard that I want!!!!!! :)
Re: Duck Mini2 GB
« Reply #12 on: Sun, 14 July 2013, 11:51:47 »
Holy **** it's phetto
and grats 1111
Offline TrueCustom
    • kbd4u
Re: Duck Mini2 GB
« Reply #13 on: Sun, 14 July 2013, 13:02:18 »
I am helping him for international shipping, but only for USA and Canada now.
Offline TrueCustom
    • kbd4u
Re: Duck Mini2 GB
« Reply #14 on: Sun, 14 July 2013, 13:07:59 »
The PCB and frame supports Old Dell and SGI alps.
I think the PCB suits for most of all Alps keycaps, but the frame doesn't.
Re: Duck Mini2 GB
« Reply #15 on: Sun, 14 July 2013, 13:11:01 »
But the picture has the Apple AEK caps. So you're saying it's using the stabilizers from the Dell/SGI keyboards and can take Apple AEK, Dell At101W, and SGI Granite keyboard caps?
Offline elton5354
Re: Duck Mini2 GB
« Reply #16 on: Sun, 14 July 2013, 13:14:18 »
Is there pick up for Toronto members? :D
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: Duck Mini2 GB
« Reply #17 on: Sun, 14 July 2013, 13:17:01 »
if you open up to Europe I'll take one. I'm available at proxying all orders to EU if you want.
Offline The_Beast
  • I like wood ಠ_๏
Re: Duck Mini2 GB
« Reply #18 on: Sun, 14 July 2013, 13:18:10 »
Does it have the same design as the first round? Could you order just the case?
Offline Dubsgalore
Re: Duck Mini2 GB
« Reply #19 on: Sun, 14 July 2013, 13:19:14 »
I would order the v1 case alone
Re: Duck Mini2 GB
« Reply #20 on: Sun, 14 July 2013, 13:20:52 »
You can order just the case, but it doesn't look the same as the original. It has space for that block + screwholes at the back.
Offline elton5354
Re: Duck Mini2 GB
« Reply #21 on: Sun, 14 July 2013, 13:25:03 »
It's different. It doesn't have the weights inside anymore...
Offline pmh1410
Re: Duck Mini2 GB
« Reply #22 on: Sun, 14 July 2013, 13:48:22 »
Hi TrueCustom (트루커스텀), Welcome to Geekhack  ;)
yes, and have not Poker logo, can not fit for Poker and 38GT PCB because the dip switch conflicts housing. But i like Duck housing with Red Color Anodized so much :(
« Last Edit: Sun, 14 July 2013, 13:53:07 by pmh1410 »
Offline WhiteFireDragon
    • youtube
Re: Duck Mini2 GB
« Reply #23 on: Sun, 14 July 2013, 14:14:42 »
So this is a full keyboard package, not just the case. And it looks like it excludes most 60% keyboards because no area for the DIP switch. Seems like it'll fit GH60 PCB though.
I'm not such a fan of those huge clamps just to act as risers.
Re: Duck Mini2 GB
« Reply #24 on: Sun, 14 July 2013, 14:18:05 »
I am also not a fan. It's very bulky and blocky. If I get one, I won't be getting the Dummy or Block.
Offline phetto
  • HHKB JP
Re: Duck Mini2 GB
« Reply #25 on: Sun, 14 July 2013, 14:34:40 »
Is there any way one of these can get shipped to sweden?
Offline Dubsgalore
Re: Duck Mini2 GB
« Reply #26 on: Sun, 14 July 2013, 14:53:43 »
I also am leaning towards disliking the block
Without it, you have those screw holes...and it just looks incomplete
Is there a price on just getting the case alone?
Offline TrueCustom
    • kbd4u
Re: Duck Mini2 GB
« Reply #27 on: Sun, 14 July 2013, 14:56:32 »
Yes it is using Old Dell/SGI.
I think the keycaps in the picture were pulled from SGI.(http://www1.kbdmania.net/xe/6597488)
AEK has diffrent size Capslock and Option keycaps, so it doesn't fit for Duck Mini2 PCB.
Actually, I am now sure if it can use other keycaps except Old dell and SGI.
Offline TrueCustom
    • kbd4u
Re: Duck Mini2 GB
« Reply #28 on: Sun, 14 July 2013, 15:02:59 »
Sure. I am going to visit S.Korea in August. I think i can bring 1~2 set. You may buy me a coke. :)
Offline TrueCustom
    • kbd4u
Re: Duck Mini2 GB
« Reply #29 on: Sun, 14 July 2013, 15:06:13 »
Thank you for the suggestion. I will reply it after i get an answer from Duck0113.
Offline elton5354
Re: Duck Mini2 GB
« Reply #30 on: Sun, 14 July 2013, 15:15:49 »
Thanks! Let me know the details. I'll buy one for sure and a coke for you :)
Offline brialona
Re: Duck Mini2 GB
« Reply #31 on: Sun, 14 July 2013, 16:54:31 »
the name of this is very misleading -____-
ozil
Offline Dubsgalore
Re: Duck Mini2 GB
« Reply #32 on: Sun, 14 July 2013, 23:39:30 »
looking at other pictures of this case from duck's blog...if i could get the case alone, but without the screw holes in the back...would be good for me :D
Offline Photoelectric
Re: Duck Mini2 GB
« Reply #33 on: Sun, 14 July 2013, 23:57:01 »
So beautiful in red.  And Alps... with backlighting... I'll be imagining owning this through others' photos, as the total cost makes it inaccessible for me :(
Offline codyeatworld
Re: Duck Mini2 GB
« Reply #34 on: Mon, 15 July 2013, 00:14:35 »
The pcbs would fit though right? just no access to the dip switch?
And I also remember seeing a numpad or extra keypad attachment on kbd.
I don't think I like the block either, I'd much rather have a solid piece.
I'm gonna try to pick this case up though.
    • youtube
Re: Duck Mini2 GB
« Reply #35 on: Mon, 15 July 2013, 02:56:29 »
No, the case looks too shallow to fit any board that has the DIP switch. That DIP switch sticks out quite a bit from the PCB, so there needs to be material milled out of the case for it to fit. I would confirm this first before you pick one up if your plan is to use the case for a different PCB than what's included.
Re: Duck Mini2 GB
« Reply #36 on: Mon, 15 July 2013, 08:22:50 »
Although the GH60 doesn't have DIP switches it does have a button on the bottom of the PCB. Whether it'll work all depends on how big the button is and how high the standoffs are.
Offline pmh1410
Re: Duck Mini2 GB
« Reply #37 on: Mon, 15 July 2013, 09:21:29 »
if you want use other PCB, maybe you must make a new Plate for it. you can think about Universale plate from GON or Beast for mini layout ;)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Duck Mini2 GB
« Reply #38 on: Mon, 15 July 2013, 11:20:42 »
Instead of having the brass weights on the inside, the weight is added by the dummy/block that is on the outside. This also serves as a riser.
However, since it doesn't fit most of the 60% out there, it's hard to justify. Might be nice for the GH60, but are we sure it'll fit?
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
Re: Duck Mini2 GB
« Reply #39 on: Mon, 15 July 2013, 12:26:16 »
Damm, thanks god it's CONUS only ...
Gosh, awesome case.
Didn't get what that bigger block behind is for tough.
    • youtube
Re: Duck Mini2 GB
« Reply #40 on: Mon, 15 July 2013, 14:14:10 »
GH60 does have the button instead of the DIP switch, but the button is much thinner. So just from looking at the pics, it should fit both GH60 PCB and plate.
Can someone as Duck0113 how tall the standoffs are?
Re: Duck Mini2 GB
« Reply #41 on: Mon, 15 July 2013, 14:51:15 »
how are the alps keys stabilized?
Also, if you know what dip switch settigns you want, you should be able to just set them and remove the block. I'd say any case I'm paying this much for, I can afford to modify my ideal pcb to fit it.
In other words, don't let the dip switches limit you.
« Last Edit: Mon, 15 July 2013, 14:55:37 by dorkvader »
Offline gnubag
Re: Duck Mini2 GB
« Reply #42 on: Mon, 15 July 2013, 15:24:52 »
setting it before removing does nothing.
you would have to remove the dip switch and bridge the connectors of the switches you want enabled.
Re: Duck Mini2 GB
« Reply #43 on: Mon, 15 July 2013, 15:42:27 »
Yes, I know about DIP switches, and I did mean jumpering the ones you wanted set after removing them. Either that or soldering leads to the switch holes and "moving" them somewhere else. This should be possible, even easy, depending on how it's done.
More importantly: what about ALPS stabilizers?
Offline bazemk1979
Re: Duck Mini2 GB
« Reply #44 on: Mon, 15 July 2013, 17:35:11 »
there are no alps stabilizers from what I see on the pic....
Offline pasph
Re: Duck Mini2 GB
« Reply #45 on: Mon, 15 July 2013, 18:12:12 »
rectangular and round holes are for that
Offline TrueCustom
    • kbd4u
Re: Duck Mini2 GB
« Reply #46 on: Sun, 21 July 2013, 09:03:43 »
Thanks.
« Last Edit: Thu, 16 June 2022, 14:02:56 by TrueCustom »
Offline TrueCustom
    • kbd4u
Re: Duck Mini2 GB
« Reply #47 on: Mon, 22 July 2013, 11:11:29 »
Thanks.
