Author Topic: [IC] ALPS ansi key cap set (07-25 update)  (Read 67550 times)
Re: [IC] ALPS ansi key cap set (07-25 update)
« Reply #150 on: Wed, 04 September 2013, 10:45:32 »
Plates we can get, no problem. The_Beast is our man. :)
« Reply #151 on: Wed, 04 September 2013, 11:02:28 »
Actually looking at the exploded drawing that was posted I believe there is an acrylic plate as part of the case.
Offline MTManiac
Re: [IC] ALPS key cap set (ANSI)
« Reply #152 on: Wed, 04 September 2013, 14:35:41 »
I like #2 can we call it batman!
only if they throw a couple batman keys up
I would have to buy multiple sets
heck I'm still going to probably buy multiple sets
Offline abdulmuhsee
« Reply #153 on: Sun, 29 September 2013, 17:51:48 »
Wondering if this is going to happen or not, but I'm definitely interested.
There are two reasons that a more "normal" color scheme might be a bit better:
1.  There is literally no way (currently) to purchase new ALPS keycaps apart from buying a new-old-stock board with pad-printed ones.  If there were already many options, blue might be nice, but it seems strange as the only option.
2.  ALPS boards are not created equal, especially in the spacebar department.  I use 101 layouts, which have a longer spacebar than those with Windows keys, and with the spacebar provided (with the cherry stuff going on), I would have no way to stabilize it.  In other words, I would be using a stock white spacebar which would stick out like a sore thumb among the blue and grey.
No matter what happens, I would have to use at least a few keys from a different board, whether it be the spacebar, slightly different caps lock, or even the alt and ctrl keys; the ALPS diaspora will make it very difficult for many to match such a specific color scheme.
Offline calavera
« Reply #154 on: Sun, 29 September 2013, 18:46:57 »
Currently on hold since I'm extremely busy with life and won't have free time for a month or two.
1. I might go with the alternative color choice instead. Nothing's set in stone.
2. main obstacle and currently working for a partial solution in providing custom stab wires that should work with most stabilizer positions on the space bar. This might take awhile.
Never meant to cover EVERY alps board in the world. That's the reason why I have this IC thread so people with different alps board can chime in with detailed info. So far only a few helped but I had to do most of the estimates and measuring myself. If you have a funky 10x spacebar with 1x size control and 2.5x caps lock...etc you're **** out of luck, chances are SP doesn't have the molds to make them anyway.
So I'll just try to cover "mainstream" ones only.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #155 on: Sun, 29 September 2013, 21:47:23 »
Hmmmmmm the color scheme is pretty cool.  I like it !!!
Though judging by the spacebar stabilizer stems and bottom row layout, it seems like it will not work with any of the Matias keyboards.
It's the only ALPS keyboard I have.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #156 on: Mon, 21 October 2013, 18:10:02 »
Expressing interest in a set or two.
Offline nourathar
« Reply #157 on: Thu, 24 October 2013, 16:16:04 »
would certainly be interested to buy a set, like the colours !
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #158 on: Thu, 24 October 2013, 16:51:00 »
I am in !  definitely !
« Last Edit: Sun, 27 October 2013, 01:15:23 by sprit »
Offline ovrskeek
« Reply #159 on: Thu, 24 October 2013, 17:23:55 »
In for a set
Offline nourathar
« Reply #160 on: Fri, 25 October 2013, 05:19:25 »
actually,
after some time pondering this, I thought that what is really missing for me from the Alps-universe are blank keycaps. If they exist, I have never seen them, and I would love to have some.
Any chance that could be an extra option ?
For me personally I do not care much if the modifiers and enter and such are blank, it is mostly the alphanumeric keys I care about, so that would effectively be one one-unit key per row, since for the rest they would be all identical...
Offline calavera
« Reply #161 on: Sun, 27 October 2013, 01:12:34 »
So anyone else want black alphas?
Offline moogle
_
« Reply #162 on: Sun, 27 October 2013, 01:29:53 »
_
« Last Edit: Fri, 18 August 2017, 05:21:37 by moogle »
Offline nourathar
« Reply #163 on: Sun, 27 October 2013, 16:35:53 »
Hi calavera,
for the blanks I would prefer the gray from this set, or perhaps the blue, so that is still nicely goes together with the rest of the set. Thanks for considering this option !
ciao,
J.
Offline calavera
« Reply #164 on: Mon, 28 October 2013, 14:51:18 »
will this key cap set be compatible with a kingsaver?
Yes and no. The Kingsaver has a unique sized Backspace, \, enter, and right shift. They're slightly longer than the standard sizes. They should still fit since the mounting is the same I believe but you'll have some gaps.
Hi calavera,
ciao,
J.
we'll see how it goes. If there isn't enough interest (at least 50 MOQ to make it reasonably priced) I don't think it will happen this time around.
Offline esoomenona
  • Gnillort?
« Reply #165 on: Mon, 28 October 2013, 14:52:31 »
Can we move this to the GB stage now?
Offline moogle
_
« Reply #166 on: Tue, 29 October 2013, 18:50:22 »
_
« Last Edit: Fri, 18 August 2017, 05:24:06 by moogle »
Offline kaotikb
« Reply #167 on: Fri, 08 November 2013, 22:34:32 »
I am in for a set if we get to the group buy stage.
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline drumflavah
« Reply #168 on: Sat, 04 January 2014, 08:05:22 »
When do you think this project will be up and running?
Offline calavera
« Reply #169 on: Sat, 04 January 2014, 10:30:12 »
If everyone's okay with spacebar and possibly left shift not fitting, we could just get this thing rolling and explore custom stabilizer options at a later time. I'll have more free time this month so will update when I can.
Offline codyeatworld
« Reply #170 on: Sat, 04 January 2014, 10:45:00 »
Either way I will join in, but I'd rather receive a complete set all at once.
Have you looked into tai hao? (I remember reading they do alps, and their legends look exactly like most alps keyboards)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #171 on: Sat, 04 January 2014, 10:46:37 »
beggars are not choosy..........
my vote is to move forward. you have made it clear with all the various alps configurations not all are applicable :-\
whenever you might find time at your convenience...........lets roll :thumb:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #172 on: Sat, 04 January 2014, 11:47:57 »
Let's get this going, please
the legends on my ducky are starting to wear off
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #173 on: Sat, 04 January 2014, 20:52:42 »
You bet.  I know I should of read everything from the beginning, but this is just a question (if it's been answered yet, sorry to repeat) - Would these double-shot ALPs key-set work within a MATIAS keyboard, especially the TKL version?
Just thought how brilliant this Group Buy would be for any owners of Matias boards (with their 'superior' version of an alps switch)  ;D .
Offline Pacifist
  • on hiatus
« Reply #174 on: Sat, 04 January 2014, 21:01:10 »
just make sure that there's a 40% setup ;)
« Reply #175 on: Mon, 06 January 2014, 07:58:10 »
You have a 40% ALPS  board?
Offline jacobolus
« Reply #176 on: Mon, 13 January 2014, 22:19:59 »
[comment deleted; I thought this was about DSA caps]
« Last Edit: Mon, 13 January 2014, 22:25:04 by jacobolus »
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #177 on: Wed, 05 March 2014, 23:15:19 »
I just came across this thread, and am interested in joining as well.  Is it still going forward?
Depending on the cost, I would probably be interested in four (yes, four (4)) sets.
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline calavera
« Reply #178 on: Mon, 10 March 2014, 09:13:59 »
Was supposed to move forward earlier beginning this year but stuff came up and I may be leaving the US for good in a few months. Space bar and shift key stabilizer issue is still up in the air and given the length it takes for a group buy and everything that's involved (organizing, payment, ordering/packing..etc) I'm not sure there's enough time to finish this. :(
Offline kaotikb
« Reply #179 on: Tue, 18 March 2014, 16:47:30 »
That is  too bad. I was looking forward to this.
Offline MOZ
  • Busy making stuff
« Reply #180 on: Tue, 18 March 2014, 17:05:04 »
If we use Sp, they can handle a lot of the logistics, with their new setup
Offline BlueBär
« Reply #181 on: Wed, 19 March 2014, 16:32:27 »
Does anybody know what kind of stabilizers sprit PCB + plate will accept?
« Reply #182 on: Wed, 19 March 2014, 16:40:10 »
Dell AT101W IIRC.
Offline BlueBär
« Reply #183 on: Wed, 19 March 2014, 19:03:12 »
Dell AT101W IIRC.
Wouldn't a Cherry/Costar combination work? I don't have a Costar board but I have two Alps boards now and by the looks of it, the cap inserts should be compatible with Costar stabs.
Offline jacobolus
« Reply #184 on: Wed, 19 March 2014, 19:11:33 »
Which “Alps” keyboards do you have? There are two styles of stabilizers I’ve seen used on keyboards with Alps switches and other Alps-mount switches. Most common is the “Alps”-style stabilizer, and less common is the “Costar”-style stabilizer.
It sounds from your description like your boards/keycaps use the Costar-style stabilizers. That means Signature Plastics’ Alps keycaps (ignoring problems w/ weird-shaped enter keys, etc.) will work great for you. Unfortunately, most people with Alps keyboards have the Alps-style stabilizer, and SP’s stabilized keycaps are not usable on those boards.
Some keyboards use both. For instance, I believe Matias uses Costar-style stabilizers on the spacebar, but Alps-style stabilizers on other keys. I’ve also seen keyboards with Alps-style stabilizers everywhere but on a “bigass” enter key.
Offline BlueBär
« Reply #185 on: Wed, 19 March 2014, 19:24:34 »
Just took a quick pic of it.
57998-0
I'm sorry I didn't read through the whole thread, what problems are there with enter keys? I want to help getting this thing rolling.
Offline jacobolus
« Reply #186 on: Wed, 19 March 2014, 19:25:58 »
Ah, okay. Yes, you have the Alps-style stabilizer. It’s not compatible with Costar-style stabilizers or their inserts.
However, it looks like your plate also might have cutouts to fit the little Costar-style stabilizer clips. So you might be able to use either one.
It seems like every Alps keyboard uses a different shaped enter key. :-)
« Last Edit: Wed, 19 March 2014, 19:28:16 by jacobolus »
Offline BlueBär
« Reply #187 on: Wed, 19 March 2014, 19:33:30 »
That plate is thin, plastic, broken and overall absolutely terrible :))
Ah yeah noticed that. Hmm.
Would it be possible to create an adapter to make them fit Costar stabs? I mean the inserts are tiny, maybe making a mold for an adapter wouldn't cost an insane amount?
Offline jacobolus
« Reply #188 on: Wed, 19 March 2014, 21:09:20 »
I’m also curious about this. What you’d actually want is an Alps-style stabilizer insert which fit into a Cherry MX mount (Costar stabilizer mount), assuming the goal is to use SP caps on existing Alps boards/plates.
Offline BlueBär
« Reply #189 on: Wed, 19 March 2014, 21:37:07 »
Ok I just measured, the stem of my inserts is 2x3x4mm. Now I need measurements from some Costar inserts (I don't have any) and I can make a 3D model of an adapter that then somebody can print at Shapeways.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #190 on: Thu, 20 March 2014, 20:23:29 »
enough dolch, go for something original :)
what do you think of...
GOSH!
Awesome colors dude!
Simple but really cool
Offline BlueBär
« Reply #191 on: Thu, 20 March 2014, 20:33:45 »
Still need the measurements btw :(
Offline Magna224
« Reply #192 on: Fri, 21 March 2014, 05:58:15 »
Ill take one set if they're done in the color combo in OP. I have ordered sprits case and getting a PCB for my blue alps when he does the Gb for that. My color combo is white+black+blue and that keycaps set would look great on it.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Offline hydrospell
  • some keyboard thing
    • octobrain
« Reply #193 on: Fri, 21 March 2014, 09:27:12 »
+1 alps caps ftw
⌨ Filco MJ2 MX Blues / M0116 Orange Alps / Homemade 60% MX Reds / M0110
Cherry MX art prints 20/50 still available!
Offline BlueBär
« Reply #194 on: Sat, 22 March 2014, 11:55:10 »
I had another idea: instead of making an adaper insert for Costar stabilizers, we could also make an adapter slider for Cherry stabilizers. It should definately work with PCB mounted stabs, will have to double check with plate mounted stabs.
Offline jacobolus
« Reply #195 on: Sat, 22 March 2014, 21:25:02 »
Can you explain what you’re trying to do? I thought the goal was to make keycaps with cherry MX shaped stabilizer insert mounts fit on existing Alps keyboards.
Offline christopher24745
« Reply #196 on: Sat, 22 March 2014, 22:24:09 »
I would buy set #1
Offline BlueBär
« Reply #197 on: Sun, 23 March 2014, 07:38:27 »
Yeah sorry, this was more related to PCBs/keyboards I guess. A stabilizer insert adapter is probably more useful.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #198 on: Sun, 20 April 2014, 15:40:57 »
i hope this does not die......... :-\
just an 89 ansi set would be great :thumb:
i know is got to be others looking for some alps love :-*
Offline Grim Fandango
« Reply #199 on: Mon, 28 July 2014, 17:08:23 »
I also hope this does not die and we will see the GB stage.
Since there are currently no other options for Alps sets (other than taking them from other keyboards) I think this will appeal to a lot of people. Also, for this same reason I think a more neutral set, like the GTF/GC
would be the a great option. I will definitely buy more than one set if this gets made (it goes with anything). I love that scheme.
