Author Topic: What is your least favorite key on your keyboard? Why?  (Read 11720 times)
Offline dadgh
« on: Thu, 25 July 2013, 20:57:53 »
Mine has to be
I have to use ampersand all the time for my job and I'm unable to hit that key without pivoting my right hand. It's either a pivot to the left with my index finger or a pivot to the right with my middle finger.
Hate it.
Re: What is your least favorite key on your keyboard? Why?
« Reply #1 on: Thu, 25 July 2013, 20:59:22 »
It's a tie between Scroll Lock and Pause
Offline dadgh
« Reply #2 on: Thu, 25 July 2013, 20:59:34 »
but why, I never have to use those keys so they don't bother me at all
Offline Xenderwind
« Reply #3 on: Thu, 25 July 2013, 21:00:04 »
but why
I think I would kind of agree...only because I've never known what they actually do.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #4 on: Thu, 25 July 2013, 21:01:21 »
^^ that's why! I don't use them.
Offline dadgh
« Reply #5 on: Thu, 25 July 2013, 21:02:15 »
That's a good thing! You can remap them to anything you want.
Offline JPG
  • Model F is my new passion!
« Reply #6 on: Thu, 25 July 2013, 21:04:16 »
For me, it's the [ and ] because I speak French and in French they are used for some accents on letters that are not so common but common enough to be annoying since I always mistype these 2 (and I have to use them with shift and just before the letter that requires the accent).
For typing, accents sucks hard!
« Reply #7 on: Thu, 25 July 2013, 23:04:08 »
Caps Lock.  It's a worthless key unless you're Kanye West and blogging.  Following that, I've never understood why "\"  and "/" are split and not right next to each other.  We pair every other symbol, but not those two, that would make too much sense.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #8 on: Thu, 25 July 2013, 23:09:58 »
After I switched this to backspace after switching to Colemak, I don't mind the key anymore.
I agree with the OP in that ampersand is really awkward to get to.  For the most part, after switching to Colemak, most of the keys aren't too bad to get to.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
« Reply #9 on: Thu, 25 July 2013, 23:25:32 »
on some terminal keybaords \ and / are on the same key. Also dvorak puts them near eathother seperated by =
my least favourite key is spacebar for sure. I have a lot of problems with stabilizers, and spacebar just makes it worse.
« Last Edit: Thu, 25 July 2013, 23:27:33 by dorkvader »
Offline TimIsABat
    • Instagram
« Reply #10 on: Thu, 25 July 2013, 23:29:13 »
I honestly don't see why people complain so much about their stabilizers. Even before I clipped my Cherry stabilizers, it really wasn't that big of a problem.
Offline AuRinBei
« Reply #11 on: Thu, 25 July 2013, 23:34:39 »
K. He knows why.
But really anything with Cherry stabilizers. It's like, ugh, what's the point of even having a mechanical switch there if you're going to put those in. Never again.
87u || Poker 2
« Reply #12 on: Thu, 25 July 2013, 23:53:15 »
I've got a lot of keyboards, and only some have cherry stabilizers.
Cherry costar, the stabilizers on this RD with NKRO, the stabilizer on my clicky hall effect keyboard, my linear hall effect keyboard, etc. They all tend to bind up unless I hit them over the switch, negating the point of a stabilizer. Might as well switch to 7bit layout on my phantom.
Offline pandather
  • Formerly gopanthersgo1
  • Hello, I'm Mark.
« Reply #13 on: Thu, 25 July 2013, 23:54:33 »
Insert, sometimes I press it instead of delete, and then it screws me over.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #14 on: Thu, 25 July 2013, 23:57:51 »
I absolutely hate all the keys on modern Cherry keyboards. I am positive if I measure them, I will find they are in fact, somewhat more narrowly spaced than a Model M. This makes me hate them a lot. I frequently move my hands from the keyboard and there is absolutely nothing as annoying as going to hit ^W and instead getting Win+E or Shift+3.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline daerid
    • Rossipedia
« Reply #15 on: Fri, 26 July 2013, 00:29:34 »
Easily CapsLock. I didn't even bother with it on my ErgoDox, and every other board has it remapped to Control (the way god intended). Seconded by Scroll Lock (completely useless in everything except Excel and KVMs).
As a software dev, I find that I use pretty much every other key quite frequently (yes, even the Context Menu/Apps key).
Offline Sniping
« Reply #16 on: Fri, 26 July 2013, 00:39:50 »
Spacebar. It makes that terrible plastic-y slap sounds that ruins the thocking and the ABS forces me to put tape over key.
Offline jeffgran
« Reply #17 on: Fri, 26 July 2013, 01:03:33 »
Mine has to be
Hate it.
I second that. Although I could put 5/% and 6/^ in the same category. They're a reach so you have to move your entire arm when you need to type one of them.
Offline esoomenona
  • Gnillort?
« Reply #18 on: Fri, 26 July 2013, 01:09:25 »
Wouldn't it be nice instead of having a numpad with movement features that no one uses, you could use it to hit all those characters as well via shift? Hmm, may have to do that.
« Reply #19 on: Fri, 26 July 2013, 01:50:02 »
Insert.
Offline PointyFox
« Reply #20 on: Fri, 26 July 2013, 01:50:58 »
Insert.
That.  It causes the most confusion/damage if you accidentally press it.
Offline Narcix
« Reply #21 on: Fri, 26 July 2013, 01:59:05 »
Scroll Lock
« Last Edit: Fri, 26 July 2013, 02:00:49 by Narcix »
Keycool 87 Grey PBT with mx blues
Offline PointyFox
« Reply #22 on: Fri, 26 July 2013, 02:02:22 »
Scroll Lock
Scroll Lock is useful for navigating Excel with the arrow keys.
Offline tormentor
« Reply #23 on: Fri, 26 July 2013, 02:06:42 »
My up arrow. It sticks because i tear them up on FFR.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #24 on: Fri, 26 July 2013, 02:09:23 »
if you dislike "pause" you clearly never built a custom firmware :) ... or you did and remapped the bootloader kickstart key.
« Reply #25 on: Fri, 26 July 2013, 02:17:45 »
I like all my keys equally.
Offline mauri
« Reply #26 on: Fri, 26 July 2013, 05:07:53 »
Left control, it's under my palm and completely inaccessible :<
I AM BABAR KING OF THE ELEPHANTS
Offline godly_music
« Reply #27 on: Fri, 26 July 2013, 06:02:24 »
Windows Key! I hated those so much when I still had a keyboard that had them. My daily driver right now doesn't. So.. number two. Either Capslock or Escape. Capslock is that guy who just wants to be useful but always ends up getting in the way. Escape because I'm an optimist and don't need that ****.
Offline dadgh
« Reply #28 on: Fri, 26 July 2013, 07:42:36 »
Insert.
None of you haters on Insert must use Linux.
Offline Jack Karneval
  • I'm gunna pop some keys, only got $20 in my pocket
« Reply #29 on: Fri, 26 July 2013, 07:47:18 »
Honestly it would probably the Pause/Break key, because I never bloody use it lol
: CM Storm Trigger (MX Green) : KBT Pure Pro (MX Blue) :
Offline Lastpilot
  • Power stance
« Reply #30 on: Fri, 26 July 2013, 07:48:34 »
In terms of function? Menu key. In terms of looks? Supers.
« Reply #31 on: Fri, 26 July 2013, 07:48:49 »
On retrospect.....I'm going to go with 'F1', I always accidentally hit it when going for escape!!
Offline gropingmantis
« Reply #32 on: Fri, 26 July 2013, 08:02:05 »
Easily CapsLock. All the other useless trash can be removed by getting a 60% but still that worthless key prevails.
Y U NO SHIFT LOCK!?!?!?!
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #33 on: Fri, 26 July 2013, 08:03:06 »
Insert. It does more harm than good. Ever remember being a highschool student working on Word 97 and for some reason you're overwriting all of your essay as you're trying to add something and you don't know what's happening or why?
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Dubsgalore
« Reply #34 on: Fri, 26 July 2013, 08:04:52 »
sometimes on my poker, i forget to lock my arrow cluster in, and accidentally hit winkey or menu and it pisses me off so much
Offline Lastpilot
  • Power stance
« Reply #35 on: Fri, 26 July 2013, 08:06:09 »
LOL yes this feeling sucks.
And yeah oTurtlez, I totally forgot about insert. It definitely does more harm then good...lol
Offline MrexD
  • aka mrwoodyxd
« Reply #36 on: Fri, 26 July 2013, 08:08:32 »
all the stupid placements on my 6GV2
Pok3r MX CLears
Offline Tarzan
  • formerly known as Greystoke
« Reply #37 on: Fri, 26 July 2013, 10:22:35 »
Insert.
Waste of space for me.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #38 on: Fri, 26 July 2013, 10:52:04 »
On staggered boards zxc, and worse yet b. And most of the number row. Never cared about caps since I use colemak, and I actually use insert and scroll lock. I used to use the pause key in Doom II.
On my edox I like them all.
Offline DamnDan
  • The Insane One
    • My Deviantart
« Reply #39 on: Fri, 26 July 2013, 11:05:29 »
ESC. It gives me feeling I can simply run away with one click....
Offline keymaster
  • Topre Revolution Theorist
« Reply #40 on: Fri, 26 July 2013, 11:17:13 »
the \ key
Sometimes I press it on accident when going for the backspace.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #41 on: Fri, 26 July 2013, 11:34:00 »
CAPSLOCK! ON MY GH SIXTY I WILL USE IT AS FN KEY!
A Ghost From The Past
Offline HongKongFui
  • No, you couldn't
« Reply #42 on: Fri, 26 July 2013, 11:48:10 »
The spacebar, the reason is in my signature... never thought it could be such a pain in the a** to get my two favourite boards complete...
Offline LouisHjelmslev
  • This is all so complicated
« Reply #43 on: Fri, 26 July 2013, 12:51:05 »
The \ on ANSI, prefer my chunky Enter on my ISO
Offline jil_jil32
  • Tokyo Press <3
« Reply #44 on: Fri, 26 July 2013, 13:11:53 »
the "HOME" key ^o^
Offline Thimplum
  • Master of all Ponies
« Reply #45 on: Fri, 26 July 2013, 13:17:10 »
but why
The pause key... um pauses. It is very common to see it in older games, like Age of Mythology, AKA one of the greatest games ever made.
TP4 FOR ADMIN 2013
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #46 on: Fri, 26 July 2013, 13:20:48 »
Caps Lock.
Win Key
Spacebar.
Once I finish building my ErgoDox, all these hated childs of keycaps shall be abolished!  >:D
Offline Thimplum
« Reply #47 on: Fri, 26 July 2013, 13:27:35 »
Caps Lock.
Win Key
Spacebar.
hehe
TP4 FOR ADMIN 2013
Offline Niomosy
« Reply #48 on: Fri, 26 July 2013, 13:31:10 »
Caps lock key comes in quite handy for the hockey sub-reddit.  Overtime = all caps.  Double OT = bold caps.  Triple OT = italic bold caps.  The trash talk thread is always all caps.
So, I find the caps lock necessary during hockey season :D
Offline Thimplum
« Reply #49 on: Fri, 26 July 2013, 13:43:29 »
Why does everypony say that & is so hard to get to? I use left shift and right index finger.
TP4 FOR ADMIN 2013
