Author Topic: What is your least favorite key on your keyboard? Why?  (Read 11766 times)
Offline CommunistWitchDr
  • >implying keyboards
Re: What is your least favorite key on your keyboard? Why?
« Reply #50 on: Fri, 26 July 2013, 15:01:30 »
Spacebar.
Once I finish building my ErgoDox, all these hated childs of keycaps shall be abolished!  >:D
What, how will you type without a spacebar?
Offline Thimplum
  • Master of all Ponies
« Reply #51 on: Fri, 26 July 2013, 15:15:53 »
Spacebar.
I hate the spacebar because the keycaps are soooo.... nonstandard.
TP4 FOR ADMIN 2013
Offline TrueOP
« Reply #52 on: Fri, 26 July 2013, 15:22:37 »
CAPS LOCK >_<
also
the Up arrow on my Choc Mini; when m playing this vid game and instead of pressing enter to say a line of chat i accidentally (constantly) press Up then Enter... which repeats the last message sent and sends it, instead of sending whatever it is you just typed out x_x
Noppoo Choc Mini
« Reply #53 on: Fri, 26 July 2013, 19:32:42 »
The ANY key?  I don't have one.
I don't have any key on my keyboard.
Offline Thimplum
« Reply #54 on: Fri, 26 July 2013, 20:06:29 »
Press any key to continue searching for the any key!
TP4 FOR ADMIN 2013
« Reply #55 on: Fri, 26 July 2013, 20:31:44 »
Mine should be here tomorrow!
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #56 on: Fri, 26 July 2013, 21:17:01 »
Spacebar.
Th ErgoDox doesn't have any keys the form factor of a spacebar (read excruciatingly long). So a 2u key would be rempped to space.
Spacebar still has to die, no two ways about it.
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #57 on: Fri, 26 July 2013, 21:35:39 »
Scroll Lock.
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
« Reply #58 on: Fri, 26 July 2013, 22:16:36 »
Scroll Lock.
I'm still not sure what it does.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #59 on: Sat, 27 July 2013, 00:18:13 »
F12.  All it ever does for me is turn off the navigation in Notepad++, a feature I never had any need for.
Overton130, Box Pale Blues.
Offline calavera
« Reply #60 on: Sat, 27 July 2013, 00:31:17 »
probably scroll lock.
Offline gropingmantis
« Reply #61 on: Sat, 27 July 2013, 05:44:15 »
What are people's problem with the Super (win) key? I use it all the time for my WMFS shortcuts
Super + F = firefox
Super + T = terminal
Super + M = thunderbird
Super + Q = close program
Super + Arrows = change focus
such a useful key.
Offline tipo33
  • "Ski"
« Reply #62 on: Sat, 27 July 2013, 05:48:05 »
The windows key, on the keyboards that have them.  Most of mine don't.
KM4COL    R.I.P.  SmallFry
Offline Ultratude
    • Ultratude's Blog
« Reply #63 on: Sat, 27 July 2013, 06:04:59 »
Esc, I always use it.
Offline Halvar
« Reply #64 on: Sat, 27 July 2013, 06:09:47 »
Caps Lock, Insert and Windows, in that order.
They do annoying things when you press them accidentally and are of little use anyway.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #65 on: Sat, 27 July 2013, 06:10:20 »
|\ after its changes to backspace.
-Enzo Ferrari
« Reply #66 on: Sat, 27 July 2013, 06:35:04 »
Ok, here's one for real.
Enter on ISO layouts.
It is too big, and obstructs where backslash should be, causing backspace to be too small.
Offline brighenne
« Reply #67 on: Sat, 27 July 2013, 12:00:17 »
I've got to go with insert also, I used to work with a guy that removed his insert keycap at work.
Following that, I've never understood why "\"  and "/" are split and not right next to each other.  We pair every other symbol, but not those two, that would make too much sense.
Gonna pull this one back up.  I see the logic here because the rest of the paired symbols are typically used as an open and close where / and \ aren't.
« Reply #68 on: Sat, 27 July 2013, 12:31:42 »
Sure, but, logically, it makes more sense to pair like symbols.  To me, it would make more sense to have an ?| key and an /\  key or / and \ on different keys near each other.  I mean, you have - and _ on the same key, ' and " on the same key, and ; and : on the same key, so why not / and \.
Offline jabar
« Reply #69 on: Sat, 27 July 2013, 17:56:49 »
I remap my caps lock so it doesn't bother me anymore. My least favorite key are the Win keys, and the right alt not being an AltGr by default.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline nullptr
« Reply #70 on: Sat, 27 July 2013, 18:22:24 »
Caps Lock and to a lesser extent the Windows key. I use Win+L to lock my computer at work though, but at home it's nothing but a pain.
'11 WASD V1 - '91 IBM Model M (1391401) - Poker II (ordered)
Offline Grim Fandango
« Reply #71 on: Sat, 27 July 2013, 18:37:20 »
I think pretty much the only key that sometimes annoys me is the caps lock. It is not that often that I accidentally hit it, but when I do , it always annoys me.
Offline Masterchief79
« Reply #72 on: Sun, 28 July 2013, 04:55:03 »
"?" Key in ISO-DE (is at the right of "9"). Don't know why, i never really hit this key in the first attempt.^^ It's such a bad position for it.
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
Offline mroldmanfunk
« Reply #73 on: Sun, 28 July 2013, 06:34:53 »
Pause Break simply becauseI have no use for it.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #74 on: Sun, 28 July 2013, 06:36:31 »
"Insert" has annoyed me many times over the years.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #75 on: Sun, 28 July 2013, 08:52:31 »
The semicolon.  I hardly use it; when I do, I wonder if I use it properly.
« Reply #76 on: Sun, 28 July 2013, 09:02:17 »
But without it you can't make these ;)
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #77 on: Sun, 28 July 2013, 09:20:51 »
Haha!  Good point but I usually click the emoticons just to be sure I get the right one :blank: oops I meant :p
Offline Hyde
  • White Tofu Extraordinaire
« Reply #78 on: Sun, 28 July 2013, 10:44:09 »
^ For the same reason I find " ~ " highly useful only because I make these (~___~) and this " yayyyyyyyyyy ~~~~~~~~~~~ "
LOL
Though I have to say my least favourite key is probably "insert".  Like most people said it causes more issues compare to most other "useless keys" also it's located in such a crucial location on keyboard.
Like they could've put a better key in that spot.  Otherwise I never use pause/break but at least I understand the importance for programmers on that key.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #79 on: Sun, 28 July 2013, 18:03:16 »
I only use this for the purpose of making my college papers look fancier.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
« Reply #80 on: Sun, 28 July 2013, 18:43:05 »
Ah, the semicolon; the most frequently misused punctuation mark.
“Here is a lesson in creative writing. First rule: Do not use semicolons. They are transvestite hermaphrodites representing absolutely nothing. All they do is show you've been to college.”
-Kurt Vonnegut
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #81 on: Sun, 28 July 2013, 18:44:24 »
The backspace, it reminds me of my failures in typing every time I have to hit it ;___;
« Reply #82 on: Sun, 28 July 2013, 19:15:32 »
-Kurt Vonnegut
Can a hermaphrodite even be a transvestite?
Anyway, I use semi-colon every day in my software development activities.
Offline Wall Street
« Reply #83 on: Sun, 28 July 2013, 21:12:03 »
such a useful key.
If you are typing quickly or playing a game, it will stop typing/playing and give you the start menu.  Similar to caps lock or insert, you usually need to stop what you are doing and redo some work.  Also, for a key that can dump you from a program, it is in a very poor spot near a lot of keys which are very frequently used.
I think that when Windows was originally made, they were smart to make Ctrl-Alt-Del and Alt-Tab into multi-key combos.  The idea of one key in the primary typing space leaving a program is nonsensical.
« Last Edit: Sun, 28 July 2013, 21:13:48 by Wall Street »
Offline Siva
    • TwitchTV
« Reply #84 on: Sun, 28 July 2013, 22:23:28 »
Easily the Caps Lock key. I'm an MMO player that is heavily into pvp. Pretty much every button I use has a shift and control modifier; and the Caps Lock always gets in the way. Also, I like my left pinky to rest when not in use and having a cavity there (yes, I remove the key cap since I never use it) helps me out a lot.
Offline davkol
  •  Post Editing Timeout
« Reply #85 on: Mon, 29 July 2013, 03:54:37 »
I could ***** about placement of some keys on ISO, TypeMatrix etc., but I won't. I really hate some layouts though. For example, too small ISO Enter—International Apple Aluminium keyboard, I'm looking at YOU!—or AltGr moved too far to the right, mostly because of no Menu key (which I actually use quite often, if I have it): this is the case of MS SideWinder X4/X6. BTW why there isn't AltGr on both sides of spacebar...?
In general, I hate Caps Lock. Its overuse is annoying on the internets.
Offline Thimplum
« Reply #86 on: Tue, 30 July 2013, 14:40:50 »
TP4 FOR ADMIN 2013
Offline inteli722
« Reply #87 on: Tue, 30 July 2013, 14:45:49 »
Waiting for: Phantom Plate
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #88 on: Wed, 31 July 2013, 00:04:26 »
Haha Good one!
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #89 on: Wed, 31 July 2013, 00:21:30 »
I don't really have a least favorite, but there is something that irks me. I hate it when a keyboard has a | printed on the keycap instead of an ¦, and yet I think I use | more often... There is a huge controversy over broken bar vs vertical bar vs pipe... Keyboards output one or the other, but operating systems and programs often change one to the other for consistency...
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
« Reply #90 on: Wed, 31 July 2013, 00:41:33 »
such a useful key.
*shrugs* Thats you people's fault for using Windows. The super key is just that in most Linux distros.
Nomsayin
/linux***
:p
Offline compgeke
« Reply #91 on: Wed, 31 July 2013, 04:02:16 »
tHE CAPS LOCK KEY. eVERY TIME i PRESS IT i FORGET HOW TO TURN IT OFF! nOT ONLY THAT, IT CAUSES PEOPLE TO TYPE LIKE THIS!
But in reality, caps lock isn't really needed that much for most people, it's really an annoyance, one of those things that should have never been given to the general public.
The other key I hate is the ' key, as I frequently miss it and hit enter, leaving lines like "So what if it" "it's 2 in the morning? I" "I'm not even tired!"
Offline Ekruceal
« Reply #92 on: Wed, 31 July 2013, 04:08:10 »
Caps lock because it's useless to me.
Offline Leslieann
« Reply #93 on: Wed, 31 July 2013, 15:24:16 »
For me.. Insert, as mentioned, it causes all sorts of damage.
For other people I despise their caps lock.
I disable insert, change caps lock into a shift, and while games run, the Win key becomes a ctrl key. Problems solved.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline davkol
« Reply #94 on: Wed, 31 July 2013, 16:33:37 »
I hate that there isn't dedicated Insert on most compact keyboards. STFU Windoze n00biez ~_^
Offline neoezekiel
    • My GW2 Guild - The Fallen Souls [SouL]
« Reply #95 on: Wed, 31 July 2013, 16:41:51 »
A tie between Caps Lock and Insert.
I have a few older boards without caps lock that I used a lot growing up so I end up hitting caps lock a lot when trying to Control (which is in place of caps lock on those boards).
My hatred of Insert actually comes from my laptop, which has a double sized Delete key so when I am at my desktop or any other full sized keyboards I end up striking insert instead.
I would probably hate the Windows key if more of my boards had one.
WTB: Cherry G80-2550, GnCC/CCnG sets, led mx greens, mx dark greys, Plate Design Service, Case Design Service
Offline neoezekiel
« Reply #96 on: Wed, 31 July 2013, 16:43:00 »
What are you using insert for anyway?
Offline davkol
« Reply #97 on: Wed, 31 July 2013, 16:48:37 »
copypasta
Ctrl-C/V cramps my left hand—or doesn't work with left-handed mousing; it means something different in shell as well.
Offline wiredPANDA
« Reply #98 on: Thu, 01 August 2013, 11:12:27 »
Why did it never occur to me to disable/remap the annoyance of Insert?  Glad I read this thread to make me realize the obvious.
| HHKB Pro 2 | Leopold FC660C
| Poker.PANDAclears | ErgoDox (62g Black)
Offline viralbug
« Reply #99 on: Thu, 01 August 2013, 11:19:54 »
Although I don't have any least favorite key per se, I would say the Backspace annoys me.
A little bit because it makes me realize I've been making mistakes. But the real reason it annoys me is because my keyboard at work sucks and I end up making mistakes more often than at home.
