Author Topic: HHKB Pro 2 Love  (Read 577789 times)
Offline vegs
Re: HHKB Pro 2 Love
« Reply #800 on: Sat, 21 November 2015, 09:49:31 »
Gotcha. Keep me updated. Def in the same boat when it comes to sounds. If you are that good with building a silent PC, I'm sure you will come up with a fix for your HHKB. Which silencing method did you use on the kb? What about the stock HHKB sound bothered you in the first place? I don't mind the bottom out or return thock at all.
Will do! I used these dental bands. I usually bring my keyboard with me to school, and I found the return thock a bit too loud for taking notes in class.
hhkb 4 life
buy less
Offline Cicada88
Re: HHKB Pro 2 Love
« Reply #801 on: Sun, 22 November 2015, 16:26:38 »
Holiday Spirit HHKB Style
Offline dan002
Re: HHKB Pro 2 Love
« Reply #802 on: Sun, 22 November 2015, 16:55:39 »
Anyone dye sublimated their own white hhkb key caps? I've seen them on ebay, so it
ought to be possible with the right tools.
Peace, love and keyboards.
Offline TieuNgu
Re: HHKB Pro 2 Love
« Reply #803 on: Sun, 22 November 2015, 19:14:08 »
The only problem that kept me from considering those caps is that I don't know how long the paint would last or if it would blend to the caps next to it :/
Re: HHKB Pro 2 Love
« Reply #804 on: Mon, 23 November 2015, 04:01:53 »
Merry Christmas :)
Offline dan002
Re: HHKB Pro 2 Love
« Reply #805 on: Mon, 23 November 2015, 08:14:03 »
Referring to the quality of the dye. I believe they are dye sublimated with heat, the same way legends on pbt are.
Cicada88 do they caps feel any different?
Offline keshley
    • Blog n stuff
Re: HHKB Pro 2 Love
« Reply #806 on: Mon, 23 November 2015, 08:49:48 »
I have some, they feel the same to me. The burgundy ones look fantastic IMO. The Navy ones are pretty subtle.
HHKB Pro 2       Pok3r
Offline Cicada88
Re: HHKB Pro 2 Love
« Reply #807 on: Mon, 23 November 2015, 09:20:44 »
Thanks for the feedback.
If you guys are interested in ordering any I have free shipping for GH users...check my thread in the artisan forum.  We can also work out specific keysets or deals.
As for the durability?  I have only been making them for 6 months or so, but I have had no complaints or problems with my own.
After they dry, I give them a hard scrub and alcohol bath to get rid of any dye thats left on the surface.  After that there isn't any transfer, and they aren't made with paint at all.  The dye is actually absorbed into the key via heat.  They feel and look stock as far as texture and keeping the matte finish.
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #808 on: Mon, 23 November 2015, 16:30:45 »
Just waiting on my PBT Spacebar to come in later this week. Already in love after just a few thocks. Lazy cellphone pic:
Offline phosphoric
Re: HHKB Pro 2 Love
« Reply #809 on: Mon, 23 November 2015, 17:05:08 »
are those mint arrows cicadas'? they look so good!
Let's get this straight. There is nothing cool about keyboards we're all lame as fk.
speak for yourself
Offline Cicada88
Re: HHKB Pro 2 Love
« Reply #810 on: Mon, 23 November 2015, 17:15:10 »
No those aren't mine--they look to be a different material than stock PBT.
 That's a great color though. I want to try do a color similar to that at some point for escape, function, and arrows.
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #811 on: Mon, 23 November 2015, 17:21:03 »
They're KeyKollectiv. Thanks!
Offline Altis
Re: HHKB Pro 2 Love
« Reply #812 on: Mon, 23 November 2015, 18:34:59 »
I can't decide if I want to lubricate the stems on my HHKBp2.
It's noticeably more gritty than my RF87U... but I don't want to somehow ruin it in the process.
I am going to be adding some sound deadening though to see how that affects it -- it's easy to undo, though.
Offline Latin00032
Re: HHKB Pro 2 Love
« Reply #813 on: Mon, 23 November 2015, 19:36:37 »
I do want a hhkb now. I want to try it out at least.
I do have a fc660c modded with 55g domes.
I just really want to see if in missing anything with a hhkbp2.
I'd love to try the type-s variant. I'd also like to see how it compares to the dental band mod.
Any one have links to show pros and cons between type-s and the dental band mod based on reviews?
Offline raymogi
Re: HHKB Pro 2 Love
« Reply #814 on: Mon, 23 November 2015, 19:38:50 »
One thing for sure is that the Type-S have longer sliders to accommodate the silencing rings so there're no travel reduction.
Please feed my addiction.
Offline slushi
Re: HHKB Pro 2 Love
« Reply #815 on: Mon, 23 November 2015, 19:49:47 »
Lubing is reversible but can be time consuming.
https://geekhack.org/index.php?topic=71930.0
 HHKB Pro 2
Offline hasu
  • @tmk
Re: HHKB Pro 2 Love
« Reply #816 on: Mon, 23 November 2015, 21:07:10 »
Type-S has 3.8mm stroke while normal one has 4.0mm, I guess those use same plungers and O-rings are 0.2mm thick.
https://www.pfu.fujitsu.com/hhkeyboard/type-s/spec.html#pro2_spec
https://www.pfu.fujitsu.com/hhkeyboard/hhkbpro2/spec.html
Offline raymogi
Re: HHKB Pro 2 Love
« Reply #817 on: Mon, 23 November 2015, 21:20:18 »
So all this time I've been reading the wrong stuff.
No wonder Hypersphere's rings installed on the normal sliders doesn't feel like it reduces the travel distance.
Thanks for the info hasu!
Offline Latin00032
Re: HHKB Pro 2 Love
« Reply #818 on: Mon, 23 November 2015, 21:28:31 »
So, the price difference is just for the silencing rings??
Offline raymogi
Re: HHKB Pro 2 Love
« Reply #819 on: Mon, 23 November 2015, 21:31:38 »
Pretty much.
And the white case has the Type-S marking on the top right. That's about it.
Offline TieuNgu
Re: HHKB Pro 2 Love
« Reply #820 on: Mon, 23 November 2015, 21:51:11 »
Hey it's good to know the process, made me feel interested in your work!
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #821 on: Tue, 24 November 2015, 00:44:42 »
Okay, after using this keyboard for the last 5-6 hours I can honestly say I hate it... because it has ruined MX switches for me. I'm still going to need some time to get used to the layout, but it just feels so good.  :thumb:
Offline slushi
Re: HHKB Pro 2 Love
« Reply #822 on: Tue, 24 November 2015, 00:46:20 »
Oh you with your switcheroo :)
 HHKB Pro 2
Offline swimmingbird
  • keyset hoarder
Re: HHKB Pro 2 Love
« Reply #823 on: Tue, 24 November 2015, 05:18:30 »
I had very similar feelings when I got my HHKB after using ergo clears
Gets even worse when you try a 55g RF
Re: HHKB Pro 2 Love
« Reply #824 on: Tue, 24 November 2015, 08:36:19 »
Offline MagicSauce
Re: HHKB Pro 2 Love
« Reply #825 on: Tue, 24 November 2015, 11:43:31 »
So once I grab that 55g RF I am going to ruin my HHKB too?
Offline slushi
Re: HHKB Pro 2 Love
« Reply #826 on: Tue, 24 November 2015, 11:48:17 »
No no no, you're going to improve your HHKB through surgery. :)
 HHKB Pro 2
Offline retrochick
  • goodbye my wallet
Re: HHKB Pro 2 Love
« Reply #827 on: Tue, 24 November 2015, 11:53:08 »
I wish you were nearby. I want to try out your modded 55g hyperfused lubed hhkb!!!!  >:D
Offline eun
  • Lunatic-hai eun .
Re: HHKB Pro 2 Love
« Reply #828 on: Tue, 24 November 2015, 12:22:04 »
I have been using this for about two days now, and I am in love. This thing is heaven right now. It makes me actually want to do my homework and papers. I just love typing with this. Topre switches really are indescribable. It's no where close to a regular rubber dome, and no where close to a mx switch. It has a feel on its own. It just feels like love on my fingers. In terms of typing improvement, I have a better flow and have made far less errors with this board than any of my others. This board just feels beautiful. I don't even fret over bottoming out because it sounds amazing and feels soft. It's like I bottom out on a bunch of soft pads. That pleasant thock and raindrop return. No stabilizers. This thing is amazing.
Actually i also love that..so i have hhbk pro1 & pro2
but im using cherry boards T_T
356CL Alps blue/ 356CL DGE not assembled/ 356CL V2 not assembled/ 356L vintage black NO.10/60/ 356N turn gray/ 356N Mark2 wyseblack/ 356Mini vintage black/ 356Mini vintage brown/ 356Pad vintage black/ 456GT vintage white/ 360 Corsa not assembled/ Kinesis mockup vintage brown/ Koala vintage black/ Koala Alps green/ hhmx-LZ-hx vintage black/ wyse saver Ferrari vintage brown/ strongman Alps geen/ strongman Alps yellow/ DK saver vintage brown/ DK saver Alps pink/ G81-1800 vintage blue/ G81-1800 vintage black/ Next Keyboard Alps turn black
Offline slushi
Re: HHKB Pro 2 Love
« Reply #829 on: Tue, 24 November 2015, 12:41:03 »
Haha, thanks! It's my baby... (don't tell my gf)
 HHKB Pro 2
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #830 on: Tue, 24 November 2015, 13:16:03 »
Since I game on whatever keyboard is plugged in, a 55g is probably out of the question. I don't really have any desire for a firmer switch regardless.
Offline TieuNgu
Re: HHKB Pro 2 Love
« Reply #831 on: Tue, 24 November 2015, 20:05:35 »
Is 55g HHKB THAT good? All people I talk too recommend it but I mean that's like a $300 surgery lol
Offline byker
  • Literally Canada
Re: HHKB Pro 2 Love
« Reply #832 on: Tue, 24 November 2015, 20:35:13 »
In my opinion, it is nicer to game on 55g topre, than 45g topre. I usually use my 55g realfoce for gaming (over my hhkb)
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #833 on: Tue, 24 November 2015, 20:37:05 »
Why is that? I was thinking about hopping on the Massdrop for the Realforce 55g, but the black ones are all gone.
Offline byker
  • Literally Canada
Re: HHKB Pro 2 Love
« Reply #834 on: Tue, 24 November 2015, 20:47:39 »
Less mushy and a more sudden collapse of the dome, makes me feel like the keys are more responsive when gaming.
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #835 on: Tue, 24 November 2015, 20:55:34 »
Ah, gotcha. I've been using mostly MX Reds at home lately, so the HHKB doesn't really feel mushy in comparison to those.
Re: HHKB Pro 2 Love
« Reply #836 on: Tue, 24 November 2015, 21:42:20 »
I'll just add my opinion to the mix: I love 55g, but I'm not the biggest fan of 55g HHKB.  It felt mushier to me - just lost the magic that is there in 55g RealForce, which has more of a snap to it.  But lots of people think 55g HHKB is top tier, so you may prefer it.  Just have to try it to see.  ;)
Offline slushi
Re: HHKB Pro 2 Love
« Reply #837 on: Tue, 24 November 2015, 21:45:43 »
Well the surgery isn't too bad if you resell the donor as a 45g. I had extra 45g domes so I made the donor a uniform 45 and got a ton of money back.
 HHKB Pro 2
Re: HHKB Pro 2 Love
« Reply #838 on: Wed, 25 November 2015, 03:42:27 »
Do we need a Thorpe Therapy thread to mourn the 55g RealForce keyboards that have been sacrificed to bring moar 55g HHKB into the world?
Offline Latin00032
Re: HHKB Pro 2 Love
« Reply #839 on: Wed, 25 November 2015, 04:37:50 »
Pics of this hhkb??
Offline Vimto
Re: HHKB Pro 2 Love
« Reply #840 on: Fri, 27 November 2015, 00:06:04 »
I have 2 HHKB Pro 2
Absolutely love them.
Just upgraded one of them with hasu's alt controller, wondering what mod i should do next?
I love the sound of them, so not sure I can be bothered with silencing them, but may try the dental band method.
What realforce keyboard would people recommend if I wanted to buy a 55g Topre model to test it out?
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline raymogi
Re: HHKB Pro 2 Love
« Reply #841 on: Fri, 27 November 2015, 00:13:29 »
I have 2 HHKB Pro 2
The 10th Anniversary Edition 55g one :)
Offline Vimto
Re: HHKB Pro 2 Love
« Reply #842 on: Fri, 27 November 2015, 09:01:22 »
I have 2 HHKB Pro 2
Is this the one you're suggesting?
http://www.ebay.com/itm/Topre-Realforce-87-10th-Anniversary-Edition-30-45-55-Variable-Keyboard-/271700719765?hash=item3f429ff895:g:L8QAAOSwq7JT36cS
Offline raymogi
Re: HHKB Pro 2 Love
« Reply #843 on: Fri, 27 November 2015, 09:02:36 »
I have 2 HHKB Pro 2
That's the variable weighting one. If you want all 55g, try messaging him. It runs out of stock pretty fast.
That's variable weighting. If you want all 55g, try messaging him. It runs out of stock pretty fast usually.
Offline Vimto
Re: HHKB Pro 2 Love
« Reply #844 on: Fri, 27 November 2015, 09:23:36 »
I have 2 HHKB Pro 2
I've seen some other Realforce 55g on eBay. Sorry for the stupid question but what's special about the 10th anniversary edition?
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #845 on: Fri, 27 November 2015, 09:29:34 »
I have 2 HHKB Pro 2
lighter colored case and a different keycaps so thats that
Offline maskey
Re: HHKB Pro 2 Love
« Reply #846 on: Fri, 27 November 2015, 11:02:19 »
I'm going to be picking one up today, depending on whether or not I can sell my Novatouch!
Offline Jeftha
Re: HHKB Pro 2 Love
« Reply #847 on: Sat, 28 November 2015, 22:22:56 »
Got a HHKB Pro 2 with these dental bands on the sliders. They're very tiny and pretty thin. I noticed a slight change in keytravel, but it sounds so much better now. No more clack, just thock.
When applying these, the easiest way I found was to first put them around your thumb. Then press your thumb firmly on top of the slider and roll the band from your thumb right onto the slider. This leads to the band being twisted sometimes, but if you press it down all the way it's still going to do the job with little keytravel reduction.
After a few months I noticed that my spacebar was rattling quite a bit. Fixed that by lubing the stabilizer wire and clips with some di-electric grease. It thocks again.
Realforce 87U 55g             HHKB Pro 2 (dental band)
Offline phruitpie
Re: HHKB Pro 2 Love
« Reply #848 on: Mon, 30 November 2015, 08:59:03 »
Picked up my HHKB today (first topre board) and oh man... had to change my profile pic because even unlubed it's that buttery smooth. Next up, hypersphere's silencing rings (if and when they restock :P).
Offline captaineleven
Re: HHKB Pro 2 Love
« Reply #849 on: Mon, 30 November 2015, 18:05:04 »
Got my HHKB today too and now I want like eleven of these things  :)) They are like nothing I've ever typed on before and I never really understood the snap back that people have mentioned about topre until today. I still have to get through a couple of days of dealing with the backspace button, but it's otherwise an intuitive feel for me. #cantgoback lol
So fancy!
