Author Topic: HHKB Pro 2 Love  (Read 577939 times)
Offline Bucake
Re: HHKB Pro 2 Love
« Reply #1050 on: Wed, 30 December 2015, 22:19:37 »
of course he's gonna say that he prefers the rings that he sells...
Having tried both myself, I'd rather spend less money on the Silencing Rings than spend the extra ~$100+ for the Type-S version.
it was about best result, not best price-to-quality ratio.
but to reply; most people are probably better off getting aftermarket rings, economically-wise.
however, installing the rings takes a lot of time, and some people think it's worth paying extra to have them do it for you at the factory.
unfortunately it's hard to find an unbiased review, especially since very few people own both a Type-S and a HHKB with aftermarket rings installed.
I posted this in the media forum but figured I would share my video recordings of an HHKB unlubed and with lube. The difference is very noticeable. I'm so pleased with the results that I don't have a need for silencing rings.
wow, that's quite a big difference. what lube have you used, and did you only lube the sliders? : )
edit: apparently i have actually damaged my case a little bit. i guess i've screwed in two of the screws a little bit too tightly, and it's caused the plastic holes to split apart, slightly. i didn't see it happen so i don't know for sure that it was me, but i doubt it came like this from the factory. so yeah, there's a tip: be gentle when screwing the PCB back on! ;D
« Last Edit: Thu, 31 December 2015, 02:24:44 by Bucake »
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: HHKB Pro 2 Love
« Reply #1051 on: Thu, 31 December 2015, 13:26:49 »
Thats some ASMR stuff right there!   ;)
It definitely sounds really close to me.. maybe a bit less "clink" on the rebound. But if its a smoother action, thats impressive on an already smooth "thunk" type of a board.
-Dana
Offline retrochick
  • goodbye my wallet
Re: HHKB Pro 2 Love
« Reply #1052 on: Thu, 31 December 2015, 13:40:57 »
I used krytox 103 and lubed sliders and stabs.
Offline Latin00032
Re: HHKB Pro 2 Love
« Reply #1053 on: Thu, 31 December 2015, 13:55:17 »
Boom roasted. I ended up buying a normal one and a set of rings. I will probably buy a Type-S to compare it to. While he may be just saying that he likes them better, since he sells them, it seems there are many fans of the Hypersphere rings around here.
I just bought a set of hypersphere rings. Lets see how they work after I get them in my hhkb.
Offline livingspeedbump
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1054 on: Thu, 31 December 2015, 15:18:41 »
I can't say EXACTLY when yet, but look for the interview with Professor Eiiti Wada to show up sometime this week  :rolleyes:
<- My Collection (so far)
Offline ideus
  • Björkö.
Re: HHKB Pro 2 Love
« Reply #1055 on: Thu, 31 December 2015, 15:42:42 »
I can't say EXACTLY when yet, but look for the interview with Professor Eiiti Wada to show up sometime this week  ::)
He is an awesome man that appears not aware of the celebrity level he has within keyboard aficionados. I wrote him this year to ask if he knows about an improved version of the HHKB and he said he is not involve with the manufacturer/designer anymore. It would be great to read your interview.
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1056 on: Thu, 31 December 2015, 15:46:57 »
One of the most humble and down to Earth people I've ever spoken too for sure. And yeah, it did seem like he was unaware of how much some of us really do still love the HHKB. Very few keyboards have such a dedicated following as it.
Offline Hypersphere
Re: HHKB Pro 2 Love
« Reply #1057 on: Thu, 31 December 2015, 16:40:05 »
I truly have tried to be objective, although clearly there is a reason for anyone to suspect bias. Of course, anyone can do a comparison for himself. The effect of the rings is similar between a Type-S HHKB and DIY-silenced HHKB, but I have noticed on my Type-S that the silencing seems not quite as even across the board as I have gotten with DIY silencing. I have not been able to do a comparison between a factory-silenced RF87U and DIY-silenced RF87U because I do not have a factory-silenced model, but I can say that silencing produces dramatic results. The before and after is the most dramatic on the CM Novatouch.
In fact, as others have discovered, there is a major improvement to be realized in Topre-switch keyboards by lubing the stabilizers and sliders. I have recently gotten the best results using Superlube 51010 oil. I apply it sparingly to just the slider rails using a small paintbrush. I do not put oil on the cylindrical part of the slider or switch housing. I also lubricate the plastic and metal contact points in the stabilzers. Finally, I have found that the spacebar sound can be deadened by placing self-adhesive squares of anti-skid foam rubber strips on top of the plate under the spacebar on each side of the spacebar switch.
So, for the best overall silencing, either install silencing rings or start with a Type-S, but also lube the stabilizers and switches and consider putting shock absorbers under the spacebar as well.
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1058 on: Thu, 31 December 2015, 16:49:18 »
I can also be found to have stated numerous times in the past that I prefer Hypersphere rings over the Type-S, and I don't sell them ;)
For me, pricing is important. I don't find the Type-S to be worth the cost, when Landing Pads and Hypersphere rings are an option. I had a Type-S for a long time, and just didn't ever love it. And for me to keep a $300+ keyboard, I have to LOVE it. Mine had whistling issues and generally wasn't great.
I also had silenced Pro's/Pro 2's with Hypersphere rings and EK Pads to compare. THe EK Pads can work quite well, but they take a ton of time and effort to get perfect. Ironing them, making sure they are all even, and trimming them can take hours for an HHKB, I wouldn't have the time to even consider using them on a RF. In the end, they do sound/feel pretty good. Hypersphere rings, while a bit pricier, are a better option than the EK Pads and the Type S IMO. They feel great, sound great, and generally get the job done.
Also, as Hypershere mentioned, there are benefits to DIY silencing as well. I also lube all of my Topre boards, so I end up having to take them apart anyways, meaning I might as well DIY silence them while I'm at it and save some money.
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1059 on: Thu, 31 December 2015, 17:20:40 »
Also, totally agree the Novatouch benefits the most from ANY silencing. It had quite a rattle to it and is unquestionably the loudest stock Topre board out there. I remember when they used to come with O-rings for silencing (not sure if that is still a thing?) but can attest to the fact that o-rings are the worst on Topre boards. Unlike Cherry boards, you obviously install them underneath the housing like the rest of the silencing methods, and they absolutely kill the travel distance and general feel of the keyboard  :-[
Offline derb2k2
  • Something of a Topre ****..
Re: HHKB Pro 2 Love
« Reply #1060 on: Thu, 31 December 2015, 17:32:35 »
having tried all known silencing mods for topre, I can safely say that Hypersphere's has worked best not only in terms of silencing, but also retaining the tactility (hardly affecting distance traveled) and feel of the unmodded topre switch. Was able to finally get rid of the damned dental bands  :thumb: :thumb:
I have a RF87 on the way so I'm going to order another set soon.
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline Bucake
Re: HHKB Pro 2 Love
« Reply #1061 on: Fri, 01 January 2016, 05:41:12 »
so, do you prefer hypersphere rings over the type-s because of the cost and "benefits", or do you think they actually make the board sound or/and feel better than a type-s?
Offline Hypersphere
Re: HHKB Pro 2 Love
« Reply #1062 on: Fri, 01 January 2016, 08:44:01 »
@Bucake: I've only tried one Type-S HHKB, and an "n" of 1 is insufficient for a statistical analysis, but based on the one Type-S that I tried in comparison to 3 standard HHKBs that I have modded with silencing rings, I did not like the Type-S as well in terms of sound and feel. In fact, I contacted EliteKeyboards about the uneven sound and feel of the keys in the Type-S, and they told me that this was typical. There is also the cost consideration, but the cost should include more than the cost of parts. You also need to put a value on your time and effort. When you do this, you might conclude that it is better to buy a ready-made Type-S rather than going to all the time and trouble of doing it yourself.
Since the time that I have done the silencing mod on my HHKBs, I have done 3 Novatouch and 3 RF87U keyboards. Each time the result seems better. My most recent one was a RF87UB55; in addition to installing the rings, I lubed the stabilizers and all the switches with Superlube 51010 oil, and I put foam rubber shock absorbers under the spacebar. I also replaced the ABS spacebar with a PBT spacebar (from matt3o's efforts). I am typing on this RF now, and I really like how smooth and quiet it is.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1063 on: Sat, 02 January 2016, 00:01:36 »
It really is so much better than the type s that my friend have. the sound and the feel is much better and no whistling issue. i think its because the lube I use but who really knows  :p
Offline OfTheWild
Re: HHKB Pro 2 Love
« Reply #1064 on: Sat, 02 January 2016, 16:51:51 »
Was there a noticeable difference in the key change to the PBT? Is it simply that the material is thicker and thus has a lower sound?
-Dana
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1065 on: Sat, 02 January 2016, 17:24:06 »
Yep there is some notabel difference it makes a deeper sound
Offline DAVYtm
  • #dateless
Re: HHKB Pro 2 Love
« Reply #1066 on: Sat, 02 January 2016, 18:00:33 »
The smoothness of the ABS is something I really dislike, the PBT spacebar makes such a huge difference in feel for me
Offline Moratorius
    • Kyle Chong
Re: HHKB Pro 2 Love
« Reply #1067 on: Sat, 02 January 2016, 18:39:49 »
Do you have any concerns about the consistency?  I've seen others mix 103 with 205 grease.
HHKB Type-S, Topre Realforce 87UB (55g)
Offline trenzafeeds
  • **** off
Re: HHKB Pro 2 Love
« Reply #1068 on: Sat, 02 January 2016, 20:44:43 »
I'm enjoying mine a bit more.
demik will never leave.
Unless he gets banned.
Offline ajx
Re: HHKB Pro 2 Love
« Reply #1069 on: Mon, 04 January 2016, 12:14:24 »
Those screw holes on both side i assume?
I did same thing, one of those screw hole has been cracked, i don't think it would change anything
Offline dgneo
  • Supervillain
Re: HHKB Pro 2 Love
« Reply #1070 on: Mon, 04 January 2016, 12:15:18 »
Yep, still standing by what I've said.
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1071 on: Mon, 04 January 2016, 13:39:20 »
Offline alexjd99
  • oozing through the cells of one's own construction
Re: HHKB Pro 2 Love
« Reply #1072 on: Mon, 04 January 2016, 17:21:25 »
https://www.keychatter.com/2016/01/04/interview-professor-eiiti-wada-creator-of-the-hhkb/
FINALLY the interview has been published on Massdrop!
That was awesome! Thanks for doing this for all of us, it was a great read  :thumb:
Offline DAVYtm
  • #dateless
Re: HHKB Pro 2 Love
« Reply #1073 on: Mon, 04 January 2016, 17:41:15 »
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1074 on: Mon, 04 January 2016, 17:43:16 »
Great work as always man, fantastic read!
THanks! Glad it finally paid off. Took a while to back and forth with him with edits and stuff because he is so busy and probably had to get some of what we were asking translated. We also didn't want to put the interview out with something like the Metal Case and make it seem like we were using the interview to sell something, that would be no good haha
Offline Madeupword
Re: HHKB Pro 2 Love
« Reply #1075 on: Mon, 04 January 2016, 19:06:43 »
Purchased, and best keyboard I've used. Was able to enter UEFI BIOS. In Mac mode with swapped Backspace, able to use media keys without additional software in OS X. Fluid on both Windows and Mac, great continuity from the Apple Wireless Keyboard. Actually adapted to navigation cluster quicker to Backspace placement. Now to look for one white Topre PBT spacebar.
Currently looking at the Magic Keyboard to replace the Apple Wireless Keyboard, but at $99, I'm contemplating to purchase another HHKB Pro 2.
Re: HHKB Pro 2 Love
« Reply #1076 on: Mon, 04 January 2016, 19:09:48 »
Fantastic!
Why am I not surprised that the Professor has a Mac mini, RPi and Macbook Air - all great accompaniments to an HHKB.
Offline OfTheWild
Re: HHKB Pro 2 Love
« Reply #1077 on: Mon, 04 January 2016, 23:08:06 »
Thats really cool! Thanks for posting it up.
-Dana
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #1078 on: Mon, 04 January 2016, 23:20:10 »
Great stuff! Wish one of the community questions would've been about which switch he preferred between the OG HHKB and the current variation.
Re: HHKB Pro 2 Love
« Reply #1079 on: Mon, 04 January 2016, 23:21:41 »
ctrl + f "demik wants you to adopt him" 0 of 0 found
much disappoint
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1080 on: Mon, 04 January 2016, 23:44:19 »
Yep me too.
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1081 on: Tue, 05 January 2016, 12:05:17 »
ironed landing pads from EK
I don't know about the type s feeling but from i ve watched on youtube, i prefer the silenced modded HHKB
Mine looks pretty similar to this although its modded in 55g
The only thing i dislike on my silenced mod, its keys feels like having little friction on some keys when you type softly and try to not bottom out
Ha, i thought the back of those hands looked familiar. Maybe there is something to that saying...
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1082 on: Tue, 05 January 2016, 20:22:09 »
Just need some artisan to make my board end game hhkb :p. Trying to sold this board but in the end I can't part away with this board, silly me said that custom will be better than hhkb  :))
Offline Ryukuxyz
  • VE.A!!!
Re: HHKB Pro 2 Love
« Reply #1083 on: Tue, 05 January 2016, 21:22:27 »
Picked up one of these last month. Absolutely love it; it's my new daily driver. The layout is literally perfect for me with dip switches 3 and 5 on.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1084 on: Tue, 05 January 2016, 21:24:27 »
You should get hasu controller to make it better  ^-^
I use the BT one and couldn't be any happier  :thumb:
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1085 on: Tue, 05 January 2016, 21:28:03 »
I had one and never used it. Still have the controller somewhere around here. The layout just didn't need any further changes as far as i was concerned. Great product though.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1086 on: Tue, 05 January 2016, 21:43:46 »
I use it because I use dvorak so whenever I use someone else computer I don't need to change setting in the computer just plug and play  :p
Offline jerue
  • (Whenever that happens :P)
Re: HHKB Pro 2 Love
« Reply #1087 on: Tue, 05 January 2016, 21:49:00 »
*still wants to buy KMAC and 5k  :rolleyes:
As much as I want to debate trying out a HHKB again I don't think I can deal with the plastic :(
I'd probably go 55g and if possible acquire a silenced Realforce or 2 for the sliders.
Aluminum RF > all
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1088 on: Tue, 05 January 2016, 21:52:36 »
Aluminum RF > all
Yep i've decided to keep topre. I never tried alu realforce because the case is near impossible to find  where do you find yours? Yep 5k and custom or model f to finish my addiction  :p
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1089 on: Wed, 06 January 2016, 03:20:45 »
I want to ask you guys do your hhkb make some spring sound? cause mine does
Re: HHKB Pro 2 Love
« Reply #1090 on: Wed, 06 January 2016, 04:00:17 »
When typing?  Nope.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1091 on: Wed, 06 January 2016, 04:14:27 »
When typing?  Nope.
fixed it. Its because the screw on the pcb are not screwed nicely
Re: HHKB Pro 2 Love
« Reply #1092 on: Wed, 06 January 2016, 04:15:11 »
When typing?  Nope.
Easy fixes are good :D
Offline ajx
Re: HHKB Pro 2 Love
« Reply #1093 on: Wed, 06 January 2016, 04:56:21 »
Tightening screws until you feel a resistance right?
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1094 on: Wed, 06 January 2016, 04:59:15 »
Yep
Offline DaveW
  • zer0knowledge
Re: HHKB Pro 2 Love
« Reply #1095 on: Wed, 06 January 2016, 08:26:47 »
I bought my HHKB second-hand and the only flaw that I've seen is this broken middle tab on the front of the case. It doesn't affect the device at all but I'd like to fix it if I can. What would be the best way to repair this?
    • KeyChatter
Re: HHKB Pro 2 Love
« Reply #1096 on: Wed, 06 January 2016, 08:56:09 »
Id start with just a touch of epoxy.
Offline meow a cat
  • Resistance is futile.
Re: HHKB Pro 2 Love
« Reply #1097 on: Wed, 06 January 2016, 09:00:10 »
My lovely HHKB.  :-*
Boards:
Offline heedpantsnow
  • Old enough to know better
Re: HHKB Pro 2 Love
« Reply #1098 on: Wed, 06 January 2016, 09:20:02 »
Be careful with any glue that is low-viscosity. Like don't use super glue. Some good two-part epoxy, mixed together, then applied with a toothpick would work I think.
I'm back.
Offline DaveW
  • zer0knowledge
Re: HHKB Pro 2 Love
« Reply #1099 on: Wed, 06 January 2016, 12:08:03 »
Thanks guys. I figured it would be some type of epoxy but was worried about using the wrong thing.
