Author Topic: What's Bothering You? (The thread about what is bothering you.)  (Read 7785958 times)
0 Members and 9 Guests are viewing this topic.
Re: What's Bothering You? (The thread about what is bothering you.)
« Reply #2200 on: Thu, 05 February 2015, 23:47:36 »
demik being a hater? so unexpected! so edgy!
« Reply #2201 on: Thu, 05 February 2015, 23:59:03 »
totally.
Offline Sygaldry
  • Edema Ruh
« Reply #2202 on: Fri, 06 February 2015, 00:00:47 »
I'm bothered by the fact that I submitted an incremental source file for my MP (Comp Sci class) and got 10% docked because one of my functions didn't work properly in that version (the final version that I failed to submit was 100% working).
I'm an idiot for naming the incremental file the same as my final version. I really need to work on file and folder naming and organization.... I did this last semester too and vowed to not let it happen again. Lo and behold, it happened again one semester later... agh!
I'm going to be bothered by this until my TA gets back to me with a response =(
null
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #2203 on: Fri, 06 February 2015, 01:08:18 »
Waiting for my package to arrive, even though it's perfectly on time. My lack of patience is disturbing.
Offline clacktalk
  • circa 2015
« Reply #2204 on: Fri, 06 February 2015, 01:11:10 »
totally.
hug me im sry i asked u 2 fite me
i don't own u. u do u bb
diary of a clacktalk
radio_killah: too much frank
Offline Jokrik
« Reply #2205 on: Fri, 06 February 2015, 09:14:11 »
Ate too much for dinner
I can hardly breath
Offline Nai_Calus
  • CLACK
« Reply #2206 on: Fri, 06 February 2015, 10:16:30 »
Right now my cat is bothering me.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
  • Live long and prosper
« Reply #2207 on: Fri, 06 February 2015, 10:38:23 »
demik is a truther...
it's not his fault we can't handle the truth...
tp thread is tp thread
« Reply #2208 on: Fri, 06 February 2015, 19:48:59 »
Coat hangers.
Every time you try to pickup just one from the pile, half the rest of the come up too in a big hooked together mess.
Try to shake the one you want loose, and a couple of them will fall down te back of some inaccessible piece of furniture.
Try to pull it loose and it will be bent out of shape.
Every time.
« Reply #2209 on: Fri, 06 February 2015, 20:07:32 »
printer decided to drop the network. GREAT.
Offline jacobolus
« Reply #2210 on: Fri, 06 February 2015, 20:43:30 »
Coat hangers.
Every time.
Easy solution: stop using metal coat hangers.
Offline FreeCopy
« Reply #2211 on: Fri, 06 February 2015, 20:49:05 »
Coat hangers.
Every time.
Whoa, whoa! That's a pile of spare car keys, depending on vehicle age that is.
Edit: This is what's bothering me or actually making me a bit angry - "Expected Delivery Day: Thursday, February 5, 2015"
« Last Edit: Fri, 06 February 2015, 21:22:41 by FreeCopy »
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
« Reply #2212 on: Fri, 06 February 2015, 22:20:47 »
Coat hangers.
Every time.
I have a wardrobe full of them.  I used to live near a row of clothes shops, and they used to throw out thousands of wire clothes hangers at a time.
Supplied for life.
Something else that is bothering me is this air-conditioner.
Today is 32 degrees outside, and 31 degrees inside.
Inside temperature has gone up 3 degrees since I turned the air-conditioner on.
Offline jorgenslee
« Reply #2213 on: Sun, 08 February 2015, 00:39:54 »
I'm bothered because my Sprit 60% is experiencing a problem and it's been my daily driver. I'm about to build my backup keyboard but the lube has not arrived yet. Should I build it with lube(mx clear + 62g spring)? or wait for the lube?
Offline Asininity
« Reply #2214 on: Sun, 08 February 2015, 00:59:29 »
I think I'm graduating with the wrong degree.
« Reply #2215 on: Sun, 08 February 2015, 11:55:22 »
Coat hangers.
Every time.
Supplied for life.
My room and several others at my school have the heater stuck on full so we control the room temp by opening the window. -10C and windy is a pretty good for AC system.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #2216 on: Sun, 08 February 2015, 12:30:04 »
Coat hangers.
Every time.
Supplied for life.
Compressed air also works if you want to turn the heater up.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #2217 on: Sun, 08 February 2015, 20:27:37 »
Insomnia, **** mattress, allergies, putting off cleaning my filthy office.
« Reply #2218 on: Sun, 08 February 2015, 20:29:55 »
Offline Veridis
« Reply #2219 on: Sun, 08 February 2015, 22:48:49 »
I bought a Ducky Shine 3 in Orange LED because the local store I bought from were not going to be restocking them.
Now every time a key lights up in reactive typing mode, I am reminded by the fact that I didn't get the color I wanted.
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
Offline Lastpilot
  • Power stance
« Reply #2220 on: Sun, 08 February 2015, 22:50:06 »
Anticipating what the Orion V2 will look like. It's killing me. I would be happy even if it's just a unicorn.
« Reply #2221 on: Mon, 09 February 2015, 00:31:51 »
Shipping my first international package tomorrow and I'm scared I screwed something up even though it looks all good.
« Reply #2222 on: Mon, 09 February 2015, 00:32:43 »
rip
« Reply #2224 on: Mon, 09 February 2015, 00:43:58 »
rip
Yep  :(
where is it going?
only problem i've ever had (wasn't my fault, it was the idiot that gave me his address wrong) was to singapore (i think) other than, everything has arrived fine.
as long as you copy/paste the address correctly you should be good.
« Reply #2225 on: Mon, 09 February 2015, 00:45:45 »
rip
Yep  :(
where is it going?
Canada, as I said everything looks good but I'm still worried. I just don't want a Bro to disappear in the mail.
« Reply #2226 on: Mon, 09 February 2015, 00:52:22 »
oh canada?
man, you're good.
« Reply #2227 on: Mon, 09 February 2015, 01:05:04 »
Lol, canada isn't international :)
Don't even worry. Bubble mailer with tracking is pretty cheap and no worries. USPS becomes canada post over the border and tracking works fine.
Offline FreeCopy
« Reply #2228 on: Mon, 09 February 2015, 05:38:22 »
The hydraulic on my chair is going out. Just randomly drops all the way down. Not sure if I should try to repair it or use this as an excuse to replace a ~5year old chair.
Keyboards
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #2229 on: Mon, 09 February 2015, 05:48:41 »
I'm there with you man, i did a super ass ghetto fix that i'm unhappy with till i can afford something worth while buying rather than buying cheap **** chairs every year or so.
GON NerD TKL DTA Edition
« Reply #2230 on: Mon, 09 February 2015, 10:15:55 »
Replace. Craigslist a leap or aeron
Offline iri
« Reply #2231 on: Mon, 09 February 2015, 10:28:36 »
trying to figure out how to bring a small container of drugs into the UK.
-Ray Bradbury
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #2232 on: Mon, 09 February 2015, 10:30:34 »
rip
Yep  :(
where is it going?
I shipped a gasmask without shipping to Australia, and it was fine, and another to Renfrewshire in the UK, but there were 2 cities listed, so I had to decide which city was more important, so I chose Renfrewshire and I guess it got there fine.
« Reply #2233 on: Mon, 09 February 2015, 10:36:32 »
Only way is to do them before boarding. All of them.
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #2234 on: Mon, 09 February 2015, 11:16:49 »
Rogers. **** everything about Rogers.
**** them so hard.
Offline jackalope
  • Now with 20% more soul.
« Reply #2235 on: Mon, 09 February 2015, 11:24:29 »
I have to sell my collection of boards and keys to raise some money, but I can't decide if i want to keep my Filco mj2 or my HHKB.
eh o well
« Reply #2236 on: Mon, 09 February 2015, 11:26:08 »
HHKB, at least if you type as much as I do. If you game a ton I prefer MX.
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #2237 on: Mon, 09 February 2015, 11:28:15 »
Truth. I finally sold my MJ2 a few months ago (or more) and kept my HHKB. Very happy with that. Then again, I might be lying a bit since I game with a Poker II with MX blacks.
Tough call on that. I guess it depends like Joey Quinn said. I use my HHKB 90% of the time, but I mostly work instead of playing now.
Offline jackalope
« Reply #2238 on: Mon, 09 February 2015, 11:31:03 »
That's the way i'm leaning, problem though is that the HHKB is worth more, and I enjoying gaming on it just as much as i do typing.  It's really become my endgame board.
eh o well
« Reply #2239 on: Mon, 09 February 2015, 11:37:14 »
If you need money and really like the HHKB that much, I'd just keep it and hope that topre is your "endgame", if that is even a thing.
Offline jackalope
« Reply #2240 on: Mon, 09 February 2015, 11:49:01 »
Haven't thought about buying another board in months sense I started using it, love the thunk lol. I think I may just keep the HHKB, at least something decent comes out of me getting rid of my collection, i'll have some bros to sell at retail to preferable broless.
eh o well
« Reply #2241 on: Mon, 09 February 2015, 11:53:02 »
It sucks that you have to sell stuff but at least you'll get to spread some artisans. Also thanks for not marking up the caps.  :thumb:
« Reply #2242 on: Mon, 09 February 2015, 12:04:34 »
Contract jobs. Especially when they have nothing for you 3 straight weeks. Niggas gotta pay rent!
Offline radio_killah
  • Chinchillin'
« Reply #2243 on: Mon, 09 February 2015, 12:09:23 »
The fact that I got like $1000 in keyboard stuff up in the air right now. Its all group buys and keycaps and I know they take time but it sucks having to wait 3+ months after giving away your money to see any results.
Offline iri
« Reply #2244 on: Mon, 09 February 2015, 12:20:29 »
so glad i am white.
-Ray Bradbury
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #2245 on: Mon, 09 February 2015, 12:22:42 »
If it makes you feel any better, I did too, and I'm just fine. I picked my major when I was 17, and I have always maintained very few 17 year olds can accurately predict what they want to do for a career. I was so off base it wasn't even funny!
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2246 on: Mon, 09 February 2015, 15:22:45 »
people stirring up **** for the sole purpose of causing drama
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #2247 on: Mon, 09 February 2015, 15:24:35 »
so glad i am white.
Right there with you. I haven't paid rent since I was born, thanks to my skin tone!
« Reply #2248 on: Mon, 09 February 2015, 15:29:42 »
Welcome to DramaHack!
« Reply #2249 on: Mon, 09 February 2015, 15:31:16 »
shut your white ass up
