Author Topic: LightSaver V2 Group Buy  (Read 721315 times)
Offline taylordcraig
Re: LightSaver V2 Group Buy
« Reply #750 on: Tue, 29 July 2014, 16:29:33 »
So is round 1 + 2 pcbs different for the 1800 layout? or could i get a new plate and resolder my v1?
Offline elton5354
« Reply #751 on: Tue, 29 July 2014, 16:32:06 »
Yes, V2 PCB is different than V1 PCB.  The only difference I think is 1800 layout compatibility.
« Reply #752 on: Tue, 29 July 2014, 16:44:07 »
Oh darn. I don't like the short right shift but I do like the idea of squeezing a full numpad in there. Might just have to shift mine over and half a 1u "+" or "enteR" on the numpad.
Offline elton5354
« Reply #753 on: Tue, 29 July 2014, 16:52:35 »
Anyone know the right way to install stabilizers? Starting from which way to put together the black stabilizer standoffs..lol
Offline keyit
« Reply #754 on: Tue, 29 July 2014, 16:57:35 »
stick the black slider into the housing making sure to orient the correct way. stick wire into the slider then clip the wire into the slider housing. do this for both ends of wire then insert into pcb. idk if this was what you were asking though lol. you can tell which way the slider enters the housing by looking at the bottom of the two, unless you clipped the sliders then it might be a lil more difficult to tell.
Edit: i know this is a lubing tutorial, but it also demonstrates how to assemble it near the end. (skip to cherry stabs of course)
« Last Edit: Tue, 29 July 2014, 17:00:35 by keyit »
boop
« Reply #755 on: Tue, 29 July 2014, 17:01:37 »
Elton, I use this photo as a reference:
From here
That should at least clue you in to which way those two pieces fit together.  And from there, the "non-clipping" part (the one that slides in to the PCB rather than snaps in) goes in the bigger of the two holes.  Does that make sense?
Offline elton5354
« Reply #756 on: Tue, 29 July 2014, 17:09:40 »
Thanks keyit and hoff.  Got it.  It's easier to assemble it first then install it on the PCB.  It was kind of hard to find that hole for the wires to go in the standoffs.  I think the wire is a tiny bit bigger than that hole.
« Reply #757 on: Tue, 29 July 2014, 17:22:11 »
I had trouble my first few encounters with those stabs. ^.~ Had one in backwards and my key wouldn't press. :<
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #758 on: Tue, 29 July 2014, 17:29:39 »
From here
Clip those little landing feet off too! I can't stand that mushy feeling you get from them!  :mad:
« Reply #759 on: Tue, 29 July 2014, 17:30:43 »
From here
Glad you mentioned that.  ;)  I clip mine, so I would have probably clipped yours anyway without thinking.  :P
  • Kitteh Overlord
  • Say WHAAT...
« Reply #760 on: Tue, 29 July 2014, 17:45:53 »
From here
AH YEAH! BTW I sent everything off yesterday 2 day mail... should be there tomorrow...
Offline domoaligato
« Reply #761 on: Tue, 29 July 2014, 18:21:39 »
From here
I noticed a noticeable difference on my custom board after doing this. It makes it much better. But you might inquire with the users on if they have a preference...
I have actually read some people here that like the cushion during the pushin...
  • Kitteh Overlord
  • Say WHAAT...
« Reply #762 on: Tue, 29 July 2014, 20:11:25 »
From here
Offline elton5354
« Reply #763 on: Tue, 29 July 2014, 20:13:26 »
The screws are way too small.  I may need to buy a new torque screw driver that is small enough.  Or are there alternative screws?
Offline elton5354
« Reply #764 on: Tue, 29 July 2014, 20:45:17 »
Missing screws and few keys. I want to put coloured arrow keys and enter key from EK. Maybe get that later.
Offline Ronnn
« Reply #765 on: Tue, 29 July 2014, 20:52:27 »
Almost finished. Anyone know how many brightness levels are there? Why I only have 2 levels(1 on 1 off)?
Offline elton5354
« Reply #766 on: Tue, 29 July 2014, 21:15:36 »
- Notes about LED modes:
by default, they are on Function Layer #3, which means press the MFN button 3 times in a quick succession to get to the 3rd function layer, and on the third time hold it and press a number associated with the area on the keyboard you want illuminated (alternatively, if you bind FN3 to some key, press FN3 + number)
1 = Function row LEDs
2 = Modifiers + number row
3 = Alphas
4 = Numpad
5 = Side LEDs
To cycle through different lighting modes, you can press those keys repeatedly.  For example holding down FN3 (or having pressed MFN 3 times and holding it), you can keep pressing "3" to cycle through lighting modes for the alphas.  Here are the lighting modes, in a cycle:
  • All ON
  • All OFF
  • Breathing with longer dark periods
  • Breathing with short dark periods (basically the opposite of the other kind of breathing, if you want to have 2 sections breathing exactly out of sync)
  • Reactive ON (off until you push a key, then that section turns on briefly at maximum set brightness)
  • Reactive OFF (on until you push a key, then that section turns off briefly)
  • Breathing mode where speed varies based on typing speed--starts off breathing quickly then slows dramatically until you begin typing
  • Breathing mode where speed varies based on typing speed--reverse of the above (breathing out of sync)
  • OFF until you begin typing, then the section turns on gradually the faster you type.  Fades back to off once you stop typing.
LED brightness level can be varied with LED D[ow]N and LED UP keys, on the same function layer #3 by default
Offline Ronnn
« Reply #767 on: Tue, 29 July 2014, 21:30:11 »
3 = Alphas
4 = Numpad
5 = Side LEDs
  • All ON
  • All OFF
I know how to change brightness or cycle through different modes, my question is that for brightness level, it seems that there are only two levels. Pressing led dn key while leds are on will go directly to off, pressing led up key while leds are off will go directly to maximum brightness.
Offline domoaligato
« Reply #768 on: Tue, 29 July 2014, 22:23:04 »
have you updated the firmware? maybe the firmware that came with it is not the latest version?
http://duck0113.tistory.com/84
this thread has the info in the first page
http://geekhack.org/index.php?topic=53942.0
Offline bianco
« Reply #769 on: Tue, 29 July 2014, 22:25:40 »
great looking v2s!
Offline domoaligato
« Reply #770 on: Tue, 29 July 2014, 22:35:07 »
does anyone happen to have close up shots of the blockers? I am curious how they attach.
I did not notice that in the OP or I would have ordered a bunch of them. :(
Offline bianco
« Reply #771 on: Wed, 30 July 2014, 00:02:14 »
it sits on top of the space for the switch.
and screwed in place at the bottom.
Offline domoaligato
« Reply #772 on: Wed, 30 July 2014, 00:13:25 »
this is exactly what I was hoping feng could have the fmj guy make. but in 1x 1.25x and 1.5x... HHKB and Winkeyless blockers for all...
edit : that is a nice pic sir. :)
Offline sakai4eva
« Reply #773 on: Wed, 30 July 2014, 00:40:28 »
F5, F5, F5, F5, F5, F5, F5, F5, F5, F5, F5, F5, F5, F5.
« Reply #774 on: Wed, 30 July 2014, 15:34:57 »
I know that feel.
Offline sakai4eva
« Reply #775 on: Thu, 31 July 2014, 10:40:21 »
Elton, will Duck be open to making additional plates in the future?
Offline Ronnn
« Reply #776 on: Thu, 31 July 2014, 20:15:25 »
 :-[ I am still having problem with the led brightness control (only two levels). FYI, I am using the latest firmware.
Can someone tell me how many brightness levels are there?
I think the leds I am using may be the cause of the problem. What's the preferred voltage range for the leds?
EDIT: BTW, I think I find a bug: the number lock indicator lignt would stay the same after I press the led ctrl key to turn off the leds. And when the leds are off, the num lock light cannot be swithced on/off, but the caps lock light can. Not really a big problem.
« Last Edit: Thu, 31 July 2014, 20:21:41 by Ronnn »
« Reply #777 on: Fri, 01 August 2014, 02:27:41 »
haha did you find a buyer if you can get a diff plate?
had a similar problem...
@elton: any chance?  :-*
Offline sakai4eva
« Reply #778 on: Fri, 01 August 2014, 06:42:15 »
Not really. I like the 1800 layout (actually might be more perfect for me than any other layouts) but I'm curious because some of my endgame caps might not fit on this thing otherwise :(
Offline bianco
« Reply #779 on: Fri, 01 August 2014, 08:18:49 »
different plate with slots for switch top removal! i'm in!
Offline Blackehart
« Reply #780 on: Fri, 01 August 2014, 11:29:18 »
YUSS!
GOT ONE!
*does the Humpty Dance*
« Reply #781 on: Fri, 01 August 2014, 17:16:26 »
I have a v1 right now. I think I would really like a v2 with 1800 layout.
Offline sakai4eva
« Reply #782 on: Sun, 03 August 2014, 21:25:23 »
It's here. Pressing F5 does make the delivery man faster :)
Actually, it was here since last Thursday but I was working from home until today :)
Offline Blackehart
« Reply #783 on: Thu, 07 August 2014, 10:07:17 »
How often are tracking numbers added?  :p
Offline elton5354
« Reply #784 on: Sat, 09 August 2014, 19:02:42 »
It will be shipped out once they're all assembled.  It is easier for them to ship the keyboards out all at once rather than individually one by one.  Again, I apologize for the delay.
Offline LechnerDE
« Reply #785 on: Sun, 10 August 2014, 00:36:25 »
I don't mind waiting a little longer :)
I just hope they put a "decent" value on the shipping box, otherwise I'll have to pay a little fortune :(
Offline Blackehart
« Reply #786 on: Wed, 13 August 2014, 11:04:00 »
It's like waiting for christmas :p
Offline Zombly
  • Zombie Enthusiast
« Reply #787 on: Wed, 13 August 2014, 11:29:24 »
Agreed, I just want it naow, I'd beat a child for one today. :)
In the process of my custom Zombie board
[WTB MX Zombro's]
« Reply #788 on: Thu, 14 August 2014, 01:30:22 »
Hey guys. I'm holding a V1 in hand. I want to trade for a V2 or, I'll straight up buy your V2 off you. [I want that 1800 layout!]
Great chance for someone to switch up who was caught off guard by 1800 layout.
Thanks for your time.
edit2: found out a v2 pcb + plate can fit in my v1 case; willing to trade just pcb+plates
Offline Blackehart
« Reply #789 on: Mon, 18 August 2014, 15:08:50 »
*pokes thread*
Is this thing on?
 ;D
Offline elton5354
« Reply #790 on: Tue, 19 August 2014, 20:55:22 »
I've got news that the sets are all assembled now.  If you have to update your address, tell me NOW.  They will start shipping by next week.
Offline witbliz
« Reply #791 on: Tue, 19 August 2014, 20:56:27 »
Best news of my week !! Wished there was pictures to see.. Can't imagine how long I wanted this
Offline elton5354
« Reply #792 on: Tue, 19 August 2014, 22:35:00 »
Here are the pictures of the assembled sets..
http://kbdlab.co.kr/index.php?document_srl=449172&mid=board_hDJd48
Also,
To adjust the brightness:
You can find the MFN key.
To adjust LED brightness you keep pressing MFN + LED UP(or LED DOWN)
Please make sure you keep pressing the key for a while.
« Last Edit: Tue, 19 August 2014, 22:38:21 by elton5354 »
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #793 on: Tue, 19 August 2014, 22:56:42 »
Also,
Amazing!!!!! I can't believe he/they built these so quick! I wasn't expecting to see pics this soon  :eek: :eek:
Thanks Elton! :thumb: :thumb: :thumb:
Offline Blackehart
« Reply #794 on: Tue, 19 August 2014, 23:12:36 »
JOYGASM!
« Reply #795 on: Wed, 20 August 2014, 01:29:01 »
Quick reminder that I'm dying to throw cash at someone for their V2.
I'll even pay you to trade me PCB/Plates/WholeUnits for my V1.
Offline LechnerDE
« Reply #796 on: Wed, 20 August 2014, 02:38:46 »
Nice preview of mine:
Is the upper right LED malfunctioning or isn't it supposed to light up?
Offline bianco
« Reply #797 on: Wed, 20 August 2014, 02:41:08 »
it's the indicator light for which layer that is active
Offline LechnerDE
« Reply #798 on: Wed, 20 August 2014, 02:54:54 »
Ah ok, thanks for clarifying  :thumb:
Offline dragonken
« Reply #799 on: Wed, 20 August 2014, 05:41:40 »
It's mine. :cool:
