Author Topic: LightSaver V2 Group Buy  (Read 721207 times)
Offline cirrus82
Re: LightSaver V2 Group Buy
« Reply #1000 on: Sun, 02 November 2014, 19:03:46 »
I finally set mine up this weekend!
The only problem I'm encountering is that the scroll lock is not working on my Mac.  This works on other keyboards, it looks like the keycode might be the wrong one (odd as it works on my PC).
I need to have scroll lock work as I went with the layout without dedicated arrow keys (need them on my numpad).  I was wondering if I could fake a scroll lock by using some kind of a function toggle key but I don't see that in the mapper for the LightSaver v1.x, I do see one in the v1.9a but the keyboard didn't work after I flashed it with that. Back to a v1.x one and it works, but still no scroll lock in Mac.
Did anyone run into this?
I haven't tested this or encountered this problem but have you tried the trick of setting your windows localization to korean? It's what was preventing some people from having functioning arrows and I suspect the scroll lock might be the same issue.
If you've already tried forgive me and contrats on your lightsaver.
Thanks! I don't think that's the issue, however.  The key gets set properly (and I can see it in the keymapper tool) it just seems to not work on the Mac side.  It does work in Windows.  I'm wondering if there's a more ubiquitous keycode that is sent for the numlock that other keyboards use.
It's strange, on my Mac side the Numlock key is coming through as the Clear key (You can get this on Windows with Numlock Off + Numpad 5).  I've hooked it up to two different version of OSX and both are doing the same thing.
Offline cirrus82
« Reply #1001 on: Mon, 03 November 2014, 15:14:34 »
Alright, upon further investigation it definitely seems like this is a Mac issue, and I guess I remembered wrong because none of my custom boards have a working Num Lock on Mac!!
Is there any way to toggle a function layer on? I see that the 1.9a firmware has a FN TOGGLE switch option.  Is there any way to do that with the 1.x? I could basically make my own Num Lock mode like this.  I don't want to have to keep the Function key pressed...
Offline gogusrl
« Reply #1002 on: Mon, 03 November 2014, 15:47:31 »
any way to buy just the pcb from somewhere or a clonepcb with similar layout ?
Offline taylordcraig
« Reply #1003 on: Tue, 04 November 2014, 07:44:09 »
This I can help you with!
For clarity sake, Lightsaver has Layer 1, 2, 3, 4 and Layer FN 1, 2, 3.
Edit:
Ly 1-4 will set your keyboard to Layer 1-4 respectively.
If you set your Num Lock to "Ly 2" and then on Layer 2 set Num Lock to "Ly 1" I believe you'll get the effect you're looking for.
Layer TG is layer toggle.(not sure how it works) Layer CH is layer change.(Pretty sure it moves to the next layer. Ly+1)
MFN is the key you're looking for.
(old info kept for others to see)
Info for others.
If you hold MFN you access the Layer FN 1.
MFN, I have concluded, stands for multi-function.
If you press the MFN key twice, and hold it on the second press, you access Layer FN 2;
on the third press, you get Layer FN 3.
Offline cirrus82
« Reply #1004 on: Tue, 04 November 2014, 15:08:10 »
Edit:
Info for others.
Awesome, thanks! I'll be giving this a shot tonight, will report back :)
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #1005 on: Tue, 04 November 2014, 15:24:58 »
How do you get back to Layer 1 with the MFN key?
If today had been a hippo, then you'd really have to worry about tomorrow.
« Reply #1006 on: Tue, 04 November 2014, 19:45:56 »
MFN functions much like a regular function key.
While holding it down[after a single press] you're on Layer FN 1, when you let go you're on whatever normal layer you left off on.
If you were on Layer 2 and used single-press-MFN you'd still be on Layer FN 1.
You can't navigate the regular layers with MFN, just the FN layers.
Offline cirrus82
« Reply #1007 on: Tue, 04 November 2014, 21:49:04 »
Edit:
Info for others.
Works! Awesome!! Thanks for the help.
Offline Sniping
« Reply #1008 on: Wed, 05 November 2014, 04:11:18 »
Does anyone know how I can stop that blinking light? I have no idea how to turn it off.
Offline elton5354
« Reply #1009 on: Wed, 05 November 2014, 10:27:56 »
Maybe this?
There are 2 modes in which that LED can be:  either blinking every 2 seconds to let you know which layer you are in at all times or you can change it to only show you the layer number when changing into that layer, and then that LED will remain off until the next layer change.  To switch between these two modes:
LLB: default LED Blink mode (every 2 seconds)
LLN: "Normal" LED mode (off until changing layers)
  • Enter Control Mode (press the C/M button); the Layer Status LED should be lit now without blinking
  • type LLN (or LLB) and press Enter
  • Exit Control Mode by pressing Esc
Offline bazemk1979
« Reply #1010 on: Tue, 11 November 2014, 16:58:20 »
wondering when will next GB be for this board again
Offline tjweir
« Reply #1011 on: Tue, 11 November 2014, 19:40:44 »
Yes, this layout looks rad. I missed the first round as well.
Offline deci
« Reply #1012 on: Tue, 11 November 2014, 23:12:09 »
Same, this is my most wanted keyboard.
Offline Chedda7
« Reply #1013 on: Tue, 11 November 2014, 23:23:37 »
Also interested in getting in on a GB for this.
Offline feizor
« Reply #1014 on: Tue, 11 November 2014, 23:33:53 »
If another GB happens I'm all in. But I'm also keen to see what Duck comes up with next after the Octagon 75%.
Offline elton5354
« Reply #1015 on: Thu, 13 November 2014, 17:58:46 »
For those who ordered the acrylic inserts, I'll have them shipped next Friday or so.
Offline Sniping
« Reply #1016 on: Thu, 13 November 2014, 20:08:31 »
Crap, forgot to pay for mine...
Offline elton5354
« Reply #1017 on: Thu, 13 November 2014, 20:23:56 »
« Reply #1018 on: Fri, 14 November 2014, 17:02:15 »
Elton you should talk to duck, there's probably at least 20 people on GH that want lightsavers.
Offline radio_killah
  • Chinchillin'
« Reply #1019 on: Fri, 14 November 2014, 17:44:48 »
Craigs got the right idea.
Offline deci
« Reply #1020 on: Fri, 14 November 2014, 17:46:34 »
My wallet is ready...
Offline animaliaparadoxa
« Reply #1021 on: Fri, 14 November 2014, 17:49:57 »
I really do think there's the demand for another group buy.
Offline Elocutive
« Reply #1022 on: Fri, 14 November 2014, 18:06:01 »
I'd get in on most likely
LZCE- Black, red, ergo clears
Wanting Skeldon
Offline witbliz
« Reply #1023 on: Sat, 15 November 2014, 01:54:31 »
Hi elton can i buy the inserts for my lightsaver v2 since you have extras. u were supposed to invoice me but it didnt happen...
Offline jorgenslee
« Reply #1024 on: Sat, 15 November 2014, 02:12:46 »
He never invoiced someone for the inserts. He asked before to send the payment as gifts to his paypal account.
Offline witbliz
« Reply #1025 on: Sat, 15 November 2014, 20:21:51 »
Thanks for the info.. Must have missed it. Are there any extras for purchase ?
Offline elton5354
« Reply #1026 on: Sat, 15 November 2014, 21:31:14 »
Send me a PM with your address and name and what you want and i'll add you to the list..
If you can't send gift payments, I guess I can send you an invoice.
Offline elton5354
« Reply #1027 on: Sat, 15 November 2014, 21:46:35 »
As for another group buy for the lightsaver v2s, they want at least 30 orders to even consider.  I'm not sure if we can get that many.  30 may fill in the order form, but will they all pay..?
  • Chinchillin'
« Reply #1028 on: Sat, 15 November 2014, 22:48:09 »
Shall we create an IC thread than?
« Reply #1029 on: Sat, 15 November 2014, 23:36:29 »
I'd maybe be in for a PCB and plate depending on the price, if thats an option. I want the 1800 layout for my V1 case.
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #1030 on: Sat, 15 November 2014, 23:51:30 »
Count me in for paying. I've been making threads everywhere trying to find this board, so I'm definitely good for the money.
Mmm... machined aluminum
Offline gogusrl
« Reply #1031 on: Sun, 16 November 2014, 01:03:31 »
Plate and pcb for me as well.
« Reply #1032 on: Sun, 16 November 2014, 09:51:28 »
@elton: thank you for the info.
Yeah 30 is a lot of full kits. I'll try an IC after the new year when everyone's wallets have recovered from Christmas.
I think we could get 30 orders next spring, might even get another one myself.  :rolleyes:
For everyone interested, hold your breath until the new year and we'll see if we can't round up 30 people in February/march.
  • Chinchillin'
« Reply #1033 on: Sun, 16 November 2014, 10:09:29 »
I am perfectly good with that. I'm sure most people will be too!
Offline bazemk1979
« Reply #1034 on: Sun, 16 November 2014, 10:30:23 »
that sounds good, let all wallets recover a bit ;)
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #1035 on: Sun, 16 November 2014, 11:11:36 »
Sounds splendid.  :thumb:
Offline Chedda7
« Reply #1036 on: Sun, 16 November 2014, 15:33:08 »
Seems a few people, including myself, are interested in a PCB+Plate combo.  Would a GB for just those items be possible?  This would drive the cost down and make it easier to manage (I assume since I have no experience doing this).  A lower price on a unique (and amazing) layout would probably entice more members to join.
Offline kennyk64
« Reply #1037 on: Sun, 16 November 2014, 19:13:41 »
Hi Elton, if you have extras can you send me an invoice too? Thanks!  :)
Poker II  Shine II  Realforce 87u
Offline bazemk1979
« Reply #1038 on: Mon, 17 November 2014, 12:54:08 »
dude not just pcb and plate.... we want the case too cause it looks bad ass
Offline deci
« Reply #1039 on: Mon, 17 November 2014, 12:55:51 »
Yeah this sounds good!
That or we can keep our fingers crossed for a V3 lol
Offline Sygaldry
  • Edema Ruh
« Reply #1040 on: Mon, 17 November 2014, 13:17:34 »
This.
Will have spent 900 dollars on keyboards this month, could definitely use the break!
null
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #1041 on: Tue, 18 November 2014, 01:01:34 »
Just expressing interest for the next round.
This is something I've wanted 100% and won't back out on, due to it being a completely unique layout :thumb:
That said, what are the chances of an upgrade to RGB LEDs and stuff like that, or hard anodized cases?
I feel that it would really add value and desirability to an already great keyboard.
Elton, what are the chances of pushing it to a LightSaver V3 with these additions?
« Last Edit: Tue, 18 November 2014, 01:04:37 by Karura »
Offline witbliz
« Reply #1042 on: Tue, 18 November 2014, 06:45:15 »
Hi Elton . pmed u my address n email for invoice :) thank u
Offline elton5354
« Reply #1043 on: Tue, 18 November 2014, 07:12:12 »
I PM'd you if it's for one set of lightsaver v2 inserts..
Regarding another round of lightsavers, maybe in several months.
Offline feizor
« Reply #1044 on: Tue, 18 November 2014, 17:33:14 »
Sweet!  Time to start saving
Offline tjweir
« Reply #1045 on: Wed, 19 November 2014, 08:53:25 »
Great timing, my wallet will be ready.
« Reply #1046 on: Wed, 19 November 2014, 10:05:50 »
The reason I believe is mostly that duck does not want to offer just pcbs and plates.
They were an add-on to the full group buy last time. I believe it is encouraged to buy a full kit.
That said, there were DWGs available on his site to have your own acrylic case cut, so maybe PCB/PLATE was always intended.
Regardless, I'll be PMing each and every one of you [being everyone expressing interest thus far] come the start of Feb.
Offline bazemk1979
« Reply #1047 on: Wed, 19 November 2014, 19:54:45 »
once again, passing new years is a good idea in hopes people will recharge their walletts
Offline witbliz
« Reply #1048 on: Thu, 20 November 2014, 10:48:11 »
Hi Elton. Yes the inserts are for my light saver version 2 .. Do you have inserts for three butterfly pad as well ? I'll buy one set of each than you
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #1049 on: Thu, 20 November 2014, 11:44:31 »
I would really like another shot at the light pads.
|||My other keyboards :
x
