Author Topic: LightSaver V2 Group Buy  (Read 737833 times)
Offline elton5354
Re: LightSaver V2 Group Buy
« Reply #850 on: Fri, 05 September 2014, 15:17:27 »
I just received and quickly install everything. By default it's all LEO turned on. Would any1 tell me how to toggle LED mode in v2? I cannot locate the MFN button -_-!
MFN button should be on the right of F12. Hold it and press F6 (+?) F7 (-?).
TrueCustom is going to translate the instruction over the next few days.  If it's not working after the translation, I'm going to lend him my LS2 for him to fix the problem, if that helps.. He said none of the Koreans have problem with it, so it should just be a translation problem. Let's see. :)
just got LS2 as well , however i would like to know what screws does those blockers use ? it didn't come with my package. Anybody able to let me know where can i buy them ?
I'll let you know
EDIT: They are M3x5mm screws.
« Last Edit: Fri, 05 September 2014, 15:25:23 by elton5354 »
Offline Jokrik
« Reply #851 on: Sat, 06 September 2014, 07:18:35 »
Thx for making this happen Elton ! :)
Lightsaver v2 + Caps by hansen_oe, on Flickr
Lightsaver v2 Night + Caps by hansen_oe, on Flickr
Offline dragonken
« Reply #852 on: Sat, 06 September 2014, 22:43:36 »
It's mine together with Orion TKL. Again great thanks to Elton.
Offline Fnzzy
« Reply #853 on: Sun, 07 September 2014, 19:59:08 »
The key mapping software is not very good at this time - I gave it a couple of tries, but in the end decided to use TMK firmware.  Highly recommend using that if you're comfortable with the process of editing config files in text, building via Makefile/GCC and flashing using FLIP.
Why is the Duck software bad and why is the TMK firmware better? I'm asking because I am getting my Duck Viper soon and want to do the right thing.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #854 on: Sun, 07 September 2014, 21:19:11 »
Just try both and decide which you like more.
Offline SL89
« Reply #855 on: Sun, 07 September 2014, 21:21:31 »
 :'( one day... one day ill get one!  :))
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #856 on: Mon, 08 September 2014, 19:13:18 »
I received my LS2 and I'm also curious about how to change the led brightness/modes. I tried the steps you posted to adjust the brightness but it doesn't work. Looking forward to the translated instructions to see if that helps any. Thanks again Elton =)
Offline dragonken
« Reply #857 on: Mon, 08 September 2014, 22:03:33 »
It doesn't work. I think I should flash a custom firmware to enable the MFN button.
Offline WinterIsle
« Reply #858 on: Tue, 09 September 2014, 07:02:30 »
MFN key doesn't do any thing with brightness/LED modes.
You just need to have Different LED modes keys, LED Ctrl and LED Up/Dn on desired layer.
Hold LED Ctrl and press any LED modes that u wish to control the brightness, after that just press and hold LED Up/Dn for a few seconds u will observe brightness increases/decreases.
Offline digi
  • elite af tbh
« Reply #859 on: Tue, 09 September 2014, 09:47:22 »
My LS2 was assembled so I'm not sure which layers are what..or even how to switch layers for that matter. Do you happen to know what the default LED Ctrl / LED Modes & LED Up/Dn keys are? thanks.
Offline sakai4eva
« Reply #860 on: Tue, 09 September 2014, 10:29:00 »
Elton, I was under the impression that the new plate supports the 1800-layout. Mine doesn't seem to be able to do so...
Please stop ignoring my PMs. This is getting a little distressing :(
Offline elton5354
« Reply #861 on: Tue, 09 September 2014, 11:07:03 »
Show a picture of your plate...
What PMs? You only PM'd me once and it was about the firmware which I addressed here.
The 1800 plate is the one on top.
« Last Edit: Tue, 09 September 2014, 11:14:56 by elton5354 »
Offline sakai4eva
« Reply #862 on: Tue, 09 September 2014, 12:04:40 »
Offline blighty
« Reply #863 on: Tue, 09 September 2014, 14:02:23 »
http://imgur.com/LxXu8s2
That looks like the older plate.
Question:  My + and - keys on the numberpad (in 1800 layout) are giving the same scancodes (P+ 107 on the 02d keymapper, and 0x6B, BIOS 0x4E on EK's Switch hitter software).  Is this a glitch? Or just how it was programmed by who built it?
Also, the board feels great to type on.  Thanks for running this elton!   Did anyone else put a pad between the the pcb and the case?  I used the foam material that the case was wrapped in to get rid of as much air space as possible.
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline sakai4eva
« Reply #864 on: Tue, 09 September 2014, 21:14:25 »
Frick! I checked the option for the new plate :(
This sucks...
@elton, is there any remedy for this, or will I now have to cute my own plate?
Offline moemoe666
  • Silence Unicorn <3
« Reply #865 on: Tue, 09 September 2014, 21:34:52 »
When I try to keymapping the Light saver, I got the runtime error 53 - File not found
02D_KeyMapper_Custom
any help?
Stuff:
Black Bird V1: Clear 72g - Light Saver V2 : Black 62g  - Rosewill : Vintage Black - 38gt Acrylic case : Brown 55g - Ducky Z One : Brown - Keycool Brown: R.I.P
Zowie EC2 Evo Black & White - SS Sensei MLG - SS Frost blue - Kana V1 - Kinzu V1
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #866 on: Tue, 09 September 2014, 21:54:56 »
any help?
Are you running it as an administrator?
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline elton5354
« Reply #867 on: Tue, 09 September 2014, 22:20:51 »
Here's a tutorial for the layout editing tutorial. Hope this helps.
@sakai4eva I'll let them know.
  • Keyboard Hipstar
« Reply #868 on: Tue, 09 September 2014, 22:30:09 »
Where can one download KeyMapper v1.5.334_RGB?
The highest version I can find is v1.5.333
EDIT: Nevermind, had some trouble navigating the site in Korean.
Quick question, is there something I need to enable in Windows to get the arrows to show up in the keymapper?
Is it like a problem displaying the character?
Because they're just question marks.
« Last Edit: Tue, 09 September 2014, 22:50:49 by StylinGreymon »
Offline sakai4eva
« Reply #869 on: Tue, 09 September 2014, 22:35:01 »
Thank you. Please save this keyboard. I've already been paid for it and I hate to deliver a something I think is incomplete, not to mention the buyer also agreed to pay for an additional Tsangan kit just to make it work in 1800-layout.
Also, as an alternative, I wouldn't be partial to getting the specs/schematics for the plate, as I believe I can get a local cutter to do it for me, but it's going to cost money :(
Offline digi
  • elite af tbh
« Reply #870 on: Tue, 09 September 2014, 22:39:01 »
Where is FN1~FN3 by default in layer 1? Or, if anyone knows of a way to download the current firmware from the lightsaver and view the key mappings that would be helpful as well. I only see 'Firmware Upload' in the O2D KeyMapper, no option to download. Nevermind, I just remapped the layout and flashed the firmware.
Does anyone know what the MFN button does? It appears to do the same function as FN1?
« Last Edit: Wed, 10 September 2014, 00:00:42 by digi »
  • Keyboard Hipstar
« Reply #871 on: Tue, 09 September 2014, 23:09:11 »
Ah, if I change the locale to Korea, the arrows show up, and I can map them.
Offline animaliaparadoxa
« Reply #872 on: Wed, 10 September 2014, 00:05:56 »
The locale? In windows for character encoding?
  • Keyboard Hipstar
« Reply #873 on: Wed, 10 September 2014, 00:09:25 »
See image:
In other news, macros are still beyond me.
Offline digi
  • elite af tbh
« Reply #874 on: Wed, 10 September 2014, 00:26:38 »
ok, I think I got layers working now, pretty cool stuff but I pretty much have to figure out what does what by flashing it and trial/error, lol. Thanks for the Locale tip Stylin..
Offline elton5354
« Reply #875 on: Wed, 10 September 2014, 00:27:59 »
Can you send the link please?
I think so. MFN (Miscellaneous FN?)
« Last Edit: Wed, 10 September 2014, 00:29:34 by elton5354 »
  • Keyboard Hipstar
« Reply #876 on: Wed, 10 September 2014, 00:32:28 »
Here:
http://kbdlab.co.kr/index.php?document_srl=309373&mid=board_sw
It's near the bottom.
Anyone get text or action macros working?
Offline digi
  • elite af tbh
« Reply #877 on: Wed, 10 September 2014, 00:40:21 »
Here:
What's the RGB version for?
Offline sakai4eva
« Reply #878 on: Wed, 10 September 2014, 00:44:17 »
Here:
At work now, so I don't have access to the Lightsaber (disassembled and left at home pending the plate confusion), but I can open the keymapper.
Caveat: I have only programmed text macros so far, but I think action macros should run on the same principal.
Using the latest 02D mapper software;
1. Tools > Static Macro Editor (at the top menu bar)
2. Check the "Macro Index" option on the middle right, and make sure the macro number is the one you want to edit/program
3. Click "Load"
4. Edit the macro.
5. Click "Apply"
It should work at this point, because I have programmed my text macros the exact same way.
I'd post pictures, but work Internet has decided to block imgur. If there's still confusion, I'll look for alternatives.
@elton; can we continue the plate discussion via e-mail or PM? I don't check threads that often anymore :(
« Last Edit: Wed, 10 September 2014, 00:45:53 by sakai4eva »
Offline elton5354
« Reply #879 on: Wed, 10 September 2014, 00:48:36 »
Yes, I'll PM you an update when I receive news on it.
Btw, can you please stop using that emoticon on every post? It's getting annoying...
Offline sakai4eva
« Reply #880 on: Wed, 10 September 2014, 00:55:45 »
Not sure if serious, but ok. Thanks for all the help.
  • Keyboard Hipstar
« Reply #881 on: Wed, 10 September 2014, 00:56:26 »
Here:
Looks like it has support for RGB switches.
I only grabbed it because it was a higher version number.
Offline WinterIsle
« Reply #882 on: Wed, 10 September 2014, 03:13:03 »
I think the RGB version of 02D firmware is for rgb backlit under the pcb by jumping wires, I have only seen korean done this demo on Orion PCB with Unicorn housing. The light effects are awesome  :thumb: .
Offline Zombly
  • Zombie Enthusiast
« Reply #883 on: Wed, 10 September 2014, 07:39:07 »
Got mine yesterday!, won't be building it fully till I move in 10 days, anyone got any ideas for a black/green themed keycap set, or any other ideas I have the silver base also need to buy a usb wire.. thinking going with Zeal's green and black
In the process of my custom Zombie board
[WTB MX Zombro's]
Offline Jokrik
« Reply #884 on: Wed, 10 September 2014, 09:51:20 »
Have you checked out Toxic set?
It would take sometime to find one now though
Offline FrostyToast
  • Litshoard
« Reply #885 on: Wed, 10 September 2014, 10:19:34 »
I second this. There are still rumors floating around about the toxic r2 right?
Quote from: elton5354
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #886 on: Wed, 10 September 2014, 11:53:31 »
R2 DSA I hope, I hope, I hope...
« Reply #887 on: Wed, 10 September 2014, 13:28:48 »
Any link to the demo? I'm curious but I don't understand how it's done.
Offline digi
  • elite af tbh
« Reply #888 on: Wed, 10 September 2014, 13:35:17 »
Does anyone know exactly how the FNLayer's work? I can't figure out how it knows that on FNLayer1 that it should perform LED Brightness only but on FNLayer3 it knows to dance through the various lighting schemes while keeping in mind that I only see one set of LED commands in the firmware which are already assigned in FNLayer1.
Offline Zombly
  • Zombie Enthusiast
« Reply #889 on: Wed, 10 September 2014, 14:18:05 »
I did check it I was waiting for Mr. Buns to pm me if there are any extras though due to problems with that GB I'm still waiting, looking to pick something up temporarily until I get used to the layers as it's my first custom keyboard been using a Logitech/wireless Logitech forever haha
[WTB MX Zombro's]
Offline WinterIsle
« Reply #890 on: Wed, 10 September 2014, 17:02:49 »
There's a link above shared by StylinGreymon  ;)
Offline dragonken
« Reply #891 on: Thu, 11 September 2014, 00:06:32 »
Thanks Elton.
I follow the guideline and I am now able to flash the firmware for my Orion and Lightsaver.
P.S.
- I feel the v1.5.333 keymapper is better than the RGB one. It has better LED toggle keys.
- Use Applocale to open the keymapper can show the correct arrow keys.
Offline dragonken
« Reply #892 on: Thu, 11 September 2014, 00:55:36 »
Hold the FN1 (which is assigned in your current layer, say Layer 1) + press LED UP or LED DN (which is assigned in FNLayer1) to adjust LED brightness.
Hold the FN3 (which is assigned in your current layer, say Layer 1) + press LED Func (which is assigned in FNLayer3) to change the LED mode of your F-keys.
etc...
MFN key is useful to trigger FN key. E.g. press MFN three times within a second and then hold it = directly hold FN3.
So that you can use 1 single key (MFN) to perform FN1 - FN3 keys.
« Last Edit: Thu, 11 September 2014, 00:57:38 by dragonken »
Offline digi
  • elite af tbh
« Reply #893 on: Thu, 11 September 2014, 13:02:17 »
etc...
Hey dragonken, I understand how that part works (thank you btw) I just don't understand how the Lightsaver knows that FNLayer1 functions as LED Ctrl & LED Brightness only, but on FNLayer 3 it knows to perform LED Patterns, eg. pulse, etc.
In the keymapper software I only see the LED Ctrl w/ Brightness Up/Dn. How does FNLayer3 know to control the LED Patterns? Is that hard-coded into the PCB Controller ?
Offline blighty
« Reply #894 on: Thu, 11 September 2014, 15:15:29 »
Finally figured out my file save problem (default file name not windows friendly), and the firmware that it came with had multiple keys flashed to the same key (hence my 2 Number pad "+ triggers).  I've been getting exercise carrying it around in my backpack, using it with my Surface Pro 2.  I've already got some scratches on it, and will just let that happen.  I like my gear having some wear and tear on them.  :thumb:
potato pic:
76803-0
Thanks again!
Offline sakai4eva
« Reply #895 on: Thu, 11 September 2014, 21:01:20 »
potato pic:
Thanks again!
Ah... we have similar plans :)
Offline digi
  • elite af tbh
« Reply #896 on: Fri, 12 September 2014, 11:36:43 »
Oh man, I love layers! Elton, I just want to thank you for putting up with all my questions and following through on everything. Thanks again for running this successful GB <3 I love my Lightsaver!
Offline elton5354
« Reply #897 on: Fri, 12 September 2014, 12:47:38 »
If anyone is having trouble creating macros, TrueCustom is translating the instruction for it atm.  I'll post it when it's ready.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #898 on: Fri, 12 September 2014, 12:53:23 »
potato pic:
Thanks again!
  • Keyboard Hipstar
« Reply #899 on: Fri, 12 September 2014, 13:18:13 »
Awesome.
I think I got text macros to work one time, completely by accident, and never again.
