Author Topic: LightSaver V2 Group Buy  (Read 737708 times)
Offline Blackehart
Re: LightSaver V2 Group Buy
« Reply #900 on: Fri, 12 September 2014, 16:46:16 »
Oh yeah!
How do we go about getting them fancy acrylic doodads for the side thingiemajigs?
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #901 on: Fri, 12 September 2014, 21:34:08 »
Is there a way to map media keys (volume up/down) or is the mapping option for media keys in the software for Mac's only? I have Winders.
« Last Edit: Fri, 12 September 2014, 21:36:27 by digi »
Offline blighty
« Reply #902 on: Sat, 13 September 2014, 14:43:54 »
Anyone know if the 02D keymapper software can enable usage under BIOS?
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline Blackehart
« Reply #903 on: Mon, 15 September 2014, 18:31:57 »
ok, so...
The default led toggles are INS and F6 and F7?
I'm not getting anything when I hold down INS and press and hold F6 or F7.
I haven't flashed anything, this is still default. I just popped on some keys to test it.
Offline blighty
« Reply #904 on: Mon, 15 September 2014, 19:36:12 »
ok, so...
I don't think there is a "default" led control.  I was only able to adjust the LEDs once I had set buttons for the various functions (I put the light controls in the FN layers).
Offline digi
  • elite af tbh
« Reply #905 on: Mon, 15 September 2014, 19:39:08 »
flash it with the o2d keymapper software, the layers used in their default '02D Lightsaver Custom v1.x' will get you started..
Offline Blackehart
« Reply #906 on: Mon, 15 September 2014, 20:15:13 »
well, i tried a link that elton suggested a few pages back, but i can't get the o2d mapper to connect...
Offline digi
  • elite af tbh
« Reply #907 on: Mon, 15 September 2014, 20:17:08 »
Did you download the Guide that Elton posted on page 29?
Offline Blackehart
« Reply #908 on: Mon, 15 September 2014, 20:26:02 »
yes.
I think my issue is that i need to remap and save before i do that.
But I have no idea how to do a correct mapping or one that makes sense.
Could someone perhaps share their hex?
I just need access to the led modes and such, dont care for macors and other stuffs.
EDIT: im on a winkey layout, with insert, delete,home, end, page up and page down going from left to right after the F12 key.
Thanks in advance,
-Blacke
« Last Edit: Mon, 15 September 2014, 20:42:40 by Blackehart »
Offline digi
  • elite af tbh
« Reply #909 on: Mon, 15 September 2014, 20:45:30 »
yes.
Thanks in advance,
-Blacke
Try to map FN1 & FN3 on Layer 1 instead of using the MFN key, let me know if that works.
If that doesn't work, pm me a pic of your layout and I'll make a .hex file for ya.
« Last Edit: Mon, 15 September 2014, 20:55:11 by digi »
Offline Blackehart
« Reply #910 on: Tue, 16 September 2014, 10:52:20 »
Digi is the man!
Also, how bout them acrylic side pieces?
Anyone know a shop or somebody that sells them?
Offline taylordcraig
« Reply #911 on: Tue, 16 September 2014, 10:57:54 »
Digi is the man!
Someone was looking at getting them made for v1 and v2 a while ago. Cant remember who.
Someone should figure it out!
Offline elton5354
« Reply #912 on: Wed, 17 September 2014, 10:42:51 »
I think I can do it from my secret source. Will be shipped to me and I will distribute it. Not sure about cost yet.
Offline LechnerDE
« Reply #913 on: Wed, 17 September 2014, 10:50:21 »
My Lightsaver was delivered today!
I won't be home for another 3 weeks, so I can't even test it :(
Feels like torture  :p
Offline dragonken
« Reply #914 on: Fri, 19 September 2014, 21:08:31 »
I found one minor bug in the v1.5.333 keymapp. If all LEDs are turned off by the 'LED CTRL', the num lock key LED cannot light on.
I have to turn on the LED by 'LED CTRL' -> press num lock key twice to get it back.
dragonken
« Last Edit: Fri, 19 September 2014, 21:10:53 by dragonken »
Offline digi
  • elite af tbh
« Reply #915 on: Fri, 19 September 2014, 21:12:37 »
dragonken
yes, I noticed the same result.
Offline seedvd
« Reply #916 on: Sun, 21 September 2014, 23:52:25 »
Whoo! I ordered a  Lightsaver V2 today from GB outside of this site.
Offline animaliaparadoxa
« Reply #917 on: Mon, 22 September 2014, 00:02:03 »
And where would that be? If you don't mind telling.
« Reply #918 on: Mon, 22 September 2014, 00:45:48 »
yeah, is this legit?
i mean i have mine pretty close to secured [minus my funds D:] but that seems interesting, maybe I could use another case or pcb....
« Reply #919 on: Mon, 22 September 2014, 00:52:11 »
edit LOL
Offline bianco
« Reply #920 on: Mon, 22 September 2014, 01:01:50 »
grabbed a colepack and deep beats. added 1 more of space bar to my order
i think you meant to post this in the pulse gb
Offline feizor
« Reply #921 on: Mon, 22 September 2014, 01:09:15 »
Hmm guy with 5 posts suggests external site.
Offline seedvd
« Reply #922 on: Mon, 22 September 2014, 02:16:35 »
Yeah, it is for real. Take a look at the GB: http://kbdlab.co.kr/index.php?mid=board_gb_do&document_srl=412282.
« Reply #923 on: Mon, 22 September 2014, 02:41:34 »
anyone speak korean help me out here?
is it possible to order just a case/plate/pcb? i might get a couple more parts
Offline seedvd
« Reply #924 on: Mon, 22 September 2014, 02:50:17 »
I am waiting for his reply if i can give you his email. I'd be glad to help you. Just wait. He said he has few left.
Offline cyberwave
« Reply #925 on: Mon, 22 September 2014, 06:36:12 »
do share! been looking for 1 all this time!
Offline seedvd
« Reply #926 on: Mon, 22 September 2014, 12:09:46 »
I am sorry to tell you that he is not able to take orders this time because there is no left now.  I think I am the last person to take last one.
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #927 on: Tue, 23 September 2014, 17:41:54 »
In regards to the keymapping software, is there a way to choose which character resides on the 'shift layer'? (I dunno what you actually call it)
Take ;: for example.
Is there a way to make it so I have to press shift for ; and have : be the default?
Currently I achieve this just fine with xmodmap, so it's no big deal, but it'd be great to have a keyboard-side solution.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline digi
  • elite af tbh
« Reply #928 on: Tue, 23 September 2014, 17:44:44 »
I think what you might be looking to do is put : on layer 1 & ; on layer 2 then just map the layer toggle or layer number to any key you want, does that work?
  • Keyboard Hipstar
« Reply #929 on: Tue, 23 September 2014, 17:57:00 »
That seems a little unwieldy...
It'd throw off all my layers a little.
If that's the solution, would that mean that I'd need to set every secondary character like that?
Offline digi
  • elite af tbh
« Reply #930 on: Tue, 23 September 2014, 18:06:50 »
I haven't had a chance and tinker with macro's in the software but that might be what you're looking for?
  • Keyboard Hipstar
« Reply #931 on: Tue, 23 September 2014, 18:15:23 »
I haven't been able to get macros working at all with my Light Pad, and I won't have another Duck board to try them on until I get my Viper, so I dunno if that'll work.
Thanks for trying to help, though :)
Offline Blackehart
« Reply #932 on: Wed, 24 September 2014, 11:28:33 »
*poke*
*poke*
Them acrylic pieces...
MUST HAZ!
Offline elton5354
« Reply #933 on: Wed, 24 September 2014, 22:28:27 »
I can get the side inserts for $4 a pair.  I'll make an order form tomorrow.
Only normal ones, not sand blasted (frosted) ones.
Offline tuantruong
« Reply #934 on: Wed, 24 September 2014, 22:54:57 »
May we have options for lightsaver v1 and orion?
Offline elton5354
« Reply #935 on: Wed, 24 September 2014, 23:00:47 »
I'll cover all their keyboard that can use the inserts.
Offline witbliz
« Reply #936 on: Wed, 24 September 2014, 23:05:36 »
Thank u Elton !
Offline tuantruong
« Reply #937 on: Thu, 25 September 2014, 00:48:43 »
Sweet, thanks Elton. :thumb:
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #938 on: Thu, 25 September 2014, 09:25:52 »
Yay! Orion here we come!
|||My other keyboards :
x
Offline elton5354
« Reply #939 on: Thu, 25 September 2014, 09:40:43 »
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #940 on: Thu, 25 September 2014, 09:44:11 »
Done!
x
Offline elton5354
« Reply #941 on: Thu, 25 September 2014, 09:45:29 »
Each set comes with 2 inserts, so if you put 2 you will get 4.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #942 on: Thu, 25 September 2014, 09:50:27 »
That's the idea. ;)
I will be trying to frost one set myself using sandpaper and patience.
x
« Reply #943 on: Thu, 25 September 2014, 09:50:53 »
Filled out the form.    :thumb:
Excited to see the insert GB get rolling.  :)
Offline tuantruong
« Reply #944 on: Thu, 25 September 2014, 10:08:04 »
Found an instruction about frosting the clear acrylic  :p
http://www.instructables.com/id/Music-LED-Light-Box/step3/Frosting-and-Diffusing/
Offline digi
  • elite af tbh
« Reply #945 on: Thu, 25 September 2014, 10:08:45 »
chea!
Offline Blackehart
« Reply #946 on: Thu, 25 September 2014, 10:49:43 »
SCORE!
Offline LechnerDE
« Reply #947 on: Thu, 25 September 2014, 11:00:59 »
What's the major advantage of these inserts?
Is the light spread better? Can somepne provide comparison pics please?
I am not sure if I need these for my Lightsaver V2  :p
Offline digi
  • elite af tbh
« Reply #948 on: Thu, 25 September 2014, 11:06:58 »
For dat swag lyfe, Lechner!
Offline elton5354
« Reply #949 on: Thu, 25 September 2014, 11:08:05 »
You can see the difference in photoelectric's album.
https://m.flickr.com/#/photos/photoelectric_effect/sets/72157640117516876/
