Author Topic: CMStorm Switch Tester - LED Mod  (Read 14310 times)
Offline infiniti
  • I <3 KB
  • Bob was here
« on: Thu, 08 May 2014, 08:06:28 »
I discovered that my 10-month old son likes playing with and "typing" on my QFR.  This was fine until rotation day came and he kept wanting to play with it even while it was on my desk.
The solution?
Get him his own keyboard.  No.  Not the FaceW. :p
The Board
I started off with a CMStorm Switch Tester.  Many thanks to Carter for helping me get this!
Opening up the CMStorm Switch Tester
The easiest way to open the case is by prying it from the front.
Ta-dah!
Stripped down:
Switches
I swapped out the switches with Cherry MX Blues (silver switch stickers, sprit 55g gold springs, and abostudio clear switch top covers) so that they have a nice click to it.
Keycaps
At the suggestion of blackbox, I will glue the keycaps to the stems to avoid any accidental removal and/or swallowing of keycaps.  That would be a little embarrassing to explain at the ER.
I have some colored translucent polycarb keys from SP on the way.
'got the colored translucent polycarb keys from SP. Thanks to asdfjkl36 for the proxy! :thumb:
Setup will be red, orange, blue, green, yellow, and clear. :thumb:
P.S. This was easier than having to find different color LEDs and have to deal with resistors.
Wiring <-- weird kerning between the "W" and the "i" :'(
Here's the wiring diagram I used:
Here's the original one I conceptualized a few weeks back (WARNING: it's fugly):
Popped in the LEDs and got bending!
I bent the LEDs against the bottom switch housing to keep the LEDs in place.
It looked better before I added the wires... :-X
Reassembly
I had to remove one of the support pegs to make space for the battery.
It is that part in red that makes the case extremely difficult to open by prying from the rear of the case.
Snap it shut! :cool:
Testing
All buttoned up!
It works!
Testing Video
Pardon the sausage fingers..
I'll post another video when I get the colored polycarb keycaps.  In the meantime, I leave you with The Gang:
Updated Video with Polycarb Keycaps
Playtime:
I think it looks better with the GH keycap on it. ;)
« Last Edit: Tue, 20 May 2014, 05:09:41 by infiniti »
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: CMStorm Switch Tester - LED Mod
« Reply #1 on: Thu, 08 May 2014, 08:10:04 »
Awesome write-up, sir! I absolutely love your build logs.
« Reply #2 on: Thu, 08 May 2014, 08:10:30 »
Very awesome write up, thank you for sharing!!
« Reply #3 on: Thu, 08 May 2014, 08:12:13 »
Ha that's awesome. I bet you could sneak a Teensy inside and get it actually typing. But I like that LED mod regardless. Plus your pictures are great :D.
« Reply #4 on: Thu, 08 May 2014, 08:14:51 »
Ha that's awesome. I bet you could sneak a Teensy inside and get it actually typing. But I like that LED mod regardless. Plus your pictures are great :D .
Grendel did that http://geekhack.org/index.php?topic=50594.msg1154494#msg1154494
and there is this
http://www.pcwaishe.cn/thread-543318-1-1.html
« Last Edit: Thu, 08 May 2014, 08:16:29 by SpAmRaY »
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #5 on: Thu, 08 May 2014, 08:24:48 »
Whatt. That looks so cool. I wonder if this is possible with the qwer switch tester. I might give it a shot. :0
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #6 on: Thu, 08 May 2014, 08:34:12 »
Thanks guys! ;D
Ooh a Teensy mod!  Bookmarking that idea for future mods. :thumb:
« Reply #7 on: Thu, 08 May 2014, 08:35:43 »
Or or or? Make it complicated and have it driven off the TechKeys business card. One button for on, one for off, and one for an LED toggle :P
Offline osi
« Reply #8 on: Thu, 08 May 2014, 08:46:59 »
Very cool sir!
Offline asdfjkl36
  • blue shirt guy
« Reply #9 on: Thu, 08 May 2014, 08:54:39 »
Turned out pretty nice
 :thumb:
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #10 on: Thu, 08 May 2014, 09:53:00 »
I like your ideas!  But something like that would be deserving of its own project.  I'll PM you after my FaceW build and run some ideas by you if that's cool.
Very cool sir!
 :thumb:
Wait 'til you see it with the polycarb caps! ;)
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #11 on: Thu, 08 May 2014, 10:43:57 »
Such a cool dad! Great build log too, thanks for sharing  :thumb:
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline Grendel
« Reply #12 on: Thu, 08 May 2014, 13:52:44 »
Very nice !  :D
Here's a better writeup of what I did.
- I'm game !
« Reply #13 on: Thu, 08 May 2014, 19:17:00 »
Nicely done - both of you! :)
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #14 on: Fri, 09 May 2014, 01:59:15 »
Very nice !  :D
Very nice !  :D
Bookmarked for possible future use. :thumb:
Offline Razor Lotus
« Reply #15 on: Fri, 09 May 2014, 07:03:32 »
Is the case easy to open up after you've modded it to fit the batteries?
I suppose if it's for your kids you wouldn't want it to be easily opened up but as a novelty item, would it be difficult to change the battery? If it's difficult to do so, any way of making it easier to open but still allowing it to snap shut nicely?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #16 on: Fri, 09 May 2014, 08:55:01 »
Nope, there's no way a kid could open it with his bare hands.  It's rather difficult to open the case even for an adult.  I had to use a plastic pry tool...I tired one of those credit card type membership cards and messed it up.
Umm...changing batteries...umm...I hadn't really considered that. :( I'll probably find a way to pop in a rechargeable battery that can be recharged over USB or something.
It would be nice if it had a screwed on door underneath for AAA batteries likes children's toys.  Hmm...time to do some more thinking.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #17 on: Tue, 20 May 2014, 05:11:01 »
Updated the OP with pics and video with the colored polycarbonate keycaps from SP. :cool:
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #18 on: Tue, 20 May 2014, 09:07:11 »
Really really nice Indeed. I'm gonna try to do something similar with the qwer keys tester when I have the time !
« Reply #19 on: Tue, 20 May 2014, 09:10:50 »
Now make it make noise!! ;)
Offline blackbox
« Reply #20 on: Wed, 21 May 2014, 04:04:23 »
Very nice writeup! thanks for refering to me, it would have indeed been difficult to explain the situation.
The LAN table!
Offline James35
« Reply #21 on: Wed, 21 May 2014, 04:52:48 »
Outstanding. I'm really thinking of doing this for my son if I get the time.
Offline rosslerosa
  • MF DOOM
« Reply #22 on: Thu, 22 May 2014, 00:50:26 »
Amazing!
Offline KTKM
« Reply #23 on: Thu, 23 July 2015, 17:05:13 »
Where did you get that plastic wedge to pry it open?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #24 on: Thu, 23 July 2015, 19:48:01 »
Hmm...I'm not too sure.  It was just in a box of random things I've accumulated over the years.  I have a feeling it came with a screen protector as a squeegee type tool.
Offline KTKM
« Reply #25 on: Fri, 24 July 2015, 00:27:07 »
It's such a pain in the ass to open... did you pry only in the front in the middle?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #26 on: Mon, 27 July 2015, 10:18:06 »
Yeah it is even with the tool. :'(
Basically prying like this while pushing on the keycaps until it pops out.
