Author Topic: Unpopular Keyboard Opinions  (Read 2542350 times)
0 Members and 6 Guests are viewing this topic.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: Unpopular Keyboard Opinions
« Reply #4550 on: Fri, 08 November 2019, 08:11:02 »
Speaking of wobble...
I do not care about wobble, it's not a metric I give two ****s about as long as keys don't bind.
Thank you!  Of all the things to be anal about wobble doesn't even need consideration...
The reason to care about wobble is mostly sound related, and it also gives a certain "less premium" feeling to any board if you are a lighter typist. I understand the feeling you guys have if you aren't sensitive to that sort of thing though, it's one of the lower tier concerns on stock keyboards.
« Last Edit: Fri, 08 November 2019, 08:14:34 by DALExSNAIL »
Offline Straw
  • NIEWB
« Reply #4551 on: Fri, 08 November 2019, 08:22:56 »
Wobble makes the board feel less solidly made for sure.
Like it came out of a candy machine.
"Go confidently in the direction of your dreams. Live the life you have imagined."
-Henry David Thoreau
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #4552 on: Fri, 08 November 2019, 08:29:46 »
Plus it makes more rattle noise, and makes the board sound like white noise.
Offline Gampela
« Reply #4553 on: Sat, 09 November 2019, 10:16:09 »
EnjoyPBT's (and I guess this goes for GMK and many other makers too) alpha legends are a bit too large/bold, which make the keycaps look a bit comical. Also, to my eye SA, XDA, DSA or whatever set that center their legends look kinda "childish" for lack of a better word. I think Leopold really nails the legend aesthetics the best.
Offline HungerMechanic
« Reply #4554 on: Sun, 10 November 2019, 21:23:35 »
Gampela, I'm not sure your opinion is entirely unpopular. ePBT is known for printing their legends a little bold and comical (although 9009 R4 is getting closer to GMK). Saying that GMK is also too bold and near-comical is unpopular, but I agree with you. [I am typing this on GMK].
You're right about Leopold. Their doubleshots are very professional-looking, and most people agree. There's a reason their caps are called "God tier."
I also enjoy Varmilo, although the italics are somewhat controversial. My favourite keycaps - Leopold, Varmilo, and DCS, all have less-bolded legends. WYSE DCS was the nicest, in my view.
Offline mode
« Reply #4555 on: Sun, 10 November 2019, 23:49:06 »
Yup, I hope some day SP does a premium version of DCS, 1.5mm thick. I prefer the look of it to GMK.
Offline trombompoline
« Reply #4556 on: Mon, 11 November 2019, 04:13:37 »
Any clicky switch lighter than gateron green is unusable.
Typing on anything other than standard QWERTY is retarded unless you literally only use your computer. Even then alternate layouts aren't supported by anything.
« Last Edit: Mon, 11 November 2019, 04:19:15 by trombompoline »
Offline Gampela
« Reply #4557 on: Mon, 11 November 2019, 04:27:19 »
I have to admit I don't actually own any GMK sets and my previous inclusion of GMK was based entirely on falsely thinking that ePBT 1:1 copied their legend design from old Cherry/GMK sets. This is good to know. I guess the problem isn't too big since I didn't notice these differences from pictures. I just know I much prefer Leopold pd to ePBT (9009, R2 I think) when I compare them close by.
I've praised Leopold's makings here so many times I wonder if people start thinking I'm a paid shill. I just really like what they have got going on. I guess it's too much to ask for them to start selling separate kits with wide compatibility. Varmilo does have pretty nice variety of keycaps but I don't think I can go back to oem after getting used to sleeker profiles. Leopold's ss2 profile actually sits noticeably lower than cherry which is another thing I quite like.
« Reply #4558 on: Mon, 11 November 2019, 14:43:19 »
Oh, your assumption is right. As far as I can tell, ePBT is largely trying to mimic classic GMK. However, its dye-sub process was always 'runnier' or blurrier than GMK. It is closing in on GMK in legend sharpness, however. But there are other issues with their keycaps.
I actually like the feel of ePBT more than GMK, no matter if it is on MX Browns or Zealios. ePBT 9009 was using some very smooth-surfaced blanks that were still grippy. But the keycaps themselves were less consistent than GMK - some of them had flaring at the bottom, for example.
If you put an ePBT set on a big board, you can usually see the difference from GMK, which is more orderly and regimented. GMK is known for a higher degree of consistency in the keycap shape, and they don't warp or get tilted off-centre easily. If only the legends were a nicer font, like Gorton Modified.
I find the colouration of most Leopold keycap sets to be a bit dull, but that's understandable as they have to use PBT. The legends are amazing, though. Really set a standard for the industry. And the profile is truly something special. I wonder if the rumoured "Gateron profile" will beat it.
Offline Gampela
« Reply #4559 on: Mon, 11 November 2019, 15:34:03 »
There are definitely some inconsistencies on my ePBT set as well. My set has really rough bottom edges. It's actually so bad that you can easily see the roughness from above when using them. Makes me almost wonder if I should manually sandpaper them. Not really something you wish to do after dropping 100-150€ on them. This is especially weird since my blank gateron set has perfectly fine edges, which ePBT at least used to use as a keycap suplier to my knowledge. Maybe it was just one bad patch. The dye sublimation is pretty good on my set but there is some blurriness especially on longer words like "delete" and "insert".
Another thing I noticed is how scooped and barred F and J keys clanck differently when bottoming out on my normal south-facing non-led cherry switches. Really noticeable when using silenced switches. My Lepold set doesn't do this, but then again they don't seem to be using extra scooped homing keys.
Only thing I somewhat dislike about Leopold doubleshots is their slightly smaller size on xy axis leaving larger caps between the keys. Not a dealbreaker though.
By Gateron profile do you mean this one? https://www.kickstarter.com/projects/woo-dy/woo-dy-a-67-keys-mechanical-keyboard-that-is-breathing
« Reply #4560 on: Tue, 12 November 2019, 14:03:49 »
I've heard of keycap flaring on ePBT 9009 R2, and my R4 has it as well. According to some hobbyists, 'enthusiasts' are expected to undertake minor post-sale tasks with some Chinese parts, such as sanding down keycap flaring. Apparently, you have to do some work on them to get them to 'endgame' level or whatnot.
See, for example, this review of ePBT 9009:
https://brianlee.blog/2018/07/26/review-enjoypbt-9009/
However, the keycaps are not all perfect.
As seen in the photo above, the edges of the keycaps are pretty jagged and rough. In some cases, there are even extra PBT bits protruding outwards from the keycaps. Nothing that a file can’t solve, but I wish it were better. You get jagged edges with most PBT sets, even the more expensive ones like IMSTO Ural. However, the edges on /dev/tty are near perfect on every key and are the benchmark of PBT quality (as in the keycap itself, not the legends) to me so seeing burrs on the ePBT is off-putting.
Warping is a serious issue that past iterations of ePBT/Gateron caps and most PBT keysets face. In many cases, the long modifier keys and spacebars are so warped that even with the most well-lubed of stabilizers, they would cause an uneven depress and as such cause the stabilizer to rattle.
In the case of the ePBT 9009, warping is still an issue on the longer keys, but much less so. On the shorter keys like both shifts, backspace and enter, warping is a mild issue at best. The keys look relatively straight on all 3 axes and probably won’t cause an issue with your stabilizers.
I've heard that the way ePBT caps are shaped is also suboptimal for Zeal switches. Apparently, they slam into the switch housing, which undermines the silencing. I'll have to test this.
I'm going to be testing Leopold doubleshots on my Zilents eventually, after I'm done with GMK.
As for Gateron profile, that might be it. Only a little is known at this time.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #4561 on: Thu, 14 November 2019, 11:40:07 »
So that's what Epbt is!
Just my thoughts
« Reply #4562 on: Thu, 14 November 2019, 13:13:49 »
I wonder if the rumoured "Gateron profile" will beat [Leopold].
Gateron manufactures the plastic keycaps, that get printed and sold as EnjoyPBT. I dunno who does the printing, whether EnjoyPBT is a separate company or just a brand of Gateron's.
« Last Edit: Thu, 14 November 2019, 13:16:23 by Findecanor »
« Reply #4563 on: Thu, 14 November 2019, 13:28:19 »
Okay, but it turns out that we're talking about two different things here.
ePBT uses (or used to) Gateron blanks for their printing process. The Gateron blanks are well-liked, and represent good value. There have been some rumors that ePBT hasn't been using those blanks in recent batches.
There are a number of Chinese manufacturers who are distributing keycaps, and I've seen that some of the different companies seem to be using the same blanks, the same molds. Probably Gateron, but I don't have measuring equipment to tell. Again, some of the Cherry-profile keycaps from different dye-sub companies look like they are using the same molds.
The other issue, though, is the new 'Gateron profile,' which seems to be something new and unique. 'Gateron profile,' in this context, is not a reference to the Gateron blanks used by ePBT, but an entirely new profile that is property of Gateron. These keycaps are not commonly available yet, so details are scarce.
« Reply #4564 on: Thu, 14 November 2019, 13:56:00 »
I know about that one. But please express yourself properly!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #4565 on: Thu, 14 November 2019, 15:07:55 »
This is probably less of an unpopular opinion here, and more of one on DT, but I really do think MX for the most part sounds better. Could be a result of lack of cap selection, or me just never using lubed/modded alps, but the sound is just never as good for me. Especially for linears.
Offline Sintpinty
    • My Roblox Profile
« Reply #4566 on: Fri, 15 November 2019, 05:51:53 »
Cherry MX brown sound and feel terrible though.
Just my thoughts
Offline vegs
« Reply #4567 on: Fri, 15 November 2019, 08:12:38 »
hhkb 4 life
buy less
Offline Sintpinty
    • My Roblox Profile
« Reply #4568 on: Fri, 15 November 2019, 12:09:35 »
I don't understand this GIF
Just my thoughts
« Reply #4569 on: Fri, 15 November 2019, 12:23:47 »
How is it misunderstandable to you?
Offline Sintpinty
    • My Roblox Profile
« Reply #4570 on: Fri, 15 November 2019, 13:22:42 »
Oh, it says "wrong" D:
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #4571 on: Fri, 15 November 2019, 13:23:31 »
I can describe the feel and sound of cherry mx browns.
The sound is kinda like scratching against some plastic plunger, which is a horrible clack. The feel is kinda like cherry mx reds, except i have more accuracy.
Just my thoughts
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #4572 on: Fri, 15 November 2019, 14:51:44 »
I mean, tbh brown's aren't the example I'm speaking on, but they sound better than Alps to me still.
Alps are just so........Hollow? I think that's what it is, but I can't really say.
« Reply #4573 on: Fri, 15 November 2019, 16:36:43 »
Keycap selection has a considerable impact on the sound of MX Browns, though. That's why I put WYSE DCS on them. It's a deeper, lower-pitched clack. Even GMK sounds chittery on Brown, but WYSE is an improvement.
Offline VimLover
« Reply #4574 on: Fri, 15 November 2019, 19:12:17 »
1. Switches are personal preference and cherry switches and rubber domes are just as good as super lubed holy trash panda X zealios hand made switches.
2. The Microsoft Sculpt is more Ergonomic than Ergodox and other non sculpted split keyboards.
3. High end plastic like the HHKB is much better than aluminum. Better weight, better looks.
4. I lied in #1, Topre is the best switch.
« Reply #4575 on: Fri, 15 November 2019, 20:33:01 »
wow the topre circlejerk, so brave, controversial and unpopular!
Offline yui
« Reply #4576 on: Sat, 16 November 2019, 03:32:04 »
can't fault him, he loves vim, real programmers uses C-x M-c M-butterfly :)
(https://xkcd.com/378/)
Offline VimLover
« Reply #4577 on: Sat, 16 November 2019, 18:41:55 »
I would argue that it has become a fad to hate on Topre as an overpriced switch/expensive rubber dome. At least that's my read of the current meta.
Offline cicada
  • Formerly iamacicada
« Reply #4578 on: Sun, 17 November 2019, 07:28:47 »
Heavy keyboards are overrated.
Offline Sintpinty
    • My Roblox Profile
« Reply #4579 on: Sun, 17 November 2019, 08:24:43 »
I don't even program  :eek:
Just my thoughts
Offline treeleaf64
    • treeleaf64
« Reply #4580 on: Sun, 17 November 2019, 08:44:37 »
Only if they look bad :)
Everyone must pay the cat tax
Offline Sintpinty
    • My Roblox Profile
« Reply #4581 on: Sun, 17 November 2019, 12:30:49 »
I would rather like something that's light and portable.
Just my thoughts
Offline ergonaut
« Reply #4582 on: Sun, 17 November 2019, 16:37:28 »
Typing speed doesn’t matter.
Offline Sintpinty
    • My Roblox Profile
« Reply #4583 on: Sun, 17 November 2019, 19:47:31 »
*120 wpm noises*
Just my thoughts
Offline MMKB
« Reply #4584 on: Mon, 18 November 2019, 18:58:09 »
Yes!
(“Do you hear the people sing?”)
Offline cultofjosh
« Reply #4585 on: Tue, 19 November 2019, 04:09:12 »
Haha, emacs rocks! I own the domain correct.horse - guess which XKCD that's based on :)
Back to topic:
1) I don't get clacks or artisan keycaps
2) You CAN have too many 60% keyboards
3) I can't stand DSA (I have the one set that's based on star trek TNG, and I will never be using it again)
4) SA is far superior to DSA
5) You've got to be insane to try a 40% keyboard
Engage...
Offline yui
« Reply #4586 on: Tue, 19 November 2019, 04:41:24 »
Back to topic:
Engage...
you should not give away your password like that
and really i kind of think that those opinions are not that unpopular, at least i pretty much am the same way, will see with time if it changes
Offline Sintpinty
    • My Roblox Profile
« Reply #4587 on: Tue, 19 November 2019, 07:06:11 »
Back to topic:
Engage...
I don't even have password§ to show you
Just my thoughts
Offline cultofjosh
« Reply #4588 on: Tue, 19 November 2019, 12:43:04 »
OMG, I didn't get the joke for at least 30 seconds. I was confused. I guess I'm still tired, LOL.
I use a much longer passphrase for 1password and long random junk for almost every website. I know my email password too, but that's about it.
Offline Steezus
  • Keeper of Facts
« Reply #4589 on: Tue, 19 November 2019, 13:25:59 »
Icon + Text Modifiers > Icon-Only Modifiers
I didn't think this would be unpopular but I keep seeing more sets that have been coming out that use icon-only modifiers. I always think the backspaces look awkward with the tiny little arrow and all that empty space.
Offline yui
« Reply #4590 on: Tue, 19 November 2019, 14:22:35 »
Back to topic:
Engage...
that was not for you Sintpinty, you do not need to answer all and every post (especially if you have nothing to add)
Offline rxc92
« Reply #4591 on: Tue, 19 November 2019, 15:59:58 »
^ and please stop replying 5 times to one pose because you refuse to learn how to insert quotes. It’s really not difficult, just hit ‘reply’ and press ‘insert quote’ so you don’t crap every thread with a wall of responses.
Offline Sintpinty
    • My Roblox Profile
« Reply #4592 on: Tue, 19 November 2019, 20:06:52 »
Back to topic:
Engage...
Need to have most posts.
Just my thoughts
Offline VimLover
« Reply #4593 on: Fri, 22 November 2019, 14:36:40 »
Any programmer that is pressing a fn key to get to [](){}; (btw that's a valid C++ anonymous func) is insane. TKL is the way to go so you don't have your mouse falling off your desk, but there is such a thing as diminishing returns.
Offline Altis
« Reply #4594 on: Fri, 22 November 2019, 21:54:02 »
40% is worse yet -- need a function layer to get numerical digits.  :eek:
Offline Sintpinty
    • My Roblox Profile
« Reply #4595 on: Sat, 23 November 2019, 07:51:37 »
EWWW!
*looks at 60% rubbery-ish keyboard*
Just my thoughts
Offline Kevadu
« Reply #4596 on: Sat, 23 November 2019, 12:02:31 »
I feel like these super-small keyboards are more of a gimmick or novelty than anything.  Is anyone seriously doing work on them?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #4597 on: Sat, 23 November 2019, 14:30:28 »
There are arguments to be had that they are more ergonomic, depending on the layout and how you use them. Sysadmin I work with won't use anything over 60 after getting a 40%.
Offline MMKB
« Reply #4598 on: Mon, 25 November 2019, 12:23:13 »
Personal experience: 45% works for programming. I prob have spent 2 years on a JD45 at work. The hardest part is to remember where "$%^&" are. Later on I tried 40% but the lack of [{ and '" was too limiting for me.
Offline mode
« Reply #4599 on: Tue, 26 November 2019, 02:48:39 »
I honestly couldn't consider going less than TKL at work, and I'm happy on my full size AEK. Do you not use an IDE? switching my shortcuts to a smaller layout would be hell.
