Author Topic: eBay Germany discussion (was: [.de] A few Cherry finds)  (Read 103365 times)
Offline o2dazone
« Reply #100 on: Thu, 27 August 2009, 08:38:40 »
Quote from: sixty;112250
(I ran out of fingers)
I want to know what you used to hit the 11th key
...actually scratch that, I don't
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #101 on: Thu, 27 August 2009, 09:56:28 »
Try more keys in one row, that is usually the weak point of the old Cherry matrix. It seems to manage at least 5KRO though, which is better than what a regular revision 17 board (or 1196 OEM board) of similar vintage does (3KRO), so it may very well do NKRO. Seems like it isn't the only OEM version like that, the same reportedly applies to 1273 and 1286 as well.
Offline keyb_gr
  • Cherrified user
« Reply #102 on: Thu, 27 August 2009, 13:26:43 »
Quote from: ripster;112293
Please post if any Cherry keyboards pop up  that are black (the case, not the switch) and potentially have double shot keys.
That would be once in a blue moon. I think you have a far better chance of finding something (typically G81-1900/7000) on your side of the pond. "Serious" keyboards have been almost exclusively light-colored here.
Offline sixty
    • http://deskthority.net
« Reply #103 on: Fri, 28 August 2009, 02:13:26 »
Quote from: keyb_gr;112353
I agree, most Cherry boards don't come in black here. Even getting a current generation black G80 with English layout was hard.
In regards to the boards I got yesterday, some production dates:
G80-1212: 20th April 1989
G80-1000: 1x August 1990 (can't read the 2nd digit, rubbed off)
G80-3019: Unknown, this one has a fancy sticker with lots of hand written numbers on it inside. Maybe this has to do with the OEM customization.
PS: Should I move any further discussion regarding these boards (i.e more roll over tests, etc) to a more fitting topic? Maybe your "dating cherry keyboards" entry keyb_gr?
PPS: Maybe we can rename this topic to eBay Germany or something? Its not really only about Cherry anymore.
Offline keyb_gr
  • Cherrified user
« Reply #104 on: Fri, 28 August 2009, 02:45:16 »
Quote from: sixty;112476
Sounds like a good idea.
I tried, but it seems editing the title of the first post is not enough.
Offline lowpoly
« Reply #105 on: Tue, 01 September 2009, 05:24:40 »
Quote from: keyb_gr;111483
Looks like a Model M, might be a rubber dome version though - ends tomorrow
Turned out to be a regular gray label BS with a cable in very good condition. Just needs cleaning.
Offline sixty
« Reply #106 on: Tue, 01 September 2009, 05:40:53 »
Quote from: lowpoly;113598
Congrats. Very nice score :)
Offline huha
« Reply #107 on: Wed, 02 September 2009, 18:24:43 »
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline keyb_gr
  • Cherrified user
« Reply #108 on: Thu, 03 September 2009, 07:44:37 »
Some new G80 or G81 in original packaging, ending soon
Seems like G80-1501s are quite sought-after, as  this and this one show. Apparently they're still of value to the medical folks, otherwise they'd be a good candidate for a NKRO board on the cheap.
G80-11900
Offline molto
    • http://www.friv.gs
« Reply #109 on: Thu, 03 September 2009, 08:12:02 »
« Last Edit: Thu, 03 September 2009, 08:14:18 by molto »
y8 | Miniclip | y3 | friv | ben10 | y8 | kizi | y8 | y3  | y8 | pogo
Offline huha
« Reply #110 on: Sat, 05 September 2009, 08:44:39 »
Still no bids on this one yet? Keys seem to be 2-shot judging from the high contrast on the picture.
-huha
Offline keyb_gr
  • Cherrified user
« Reply #111 on: Sat, 05 September 2009, 09:06:52 »
Perhaps it's the MFII layout and DIN plug deterring folks. Seems to be a ca. 1996 or later sample in any case, judging by the model name.
I'm done buying keyboards for sure.
Offline lal
« Reply #112 on: Sat, 05 September 2009, 09:13:17 »
And it probably has linear black switches, no?
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline keyb_gr
  • Cherrified user
« Reply #113 on: Sat, 05 September 2009, 11:04:35 »
Quote from: lal;115019
Hard to tell. Blacks should be fairly common, of course, but my random picks of unspecified G80s had clears (twice actually, crazy luck). So it could also have blues or clears. It's a gamble, probably more for those content with whatever they get. My G80-3000HAD ended up with the case and keycaps from my very first G80 with blues, now serving as an experimental board (QWERTά etc.) while the board with blues and two-shot keycaps sits on my main comp.
Offline sixty
« Reply #114 on: Sat, 05 September 2009, 12:07:52 »
Quote from: huha;115016
-huha
Looks like double shot keys for sure. Sadly I am as well done buying G80s, I can literally pile them to the ceiling, or take a bath in double shot keycaps (take that ripster!)
Offline huha
« Reply #115 on: Sun, 06 September 2009, 06:13:38 »
Here's an IBM XT keyboard, looks like a Model F?
A Cherry G80-11900 with thouchpad.
-huha
Offline sixty
« Reply #116 on: Tue, 08 September 2009, 10:22:31 »
A really good deal on this Apple Extended keyboard, it seems to be new in box, or at least boxed in great condition:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=180402101211&ssPageName=STRK:MEWAX:IT
Someone please buy it before I do so. I don't have the space!!
Offline lowpoly
« Reply #117 on: Tue, 08 September 2009, 10:56:56 »
^^^ Apple Adjustable
Edit: looks like the manual and floppy are missing.
« Last Edit: Tue, 08 September 2009, 10:59:42 by lowpoly »
Offline lal
« Reply #118 on: Tue, 08 September 2009, 11:23:19 »
If it had an ADB-Converter included I'd be all over it.  AFAIK those converters are pretty expensive?  Griffin iMate or what they're called...
Offline sixty
« Reply #119 on: Thu, 10 September 2009, 09:12:02 »
Offline lal
« Reply #120 on: Thu, 10 September 2009, 10:55:56 »
Quote from: sixty;116573
Mitsumi: http://cgi.ebay.de/Tastatur-Keyboard-PC-Mitsumi-5pol-DIN-Stecker_W0QQitemZ160361065262QQcmdZViewItemQQptZM%C3%A4use_Tastaturen?hash=item255643ab2e&_trksid=p3286.c0.m14
Uses the hybrid spring loaded rubberdomes I think - According to Amiga users a decent switch type.
Where did get that info from?  Unless that is some kind of special edition, that is a standard rubber dome board.  Very common.
Offline sixty
« Reply #121 on: Thu, 10 September 2009, 11:00:00 »
Quote from: lal;116621
http://eab.abime.net/showpost.php?p=383886&postcount=18
It seems as if the later models used rubber springs instead of actual springs, but yeah. It seems to be not a normal rubber dome but rather a fancy rubber dome with one dome that collapses and one that puts the keycap back up? Maybe similar to the Fujitsu LiberTouch?
Offline keyb_gr
  • Cherrified user
« Reply #122 on: Thu, 10 September 2009, 14:43:19 »
Carl Zeiss Jena Keyboard: http://cgi.ebay.de/PC-Tastatur-neuwertig-Carl-Zeiss-Jena_W0QQitemZ110430390420QQcmdZViewItemQQptZM%C3%A4use_Tastaturen?hash=item19b62a0894&_trksid=p3286.c0.m14
WTF is this? OEM Model M? Some clone? High shipping :(
Doesn't look like a real M, more likely a clone. Has to be some kind of membrane-based board due to the curvature.
Offline lowpoly
« Reply #123 on: Mon, 21 September 2009, 06:49:02 »
Quote from: sixty;111466
Btw: The G80-5000 ended today.. 584,90 EUR.
This one in used condition just went for Euro 406,-.
The time for cheap G80-5000s seems to be over. At least if the seller is willing to ship international.
Offline lowpoly
« Reply #124 on: Sun, 27 September 2009, 09:37:48 »
Offline lowpoly
« Reply #125 on: Sat, 03 October 2009, 10:32:13 »
Offline Z Redux
« Reply #126 on: Sat, 03 October 2009, 21:35:06 »
Quote from: lowpoly;122556
Monterey International Corp. Model No. K104
Does anybody know what kind of switches the second one has?
I think this keyboard uses the same SMK-Monterey switches that are found in certain Chicony KB-5181s - tactile click with blue axis. It's a bit hard to tell, though, as Monterey seems to have varied components under the same model number... much like Chicony.
A Google image search for 'Monterey K104 keyboard' yields two different keyboards with the same model number (one appears to use a blue axis Alps-style switch), both of which look different than the keyboard in the auction.
To find out what switch this particular keyboard uses you could ask the seller to pull a key cap and photograph the switch. Unless, that is, you like to gamble.
In any case, Sandy has photos and discussion of the SMK-Monterey switch here. (Japanese)
mousefan has a few additional photos here. (Japanese)
Geekhack member maxlugar talks about his Chicony KB-5181 equipped with the blue SMK-Monterey switch in this post. (English)
 -Z
Offline lowpoly
« Reply #127 on: Sun, 04 October 2009, 03:45:53 »
Thanks. :-)
Offline lowpoly
« Reply #128 on: Wed, 07 October 2009, 09:12:50 »
Offline sixty
« Reply #129 on: Fri, 09 October 2009, 00:37:40 »
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=250509638310&ssPageName=STRK:MEWNX:IT
MX 11900 (G80- 11900 LTMEU-0). Brand new and QWERTY layout. This is a great deal. I don't know what type of switches it uses yet.
I already ordered one and can repost here first when it arrives.
PS: They ship within Europe and also worldwide on request.
« Last Edit: Fri, 09 October 2009, 00:58:53 by sixty »
Offline JBert
« Reply #130 on: Fri, 09 October 2009, 02:01:25 »
Cherry only made those models with black switches.
If you want some other switch, you can only hope that someone asked Cherry to make an OEM version.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline xyzzy
« Reply #131 on: Fri, 09 October 2009, 03:35:48 »
Quote from: sixty;124032
Hmmm, the auction photo is of a G84-5500, which uses ML switches. Still a good deal, but I wonder whether they got the title or the photo wrong.
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline sixty
« Reply #132 on: Mon, 12 October 2009, 10:31:29 »
I just got the board and can confirm that its indeed the described keyboard with full US QWERTY layout. The picture is wrong. Really good deal, go grab one!
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #133 on: Mon, 12 October 2009, 19:56:58 »
That looks like an interesting keyboard.
Offline lowpoly
« Last Edit: Wed, 28 October 2009, 14:43:38 by lowpoly »
Offline keyb_gr
  • Cherrified user
« Reply #135 on: Thu, 29 October 2009, 15:08:38 »
G80-3000, ANSI layout, blacks, PS/2 (ends tomorrow)
Real old Olivetti board
Supposedly rugged lefty keyboard, PS/2 (manufacturer, specialises in keyboards for people with disabilities)
« Last Edit: Thu, 29 October 2009, 15:12:35 by keyb_gr »
Offline itlnstln
« Reply #136 on: Thu, 29 October 2009, 15:10:58 »
That Olivetti 'board is stylin'.
Offline Hakhu
« Reply #137 on: Fri, 30 October 2009, 04:33:48 »
Quote from: keyb_gr;129211
Shush! :)
« Reply #138 on: Mon, 02 November 2009, 18:32:59 »
Does ANSI main there are Windows keys?
Offline keyb_gr
  • Cherrified user
« Reply #139 on: Tue, 03 November 2009, 07:46:41 »
Quote from: microsoft windows;129997
Nope, just that it's a US-style layout, which is kinda rare over here where ISO layouts (102/105-key with inverted-L Enter) are the norm.
Offline Hakhu
2x Cherry G80-5000 + 5700
« Reply #140 on: Tue, 03 November 2009, 08:19:56 »
There are currently two Cherry G80-5000s to be had. Both offers include a 5700 numpad.
Link 1
Link 2
Offline lowpoly
« Reply #141 on: Tue, 03 November 2009, 08:39:00 »
Both are relists. First one went for Euro 584,- before, second one for Euro 406,-.
Unlike before, the seller in Link 1 only sells to Europe now.
Q: hallo. i need buy it now. tell me buy it now price please. thank you.
A: Hello, the last auction with this keyboards was ended with 580€ Is this ok for you?
LOL
« Last Edit: Tue, 03 November 2009, 08:43:10 by lowpoly »
Offline Hakhu
« Reply #142 on: Tue, 03 November 2009, 08:51:53 »
Relists by the people who bought them before or by the same sellers (that would mean they tried to up the price and ended up buying their own s**t)?
Offline lowpoly
« Reply #143 on: Tue, 03 November 2009, 09:25:34 »
Same sellers.
Not sure if it was shill bidding. The Link 1 guy reduced the sales area to Europe, I suspect he had a non-paying overseas bidder or other problems with the transaction.
Offline xyzzy
« Reply #144 on: Tue, 03 November 2009, 10:26:57 »
Quote from: lowpoly;130091
LOL
The auction has ended early, maybe the buyer agreed on the 580€ price after all... :madgrin:
Offline J888www
« Reply #145 on: Tue, 03 November 2009, 10:37:39 »
Curious, I wonder if the buyer just happen to be from Plα de Palau, Barcelona. One of my silly hunches.
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline xyzzy
« Reply #146 on: Tue, 03 November 2009, 10:52:30 »
Quote from: J888www;130129
Ha! No I already have a G80-5000 + numpad and I paid around €60 for both IIRC.
Plus the coordinates are approximate :wink:
Offline J888www
« Reply #147 on: Tue, 03 November 2009, 10:55:16 »
Tocado mi amigo
Offline Mnemonix
« Reply #148 on: Tue, 03 November 2009, 11:10:46 »
Dude, what's so special about these boards? I mean, they are broken in the middle, and they have German layouts. :wink:
Seriously, why would I want one of those?
Offline itlnstln
« Reply #149 on: Tue, 03 November 2009, 11:13:01 »
Quote from: Mnemonix;130141
You're right.  I would take one off someone's hands just so they wouldn't have to deal with this trash laying around their house.
