Author Topic: [META] Interest Check Tracker  (Read 50974 times)
Offline Dihedral
  • Mostly Harmless
« on: Sun, 17 May 2015, 11:16:27 »
IC Tracker
Any updates or information is helpful. I'm one person at a desk and I can't track every IC all the time. It's particuarly hard for me to know when ICs become GBs, so if an IC goes into production let me know.
I'm generating these lists with a python program, so if you think the template should be changed just let me know.
Contribute
There are a lot of ICs, so I need your help to keep this up to date. If you want to help out, contribute to the google sheet which contains all the data for this tracker.
Link to Spreadsheet - Sorry for link shortener but the google sheets link contained a homophobic slur which was starred out by the spam filter, breaking the link.
Anyone can edit this document. Please help to keep it vandalism clear. Just add each IC as a row, filling in the appropriate fields.
Current ICs Only - if the part has gone in to production please request that it is added to the [Group Buy Tracker](https://geekhack.org/index.php?topic=57761.0).
If there has been no progress on an IC for at least a month, then please do not add it to the spreadsheet. Chances are that it is dead or dormant.
TYPE should be one of the following: KEYCAP, KEYSET, KEYBOARD, ACCESSORY, PART
KEYCAP is for single caps or small sets (GH labelled keys for example).
KEYSET is for whole keysets
KEYBOARD is for a keyboard or keyboard kit such as LightSaver
ACCESSORY is for a keypuller or keyring and the like.
PART is for switches, springs, landing pads etc.
If this is a totally new IC, specify it as Round 1
Bonus python repo
« Last Edit: Sun, 21 June 2015, 09:24:59 by Dihedral »
Offline Dihedral
  • Mostly Harmless
Re: [META] Interest Check Tracker
« Reply #1 on: Mon, 18 May 2015, 09:59:06 »
Updated
Offline Dihedral
  • Mostly Harmless
« Reply #2 on: Mon, 18 May 2015, 10:34:21 »
Updated Again. I think I've got almost all current ICs now.
Offline livingspeedbump
    • KeyChatter
« Reply #3 on: Mon, 18 May 2015, 23:38:00 »
missing Jukebox ;)
<- My Collection (so far)
Offline Dihedral
  • Mostly Harmless
« Reply #4 on: Tue, 19 May 2015, 01:06:19 »
missing Jukebox ;)
It's going into production so in my mind it's now A gb.
Offline Chedda7
« Reply #5 on: Tue, 19 May 2015, 01:23:02 »
This is awesome.  What condition do you use to check if an IC is still active?
Offline Dihedral
  • Mostly Harmless
« Reply #6 on: Tue, 19 May 2015, 01:38:32 »
No hard and fast rules, but if there still appears to be interest I'll put it in. If in doubt, add it is my philosophy
« Reply #7 on: Tue, 19 May 2015, 02:11:59 »
Just to mention that the blue on dark gray is kinda difficult to read ...
Offline Dihedral
  • Mostly Harmless
« Reply #8 on: Tue, 19 May 2015, 02:57:25 »
Ah, my bad, I use thoriated. Ill change it later.
Offline Dihedral
  • Mostly Harmless
« Reply #9 on: Tue, 19 May 2015, 10:28:10 »
Updated for those with dark themes. Now shows newer ICs first.
« Reply #10 on: Tue, 19 May 2015, 10:29:37 »
This is really cool :D. I know infiniti has been updating the GB tracker manually. Maybe you can work with him in using that Python script over there too?
Offline Dihedral
  • Mostly Harmless
« Reply #11 on: Tue, 19 May 2015, 10:37:00 »
I'm glad it's useful.
I'll put the code in a GH repo and post a link over there. That's GitHub, not GeekHack.
Offline Dihedral
  • Mostly Harmless
« Reply #12 on: Tue, 19 May 2015, 10:43:11 »
Awesome, this is stickied :)
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #13 on: Tue, 19 May 2015, 22:57:20 »
I'm all about the old school Ctrl+C and Ctrl+V yo!  I also LOOOOOVE typing on keyboards! :))
But yeah, I'll take a look at this tonight.
Also posting to subscribe!
Offline Dihedral
  • Mostly Harmless
« Reply #14 on: Thu, 21 May 2015, 11:58:55 »
Updated
Offline Dihedral
  • Mostly Harmless
« Reply #15 on: Thu, 21 May 2015, 13:19:06 »
Removed PBT Spacebars - Now a GB.
Offline Dihedral
  • Mostly Harmless
« Reply #16 on: Sat, 30 May 2015, 05:56:37 »
Updated
Offline Dihedral
  • Mostly Harmless
« Reply #17 on: Sat, 30 May 2015, 11:37:11 »
Updated
Offline Dihedral
  • Mostly Harmless
« Reply #18 on: Mon, 08 June 2015, 12:18:46 »
Updated.
This list is getting pretty long now, I might split it into 'Newest 10' and 'Older ICs'
Offline Dihedral
  • Mostly Harmless
« Reply #19 on: Sun, 21 June 2015, 09:25:39 »
Another Update, with a slightly new sorting mechanism.
Offline ideus
  • Björkö.
« Reply #20 on: Fri, 17 July 2015, 13:02:20 »
It may help to have the IC threads grouped by type: Keysets, keyboards, parts, ...
Thank you very much for the effort, it makes very easy to follow up the ICs. Thank you.
Offline Dihedral
  • Mostly Harmless
« Reply #21 on: Sat, 18 July 2015, 04:10:43 »
I think I'm going to work on a better system for sorting the interest checks.
Offline crayzieap
« Reply #22 on: Sat, 24 October 2015, 17:25:19 »
Wow.. thank you so much for grouping these together.
Offline ideus
  • Björkö.
« Reply #23 on: Sat, 24 October 2015, 20:21:06 »
The GB section had a similar list that has not been updated recently, maybe you could share your python code with someone to keep that tracking also.
Offline breusch91
« Reply #24 on: Thu, 22 December 2016, 00:04:34 »
anyway to start getting this going again?
Offline muten-roshi
« Reply #25 on: Tue, 10 January 2017, 11:40:36 »
this seems to be very outdated....
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #26 on: Wed, 11 October 2017, 18:07:50 »
Expanding the top post shows a link to a Google spreadsheet that supposedly contains everything in the current list.  But it looks like that spreadsheet is VERY out of date.  So is that spreadsheet no longer used?
Offline xondat
  • i'm not a star
« Reply #27 on: Wed, 11 October 2017, 18:11:06 »
When the OP hasn't logged in for 6 months and the 1st post hasn't been edited for over 2 years, does that question really need to be asked? :))
Offline dvorcol
« Reply #28 on: Thu, 12 October 2017, 20:54:39 »
I would assume this thread is dead, except it is one of the three pinned to the top of the [IC] page.  Why is it still pinned there?  And the list seems relatively current...
« Last Edit: Thu, 12 October 2017, 20:56:39 by dvorcol »
