Author Topic: Clueboard 66% PCB - Pre-soldered Underlight Available!  (Read 473749 times)
Offline pwade3
Re: Clueboard 66% PCB - New version 2.0!
« Reply #250 on: Tue, 03 May 2016, 20:02:46 »
Hey skully, no issues getting that hex on the board, but it seems I've got some issues with my LED soldering.
Here's my current results, mind you LED 2 and 3 were blinking while all others were solid. 136098-0
Close up of LEDs 1, 2, and 3:
136100-1
Close up of LED 11 where the chain stops, I think I fried this spot on the board or something? Not sure, occasionally when I plug in the board this one will blink once very dimly and then nothing.
136102-2
Any advice on what I need to do as far as jumping these guys to work correctly? Or has that ship sailed? Or if you need better pics to diagnose, let me know!
Offline StormyMonday
« Reply #251 on: Tue, 03 May 2016, 22:27:58 »
Here's my current results, mind you LED 2 and 3 were blinking while all others were solid. (Attachment Link)
I tried to post a vid from my phone, but it crashed and burned. Anyhoo, I'm running a v2.0 PCB, with Skully's latest hex and I initially had orange LEDs racing back and forth in a marquee effect. Cycling through the modes Fn+S+Spacebar gave me all of the LEDs cycling through the rainbow together. That seems to be the only effect programmed at present, perhaps due to a memory limitation.
Based on your vid, I'd guess that you have either a bad solder joint, or a faulty LED, since these work like old Christmas lights ... when one goes out, it affects its neighbors. Sorry, but the resolution of my laptop screen isn't good enough for me to spot the trouble area.
Best of luck!
Offline skullydazed
  • * Moderator
  • Had to turn PM's off. Email info@clueboard.co!
    • Clueboard
« Reply #252 on: Tue, 03 May 2016, 23:55:39 »
If the LED's are flashing when you plug in you can ignore the pin at the corner with a line. You can also ignore the pin kitty corner from that.
Of the two remaining pins there is one that is on the same side as the "previous" LED. That one is the DIN (Data In) pin, and is where the control signal comes in at. Kitty corner from that pin is the DOUT (Data Out) pin. The DOUT on the last working LED should connect to the DIN of the first non-working LED, so check both of those first. If you really have lifted the pad in an unrecoverable way those are the two pins to jumper.
Good luck! You're getting closer to having it all working.
Offline faxe
« Reply #253 on: Wed, 04 May 2016, 07:51:49 »
so, clueboard assembled, collected Massdrop case from the customs office. Tried to assemble it, but how on earth do I fix the plate/pcb assembly to the case? It moves up and down inside..
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline pwade3
« Reply #254 on: Wed, 04 May 2016, 07:52:41 »
Thanks so much for the info, hopefully I can try to work on it soon.
Darn work is keeping me from putting together my board for work.  :))
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #255 on: Wed, 04 May 2016, 09:14:48 »
It's moving even after you screw it together? That's the part I find the trickiest with those cases, getting everything lined up just so. Try moving the plate around inside the case while lightly pressing the top of the case down. It should find a position that sorta sucks it all into place.
Offline merlin64
    • MechMerlin
« Reply #256 on: Fri, 06 May 2016, 09:17:54 »
pwade3, take a look at what I did to get around this. It's ugly, and it shows through my clear acrylic case, but it works on the solid colors just fine.
Offline pwade3
« Reply #257 on: Fri, 06 May 2016, 10:17:47 »
Did you get the correct jump figured out so that the one LED isn't messed up? I didn't see a post about it.
Offline merlin64
    • MechMerlin
« Reply #258 on: Fri, 06 May 2016, 10:21:05 »
It works more or less lol. The breathing effect works the best as all the LEDs are the same color, the ones that change or the ones that blink around are the ones you can tell something is wrong. I'm still gonna wait till the next PCB rev comes out though.
Offline maximm
« Reply #259 on: Wed, 11 May 2016, 15:04:55 »
Are any of the acrylic layers RGB Diffusors? Like this
Does the "Smog" one have this effect?
Otherwise im thinking
Assembly: Do it myself!
Screw Color: Silver
Top Plate: Transparent Dark Blue
Switch Plate: Clear Acrylic
Reinforcing Plate: Clear
Middle Plate: Clear
Bottom Plate: Transparent Dark Blue Acrylic
« Last Edit: Wed, 11 May 2016, 15:07:45 by maximm »
Offline pwade3
« Reply #260 on: Wed, 11 May 2016, 17:37:50 »
Finally had the time to look at my board, touched up a few of the LEDs and we have light!
Any advice on what to do from here? This is single color mode.
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #261 on: Wed, 11 May 2016, 17:51:23 »
Screw Color: Silver
Middle Plate: Clear
White diffuses pretty well, but to get that kind of effect you want clear and then you'll sand it yourself to frost the acrylic. The smoke acrylic won't diffuse as well as sanded acrylic will.
I'm not sure why that's happening. It's possible that you heated them up too high or too long. What temperature is your iron at?
I'm pretty confident they're otherwise soldered correctly, as the rest of the string are lighting up properly.
Offline pwade3
« Reply #262 on: Wed, 11 May 2016, 17:55:59 »
~300 C
« Reply #263 on: Thu, 12 May 2016, 23:58:19 »
So I'm trying to come up with different layouts for what I'd finalize for my Clueboard. At the moment, I have AEK II and M0116 caps I'd like to utilize. After fiddling with Keyboard Layout Editor, I realize the AEK II space bar wouldn't work with any of the layouts I had in mind, so I guess I'd have to order space bars from PMK to fully optimize what I'd prefer
Below I have two different ideas, one with a 6u space bar and the other (2nd) with a 6.75u space bar. Are any of these renders possible, even?
6u space bar
136989-0
6.75u space bar
136991-1
Any one else got any other ideas? The only caps I'd have to prioritize at the bottom would be the Caps Lock at the far left from the M0116 board (would the lock switch be a possibility to use, too?). Any other layouts I can consider. Thanks!
« Last Edit: Fri, 13 May 2016, 00:00:52 by romevi »
Offline Dernubenfrieken
« Reply #264 on: Fri, 13 May 2016, 06:09:52 »
6u space bar
6.75u space bar
I beleive the bottom left key has to be 1.25. Might have to put Option there and use the bottom layout.
« Reply #265 on: Fri, 13 May 2016, 13:47:30 »
6u space bar
6.75u space bar
So the only keys on the far bottom left have to be 1.25u or 1.5u?
Offline zombimuncha
« Reply #266 on: Thu, 19 May 2016, 06:16:35 »
Can toggle Fn on/off (like capslock), like with a long press or something???
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #267 on: Thu, 19 May 2016, 16:42:55 »
Yes, you can have a simple toggle or you can program a key so that if you press and release it is one key (like switch layer) but if you hold it down it's another key (like momentary toggle layer.)
Offline zombimuncha
« Reply #268 on: Fri, 20 May 2016, 04:39:31 »
OK, so could it be set up so that it's otherwise exactly the same as my stock 660m, but if I hit Fn-Capslock the Fn-layer is toggled on, so I could then hit sequences of F-keys without holding any other key down, then toggle the Fn-layer back off by tapping Fn again?
Offline need
« Reply #269 on: Fri, 20 May 2016, 05:25:05 »
Do the Acrylic case metal plate also fit the regular FC660m/Varmillo case
Yes
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #270 on: Fri, 20 May 2016, 16:26:33 »
That specific behavior is rather complicated, but you could do it if you know a little bit of C. You'd need to write custom behavior for the Fn key but it could be accomplished.
If you are ok with Fn-Capslock toggling both on and off it's much simpler.
Offline zombimuncha
« Reply #271 on: Sat, 21 May 2016, 01:39:27 »
Great answer. Really tells me everything I wanted to know and reassures me that you fully understood the question. Thanks!
« Reply #272 on: Fri, 27 May 2016, 08:09:12 »
« Reply #273 on: Fri, 27 May 2016, 19:55:57 »
Yay!
Offline cheddarbek
« Reply #274 on: Tue, 31 May 2016, 09:28:58 »
Got my Clueboard built over the weekend. I ran into some trouble with the left shift key. Putting the switch in LShift, it wasn't recognized by the board. After putting a jumper in ISOLShift it worked perfectly - why, I'm sure I do not know.
I've got it assembled with the aluminum Leopold case from Massdrop, with 65g Zealios and Originative Co keycaps. I'm chuffed with this!
The Alps cover 65% of Switzerland's surface area (41,285 kmē), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 kmē),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline faxe
« Reply #275 on: Tue, 31 May 2016, 09:32:36 »
Did you have any problems with the pcb/plate combo sitting loosely in the massdrop case?
Offline cheddarbek
« Reply #276 on: Tue, 31 May 2016, 09:35:50 »
I did, yeah. I had a good millimeter or two of play, especially on the left hand side. When I would put the case together everything would seem fine, but any movement of the board and suddenly the pcb/plate would come loose. I resolved it by putting little foam feet on top of the plate at each corner. Now it's in there solid and perfect.
« Reply #277 on: Tue, 31 May 2016, 11:45:41 »
Looks great!
Congrats!!!
Offline merlin64
    • MechMerlin
« Reply #278 on: Tue, 07 June 2016, 13:09:21 »
Looks like my soldering didn't hold up. I left my keyboard plugged in over the weekend, when I got to it, I noticed my solid colored light was exhibiting different colors. I unplugged/replugged the USB cable and I haven't been able to get the LEDs to turn on again. All keys still work fine.
Is there anyway I can just buy parts of the acryllic case such as the bottom metal plate?
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #279 on: Tue, 07 June 2016, 17:17:32 »
Not yet, but soon. I'm working this week on a new storefront where you'll be able to buy individual parts as well as kits.
« Reply #280 on: Fri, 10 June 2016, 10:38:10 »
Okay, so I think I've come up with the layout I'd like to use with Alps:
139412-0
I'm almost certain that this layout will be fully supported by the PCB, but if anyone can correct me let me know. Ideally I'd like to change the space bar to 6.25u or one of the right mods to 1u to accommodate a 0.25u gap between the right mods and arrows, but don't think that's possible.
Now, the only issue would be finding a keyset with a bottom row that accommodates this, well as the right Shift, which I didn't realize until recently is the same size as the left Shift.
Man, this is tricker than I thought for Alps!
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #281 on: Sat, 11 June 2016, 00:39:02 »
I might br able to check tonight but keep in mind the issue with Alps isn't so much the pcb... but the plate. I wanted a 1.25x + 1x right shift +Fn combination but the plate dimply doesn't support it due to the nature of Alps.
As to keycaps;
Here is a teaser of what I plan on doing with the board. It's not soldered yet just sort of assembled with the switches popped in.
First thoughts:
- I need new smaller screws.
- This will be one of my most colorful boards yet. :P
- Unless I can find an Alps spacebar I might just pop in a cherry switch for that key
- It's a good thing Alps DCS Infinity came with an extra set of mods with different legends for that second shift.
- Quiet Clicks are really quiet. Even compared to MX Clears  :eek:
- I need more Cherry stabs
- My colleagues are going to think this thing is freaky. :))
« Last Edit: Sat, 11 June 2016, 00:41:06 by JaccoW »
|||My other keyboards :
x
Offline zombimuncha
« Reply #282 on: Tue, 14 June 2016, 01:41:31 »
Do you have any plans to add backlighting support to the PCB? I'm thinking it'd be nice to be able to indicate the different fn-layers by different patterns of LEDs, like lighting only the top row to show that they are F-keys instead of numbers, or lighting only the embedded numpad below 890.
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #283 on: Wed, 15 June 2016, 14:57:53 »
It's on my roadmap but I don't have a timeframe in mind yet.
Offline merlin64
    • MechMerlin
« Reply #284 on: Thu, 16 June 2016, 00:14:51 »
Anyone have a solution to not having to disassemble my acrylic case every time I need to hit the reset button?
For future revisions of the case,  can we have a cutout for the button or something?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #285 on: Thu, 16 June 2016, 00:50:57 »
Can't you assign it to a key on an alternate layer?
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #286 on: Thu, 16 June 2016, 02:29:08 »
The official firmware is QMK now, and that has a RESET button you can assign somewhere. By default you press Fn+S+R.
Offline kokokoy
« Reply #287 on: Thu, 23 June 2016, 06:38:02 »
Thanks for sharing this out. Just tested my PCB today and it behaves the same as yours.
Offline Wannabe
  • Independent Adjudicator
« Reply #288 on: Thu, 23 June 2016, 12:51:45 »
Did you guys not have a packet in your package labeled Clueboard 2.0 Errata? My PCB came with a stapled together pack of papers that stated the pcb had this problem and how to fix it (the fix being what you guys already figured out...putting a jumper in ISOLShift).
I liek keyboards
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #289 on: Thu, 23 June 2016, 13:23:04 »
I may have forgotten it on a couple.  :'( I also have a page about it on my in progress support site: https://clueboard.freshdesk.com/solution/articles/16000002183-my-left-shift-doesn-t-work
The next batch of PCB's will not require that, but I still have a good bit of stock left.
Offline cheddarbek
« Reply #290 on: Thu, 23 June 2016, 14:10:43 »
That sounds like instructions. We don't need instructions, half the fun is ruined when everything just works properly.
Offline liftylol
« Reply #291 on: Tue, 28 June 2016, 13:32:28 »
hey everyone, i was just wondering if all the supported layouts on the pcb are supported by the top plate for alps? and if not, which layouts are supported? standard/iso/iso/standard, would that work?
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #292 on: Tue, 28 June 2016, 21:10:54 »
For alps only ANSI with a standard top row is supported. If you're OK with an acrylic plate I can cut a custom plate to support any layout.
Offline liftylol
« Reply #293 on: Wed, 29 June 2016, 10:42:22 »
hey skully, thanks for the answer! i oredered yesterday, a custom plate would be so awesome! i can send you the order number if you want. thanks mate!
Offline yinzer
  • I'm new around here ... please don't notice.
« Reply #294 on: Sun, 17 July 2016, 15:37:47 »
I've been working on a web UI for configuring the Clueboard. Eventually I'd like it to give you a hex you can flash, but for now it's only a UI demonstration. You can check it out here:
http://configurator.clueboard.co/keyboard/clueboard
The best part is that I've open sourced it. I hope it won't stay limited to just the Clueboard but will be used by lots of QMK based projects.
https://github.com/skullydazed/qmk_configurator
Please try it out and tell me how this works for you so far.
OK, I've got it working for now. You can fetch the latest code to build a working firmware.
However, RGB Underlighting does not work. It's adding 4870 bytes to the final hex, pushing up way over the 32k limit. I'm trying to figure out why that is.
Thanks for the heads up, might be able to try putting it on when I get home from work.
I think someone posted something saying with certain firmware that the LEDs would flash when plugging in the board, but not be controllable. Don't suppose that's the case for this firmware is it?
Wanted to test one LED before proceeding to solder all of them on. Luckily I'm busy tonight and tomorrow, so I'm not too heartbroken or anything.
I think I have some answers here. The combination of options in the Makefile I have published now should result in a firmware of the proper size. If you just want to test you can grab the pre-compiled firmware I published here:
https://www.dropbox.com/s/fue7hcnf9h4n4fz/clueboard2_with_underlight.hex?dl=0
I've been talking to Jack about how to reduce that size for the Clueboard, and have a couple avenues I'm investigating for that so we don't run into this problem again.
Any updates on this front? I'd like to customize the keymap while maintaining the underlight. It's also possible that I missed an update and it's good to go from GH.
« Reply #295 on: Sun, 17 July 2016, 21:29:36 »
Speaking of acrylic plates, are they completely translucent or do they come frosted as well? I was wondering how orange Alps would feel like with acrylic plates; I've already decided on a layout I'd like, but wondering if I should go with an acrylic plate to give it less resistance.
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #296 on: Mon, 19 September 2016, 03:59:59 »
The acrylic I have for switch plates is either opaque or transparent, nothing transcluent. (Although even the opaque white lets some light through.)
Offline skullydazed
  • * Moderator
    • Clueboard
Re: Clueboard 66% PCB - Pre-soldered Underlight Available!
« Reply #297 on: Mon, 19 September 2016, 04:01:18 »
Exciting News! You can now pick up a PCB with the underlight pre-soldered! Pick yours up today: https://shop.clueboard.co/clueboard-66-pcb-version-2-0.html
Offline Phenix
« Reply #298 on: Mon, 19 September 2016, 09:23:43 »
Nice!
Whats the progress on the cluepad?
Winter is coming.
Offline kokokoy
« Reply #299 on: Fri, 30 September 2016, 06:41:16 »
Need help guys / skully. Had the board for ~3 months w/o issues but few weeks ago it started to act up. First noticed that suddenly the left win key and left alt key started to be on the other way around. Never messed around the firmware since I flash it. Ignored this then a week after its now completely a mess. Only 2 keys are registering correctly left shift and left arrow, can still flash and change the assignment for this two. But the rest of the keys its either not registering any, wrong keys being thrown or multiple key presses.
My soldering was a mess since this was my first, but it worked for months so don't know whats going on. Anyway here\s an image after flashing. Is there anything off here?
149465-0
