Poll
PCB colour preference, we will have colours, I will decide it in the end, but would love some community input.
Mint Blue
Black
White
Orange
Lime Green/YellowGreen
Purple
Author Topic: [GB][CLOSED] LeandreN Round 4, 60% kits, HHKB and winkeyless plates  (Read 454117 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] LeandreN Round 4, 60% kits, HHKB and winkeyless plates
« Reply #450 on: Mon, 28 March 2016, 03:21:43 »
What would the shipping cost to Canada for a plate and PCB be?
15$
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #451 on: Mon, 28 March 2016, 07:59:01 »
I'm back. Let me know if you have any questions. 7 days left.
Offline Tobi45
« Reply #452 on: Mon, 28 March 2016, 09:08:46 »
Hi Leandren,
I got a question regarding the white plate.
If I'm not mistaken it's a white anodized aluminium plate? How does that work, did they finally come up with a way to anodize white? I guess you don't have a picture of a sample, so I know what'd await me?
Kind regards,
Tobias
Offline Bumbibear
« Reply #453 on: Mon, 28 March 2016, 09:09:56 »
Will I be able to mount the plate mounted 65g zealios on the universal plate in this GB? Or should I order the PCB Mount switches?
Ducky Shine 3 TKL ISO
Soon: LeandreN GB 4 60% - Sentraq 78%
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #454 on: Mon, 28 March 2016, 09:11:38 »
Hi Leandren,
Kind regards,
Tobias
Very light silver anodizing. It won't be completely white.
I will try to get you a sample picture.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #455 on: Mon, 28 March 2016, 09:12:07 »
Plate mounted will work very good.
Offline Jumie
« Reply #456 on: Tue, 29 March 2016, 03:33:55 »
Can I buy plate only?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #457 on: Tue, 29 March 2016, 03:34:48 »
Offline Diokhan
« Reply #458 on: Tue, 29 March 2016, 03:40:38 »
9 more orange pcb's to go!
Offline TalkingTree
    • My projects
« Reply #459 on: Tue, 29 March 2016, 04:17:00 »
Technically, based on LeandreN's last statements, we are good already; I suspect he's gonna buy 10 for himself to sell later on.
Offline Jumie
« Reply #460 on: Tue, 29 March 2016, 04:34:39 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #461 on: Tue, 29 March 2016, 04:39:23 »
News. The Winkeyless plate will have ISO & ANSI enter support, 2,75u support(in addition to 1,75u + 1u) it will have ISO shift support and ANSI shift support. The same with the HHKB plate, so now you will have a lot of options here.
TLDR: merging ISO & ANSI designs on the winkeyless/HHKB plates. HHKB will have ISO enter support.
Offline TalkingTree
    • My projects
« Reply #462 on: Tue, 29 March 2016, 04:41:12 »
ISO left shift on HHKB was all I wanted. Thanks a bunch mate, you're the best.
Offline need
« Reply #463 on: Tue, 29 March 2016, 05:33:54 »
Great news !
Offline Dernubenfrieken
« Reply #464 on: Tue, 29 March 2016, 06:47:39 »
Wait, so the plate now has universal style cutouts?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #465 on: Tue, 29 March 2016, 06:48:52 »
For some of the places, yes. This makes no difference for those that wanted the base layout whatsoever.
Offline soilheart
« Reply #466 on: Tue, 29 March 2016, 07:48:39 »
I think saying "no difference" is taking it a little too far. I haven't joined yet, but I've been thinking about picking up a WKL plate, and one of the main reasons why is that I don't really like the gaps between switches in my current universal plate. The bottom row is the most important IMO, so the shared enter doesn't make any difference to me really (as row 3/4 isn't as visible). I don't like the idea of an universal shift cutout though, as I'm afraid it'll visible between the WKL gap, which could ruin it a little bit for me...
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
« Reply #467 on: Tue, 29 March 2016, 08:15:54 »
I have to agree with this. I'm not the biggest fan of the gaps in plates between switches, and was planning on using this build with some experimental backlighting and not sure if this will lead to inconsistent lighting. And I know a visible gap for the shiftcut would make this a deal breaker.
« Reply #468 on: Tue, 29 March 2016, 08:40:41 »
Unfortunately, the participants of this GB can't have it both ways. There are EITHER multiple layout options for those who need them, OR there is one fixed layout where you won't see the cutout if you look at it at a certain angle. Which is more beneficial to the participants as a whole?
« Reply #469 on: Tue, 29 March 2016, 08:49:13 »
I mean, there are universal plates in the GB too. The HHKB ones are specifically so you don't have gaps where there are missing bottom row switches. That issue is a bit more extreme aestethically, but its still an option for ISO users to simply buy those.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #470 on: Tue, 29 March 2016, 08:52:18 »
I mean, there are universal plates in the GB too. The HHKB ones are specifically so you don't have gaps where there are missing bottom row switches. That issue is a bit more extreme aestethically, but its still an option for ISO users.
I mean, I will have ISO shift support on the HHKB plate as I said in the beginning, so there will be very little difference by adding right shift support too. You don't really see it from a normal angle
« Reply #471 on: Tue, 29 March 2016, 08:53:53 »
There still are not gaps. It will be difficult to see the universal cutout gaps with keycaps installed, unless you are really looking for them.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #472 on: Tue, 29 March 2016, 08:55:14 »
Low angle. You can see the stabiliser spot.
« Reply #473 on: Tue, 29 March 2016, 08:57:46 »
I believe he's referring to the right shift, where the universal cutout is much larger than two switches for the HHKB split shift.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #474 on: Tue, 29 March 2016, 08:59:37 »
Offline Porkins
  • HHKB Pro
« Reply #475 on: Tue, 29 March 2016, 09:34:47 »
I don't want to out myself as a complete noob or anything, but this is my first time assembling. Is there a lot of soldering that is going to need to be done? Also, what all should I need to purchase to finish out the build?
I have already purchased a 60% case and some zealio switches. Am I missing anything?
Custom KC60
Offline soilheart
« Reply #476 on: Tue, 29 March 2016, 09:37:46 »
Haha, sorry for creating such a discussion and getting LeandreN all photo:y, was not my intention.
What I'm saying:
I do find the gaps in my current universal plate annoying sometimes. It's mainly noticeable on the bottom row, both because the white PCB and the backlighting bleeding through the unused mounting holes. But I also notice it on the shift, mostly when enabling the RGB-leds on my b.face, as the mounting holes in the PCB shines through between the keys. This is very much noticeable between the left ISO shift and the ISO key ("<>"-key).
Because of this I was a fan of the split ISO/ANSI WKL plates as I hoped that would solve both problems. (To be blunt, the HHKB-plate doesn't matter to me, as I wasn't going to get one). Making more switch placements universal and making more possibility for backlight (and PCB) bleed makes me unsure though.
So sorry for not being clear the first time, and I hope I didn't offend anyone, if so, sorry once again.
Picture showing the backlight-"issue": http://imgur.com/EvUmvRm
I agree, I'm just saying my opinion on why I may not get a plate because of this change. I was kinda assuming/hoping that people with special requirements would go wit the universal plates, and that the other plates would be as clean as possible.
« Last Edit: Tue, 29 March 2016, 09:46:05 by soilheart »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #477 on: Tue, 29 March 2016, 09:41:01 »
You will need some keycaps and a cable. There is not much soldering as you only have to do the switches.
Offline ideus
  • Björkö.
« Reply #478 on: Tue, 29 March 2016, 09:43:10 »
It is just a visual artifact, or is the "4" key taller?
Offline Porkins
  • HHKB Pro
« Reply #479 on: Tue, 29 March 2016, 09:45:32 »
Awesome. Thanks for the quick reply.
Custom KC60
Offline Porkins
  • HHKB Pro
« Reply #480 on: Tue, 29 March 2016, 09:46:23 »
Woops double posted.
« Last Edit: Tue, 29 March 2016, 09:48:37 by Porkins »
Custom KC60
Offline soilheart
« Reply #481 on: Tue, 29 March 2016, 09:57:39 »
Oh, and with all said above, I think a simple picture (as on the first page) on how the new plates would look would be helpful for us concerned ;)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #482 on: Tue, 29 March 2016, 10:11:29 »
Not properly placed on the switch.
Offline TalkingTree
    • My projects
« Reply #483 on: Tue, 29 March 2016, 10:41:52 »
I gotta say, the universal plate is way too universal, but for that price I can't really ask for anything better. I got myself some quotes for lasercut and CNC plates in Italy and a single plate would cost over € 40.
Offline soilheart
« Reply #484 on: Tue, 29 March 2016, 11:36:49 »
Yeah, what it lacks in "style" it makes up for in versatility and price, clearly. Which is why I'm (still) a little hyped on the WKL plates as they have the style the universal plates are lacking IMO, and without having a higher price.
Offline johuu
« Reply #485 on: Tue, 29 March 2016, 12:31:37 »
FYI Tex 60% cases back in stock at mechanicalkeyboards.com. Orange!!!  :D
Offline Xiro7
« Reply #486 on: Tue, 29 March 2016, 12:38:11 »
Awesome! I have the orange PCB + carbon fiber plate from this GB, so that orange Tex Alu case will look great with that.
Offline Metr0
  • HHKB or nuttin
« Reply #487 on: Tue, 29 March 2016, 14:05:57 »
Do the PCBs have SMD components pre-soldered? (Diodes etc)
[WTB] BLANK PINK HHKB ARROW CLUSTER
Offline rfja
« Reply #488 on: Tue, 29 March 2016, 14:06:28 »
Placed an order!
Will I get a confirmation email or smthg?
Offline Diokhan
« Reply #489 on: Tue, 29 March 2016, 14:18:00 »
Placed an order!
IS IT ORANGE?! :P
Offline TalkingTree
    • My projects
« Reply #490 on: Tue, 29 March 2016, 14:18:13 »
Just to clarify
there are 3 LED spots on the keyboard
1x SMD switch leds
1x normal switch leds
1x side/under leds
The presoldered resistors cover the side/under leds spots and one of the top spots.
No LEDs come presoldered.
Resistors and diodes are presoldered. LEDs don't.
Offline TalkingTree
    • My projects
« Reply #491 on: Tue, 29 March 2016, 14:19:12 »
Placed an order!
You'll receive invoice when the ordering phase is over.
Offline flob_ert
« Reply #492 on: Tue, 29 March 2016, 15:35:18 »
I have ordering regrets... I didn't order enough  :))
Email sent  :thumb:
Offline ideus
  • Björkö.
« Reply #493 on: Tue, 29 March 2016, 17:10:09 »
Yes they do, only switches and LEDs will have to be soldered.
Offline spanyam
  • Enjoy the gift of life!
« Reply #494 on: Tue, 29 March 2016, 17:12:15 »
So I'm having a debate on whether I should stick with the black PCB w/ white plate I ordered, or if I should go orange and white. I plan to put this in a wood case with the 1976 keyset, so orange might be a better fitting piece. But then again, with a plate on top, will the PCB even show? What do you guys think?
SKCM Orange ALPS on Infinity 60% bent-metal case w/ hasu ALPS64 PCB and PBT blank DSA caps | KBP V60 w/ Matias Quiet Linears | IBM Model M | QFR w/ MX Blues
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #495 on: Tue, 29 March 2016, 17:51:27 »
Personally, I'm going for a black PCB with a red plate. I have an alu case that is greyish so I think the contrast would be pretty nice.
Orange might be nice for your case. But I'm just picturing it in my head lol.
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #496 on: Tue, 29 March 2016, 18:21:22 »
In for PCB + Black universal plate.  :thumb:
I love the HHKB look, but it kills my soul that I really can't use it with i3wm and irssi.
[WTB] HHKB Black
Offline spanyam
« Reply #497 on: Tue, 29 March 2016, 19:15:39 »
Yeah I was considering that too. I think I will stick with the order as it is now.
Offline kaeeeede
« Reply #498 on: Wed, 30 March 2016, 00:35:30 »
So just to clarify, I can just solder RGB LEDs on the board and I'll be g2g? I'm pretty sure I get it but I want to be super duper sure, you know?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #499 on: Wed, 30 March 2016, 05:36:03 »
Great picture of the CF plate by Axtran
