Author Topic: [IC]Revo & Dr.D Sandwich TKL keyboard  (Read 58902 times)
Offline RevoTeam
Re: [IC]Revo & Dr.D Sandwich TKL keyboard
« Reply #100 on: Fri, 12 August 2016, 11:06:42 »
got updates. more picture. up up up
Thanks! Gives us a better idea of the colour options.
I'm also interested in half plate.
some people suggest me to do PC plate. i can do that,but moq is 10. so i am not sure if we can get that done :thumb:
I'm also interested in PC plate. 10 people doesn't seem terribly high!
The plates don't support switch opening, right?
no it doesn't support switch opening.  about the PC plate, i'll see what i can do about that. i'll try to lower the moq,but i dont think i can do that.
Offline alienman82
« Reply #101 on: Fri, 12 August 2016, 11:34:33 »
I'll get a PC plate.  For sure my friend!
Offline joey
« Reply #102 on: Fri, 12 August 2016, 11:47:31 »
I think me and alienman82 want a PC plate in addition to the alu plate.
(In a PM it seemed RevoTeam thought I meant that I wanted to replace the Alu with a PC plate)
Offline alienman82
« Reply #103 on: Fri, 12 August 2016, 11:48:30 »
I would get both plates if it mean the PC will happen.
Offline RevoTeam
« Reply #104 on: Fri, 12 August 2016, 11:51:38 »
In that case, i'll tell the price tomorrow... i am talking to alienman82 now. He think we all be ok with 10....
Offline JDragon
« Reply #105 on: Fri, 12 August 2016, 12:09:22 »
PC plate = polycarbonate? If so, I'd be interested.
Offline alienman82
« Reply #106 on: Fri, 12 August 2016, 12:20:55 »
correct
Offline Data
« Reply #107 on: Fri, 12 August 2016, 13:34:13 »
I'd also be interested in Alu + PC plates.
Offline redbanshee
  • actually Dade Murphy
« Reply #108 on: Fri, 12 August 2016, 13:50:34 »
If it is a 5mm polycarb plate with stabilizer cutouts on the underside I would also be interested in a PC and alum plate. But if its a 1.5mm PC plate that will be pretty flimsy.
Offline joey
« Reply #109 on: Fri, 12 August 2016, 13:54:59 »
5mm polycarb plate would likely need to have some bits CNC'd to 1.5mm, which would probably make that a weak stress point.
Look at how the plate mounts to the middle piece:
https://geekhack.org/index.php?action=dlattach;topic=83590.0;attach=143238;image
Offline Data
« Reply #110 on: Fri, 12 August 2016, 13:57:36 »
Did I read that this was both Winkey and Winkeyless?  It looks like the plate and PCB support both layouts, but all the renders show Winkelyess.  Are the blockers optional in the top case?
Offline redbanshee
« Reply #111 on: Fri, 12 August 2016, 14:09:30 »
Trade off I guess, flimsy plate or plate with weak points... actually dont think I would want a PC plate after you pointing that out.
« Last Edit: Fri, 12 August 2016, 14:14:55 by redbanshee »
Offline alienman82
« Reply #112 on: Fri, 12 August 2016, 14:10:23 »
I think the PC plate should be a 1.5mm~~ (not 5mm) partial plate.  This is to allow for the PCB switch feel while allowing the mods stability.
Offline redbanshee
« Reply #113 on: Fri, 12 August 2016, 14:18:31 »
You cant just have your PCB hanging off a 1.5mm PC plate with an air-gap, especially a partial plate. Its not strong enough.
Theres a reason why WKL and GON have another layer between the 1.5mm plate and the PCB..
Offline alienman82
« Reply #114 on: Fri, 12 August 2016, 14:20:23 »
We will see what Revo says.  I am not sure what the thickness is.
Offline joey
« Reply #115 on: Fri, 12 August 2016, 15:16:55 »
I assembled an octagon with just a 1.5mm polycarb full plate.
I agree with the other layer thing though, was planning to make one of those actually.
Offline JDragon
« Reply #116 on: Fri, 12 August 2016, 18:56:22 »
5mm acrylic/PC plate would be a dream. I have a SPRiT one and the sounds from that board are so much better than those from my boards with metal plates.
Offline ramnes
  • T fou, mec?
« Reply #117 on: Fri, 12 August 2016, 19:18:32 »
Interested without the D (could be something smaller though)
Offline RevoTeam
« Reply #118 on: Fri, 12 August 2016, 21:55:01 »
Guys, it will be a 1.5mm pc plate. Because it have to be the same thickness with the alu plate. Or just make something in between the plate and pcb.
The cost will be 15 usd. moq still 10.
Offline RevoTeam
« Reply #119 on: Fri, 12 August 2016, 21:56:35 »
yep, just having two kind of topping case. no blockers. blockers dont look good.
Offline RevoTeam
« Reply #120 on: Fri, 12 August 2016, 22:00:00 »
if it's a 60% i can do 5mm no problem. but 80% have to mounted the plate on the upper case or the lower case(middle case in this keyboard). in that case i cant do 5mm.
Offline Data
« Reply #121 on: Sat, 13 August 2016, 12:29:13 »
Thanks. I thought you had responded to this before but I couldn't find it.
Offline joey
« Reply #122 on: Sat, 13 August 2016, 12:50:23 »
Dang, 15 USD is cheap.
Offline alienman82
« Reply #123 on: Sat, 13 August 2016, 15:12:07 »
yeah pretty darn cheap, should hit 10 orders easily.
Offline JDragon
« Reply #124 on: Wed, 17 August 2016, 19:31:05 »
Is there any chance of gold being a color option for the GB by any chance?
Offline RevoTeam
« Reply #125 on: Wed, 17 August 2016, 20:38:33 »
Sorry,we dont have the color of gold at the moment.
Offline JDragon
« Reply #126 on: Wed, 17 August 2016, 20:47:24 »
Ah darn, black and gold would have looked amazing imo.
It's too hard to choose colors, so many possibilities. I think I'll probably go black and pink, super hyped for the GB. :D
Offline RevoTeam
« Reply #127 on: Wed, 24 August 2016, 08:58:06 »
everyone, final update. GB is coming. My work have been dragging me lately. But we will be good to go this weekend.:D
Offline gadzkun
« Reply #128 on: Wed, 24 August 2016, 11:06:42 »
HYPUUUUUU :p
Offline joey
« Reply #129 on: Wed, 24 August 2016, 11:10:40 »
HYPUUUUUU :p
:thumb:
Offline Data
« Reply #130 on: Thu, 25 August 2016, 06:57:36 »
YISSSSSSSSSSSSSSSSSS.
Offline gadzkun
« Reply #131 on: Thu, 25 August 2016, 11:29:50 »
oh yeah i forgot, can Dr.D use 1.75 right shift?
like this
Offline xondat
  • i'm not a star
« Reply #132 on: Thu, 25 August 2016, 11:33:21 »
like this
Plate design in the OP doesn't allow for it, whether they've changed it is beyond me.
Offline RevoTeam
« Reply #133 on: Thu, 25 August 2016, 11:39:19 »
like this
no  it doesn't support that :D
从我的 iPhone 发送,使用 Tapatalk
Offline gadzkun
« Reply #134 on: Thu, 25 August 2016, 12:18:43 »
like this
like this
ahh ic, but its okay i just change right alt to FN then :p
Offline Data
« Reply #135 on: Thu, 25 August 2016, 13:14:33 »
So... fixed cable for this?  Am I reading that right?
Offline JDragon
« Reply #136 on: Thu, 25 August 2016, 13:24:01 »
Darn it, fixed cable. Everything else was perfect. T_T
Offline joey
« Reply #137 on: Thu, 25 August 2016, 13:33:06 »
Hm, I might not be able to order then.
Revo can you show a picture of the PCB and where the xh2.54 has to go?
Or do you think a USB connector could still fit in that hole, if I make the PCB myself?
Offline xondat
  • i'm not a star
« Reply #138 on: Thu, 25 August 2016, 13:35:47 »
Some pictures show the USB port sticking out  :))
Offline joey
« Reply #139 on: Thu, 25 August 2016, 13:55:50 »
I'm just worried that they've changed the design.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #140 on: Thu, 25 August 2016, 21:44:45 »
It means you can ALWAYS hook up your keyboard no matter what.
I HATE when a new keyboard design presents itself without a cable attached then tells me I have to spend MORE money to buy it, so that the damn keyboard would work, sux to the extreme.
When I lay down my money I want the keyboard ALL there, ready to be connected to any PC for work.  Also I've seen keyboards with failed usb micro/mini ports, so for all intensive purposes that keyboard becomes dead to everyone unless someone re-solders a brand new usb connector to it  >:( .
For once it's time to finally make a keyboard with a usb cable attached to it, I'm no idiot wireless fanatic and will never be one BUT I want this keyboard with an inbuilt cable ready to be used immediately when it arrives at my address.
Offline gadzkun
« Reply #141 on: Thu, 25 August 2016, 21:52:36 »
i really like the cables its already coiled, and with +$10 you get a high quality ones :thumb:
Offline whentheclouds
« Reply #142 on: Thu, 25 August 2016, 22:01:12 »
it also means you lose the customizability aspect, which sorta goes against the idea of a custom keyboard. so i can understand why it would be a dealbreaker to some
Offline RevoTeam
« Reply #143 on: Thu, 25 August 2016, 22:01:40 »
the reason why we  change it to fixed cable is after the test we find out  the mini usb cant fit all the cables. some cable  will  not be working well. it  may caused disconnection sometimes. if we  widen the usb port  it  will be very ulgy...so we give everyone a free  cable. yabro port have to  charge another 10bucks is because the cost of  it is expensive otherwise  we will  be losing  money. its hard to  please everyone but i  am trying here . thanks for every comment. cheers
Offline RevoTeam
« Reply #144 on: Thu, 25 August 2016, 22:06:36 »
tbh its not against the custom its  just  harder  to do  it. people  make  great cables for otd keyboards. same case here. anyway you can solder the cable on the pcb as well. just you have fix the cable on the pcb
Offline Elrick
  • Hype Master
« Reply #145 on: Fri, 26 August 2016, 00:24:42 »
Also don't forget for some wanting to use their keyboard EVERYWHERE means that they are more prone to having a faulty usb connection involving fitting and removing the cable multiple times.
So you have to decide what will work long term, a removable cable prone to eventual failure or a permanent connection that lasts longer?  Can see why Real Force/Filco and some other manufacturers went with a permanent cable attached due to the same circumstances faced with their usage.
Offline loud_asian
« Reply #146 on: Fri, 26 August 2016, 01:53:26 »
Is the hole for the USB the same size?
If so, I don't really mind the fixed cable. I just want compatibility with other custom PCBs, in case I accidentally mess up the original
Offline RevoTeam
« Reply #147 on: Fri, 26 August 2016, 01:59:08 »
not the same. you can buy extra pcb. the pcb wont be  broken easily. even if you broke it somehow i can always repair it for you or  sell you  a new one.
Offline joey
« Reply #148 on: Fri, 26 August 2016, 02:41:22 »
Revo: So you're changing the design and a USB port will no longer fit there?
Since I was going to be designing my own PCB for this, I need to figure out what I can do.
Offline RevoTeam
« Reply #149 on: Fri, 26 August 2016, 02:43:45 »
you can cut down the usb port and it will fit in....i dont think that's a problem for you...
