Author Topic: [IC]Revo & Dr.D Sandwich TKL keyboard  (Read 58903 times)
Offline joey
Re: [IC]Revo & Dr.D Sandwich TKL keyboard
« Reply #150 on: Fri, 26 August 2016, 02:47:17 »
Revo: So you're changing the design and a USB port will no longer fit there?
Since I was going to be designing my own PCB for this, I need to figure out what I can do.
you can cut down the usb port and it will fit in....i dont think that's a problem for you...
从我的 iPhone 发送,使用 Tapatalk
Do you mean cut down a usb cable?
How wide will the hole for the USB port be?
Offline RevoTeam
« Reply #151 on: Fri, 26 August 2016, 02:53:20 »
no  i  mean  cut  down the usb  part on your pcb. you can solder any cable on your pcb. :D
« Last Edit: Fri, 26 August 2016, 05:45:41 by RevoTeam »
Offline RevoTeam
« Reply #152 on: Fri, 26 August 2016, 07:28:55 »
I have started the GB so this IC will be closed.
please go to  https://geekhack.org/index.php?topic=84328.0
Offline joey
« Reply #153 on: Fri, 26 August 2016, 07:54:33 »
How long will the GB ordering phase last? I need to understand if I can make my PCB work for this GB.
Offline RevoTeam
« Reply #154 on: Fri, 26 August 2016, 08:00:45 »
2 weeks after the GB start
