Author Topic: [IC] ePBT Fortune (ssssamples)  (Read 53690 times)
Offline portbaron
Re: [IC] ePBT Fortune (ssssamples)
« Reply #150 on: Sat, 06 October 2018, 19:55:05 »
I think the mods will look nicer in white text, just like the actual keys.
Can't do that with dyesub
| LIVING THE 1800 LIFE |
Offline ye_cole
« Reply #151 on: Sun, 07 October 2018, 18:44:57 »
Hey OP! I know you're still working out the colors for the set with ePBT, but I was wondering if you had a rough estimate on when the group bay will start? I'm trying to figure out my finances to buy into all of these group buys x|. Thanks!
I'd guesstimate in 1-2 months. I can't be 100% sure, though, as making sure the colors are correct is very important to me.
Offline _ODIN_
« Reply #152 on: Wed, 24 October 2018, 06:49:40 »
Are the kits final yet? I would love to see split space bars in the alpha color.
Offline the_high_5
« Reply #153 on: Tue, 06 November 2018, 18:15:56 »
Also checking in for updates.
Offline ye_cole
« Reply #154 on: Tue, 06 November 2018, 19:49:11 »
Kits are final, just sent over new sample colors for KBDfans to match yesterday.
