Author Topic: [IC] ePBT Fortune (ssssamples)  (Read 53689 times)
Offline ye_cole
Re: [IC] ePBT Fortune
« Reply #100 on: Mon, 20 August 2018, 00:25:57 »
Mmmhmm, yup. ePBT everything. Looks good,  :thumb:
do it for the texture
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #101 on: Mon, 20 August 2018, 01:21:28 »
Any forthcoming plan for the keyset?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #102 on: Mon, 20 August 2018, 18:10:26 »
If you're still debating profile, there's now PBT SA and KAT/KAM to consider.
Offline ye_cole
« Reply #103 on: Mon, 20 August 2018, 20:57:15 »
KBDfans will have samples done in 25-35 days.
Sticking with ePBT for this run.
Offline ye_cole
« Reply #104 on: Mon, 20 August 2018, 21:03:19 »
Kit:
Offline _ODIN_
« Reply #105 on: Tue, 21 August 2018, 08:06:57 »
Just saw this.
Will an international kit be available?
Offline ye_cole
« Reply #106 on: Tue, 21 August 2018, 10:46:09 »
Just saw this.
Unfortunately, no, as there usually isn't demand for int'l kits- they end up sitting. Sorry about that.
Offline the_high_5
« Reply #107 on: Sat, 25 August 2018, 13:50:03 »
I'm sure the kit is already finalized, but all grey function and arrow keys would be awesome. Still keeping my eye out on this one though! Really looking forward to it.
Offline euphxenos
« Reply #108 on: Sat, 25 August 2018, 15:34:54 »
I think there's a mistake in the new kit, probably because ePBT's row numbering (443211) is reversed from GMK's (112344).  Where the old GMK kit had an R3 PgUp and R4 PgDn to support 65% layouts like the Tada68, the new ePBT kit would need an R2 PgUp and R1 PgDn to achieve the same goal, but the new ePBT kit has an R3 PgUp and R4 PgDn, which doesn't make any sense.  It looks like they were just moved over to the new kit without factoring in the reversed row numbering.  You probably want to drop the R3 PgUp/R4 PgDn and replace them with R2 PgUp/R1 PgDn.
Offline ye_cole
« Reply #109 on: Sat, 25 August 2018, 19:10:29 »
Thank you for pointing this out!
This was an oversight on my behalf and I've fixed it. :)
It's pretty much finalized, sorry about that! I'm glad you're looking forward to it though. :)
Offline oldcat
  • 65% is Life
« Reply #110 on: Sat, 25 August 2018, 21:09:30 »
assuming this will be cherry profile?
Offline bthezebra
« Reply #111 on: Sat, 25 August 2018, 21:11:12 »
To my knowledge epbt only does cherry profile pbt caps
Offline oldcat
  • 65% is Life
« Reply #112 on: Sun, 26 August 2018, 00:51:36 »
let's get this to work!
Offline forevermadrigal
« Reply #113 on: Thu, 30 August 2018, 06:31:36 »
Reminds me of gmk oasis!
Offline ye_cole
« Reply #114 on: Thu, 30 August 2018, 22:12:24 »
Current status- pantone chips have been sent to factory for color matching.
Offline Rubbermilitia
« Reply #115 on: Mon, 03 September 2018, 01:09:48 »
The real tragedy is that this set abandons the best thing about the original set: it was made of lovely sphericals.
Agreed, this set should def be SA/MT3
No love for the uniform gray f-row?
Agreed, should keep the gray f row, its part of the charm of the original set
I like what you're trying to accomplish and I know you've been working this for awhile, but I really think the original set is just must more attractive.. something about the wacky color scheme just works, and that charm is lost when translated to the standard color layout of every other custom set.
Agreed, color scheme should duplicate the original board rather than normalizing it to be like every other set, the way eric clapton makes every blues song sound the same
Offline yaya
« Reply #116 on: Mon, 03 September 2018, 11:01:58 »
Yep, no SA or grey F row, no buy from me.  Loses the appeal of the original.
Offline the_high_5
« Reply #117 on: Tue, 18 September 2018, 18:31:11 »
Just a good ol' fashion bump to check for any updates. I hope this set doesn't get forgotten!
Offline ye_cole
« Reply #118 on: Tue, 18 September 2018, 21:45:27 »
samples! asked about grey, no response for now
ofc not, thanks for bump!
Offline gt1989
« Reply #119 on: Tue, 18 September 2018, 22:16:32 »
any warping on the spacebars?
Offline ye_cole
« Reply #120 on: Tue, 18 September 2018, 23:32:04 »
they're not actually with me, so I cannot check.
Offline pixelpusher
Re: [IC] ePBT Fortune (ssssamples)
« Reply #121 on: Wed, 19 September 2018, 09:40:24 »
We'll see in time, but it appears the alphas are a bit more on the greenish side than the original
Offline ye_cole
« Reply #122 on: Wed, 19 September 2018, 14:04:08 »
there's some samples in better lighting
Offline ye_cole
« Reply #123 on: Wed, 19 September 2018, 14:04:54 »
I noticed the green tinge too, they're gonna ship to me so I can make sure these colors will be correct
Offline redbanshee
  • actually Dade Murphy
« Reply #124 on: Wed, 19 September 2018, 14:08:39 »
Damn bro your photos are truly ass. You should maybe mount them on a board, throw away your potato camera and take some pics that are anywhere remotely acceptable.
Thanks
Offline pixelpusher
« Reply #125 on: Wed, 19 September 2018, 14:10:50 »
Thanks
Well, they aren't his photos.  so....
These colors might just be right.  That second one you shared seems more promising.  Excited to see this one come to life.  Very unique set.
Offline redbanshee
« Reply #126 on: Wed, 19 September 2018, 14:18:51 »
Thanks
Well never mind then, just really cant tell much from the photos. Guess that sounded bad lmao, sorry ye_cole
« Last Edit: Wed, 19 September 2018, 14:24:12 by redbanshee »
Offline the_high_5
« Reply #127 on: Wed, 19 September 2018, 14:42:38 »
This photo is definitely more reassuring than the first photo. Either way, I have faith in you OP! Looking forward to seeing more.
ps. Is an all grey F-row still out of the question?  ;)
Offline oldcat
  • 65% is Life
« Reply #128 on: Wed, 19 September 2018, 15:28:11 »
When is this dropping?
Offline ye_cole
« Reply #129 on: Wed, 19 September 2018, 17:46:32 »
Actually, no, it isn't. I'll speak to KBDFans and see if we can do that.
No ETA at the moment. If I see the samples and like them, then we're ready to proceed.
« Last Edit: Wed, 19 September 2018, 22:45:18 by ye_cole »
Offline the_high_5
« Reply #130 on: Wed, 19 September 2018, 22:24:04 »
Ohhh lawdy! I'm all fired up now. Thanks for the updates.
Offline obertau
« Reply #131 on: Thu, 20 September 2018, 03:38:23 »
All gray f-row please.
Offline ye_cole
« Reply #132 on: Fri, 21 September 2018, 20:51:15 »
Yes boss
"final sample" in a few days- assuming that means with text. :)
all grey f row isn't going to be in that sample, but that shooould be made.
Offline portbaron
« Reply #133 on: Mon, 24 September 2018, 11:34:48 »
I've got an 1800 waiting for this.
« Last Edit: Mon, 24 September 2018, 11:37:19 by portbaron »
| LIVING THE 1800 LIFE |
Offline ye_cole
« Reply #134 on: Thu, 27 September 2018, 12:58:15 »
Color samples arriving tomorrow for me
Offline stoic-lemon
« Reply #135 on: Fri, 28 September 2018, 00:22:15 »
All F grey row!!!
Offline _ODIN_
« Reply #136 on: Fri, 28 September 2018, 02:29:14 »
All F grey row!!!
I prefer the normal f-row  :cool:
Offline plexabyte
« Reply #137 on: Fri, 28 September 2018, 09:38:26 »
At first I was not excited about going full "yellowed abs" but that yellow (even with the potato quality) looks pretty good; still much too yellow IMO, but I can deal with it. I'm all for more epbt sets too. As long as the blue-green is more...muted(?) like the original I'm in. Would look spicy on a blue-gray board.
« Last Edit: Fri, 28 September 2018, 09:41:19 by plexabyte »
Offline portbaron
« Reply #138 on: Fri, 28 September 2018, 10:14:51 »
All gray F bruh
Offline ye_cole
« Reply #139 on: Fri, 28 September 2018, 18:45:27 »
You can choose- both are going to be in the base kit.
It's 5 and still haven't gotten the samples yet, so I assume they're coming on Monday, but I'll make sure that the colors actually turn out nicely- don't worry! Also, I think you may be right about the "saturation" of the teal. Won't know for sure until monday/tuesday, though.
Offline obertau
« Reply #140 on: Fri, 28 September 2018, 22:32:32 »
In the last picture, all three colours look a bit saturated. Maybe it’s the picture but I would prefer a bit lighter and more muted for all three colours.
Offline ye_cole
« Reply #141 on: Tue, 02 October 2018, 21:32:30 »
I've recieved the samples. They do look a bit too saturated. I'm going to go to a pantone dealer and look at the colors in person to fine tune them a bit better, and I'll ask KBDFans to send new samples.
Offline pixelpusher
« Reply #142 on: Tue, 02 October 2018, 21:49:06 »
Thanks, man.  Yeah those look like they’ve been around cigarette smoke for a few decades.  Not the subtle yellow from normal aging.
Glad you’re going to revise the color.  Still love the idea of this one
Offline mopaska
« Reply #143 on: Fri, 05 October 2018, 18:12:27 »
I have some old GMK renders: (to show what epbt would perhaps look like)
I really like the GMK render. The colors: the off-white, the vibrant mods, the blue-gray enter.
The alphas - can you go with the standard ePBT beige? For example, the colors of the mods in this: https://www.1upkeyboards.com/shop/keycaps/enjoypbt-keycap-set-english-red/
The only reason I bring this up is because I look at the other renders, the samples, and then I look at the pic in the signature... and I keep thinking "damn, the signature looks sexy".
Offline _ODIN_
« Reply #144 on: Fri, 05 October 2018, 18:14:27 »
I like the special color. In my opinion the standard beige is a bit boring for this set.
Offline ye_cole
« Reply #145 on: Fri, 05 October 2018, 21:09:45 »
I want the set to look like the first GMK render.
Offline Nerdbot5000
« Reply #146 on: Sat, 06 October 2018, 15:45:45 »
Super glad there are more sets from enjoypbt. Really like the less intense shade of yellowing on the alpha's in the 2nd GMK render, but I do like the color of the mods you settled on.
Offline the_high_5
« Reply #147 on: Sat, 06 October 2018, 17:24:55 »
Hey OP! I know you're still working out the colors for the set with ePBT, but I was wondering if you had a rough estimate on when the group bay will start? I'm trying to figure out my finances to buy into all of these group buys x|. Thanks!
Offline _ODIN_
« Reply #148 on: Sat, 06 October 2018, 18:44:03 »
+1
Offline donutholer
« Reply #149 on: Sat, 06 October 2018, 19:41:56 »
I think the mods will look nicer in white text, just like the actual keys.
