Author Topic: [IC] Owl 660 - custom keyboard 660m layout - Prototype/PCB ready! fix plate  (Read 42861 times)
Offline hikashi1988
Re: [IC] Owl 660 - custom keyboard 660m layout
« Reply #100 on: Wed, 20 June 2018, 10:15:35 »
Looks nice though.
Missed the KBD661 though.
Offline The_judge_168
« Reply #101 on: Wed, 20 June 2018, 16:07:18 »
Sample looks nice! What will the color options be?
Offline Tree_
« Reply #102 on: Thu, 21 June 2018, 02:52:01 »
Came out looking pretty good!  :thumb:
Offline QiuFang
    • Owl Keyboard
« Reply #103 on: Thu, 21 June 2018, 10:01:28 »
Ye,The kit will come with a diffuser
Final plate will come with all layout below, and pcb mount.
have you decided on the colours ?
I have a little discussion with the engineer, since this is my first attempt to open 1 GB. So I'll just stop at 3 basic colors: silver / black / red
  You know, many colors will have more risk of error as well as difficulty in ordering process.
Offline QiuFang
    • Owl Keyboard
« Reply #104 on: Thu, 21 June 2018, 10:11:22 »
Silver/Black/Red.
 :thumb:
Offline hikashi1988
oh wait? just notice it does not support split backspace on the plate.  :'(
Offline Mcnos
    • GMK Fuyu
Proto looks good, did you lower the front angle? I can't tell from the pictures
Offline Poesjuh
Fixed bottom row and no stepped caps either. I was mostly thinking it would be a “proto” thing and the end result will have more flexibility.
Offline QiuFang
    • Owl Keyboard
This plate is just a test of the factory's ability to process.
Split space depends on the PCB
Offline QiuFang
    • Owl Keyboard
I did not change anything, still the same as the drawing I presented as the original.
Probably because I did not install the diffuser so it looks lower in the render.
Offline foxmancore
when are you planning on starting the GB?
Offline Novice
  • Bludgeoned Kaps
    • Insta
Looking forward to the GB! :thumb:
I'm not superstitious but I am a little stitious.
Offline _ODIN_
will definitely pick up a black one
Offline QiuFang
    • Owl Keyboard
I'm going to learn a few more things, maybe today or tomorrow I will open the GB
Offline QiuFang
    • Owl Keyboard
Thanks man!
It's my pleasure
Offline Randalljai
Any chance we can get a picture of it from the left/right side when its built? So that we can see the angle and etc from that side.
Looking great though!
Offline M
any updates?
Offline QiuFang
    • Owl Keyboard
PCB has finished, I will test a few points before opening GB.
Offline _ODIN_
take your time and make sure that everything is working correctly
Offline Aerizu
  • Professional Lurker
Based on the pictures, the plate doesn't seem to support split backspace but the PCB does.
Will the final plate design be a universal one (supporting both split and non-split backspace) or do you plan to offer different plates for each?
Offline _ODIN_
different plates would be better imo
Offline QiuFang
    • Owl Keyboard
Ye, this plate I made a mistake, it even has no holes to plug the leds to the 3 signal lights anymore.
But in terms of size, it's pretty accurate. Final plate will be uni version. There are enough layouts that this pcb supports, as I have posted before.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
will you be exploring other coloring options such as MAO or cerakoting for this run?
Offline QiuFang
    • Owl Keyboard
This is my first GB, I do not want to go wrong. I think it will only be silver and black.
Offline Aerizu
Alright, I think it's a nice decision and it keeps it simple enough.
Offline QiuFang
    • Owl Keyboard
Final design plate:
Offline _ODIN_
Final design plate:
Looking good :thumb:
Will the plate support stepped caps lock?
Offline foxmancore
So in! Let's start this GB :)
Offline mast3rwanderer
Consider me interested  :thumb:
Offline QiuFang
    • Owl Keyboard
Final design plate:
Yes
:thumb:
:thumb:
Offline QiuFang
    • Owl Keyboard
GB on air! waiting approval by a moderator.
Offline Abec13
Re: [IC] Owl 660 - custom keyboard 660m layout - Prototype/PCB ready! fix plate
« Reply #131 on: Mon, 15 October 2018, 07:17:55 »
 Is this a thing? A 66% with underglow has been my endgame since I started. I've been looking all over!
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #132 on: Mon, 15 October 2018, 08:19:07 »
Umm you might just be a little late to the party?
Offline Abec13
« Reply #133 on: Mon, 15 October 2018, 10:59:46 »
I always am... Damn. I really wanted something like this in Silver. I hope resale isn't too much.
[/url]
Offline slxdegrees
  • Nerds With Keebs
« Reply #134 on: Mon, 15 October 2018, 11:12:32 »
With only 10 units made...I think you'd be better off directly contacting TS/OP to see if he has an empty slot.
Offline Tree_
« Reply #135 on: Mon, 15 October 2018, 18:37:42 »
QuiFang posted in the GB thread last month saying he might have spares: https://geekhack.org/index.php?topic=96416.msg2657430#msg2657430
Offline NZcaps
« Reply #136 on: Tue, 16 October 2018, 04:07:09 »
Amazing board!
