Author Topic: [IC] Lunar AEK 65% - 100% Complete.  (Read 200416 times)
Offline reconsiderit
  • I'm actually not left handed www.switchplate.co
« on: Mon, 11 June 2018, 01:56:47 »
Lunar - AEK 65%
Designed by ai03, distributed by Switchplate Peripherals
Endgame-tier 65% board designed for the original sculpted keycap profile found on the Apple Extended Keyboard and the m0116. Composed of an entirely CNCed chassis made from 7075 aircraft grade aluminum alloy, the board features an integrated 4mm plate, USB Type-C, and split space options.
Details
Curvature-matched chassis
Fully CNCed out of durable AL7075
Integrated 4mm alps plate with cutouts engineered from the ground up
Two dedicated plate layouts available - 6.5u and Split Space
5 degree base angle
USB-C specific chassis
Alps-specific PCB available with Keyplus firmware QMK
Color Options
Silver (Non-dyed Type-2 Anodization)
Grey (Dyed Type-2 Anodization. Based off of Pantone 10388c)
Layouts
Lunar is built around a specific set of keycaps with a dedicated 4mm plate. This means that each plate will only accept a single layout. This is done so that the 4mm plate is as effective as possible, providing the most consistent feel across the entirety of the board.
The 65% layout requires the use of the AEK caps lock key or the r1 command key on the m0116 for 1.75U right shift.
Pricing
Chassis - $350
PCB - $40
Resin 1.75u Shift - $25
Rough Timeline
Late June August: Open Group Buy
Late July September: Close Group Buy
Late September TBD: Complete Production
Mid October Q1/Q2 2019: Shipping
To Do
Prototyping  DONE
Group Buy DONE
Production ROUND TWO
Shipping IN PROGRESS (kinda)
Gallery
INTEREST CHECK FORM: https://goo.gl/forms/7hlpSReRcmrMnARl1
« Last Edit: Wed, 15 January 2020, 03:37:28 by reconsiderit »
Southpaw 65 || Southpaw Full Size || Trinity XT TKL || TGR Jane V2 || TGR 910 RE || Duck Jetfire || Matrix Lab 1.2 OG || Jubi || Lunar || Lunar II || g80-1800 HEU
switchplate.co
Offline ai03
  • I do not reply to PMs; contact me via website
    • Website
Re: Lunar AEK 65%
« Reply #1 on: Mon, 11 June 2018, 01:57:15 »
FAQ, updated often
Q. How's the prototype going?
A. Photo of in-progress prototype.
See thread for newer prototypes. production units.
Q. What do I need for caps?
A. Just a single AEK and a resin-cast color-matched 1.75U shift keycap which will be offered in the buy.
If you want a legended 1.75U, another AEK (Caps lock) or a M0116 (1.75U opt) is necessary.
Q. What's this resin-cast 1.75U key?
A. It will be cast based on the original AEK caps, and will match the original caps in color.
Q. Why Keyplus rather than QMK?
A. Zero driver issues, one-click reflash keymaps in a fraction of a second, no need to reflash firmware every time, unbrickable.
Changed to QMK
Q. What do I need for stabilizers and such?
A. A single AEK will supply enough stabilizers for the entire board, even for split space (by reusing numpad stabs). For single spacebar users, the "stabilization pillar" under the spacebar should be transplanted as well.
Q. Why no ISO?
A. Unfortunately, the AEK uses a skinny ISO enter, meaning every single key would have to be shifted 0.25U to the right. It would have led to the plate being just horizontal bars between the rows, or higher price overall due to more variants.
Q. Which switches are compatible with this?
A. Alps SKCM/SKCL, Alps SKBM/SKBL, and their respective clones (Matias, Tai-Hao, etc).
Q. Any chance of different material plate?
A. Unfortunately, the plate is integrated into the top half of the chassis. A separate plate would have resulted in a ridiculous price tag.
Q. What's the price?
A. We're finalizing the target price right now. It will be below the $400 mark.
The high price is caused by the large curves and complex side/underside geometry.
Final price announced.
Q. How many will be sold?
A. Around 50, on a first-come-first-serve basis. In addition, the Z-B-stock and C-stock are available for sale.
Q. Any chances of a matching numpad?
A. One was designed and 3D-printed for prototyping. As for CNC production, possibly in the future, but not as of now.
« Last Edit: Sat, 27 April 2019, 21:30:13 by ai03 »
Offline idlemao
Re: Lunar AEK 65%
« Reply #2 on: Mon, 11 June 2018, 02:00:03 »
That's just beautiful. I wasn't sure if I'd want another board beyond the upcoming UEK, but this has my interest piqued. And the name is great! Is it too early to get an idea of the cost?
Offline Remsky
  • Lubed switch count > Puddsy post count
Re: Lunar AEK 65%
« Reply #3 on: Mon, 11 June 2018, 02:00:11 »
Been waiting on this for a while! Looks so good
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline M
Re: Lunar AEK 65%
« Reply #4 on: Mon, 11 June 2018, 02:06:55 »
will you have a physical sample of the board ready to show us before the buy opens?
Offline droideggs
Re: Lunar AEK 65%
« Reply #5 on: Mon, 11 June 2018, 02:08:51 »
simply stunning
Offline loud_asian
Re: Lunar AEK 65%
« Reply #6 on: Mon, 11 June 2018, 02:10:49 »
What's the price point that we're looking at?
I'd love to get one in each color :p
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
Re: Lunar AEK 65%
« Reply #7 on: Mon, 11 June 2018, 02:11:42 »
:nut:
Offline gok_nz
  • Enjoy your PBT
    • Website
Re: Lunar AEK 65%
« Reply #8 on: Mon, 11 June 2018, 02:23:58 »
Nice.
Offline blacksimon
  • illuminati.works
    • illuminati.works
Re: Lunar AEK 65%
« Reply #9 on: Mon, 11 June 2018, 02:26:29 »
I support this, with my wallet. Where do I insert the money sir?
Offline Remsky
Re: Lunar AEK 65%
« Reply #10 on: Mon, 11 June 2018, 02:46:09 »
Im not sure when exactly the proto is arriving, but he did order it recently.
Offline LeoShi
Re: Lunar AEK 65%
« Reply #11 on: Mon, 11 June 2018, 03:17:28 »
looks interesting, can't wait to see the samples :p
Offline stoic-lemon
Re: Lunar AEK 65%
« Reply #12 on: Mon, 11 June 2018, 03:17:35 »
A home for these green switches I have!
Offline foxmancore
Re: Lunar AEK 65%
« Reply #13 on: Mon, 11 June 2018, 03:21:45 »
Wow looks awesome, will definitely join this GB
Offline xondat
  • i'm not a star
Re: Lunar AEK 65%
« Reply #14 on: Mon, 11 June 2018, 05:53:15 »
Hotness. First PCB with Keyplus? :)
Offline donut_sauce
Re: Lunar AEK 65%
« Reply #15 on: Mon, 11 June 2018, 06:05:03 »
Yup. Interested:)
Offline Mcnos
    • GMK Fuyu
Re: Lunar AEK 65%
« Reply #16 on: Mon, 11 June 2018, 08:09:16 »
Err, YES
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Lunar AEK 65%
« Reply #17 on: Mon, 11 June 2018, 08:26:16 »
Perfect timing for me as I have been getting into ALPS switches & AEKIIs lately! I got a really janky AEK64 PCB I managed to get working I was planning on doing an ALPS build with, but would much rather go with a full kit like this. I do have say the fact the PCB is using Keyplus is a little worrisome though. I hope that it is an easier solution than the QMK or other firmware flashing utilities, but I'd be lying if I said I'd prefer it over them on what will surely be a decently expensive kit. Anybody have any experience with Keyplus at all yet? Just wondering how well it works & reliable it is so far?
Offline pixelpusher
Re: Lunar AEK 65%
« Reply #18 on: Mon, 11 June 2018, 10:06:00 »
I don't know who  ai03 or Switchplate Peripherals are.  Have they worked on other products?
Offline Mcnos
    • GMK Fuyu
Re: Lunar AEK 65%
« Reply #19 on: Mon, 11 June 2018, 10:10:43 »
Am curious to what the price point would be marketed as, iirc the UEK is just around the corner at around 200USD
Offline pixelpusher
Re: Lunar AEK 65%
« Reply #20 on: Mon, 11 June 2018, 10:14:29 »
I like the design of the UEK better, but this one is a 65%.  On top of that, you could use a layout with split spacebar to avoid the yellow space bar :)
Offline oatmicro
Re: Lunar AEK 65%
« Reply #21 on: Mon, 11 June 2018, 11:21:05 »
nice
Offline Rowanblood
Re: Lunar AEK 65%
« Reply #22 on: Mon, 11 June 2018, 13:26:06 »
This is an autobuy for me, but I'd honestly prefer to see QMK on here.
What chip is going to be on the PCB?
Offline Hokabuki
Re: Lunar AEK 65%
« Reply #23 on: Mon, 11 June 2018, 13:26:30 »
Can we get some renders with a few different key profiles?
Offline Vigrith
Re: Lunar AEK 65%
« Reply #24 on: Mon, 11 June 2018, 14:01:50 »
What do you mean? AEK is the only profile that'll fit in this.
Offline Rob27shred
Re: Lunar AEK 65%
« Reply #25 on: Mon, 11 June 2018, 15:02:43 »
The firmware is a concern of mine as well & I'd also like to know what IC the PCB will be using? Just kinda hesitant to tear apart one of my AEKIIs for a 65% or 60% ALPS build until I'm 100% behind the kit.
Offline koduh
Re: Lunar AEK 65%
« Reply #26 on: Mon, 11 June 2018, 16:08:13 »
Looks fantastic!
Offline _ODIN_
Re: Lunar AEK 65%
« Reply #27 on: Mon, 11 June 2018, 16:09:32 »
looks nice. ISO support would be awesome tho
Offline Remsky
Re: Lunar AEK 65%
« Reply #28 on: Mon, 11 June 2018, 16:26:44 »
Its gonna use an integrated thick plate, so its pretty much confirmed to be a no
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
Re: Lunar AEK 65%
« Reply #29 on: Mon, 11 June 2018, 16:29:04 »
Very yes!!
I have the most amazing salmon alps in an old M0116 that I loved as a kid sitting in my workshop. That board probably has a lot to do with my keyboard love (obsession?) now. I have been waiting for the right nudge to pull them out and make a modern board I’ll actually use again. Look, you all know I’m a nerd but these babies are a little (sniff) sentimental. This design looks great though and would be a fitting home. I’m all in when it runs, thanks for putting the project together.
Offline ai03
    • Website
Re: Lunar AEK 65%
« Reply #30 on: Mon, 11 June 2018, 16:42:01 »
Hello, replying to some questions.
The PCB runs an atxmega32a4u. It is much higher performing than a typical atmega32u4, while being lower in price.
As for the firmware, Keyplus is magic. Zero driver issues, one-click reflash keymaps in a fraction of a second, no need to reflash firmware every time, unbrickable. I have been using it on my two daily driver boards for a few weeks now without any issues.
I've designed the Contra run by Cartel a while back, along with various open-source PCBs and personal chassis commissions. Switchplate has run the Southpaw65 and various other buys through their store.
We're finalizing the target price right now. Unfortunately, it will be more expensive than the UEK.
Offline Rykno
Re: Lunar AEK 65%
« Reply #31 on: Mon, 11 June 2018, 16:47:26 »
Can we get split backspace support please?
Offline Remsky
Re: Lunar AEK 65%
« Reply #32 on: Mon, 11 June 2018, 17:02:48 »
Again, the plate is fixed, so the layout is fixed.
Offline ai03
    • Website
Re: Lunar AEK 65%
« Reply #33 on: Mon, 11 June 2018, 17:25:22 »
It would require a whole two extra variants, since Alps stabs intersect switch cutouts in such a layout on a single plate.
Offline Kan3abl3
Re: Lunar AEK 65%
« Reply #34 on: Mon, 11 June 2018, 18:04:54 »
I'm new to geekhack and groupbuys in general but will there an option for just the PCB? I love 65% and Alps but I don't think I'll be able to drop $200+ on this unfortunately.
Offline ai03
    • Website
Re: Lunar AEK 65%
« Reply #35 on: Mon, 11 June 2018, 19:14:20 »
Most likely yes.
Offline nu_types
  • Formerly Iredeus
Re: Lunar AEK 65%
« Reply #36 on: Mon, 11 June 2018, 19:22:03 »
This will be an instabuy for me!
Offline Sshimosawa
Re: Lunar AEK 65%
« Reply #37 on: Mon, 11 June 2018, 19:55:35 »
Yup. Totally. This.
Offline Rykno
Re: Lunar AEK 65%
« Reply #38 on: Mon, 11 June 2018, 20:36:39 »
Ah, I didn't know it was a technical limitation. Thanks for clarifying!
Offline bball2
Re: Lunar AEK 65%
« Reply #39 on: Mon, 11 June 2018, 21:36:54 »
Why the 6.5u spacebar? That's not a very common size and rarely included in any base kits. Have you considered a 1.25 / 1.25 / 1.25 / 6.25 / 1 / 1 / 1 / 1 / 1 layout?
Offline pixelpusher
Re: Lunar AEK 65%
« Reply #40 on: Mon, 11 June 2018, 21:56:11 »
This is a kit that requires you to use the keycaps from an Apple Extended Keyboard.  The boards have a 6.5u space bar.  Those keycaps have unique sculpture and stem height that fits the curve of this case.
Offline Remsky
Re: Lunar AEK 65%
« Reply #41 on: Mon, 11 June 2018, 22:34:01 »
Layouts
- from the OP
Offline Daellin
Re: Lunar AEK 65%
« Reply #42 on: Mon, 11 June 2018, 23:30:05 »
Ooh. A split space alps. Interest piqued!
Offline pixelpusher
Re: Lunar AEK 65%
« Reply #43 on: Mon, 11 June 2018, 23:39:42 »
So we would need 2 sets of caps to make a full 65% layout, right?  Since we need the extra for the right side shift
Offline Remsky
Re: Lunar AEK 65%
« Reply #44 on: Tue, 12 June 2018, 00:18:08 »
2 x AEK caps, or 1 M0116 I believe
Offline tanvir175
Re: Lunar AEK 65%
« Reply #45 on: Tue, 12 June 2018, 01:19:12 »
Issa good thing I have 2 x AEK keycap sets
Offline biip
    • @biipmk
Re: Lunar AEK 65%
« Reply #46 on: Tue, 12 June 2018, 04:34:04 »
very interested, rly nice look!
Offline olivia
Re: Lunar AEK 65%
« Reply #47 on: Tue, 12 June 2018, 09:10:58 »
I love this :D
Offline soba
Re: Lunar AEK 65%
« Reply #48 on: Tue, 12 June 2018, 09:23:31 »
Beautiful design.
Offline vewy_nice
Re: Lunar AEK 65%
« Reply #49 on: Tue, 12 June 2018, 10:10:16 »
Yes please.
Any even remotely small chance of different colors?
I'd LOVE something more than grey/space grey!
