Author Topic: [IC] 7V - 75% Keyboard (GB Live!)  (Read 769010 times)
Offline Denkii
Re: [IC] 7V - 75% Keyboard (14/03/2020 UPDATE - PRICING AND DATE ANNOUNCED)
« Reply #1200 on: Tue, 17 March 2020, 06:23:25 »
Is there a limit to the GB or is it unlimited?
Offline gt1989
« Reply #1201 on: Tue, 17 March 2020, 06:24:59 »
unlimited
Offline Denkii
« Reply #1202 on: Tue, 17 March 2020, 06:29:20 »
Thanks for the fast reply!
Exactly what I wanted to hear.
So Jules and this ahead...and then building bank for satisfaction r2. My wallet is crying.
Offline Jaltr
« Reply #1203 on: Tue, 17 March 2020, 08:19:15 »
Wait, is there going to be a second run of the satisfaction 75? Bruh
Sent from my SM-J415G using Tapatalk
Offline vi0till
« Reply #1204 on: Tue, 17 March 2020, 08:38:27 »
From cannonkeys IG, r2 later this year.
Sent from my VOG-L29 using Tapatalk
Offline Jaltr
« Reply #1205 on: Tue, 17 March 2020, 09:05:28 »
Thanks man, appreciate it
Offline jimcutlet
« Reply #1206 on: Tue, 17 March 2020, 17:30:39 »
are the boards just made to the numbers ordered, or will the vendors be ordering extra?
i'm keen but given the economy (as a contractor) i'm hesitant to pull the trigger on something like this when I know money is going to be tight down the line..
Offline dak148
« Reply #1207 on: Tue, 17 March 2020, 17:55:23 »
There are usually extras because not all the ones coming off the line will be up to quality standards. So there is "A" stock and "B" stock. I think most vendors will order extras though.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1208 on: Tue, 17 March 2020, 18:21:26 »
Any pictures of the final dark blue color that will be sold?
Upping this so Gok can see as well. I'm really leaning towards blue if its a decent shade.
+1 on this.
Sent from my SM-G975F using Tapatalk
+1 on this.
+1 on this
There won't be a proto of the final blue but I will have a Pantone colour. Keep in mind that anodised colours can only get to a certain level of accuracy and won't match the Pantone 100%.
I have a bunch of fan swatches from the TPG, C and U range but I'm waiting for a large swatch because things don't always look the same en masse.
Offline leexy
« Reply #1209 on: Tue, 17 March 2020, 22:38:50 »
e-whiteeeeee
Offline //gainsborough
  • MATRIXの日常
« Reply #1210 on: Tue, 17 March 2020, 22:40:44 »
april 10th GB....
7v...
gok, are you a final fantasy VII fan?
Offline verity
« Reply #1211 on: Wed, 18 March 2020, 17:11:28 »
My body is ready for this but my wallet isn't.
Offline Septemberkb
« Reply #1212 on: Wed, 18 March 2020, 22:10:31 »
Just saw the satisfaction 75 r2 ig post this morning. Wondering if they can keep their pricing to the $400 ceiling this time too.
Anyone else being forced to choose between this and the upcoming satisfaction 75?
Offline itsmartin
« Reply #1213 on: Wed, 18 March 2020, 22:14:48 »
Sat75 will be more expensive, Upas has mentioned in the CannonKeys Discord. Increased taxes are primarily a reason.
I wouldn't expect the Sat75 R2 to run until much closer to the end of the year as well, if that impacts your ability to choose between the 7V and Sat75.
Offline VoidX
« Reply #1214 on: Wed, 18 March 2020, 22:24:52 »
This looks incredible and have had my eye on it since I first started looking at custom boards. Wanted this to be my first full custom but prob will have to wait until I build up more funds haha. Satisfaction 75 r2 might fit in better with that...
Offline krey
« Reply #1215 on: Wed, 18 March 2020, 23:18:02 »
Will definitely join in!
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline pchoi
« Reply #1216 on: Wed, 18 March 2020, 23:20:41 »
@Gok (or anyone else that knows) does the WT75-C pcb support USB-C to USB-C connections? Or just USB-C to USB-A?
Offline Aznattack
« Reply #1217 on: Fri, 20 March 2020, 10:57:20 »
Just wondering if someone was able to answer this question. If I were to get this board and solder on in-switch LEDs, are the LEDs toggleable? or are they on all the time? Thanks
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1218 on: Fri, 20 March 2020, 11:07:40 »
QMK firmware has a LED toggle keycode, so you're able to toggle lights on and off and change brightness levels, yes.
Jerry Talks Tech - youtube.com/jerry
Offline batmanwcm
« Reply #1219 on: Fri, 20 March 2020, 11:38:46 »
Isn't the Satisfaction 75 limited to 100 units like the last round?
Offline gt1989
« Reply #1220 on: Fri, 20 March 2020, 11:41:05 »
round 1 was 250 GB slots, and we don't know if it'll be the same for round 2
« Last Edit: Fri, 20 March 2020, 16:55:44 by gt1989 »
Offline batmanwcm
« Reply #1221 on: Fri, 20 March 2020, 16:51:10 »
I'll be trying to get both.  Atleast with the 7V, it's a open group buy.
Offline ITjanitor
« Reply #1222 on: Fri, 20 March 2020, 19:30:14 »
Are the colors and SS weights pre-matched or can you pick the colors on both?
Offline chowbabyloving
« Reply #1223 on: Fri, 20 March 2020, 21:08:11 »
The white is an extra cost?
Will it be the usual $20-30?
Also, is it likely that getting a black weight for a blackout 7V will be about that same cost?
Offline itsmartin
« Reply #1224 on: Fri, 20 March 2020, 21:10:21 »
Gok mentioned the black PVD was significantly more expensive than the SS, so I am guessing that it will be much more than $20 for the black weight.
Offline 10peaches
« Reply #1225 on: Sat, 21 March 2020, 19:05:52 »
I would be expect the black pvd weight alone would cost at least a set of GMK keycaps.
Offline lush_bunny
« Reply #1226 on: Sun, 22 March 2020, 02:32:20 »
Damn. April's going to be an expensive month.
Offline Poesjuh
« Reply #1227 on: Sun, 22 March 2020, 12:06:51 »
Still patiently awaiting any kind of typing video so I have some clue as to how it will sound.
Offline Anj
« Reply #1228 on: Sun, 22 March 2020, 20:57:03 »
This is beautiful, I might have to buy two... a black and white one. Or maybe a white with a black weight. Curious to see how that would look and if it's possible. But damn, rip my wallet next month.
Offline psvntrm
« Reply #1229 on: Sun, 22 March 2020, 21:18:55 »
Hot swap for this?
Offline 10peaches
« Reply #1230 on: Sun, 22 March 2020, 22:07:44 »
Hot swap for this?
Only solderable pcb.
Offline kaiba
« Reply #1231 on: Mon, 23 March 2020, 13:40:59 »
Apologies if this was already asked or mentioned - are there/will there be any photos of a prototype for the grey version of the case?
Offline 10peaches
« Reply #1232 on: Mon, 23 March 2020, 15:53:19 »
The last prototype Gok is waiting for is grey.
Offline silverstreakz
« Reply #1233 on: Tue, 24 March 2020, 08:13:42 »
I'm sorry, just chanced upon this and wondering if all the colours in the gallery above will be the final colours offered?
Also, will it be possible to solder in millmax or kailh hotswap sockets on the pcb?
Offline ITjanitor
« Reply #1234 on: Tue, 24 March 2020, 10:24:16 »
Also interested in question about millmax and kailh hotswap.
Offline dom
  • allergic to hypocrisy
« Reply #1235 on: Wed, 25 March 2020, 06:40:46 »
For anyone who wants to check the color combinations, here is the PSD: https://cl.ly/da29d3b6204a
WARNING: It's crappy, but enough for reference ;)
God bless!
Offline lac29
« Reply #1236 on: Wed, 25 March 2020, 10:15:27 »
Dang, good job with the psd file. I dled it and opened it up to take a look. Great stuff ... white looks the best imo and it made me realize that gray and black don't necessarily go along with all/most keysets.
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1237 on: Wed, 25 March 2020, 10:18:08 »
Seconded! That tool has helped me settle on E-White as well! I've bought GMK Future Funk so I think the two will look absolutely stunning with the dark purple on white.
Offline Moridin
    • Infinite Diaries
« Reply #1238 on: Wed, 25 March 2020, 11:08:10 »
Thanks. Confirmed black will look good with Lunar so I might actually change up my plans but if I don’t then the next set will match nicely. Cheers 🍻!
Offline belerian
« Reply #1239 on: Wed, 25 March 2020, 12:06:06 »
God bless!
Thanks for the good work! If you are willing to take a request, can you do a layer with GMK Shoko?
Offline paobit
« Reply #1240 on: Wed, 25 March 2020, 13:17:37 »
I'm in!
Offline kru20o1
« Reply #1241 on: Wed, 25 March 2020, 13:28:23 »
I want this, I need this!
Offline qz2015
« Reply #1242 on: Wed, 25 March 2020, 17:20:52 »
I am definitely in.
Offline sdaf2
« Reply #1243 on: Wed, 25 March 2020, 18:18:44 »
God bless!
White 100%
Wish Noel was in there though
Offline TonyPia
« Reply #1244 on: Wed, 25 March 2020, 19:08:29 »
KAT Atlantis?
Offline bigboss
« Reply #1245 on: Thu, 26 March 2020, 16:54:53 »
Are there any soundtests from the prototypes?
Offline MQTThings
    • Blog
« Reply #1246 on: Fri, 27 March 2020, 01:49:14 »
I'm also considering going with KAT Atlantis for this board, so I added KAT Atlantis to the PSD. Blue seems to match well:
Blue
Black
Gray
White
https://i.imgur.com/ZpxNkEL.jpg
Bonus blue with Alt alphas
Offline DZSlasher
« Reply #1247 on: Fri, 27 March 2020, 09:59:45 »
Definitely interested. Looking forward to hearing the sound test!
Offline TonyPia
« Reply #1248 on: Fri, 27 March 2020, 10:08:51 »
Blue
Black
Gray
White
Thanks a lot! Yep blue looks better than I thought.
Offline DSF767
« Reply #1249 on: Fri, 27 March 2020, 19:38:16 »
Just joined to say this is my ideal board so I think I will be picking it up not sure what color
