Author Topic: [IC] 7V - 75% Keyboard (GB Live!)  (Read 769012 times)
Offline gok_nz
  • Enjoy your PBT
    • Website
Re: [IC] 7V - 75% Keyboard (08/02/2020 UPDATED FAQ. WAITING ON FINAL PROTOS)
« Reply #1100 on: Wed, 26 February 2020, 23:56:37 »
Do we already have confirmation on how the GB is going to run? (fcfs, raffle, auction, mix)
None of those. Unlimited GB through vendors.
Offline jedidood
  • aka neovisual
« Reply #1101 on: Thu, 27 February 2020, 02:51:19 »
Is this keyboard designed as having Poly plate originally in mind?
 I am trying to decide to see which plate will give a slight deeper sound.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1102 on: Thu, 27 February 2020, 04:18:48 »
Switches play a large part so if you are after a deeper sound, I'd go for something like cherry black with poly plate.
Offline vector88
« Reply #1103 on: Thu, 27 February 2020, 07:32:18 »
And  any idea what date to mark in calendar? :)
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1104 on: Thu, 27 February 2020, 08:34:05 »
Keeping my eye on this, I love the style ^-^
Jerry Talks Tech - youtube.com/jerry
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #1105 on: Thu, 27 February 2020, 08:54:17 »
+1
I'm like super close to picking up another board but if there's a GB date then I'll hold off.
GON NerD TKL DTA Edition
Offline varj17
  • I need ←↑↓→
« Reply #1106 on: Thu, 27 February 2020, 15:42:41 »
This looks amazing. You're amazing :thumb:
Will there be an option for the color of the logo and weight? Hoping for a black with raw polished SS logo and weight.
Sorry in advance if this has been answered.
Offline treeleaf64
    • treeleaf64
« Reply #1107 on: Thu, 27 February 2020, 16:20:05 »
The blue case is my favorite. I love dark blue, it is probably my favorite color.
Everyone must pay the cat tax
Offline lush_bunny
« Reply #1108 on: Thu, 27 February 2020, 21:56:07 »
Now imagine it with GMK Navy Blue.
Offline Ajtruong
« Reply #1109 on: Thu, 27 February 2020, 22:01:02 »
Interested in this as well!
Offline i luv chuletas
« Reply #1110 on: Fri, 28 February 2020, 08:32:34 »
Wow, I literally just caught wind of this by accident. This is looking awesome!
Any ideas how this fits in terms of timeline? Many boards coming up real fast, need to make decisions based on what will be available :(
Offline Moridin
    • Infinite Diaries
« Reply #1111 on: Fri, 28 February 2020, 08:33:43 »
It's been so long that I'm actually tempted to fly down to NZ to Gok and see what's taking so long. 😅
Offline dbeats824
« Reply #1112 on: Fri, 28 February 2020, 10:27:08 »
This keyboard in a Forest Green color would be amazing. Make that happen!
Offline Brammm87
« Reply #1113 on: Fri, 28 February 2020, 14:20:17 »
Coronavirus probably ****ing up a lot of timelines. I'm in a Kickstarter that closed just before the outbreak as well and it's just delays after delays because the product needs to be produced in China as well.
pls gief bbv2
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1114 on: Fri, 28 February 2020, 15:35:16 »
Makes sense, China does 28% of the world's manufacturing and probably 80% of the custom mech communities (I wonder if there's actually any data on that.)
Offline pchoi
« Reply #1115 on: Sat, 29 February 2020, 11:03:30 »
Fairly new to the keyboard scene. If I were to install my own RBG LEDs into this keyboard, would that customization/configuration also be controlled by QMK? Or is there a set function key and commands for lighting settings? Thanks!
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1116 on: Sat, 29 February 2020, 12:54:50 »
I can’t find any information online on whether the WT75-C PCB this keyboard will use supports RGB LEDs, it’s more common that PCBs only support two pin, single colour, LEDs.
Yes though, any lighting a keyboard has, be it RGB underglow or backlight, can usually be controlled through bindings you set using QMK, it as a range of keys for controlling things like hue, saturation, animation, etc. You can find more information in the QMK documentation.
Offline konstantin
  • Formerly constexpr
« Reply #1117 on: Sat, 29 February 2020, 12:59:00 »
You would not be able to add per-key RGB to the board unless the PCB supported it in the first place. Single-color, dimmable backlight — sure, that's controlled by a single GPIO pin and most PCBs support it, but controllable RGB requires the LEDs to be wired in a matrix and a separate driver chip to be present.
Offline Poesjuh
« Reply #1118 on: Sat, 29 February 2020, 14:21:42 »
Any chance you can share pictures and/or a video of the construction, since you have a prototype. I’m curious to see how the pcb and plate mounting works but the render you shared doesn’t make it all that clear to me.
The pcb has wilba leaf spring (that I can see) and rests on some sort of gaskets. But what the us the way the plate contributes here? Can’t really figure that out.
Edit; oversaw the link to the build album. Question regarding plate remains though. Is it only there to support the switches? Is it in contact with the case as well?
« Last Edit: Sat, 29 February 2020, 14:25:18 by Poesjuh »
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1119 on: Sat, 29 February 2020, 14:49:20 »
It is held in place by the switches and held up to prevent unclipping by the damping layer so you can build this completely plateless.
Offline Poesjuh
« Reply #1120 on: Sat, 29 February 2020, 15:24:49 »
Might be because English is not my native language, but what exactly do you mean by “held up to prevent unclipping by the damping layer” ?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1121 on: Sat, 29 February 2020, 15:55:27 »
Switches have a nub which holds it tight to the switch plate and because the plate doesn't have any fixing points to the chassis, it is possible for it to unclip from the switches if you somehow push down on the plate really hard. The damping layer keeps the plate pushed up to prevent this.
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1122 on: Sat, 29 February 2020, 16:57:37 »
I get your meaning, so the plate is held against the top part of the case by pressure from the dampening layer. I assume, looking at the build album, that plate will sit inside the machined out part of the top case to prevent it shifting at all?
Offline Hesi
« Reply #1123 on: Sat, 29 February 2020, 17:10:05 »
Hallelujah. Will be looking forward to this! Raffles and auctions are the worst..
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1124 on: Sat, 29 February 2020, 17:49:11 »
The plate doesn't shift due to being held in place by the switches and the switches are locked in place from soldering them into the PCB.
Only the PCB has direct contact with the chassis.
Offline Lovepig78
« Reply #1125 on: Sat, 29 February 2020, 20:18:10 »
Still waiting.......
Offline dbeats824
« Reply #1126 on: Sat, 29 February 2020, 20:19:11 »
@gok101 Is there any chance of a brass plate option being added? Would really like to pair some Holy Pandas with a brass plate on this!
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1127 on: Sat, 29 February 2020, 21:16:41 »
I won't be adding this as an option but I will eventually be releasing the plate files so you can get it cut in the material that you desire.
Offline lush_bunny
« Reply #1128 on: Sat, 29 February 2020, 23:41:06 »
I just reread the OP and realized the plate can (will?) be polycarb! I like this. I have never tried plateless and I’m afraid of what happens when I clack too hard (I have heavy hands and I love bottoming out). But full plate aluminum can be too tiring at times. I’d love to try halfplate someday. But I look forward to the polycarb plate, not sure how much flex it can produce at that thickness while still being durable.
Offline Poesjuh
« Reply #1129 on: Sun, 01 March 2020, 03:10:27 »
Ah yes I understand. I had this exact thing happening with my R1 cypher in the bottom corner due to the layout options (non-fixed bottom row) and used some Eva foam to prevent this.
Offline LostGoatOnHill
« Reply #1130 on: Sun, 01 March 2020, 05:30:51 »
In on this one as gorgeous, look fwd to month estimate for availability
Offline bbg
« Reply #1131 on: Thu, 05 March 2020, 21:05:10 »
What is the material used for the dampening layer?
« Last Edit: Thu, 05 March 2020, 21:26:23 by bbg »
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1132 on: Thu, 05 March 2020, 21:28:34 »
It's poron. I prototyped silicone, rubber and poron and I chose the latter because it allowed for the most flex and was also the most forgiving in terms of tolerance and fit. Plus it doesn't smell.
Offline dom
  • allergic to hypocrisy
« Reply #1133 on: Mon, 09 March 2020, 22:15:24 »
That's fantastic! Some people will be happy!
« Last Edit: Fri, 20 March 2020, 13:58:21 by dom »
Offline toxic_munkii
« Reply #1134 on: Wed, 11 March 2020, 00:27:36 »
Really looking forward to this board. Renders and layout look amazing  :D
Offline sdaf2
« Reply #1135 on: Wed, 11 March 2020, 12:20:13 »
Been looking for a nice 75% board for a while, especially with a split backspace
Will definitely buy this.
Offline bobgr8
« Reply #1136 on: Wed, 11 March 2020, 14:38:52 »
Crossing fingers for a sub 400 price tag
True, after Ai03’s Polaris, expectations are high.
« Reply #1137 on: Wed, 11 March 2020, 17:41:21 »
In for this one, absolutely gorgeous
Offline Grandmasternoob
« Reply #1138 on: Thu, 12 March 2020, 06:15:25 »
great board,man, do you have any exact dates for the order?  and approximate price
« Last Edit: Thu, 12 March 2020, 06:17:43 by Grandmasternoob »
Offline grimis
« Reply #1139 on: Thu, 12 March 2020, 23:27:50 »
According to the discord group, he should be announcing the group buy date and price hopefully this weekend some time. Fingers crossed.
Offline pcire
« Reply #1140 on: Fri, 13 March 2020, 00:35:06 »
That’s be just great. Jules is coming out and while I like it and even want it, 7V is a priority. Announcing early will make it easier to plan :)
Offline dom
« Reply #1141 on: Fri, 13 March 2020, 02:42:36 »
Exactly my thoughts as well  :thumb:
Offline bassvirtuoso
Re: [IC] 7V - 75% Keyboard (14/03/2020 UPDATE - PRICING AND DATE ANNOUNCED)
« Reply #1142 on: Fri, 13 March 2020, 13:59:51 »
4/10 and $450 - can't wait!
Offline mta
« Reply #1143 on: Fri, 13 March 2020, 14:05:36 »
Any rough idea for end date?
Offline sirieous
  • help
« Reply #1144 on: Fri, 13 March 2020, 14:08:08 »
my body is ready.
Offline lush_bunny
« Reply #1145 on: Fri, 13 March 2020, 14:16:19 »
  • Timeline: Group-buy starting 10th of April 2020
  • Price: $450 USD plus shipping for default kit (polycarbonate plate and polished stainless logo and weight)
'ERE WE GO 'ERE WE GO
Offline xantiema
« Reply #1146 on: Fri, 13 March 2020, 14:30:37 »
Is the EU proxy confirmed to be 450euros?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #1147 on: Fri, 13 March 2020, 15:00:47 »
Europe is always a bit different because of their tax laws. I'll need to get that confirmed with Mykeyboard.eu
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #1148 on: Fri, 13 March 2020, 16:16:18 »
Definitely getting one, but guess I'll have to proxy it from NK, because every package from them to Canada gets hit with duties and customs and costs like 25-50% of the package, especially if it's UPS that's shipping it.
Offline Elementboy575
« Reply #1149 on: Fri, 13 March 2020, 16:24:58 »
Do we know when the pricing for the black pvd/E-white will be announced?
I am very exceited for this board as a whole! Great work!
