Author Topic: [IC] 7V - 75% Keyboard (GB Live!)  (Read 769014 times)
Offline ITjanitor
Re: [IC] 7V - 75% Keyboard (14/03/2020 UPDATE - PRICING AND DATE ANNOUNCED)
« Reply #1250 on: Sat, 28 March 2020, 08:48:19 »
Looking to convert this PCB to hotswap.  Will there be enough room on the backside to fit a millmax?
Offline DZSlasher
« Reply #1251 on: Sat, 28 March 2020, 10:27:45 »
So does this board have a 7u, 6.25u, or 6u spacebar? Looking at the first post, I am still confused.
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1252 on: Sat, 28 March 2020, 10:29:24 »
Looks, at least to me, that it can support either 6.25u or 6u depending on modifiers.
Jerry Talks Tech - youtube.com/jerry
Offline DZSlasher
« Reply #1253 on: Sat, 28 March 2020, 15:23:15 »
Thanks. I hope that is the case. I was just in the groupbuy for GMK Apollo and I didn't get the spacebar kit. It would make me sad if this board needed a 7u spacebar.
Offline chowbabyloving
« Reply #1254 on: Sat, 28 March 2020, 15:29:32 »
Doesn't apollo come with a 7u and 6.25u spacebar in the base kit?
Offline itsmartin
« Reply #1255 on: Sat, 28 March 2020, 15:31:45 »
It does.
This board layout supports 6 or 6.25u.
Apollo comes with 6.25u and 7u.
Offline DZSlasher
« Reply #1256 on: Sat, 28 March 2020, 17:33:39 »
It does.
For some reason, I thought that the 7u spacebar in the base kit was separate. It has been a long week.
Offline kaiba
« Reply #1257 on: Sat, 28 March 2020, 21:12:50 »
Apologies if this was already asked or mentioned - are there/will there be any photos of a prototype for the grey version of the case?
The last prototype Gok is waiting for is grey.
Ah I see. Thank you for answering me. :D
Offline are2dcrz
« Reply #1258 on: Wed, 01 April 2020, 00:36:27 »
awesome looking board. this is up in the air for me between this and a tkl. still deciding...
Offline f1
« Reply #1259 on: Fri, 03 April 2020, 15:21:53 »
Heavy WK user here too. Thank you for focusing on functionality a wee bit more than pure aesthetics. After all we don't want the 7V to be just a mantle queen, we need to type on it once in a while.
Sent from my smartphone which I have. Cable, charger, everything.
Offline trustworthy
« Reply #1260 on: Fri, 03 April 2020, 18:33:31 »
I am actually torn between Navy and Blacked out. I was 100% Navy until today and now I can稚 stop looking at the other other renders.
Offline ever9415
    • EVER STORY
« Reply #1261 on: Fri, 03 April 2020, 21:59:37 »
I love Navy Blue so much.
I will participate in GB.
Offline BahaMech
  • Contact Me on Discord - dionsalekian#8349
« Reply #1262 on: Fri, 03 April 2020, 23:31:08 »
Im just wondering, how are you coating the stainless steel to make sure it doesnt scratch?
Thanks
Offline hhvphu
« Reply #1263 on: Sat, 04 April 2020, 00:53:43 »
i am 100% in
Offline Joeni
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1264 on: Sat, 04 April 2020, 02:04:46 »
Thanks
There will be a PVD coated option for the weight, at additional cost.
Also, brass is around a 3 on the Moh scale and stainless steel is around 6, which makes it harder to scratch by its nature than traditional weights.
Offline outsider
« Reply #1265 on: Sat, 04 April 2020, 08:22:35 »
So much this. :thumb:
Offline Hell-es
« Reply #1266 on: Sat, 04 April 2020, 08:50:24 »
Any updates on options / european pricing?  Or i鼠l just wait one week :)
Offline Dexter
« Reply #1267 on: Sat, 04 April 2020, 09:35:02 »
I like the really dark blue in your pre-production sample photos. Will this be an option? Could you post renders with GMK Botanical?
Offline Module
« Reply #1268 on: Sat, 04 April 2020, 09:35:43 »
Looks great, definitely interested :)
Offline Sirrom23
« Reply #1269 on: Sat, 04 April 2020, 12:27:03 »
As someone who is very interested in this board and potentially will join the group buy, what is the difference between the 1.5mm Polycarbonate and aluminium plate? I've been doing research to understand the difference as this would be my first custom board. Poly is softer, less harsh, while aluminum is harder. I've been lurking around this forum and the r/mechanicalkeyboards subreddit and it seems like most people do customs with brass plates. So why does this not have it? What are the advantages/disadvantages to Poly and Aluminum?
Offline Evo_Spec
  • (╯ーヮー)╯︵⌨
« Reply #1270 on: Sun, 05 April 2020, 04:24:40 »
Usually what your research has shown would be correct but this board is in a different category completely because it will be PCB leafspring mounted so I imagine that the plate will make a lot less difference than usual because most of the feed back will come from the PCB now instead of the plate.
GON NerD TKL DTA Edition
Offline OmniSzron
« Reply #1271 on: Sun, 05 April 2020, 11:49:52 »
Yeah, what Evo_Spec said. Usually the switches are mounted to the chassis via the plate, so it has huge impact on the feel of the board. Here, the switches are mounted to the board through leafsprings on the PCB, so the feel should be very flexy regardless of the plate material. The plate material may impact the bottom out sound, though.
Fox Lab Key 65 split space
Offline Kirihuna
« Reply #1272 on: Mon, 06 April 2020, 10:34:07 »
I've never been apart of a keyboard GB before, only cap GBs.
What's the turn around time after GB ends for production? Is it usually 6 months or so like GMK caps?
Offline Brammm87
« Reply #1273 on: Mon, 06 April 2020, 10:38:10 »
This can highly, highly vary. Some group buys go up to a year or longer, though that's rare. For a GB this size, I'd rather think 8 to 10 months realistically. Delays almost always happen...
pls gief bbv2
Offline nettoxx7
« Reply #1274 on: Mon, 06 April 2020, 13:13:52 »
Usually, turnaround time is longer for keyboard GBs when compared to keycaps. With the current outbreak and semi-functional production, most, if not all production were probably delayed and pushed back a few months. I wouldn't be surprised if it takes a year.
Offline rkarp
    • hypertext.dev
« Reply #1275 on: Mon, 06 April 2020, 13:21:22 »
Yeah, even before Covid there are always delays.  Jane V2 CE was just about a year.  And that's a low volume run, especially compared to what this will generate as an open GB.
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1276 on: Mon, 06 April 2020, 14:40:45 »
It will be worth the wait though, especially if somehow you manage to forget you've ordered it and it arrives out of the blue :D
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline akverma
« Reply #1277 on: Mon, 06 April 2020, 21:34:43 »
Is there any updates on pvd pricing?
Offline gt1989
« Reply #1278 on: Tue, 07 April 2020, 05:29:27 »
It'll be updated in a few days.....when it goes on sale on the 10th.
Offline Narcolepsy
« Reply #1279 on: Tue, 07 April 2020, 06:50:46 »
Does anyone have a link to what this kind of mounting with polycarbonate plate would sound like?
Offline itsmartin
« Reply #1280 on: Tue, 07 April 2020, 07:45:27 »
We haven't got a proper sound test yet. The final prototype was delayed.
Offline spaceshipdee
« Reply #1281 on: Tue, 07 April 2020, 07:57:43 »
This is a very nice looking board and in 75% layout no less!
Looking forward to grabbing one.
Offline fantasyrunner
« Reply #1282 on: Wed, 08 April 2020, 00:51:24 »
Finally just finished reading through all the pages, I'm so excited! Incredible work Gok
Offline lush_bunny
« Reply #1283 on: Wed, 08 April 2020, 01:00:46 »
I need to clarify something. If I want two sets 7V PCBs (each with different switches and caps) for easy swapping, I only need an extra plate and dampener right? I don't need an extra top?
Offline utdconsq
« Reply #1284 on: Wed, 08 April 2020, 04:05:38 »
Just ordered some tangerines for this bad boy, bring on the 10th!
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1285 on: Wed, 08 April 2020, 04:46:13 »
Correct. You can see in the second picture on the first page of this thread how it all fits together - the top part sits on top of the plate and PCB, so it's not permanently attached.
Offline lush_bunny
« Reply #1286 on: Wed, 08 April 2020, 10:40:41 »
Thanks! I have more keycaps than keyboards, so might as well use em for transformer keyboards
Offline monkishmonkfish
« Reply #1287 on: Wed, 08 April 2020, 13:45:37 »
I really like this keyboard. I知 getting the GMK ashes keycaps (https://store.projectkeyboard.com/products/gb-gmk-ashes) and was wondering if anyone had a good 7V color recommendation for this keycap set. I知 not too good at envisioning these things.
Offline loksmith
« Reply #1288 on: Wed, 08 April 2020, 14:56:05 »
I think it would look clean on the gray case for a monochrome look. Next choices would be black, then white.
Any would pair well since the colors are mostly neutral.
Sent from my Pixel 3 XL using Tapatalk
« Reply #1289 on: Thu, 09 April 2020, 08:49:58 »
I知 relatively new to these group buy thingies. Is the kind of thing where I need to log on at midnight to claim a board or will they decide how many boards to make after the GB period?
Offline djwadhwa
« Reply #1290 on: Thu, 09 April 2020, 09:06:51 »
For this specific GB, you place the order and the vendor makes the board after the GB concludes, given the total number of orders meet Minimum Order Quantity (MOQ). Other group buys may or may not follow this format.
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1291 on: Thu, 09 April 2020, 09:13:40 »
This Group Buy is unlimited, so it will run for three weeks and once finished, they'll make as many as are needed to fulfil the orders. Possibly more, because extras are a thing.
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1292 on: Thu, 09 April 2020, 12:40:35 »
Looks like the PVD coated weight option is PVD coated brass, according the Deskkeys
Offline ovokevin
« Reply #1293 on: Thu, 09 April 2020, 13:00:06 »
Please extend the groupbuy!!!!! The outbreak is really affecting my budget.
Offline pchoi
« Reply #1294 on: Thu, 09 April 2020, 13:32:12 »
With all due respect, this interest check was started in May of 2019... For all of us who have been waiting patiently PLEASE do not extend this lol
Offline kokugatsu
« Reply #1295 on: Thu, 09 April 2020, 13:49:47 »
I'm guessing the "normal" weight will still be stainless steel?
Bit of a shame, PVD steel looked quite nice from the pics
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1296 on: Thu, 09 April 2020, 13:51:42 »
Yeah, the standard weight is stainless steel still.
Kevin has confirmed that it'll be polished PVD on the brass, so it should still look like the render, one would hope.
Offline Evo_Spec
  • (╯ーヮー)╯︵⌨
« Reply #1297 on: Thu, 09 April 2020, 14:07:03 »
+1
Offline ovokevin
« Reply #1298 on: Thu, 09 April 2020, 14:16:19 »
Damn... One week extension would be nice but I guess not
« Reply #1299 on: Thu, 09 April 2020, 15:03:24 »
What do you guys think about trying to polish the aluminum plate to match the logo and weight? Do you think that's a bad idea?
