Hello everybody,
today I'm more than happy to present you my keycap set!
It is inspired by Kirito - character from the 2D series SAO.
In a second I will take you through my thought process of choosing colors for this set.
ColorsFor the main color I have chosen black, just black. Nothing special, move along.
Specifically speaking - RAL 8022
![[IC] GMK Dual Wield 242528-0](https://geekhack.org/index.php?action=dlattach;topic=106388.0;attach=242529;image)
For the accents I wanted to go with gray, similar to the one used for Kirito's robe.
I have modified it a bit to match the set better and finally went with RAL 7037.
![[IC] GMK Dual Wield 242513-2](https://geekhack.org/index.php?action=dlattach;topic=106388.0;attach=242514;image)
I was also thinking about RAL 7022, but it turned out to be too dark, in my opinion.
![[IC] GMK Dual Wield 242515-3](https://geekhack.org/index.php?action=dlattach;topic=106388.0;attach=242516;image)
For the final color - the one for the legends I needed some contrast and that is when I remembered one of his swords - Dark Repulser.
Dark Repulser.png (67.66 kB - downloaded 298 times.)
Same as for the gray color, I modified it a bit and finally came up with - RAL 6027.
Concept![[IC] GMK Dual Wield 242520-6](https://geekhack.org/index.php?action=dlattach;topic=106388.0;attach=242521;image)
PlansAs far as I feel like there are enough people intrested in GMK Dual Wield, I will make some novelty keycaps and upload more renders.
When it comes to the novelty keycaps I'm planing to make "Link, start!" enter with some fancy font
For the shift keys I was thinking about adding 2 different arts of Kirito's swords.
To make it a kit worth buying, I will need to come up with a few more novelties. That is why I'm open for any ideas from you guys!
All of the above wrap-up to 3 kits:
1. Base - possibly with Latin legends.
2. Hiragana sublegends kit
3. Last but not least, possible novelty keycaps.
Vendors, Price---
IC FormI would be really greatful If you could take a minute and share your thoughts in this Google feedback form:
https://forms.gle/ZS6rr8XznopcHQWB8If you want to DM me, here is my Discord EvilMario#3077.
Thank you for reading!
