Author Topic: [IC] GMK Blossom (GB Live!)  (Read 84225 times)
Offline Nukz
  • ig: nukzak
Re: [IC] GMK Blossom (Deskmat Added)
« Reply #50 on: Tue, 16 March 2021, 17:07:05 »
Consider adding B in base kit instead of spacebars kit, i like the colors! :thumb: GLWIC
Offline balance
« Reply #51 on: Thu, 18 March 2021, 14:58:24 »
looks really pretty, glwic! :)
Thank you very much!
Offline balance
« Reply #52 on: Fri, 19 March 2021, 16:20:52 »
Thank you! I added "B" in the base kit. Hope you like it!
Offline balance
« Reply #53 on: Sat, 20 March 2021, 16:47:34 »
I suggest some changes with the R4 novelties (I know novelty design is hard so this is just my 2 cents):
_ The key in "branch with 5 leaves" is to keep since it's not repeated in other rows: both in 1.5u but with different color. I believe your approach is to provide some R4 mod keys in accent color which is new and supprisingly good when put in a board. However you'll need to have a pair of these keys in mod color first, then a second pair with same design in accent color. Please consider doing this in with a 1.25u as well.
_ The rest of R4 novelties should be replaced with 3 different designs: A 1u novelty key to cover either End or PgDn + a pair of 1.25u in mod color for 2 Control/Alt keys + another pair of 1.25u novelties in accent color for system keys.
_ ISO enter novelties in the theme of sakura would be great since we don't have many of these.
I really hope that you'll consider these changes since I always buy novelty kit whenever I join a keycap GB. A good novelty kit will surely boost your sale.
Added novelties for ISO Enter. Also some new R1 novelties. Hope you like them!
Just saw the new updates, those ISO novelty enters are great. However, I believed I did not express fully and correctly my opinion about colors of R4 novelties. I mean a pair of same novelty should be in the same color, not 2. Because normally we have 2 Control/Alt/Super keys in 1.25u in TKL/Full size and fewer in 65/75s. 2 keys in a pair should have the same color, like the 2 R4 keys with the bird should all be in either mod or accent color. I'm sorry if I caused you any misunderstandings.
I know it would be expensive and time-consuming for designer to have different novelty for each mod key but if you can get different designs for those R4 keys, it'll be way better. You'll only need 2-3 more new novelties for Control/Alt or Super.
Thank you for the suggestions!
Offline Nukz
  • ig: nukzak
Re: [IC] GMK Blossom (Added new renders; Added the Accent Kit)
« Reply #54 on: Sun, 21 March 2021, 15:43:05 »
Nice change in kitting!
Offline nvh2092
« Reply #55 on: Sun, 21 March 2021, 16:08:22 »
Since you're trying to reduce the base kit due to Alice inclusion, I suggest move numpad to a child kit, then you can bring some accents to the base like that attractive 6.25u purple spacebar and possibly add 3 basic 40s keys.
Also, there's a problem with the 2 mini space bars in base, those don't seem to match 2.25 and 2.75u.
I'm still hoping you can add 3 more new novelties for R4 to place in Control/Alt/System.
« Last Edit: Sun, 21 March 2021, 16:34:30 by nvh2092 »
Offline CookieFlow
« Reply #56 on: Sun, 21 March 2021, 16:18:42 »
Thanks for adding Alice support in base kit  :thumb:
Offline Mark The Weeb
« Reply #57 on: Sun, 21 March 2021, 21:46:58 »
that is so sick !
Offline balance
Offline Eoen
« Reply #59 on: Tue, 23 March 2021, 08:38:50 »
+1 for 2.75U space in the base.
Would also be nice to see a 3U bar in the accent kit :)
Offline Scucka
« Reply #60 on: Wed, 24 March 2021, 15:34:29 »
 nice :thumb:
Offline balance
« Reply #61 on: Thu, 25 March 2021, 15:52:04 »
I have made these changes in this update! Hope you like it!
Offline Paputcher
Re: [IC] GMK Blossom (Kits update; New renders)
« Reply #62 on: Sat, 27 March 2021, 17:49:19 »
interesting
Offline Afresh
« Reply #63 on: Tue, 30 March 2021, 09:17:19 »
glwic
Offline balance
« Reply #64 on: Tue, 30 March 2021, 13:56:30 »
Added some new novelties. I hope you like them!
Offline nvh2092
« Reply #65 on: Tue, 30 March 2021, 14:02:02 »
I love them  :eek:. Also, now I think you should have a discord channel and make more ads for the set. Maybe make one or two posts on reddit about it, more people know about it, more interest, higher moq, etc.
« Last Edit: Tue, 30 March 2021, 14:49:05 by nvh2092 »
Offline balance
« Reply #66 on: Wed, 31 March 2021, 10:41:51 »
I am happy to hear that you like them! I already have some reddit posts and maybe I will make a discord server soon :thumb:
Offline DontStealMyLolipop
Re: [IC] GMK Blossom (New Novelties!)
« Reply #67 on: Wed, 31 March 2021, 16:07:38 »
I really love those novelties  :eek: :eek:
Offline highdocc
« Reply #68 on: Thu, 01 April 2021, 01:03:57 »
I really like the set, especially the colour mix!
Offline balance
« Reply #69 on: Thu, 01 April 2021, 15:23:52 »
I am happy to hear that!
Offline balance
« Reply #70 on: Fri, 02 April 2021, 13:53:19 »
Offline nvh2092
Re: [IC] GMK Blossom (Vendors and GB Date Announced)
« Reply #71 on: Fri, 02 April 2021, 16:07:35 »
I think the accent kit should have mini accent bars since the alpha ones are already in your base kit?
« Last Edit: Fri, 02 April 2021, 16:21:15 by nvh2092 »
Offline balance
« Reply #72 on: Sat, 03 April 2021, 15:08:38 »
I don't know about this, maybe I will add them. Thanks for the suggestion!
Offline nvh2092
« Reply #73 on: Sat, 03 April 2021, 15:15:57 »
I mean replacing them because you have alpha mini space bars in base kit, then you also have apparently the same mini alpha space-bars (same size if I'm not wrong) in the accent kit.
Offline balance
« Reply #74 on: Sat, 03 April 2021, 16:20:46 »
I checked and yes it was like that. I am sorry! I replaced them with a 3u and 2u in it.
« Reply #75 on: Mon, 05 April 2021, 10:31:40 »
Nice change
Offline Oddstag
Very interested in this set. Any chance of UK keys or some sort of international kit with UK keys included?
Offline balance
I am happy you are interested! I will think about your suggestion!
Offline balance
Offline kaysoo1337
Re: [IC] GMK Blossom (UK Vendor!)
« Reply #79 on: Wed, 14 April 2021, 13:58:13 »
waiting to see the prices  ;)
Offline Giorgey
« Reply #80 on: Fri, 16 April 2021, 11:42:15 »
I really like this set, waiting for the Deskmat. GLWIC
Offline balance
« Reply #81 on: Tue, 20 April 2021, 14:54:39 »
Thanks! The deskmat will be soon :thumb:
Offline nvh2092
« Reply #82 on: Wed, 05 May 2021, 04:40:31 »
If the kitting is not final, I want to add something that I recently think about:
About accent kit:
1/ I see your accent kit contains small alpha spacebars, please change them to accent color
About novelty:
1/ Also, some designers told me that big keys in novelty kit will add a lot to the price more than small keys. So I think you can do some changes about the R4 of the novelty. I think it's better to remove the 2 1.5u bird novelties. These bird keys have already existed in R1 and R2.
2/ I also recommend to have additionally the 1u single-butterfly novelty as R1 (in both mod and accent) so layouts which don't have the right nav column can still use it.
3/ Last, I remember you had a different novelty in your old design - a small branch with leaves in 1.25u or 1.5u key I'm not sure. Please replace the 2 R4 1.25u single-butterfly with that key.
Offline balance
« Reply #83 on: Tue, 11 May 2021, 14:52:51 »
About accent kit:
About novelty:
Thanks for suggestions, I think I will do some changes this week, the deskmat will also be posted this week so stay tuned :thumb:
Offline GoldenBoy
Re: [IC] GMK Blossom (Major IC Change!)
« Reply #84 on: Tue, 11 May 2021, 20:53:16 »
The aesthetic is on point. I may buy this for the GF <3_<3
Offline Belled
  • I like shoobs
« Reply #85 on: Sun, 16 May 2021, 20:43:15 »
Looking alot like darling without the purple accents
Offline Nukz
  • ig: nukzak
« Reply #86 on: Wed, 19 May 2021, 14:59:44 »
love the new renders, waiting for GB :thumb:
Offline balance
« Reply #87 on: Tue, 25 May 2021, 16:21:06 »
I am very happy to hear this!
Offline saam
Re: [IC] GMK Blossom (Deskmat Added!)
« Reply #88 on: Wed, 26 May 2021, 00:13:32 »
Looks great, just try and steer away from darling.
Sam E
Offline pcire
« Reply #89 on: Wed, 26 May 2021, 01:48:41 »
GB ETA?
Offline balance
« Reply #90 on: Wed, 26 May 2021, 15:45:00 »
Re: [IC] GMK Blossom (Major kitting changes; Improved novelties)
« Reply #91 on: Mon, 07 June 2021, 09:47:23 »
The deskmatis a great addition to the already great existing set, looking forward to the GB !!!  :thumb:
Offline Ella
  • Why is it called an oven
« Reply #92 on: Mon, 07 June 2021, 09:48:54 »
TKL base kit with GMK, yikes
Sent from my Samsung Smart Fridge using Tapatalk
Offline nvh2092
« Reply #93 on: Mon, 07 June 2021, 09:59:33 »
There's still a problem with the accent kit, it contains the same mini bars with the base kit.
Offline balance
« Reply #94 on: Mon, 07 June 2021, 10:02:15 »
It contains 3.00 and 2.00 and 1.25
Offline nvh2092
« Reply #95 on: Mon, 07 June 2021, 10:06:12 »
ok, tks for the info
Offline sterlingm
« Reply #96 on: Sat, 12 June 2021, 11:46:51 »
The Discord server invite link is invalid. Can that be updated?
Offline balance
« Reply #97 on: Sun, 13 June 2021, 10:54:04 »
I changed the link, now you can enter :thumb:
Offline Neely_12
« Reply #98 on: Sun, 13 June 2021, 11:09:18 »
Not really my type of colors but looks nice
Offline Giorgey
« Reply #99 on: Tue, 15 June 2021, 01:24:05 »
I hope the GB starts ASAP. I really enjoy the Deskmat.
Gl!
