Author Topic: [IC] GMK November Fog - Last days for the GB! Ends Dec 1 11:59PM EST  (Read 106329 times)
Offline krugerlive
Introducing GMK November Fog
a set designed to evoke those cooler and foggier days of the late fall
"keyset inspiration"
November is a time of change.
It's those late autumn days when we get ready to welcome the winter.  The days are cooler and the mood gets calmer.
Nature is preparing for its winter slumber and there is a softness and stillness in the air.
The weather shift brings on cloudier days and foggy skies.
The scents of the surroundings color the experience - pine and mountain air in the forests - a wild landscape.
The inspiration is that time and feeling spent immersing oneself in nature at the tail end of the year.  It's about cool days, overcast skies, and a fog that permeates throughout bringing a freshness and calm to all.
Color information:
Colors
The colors are selected from the above photo that I took while on a hike in the Cascade Mountains about an hour outside of Seattle, WA.
On this foggy November day, the temps were in the 40s, it was cool and breezy, and low clouds and layers of fog were rolling through the hills.
These colors are chosen because they have a naturalness to them, but as the same time, a cooler feel.
Note: The physical colors on the right were taken on a neutral gray card and the photo is color corrected (may look different across monitors).  Pantone *is still* out of the physical plastic chips for two of the colors, but I've verified with multiple types of paper Pantone chips and multiple adjacent color plastic ones that these are the best colors for the set.
This set was first posted to r/keycapdesigners here
Changes: Initially the alpha color was planned to be Pantone 621c, but in person it was too vibrant and spring-like.  The other candidate, 7541C, ended up fitting the theme perfectly.
"group buy information"
Group Buy Dates: November 1 - 30th, 2021
Vendors:
Pricing
Kitting          Cannon Keys  Daily Clack  Desk Hero  IlumKB  MyKeyboard.eu  proto[Typist]  zFrontier
Base Kit$134.99 (USD)$197.00 (AUD)$175.99 (CAD)$195.00 (SGD)140.00€ (EUR)£125.00 (GBP)¥939.00 (CNY)
Novelties$64.99$95.00$84.99$94.0067.00€£60.00¥439.00
Space Bars$31.99$47.00$41.99$46.0033.00€£30.00¥229.00
Extensions$42.99$63.00$55.99$62.0045.00€£40.00¥299.00
NorDeUK$74.99$109.00$97.99$108.0078.00€£69.00¥499.00
Estimated shipping: Q4-2022
"renders and kitting"
Renders:
"cannon keys balance in a green that really should exist""cannon keys balance in a green that really should exist"
Cannon Keys Balance
Cannon Keys Balance
"blue grey haus on the abstrat fog deskmat""Ikki 68 Aurora"
Haus by Hand Engineering
Ikki 68 Aurora
More Renders:
"dalco mini with ISO""render on dawn 75, it's quite nice"
Dalco 959 Mini by Hand Engineering
Dawn 75 FE by Finite Design
"cannon keys balance on some random plaster floor""cannon keys balance on some random rock that's lichen this scene"
Cannon Keys Balance in white
"render on dawn 75, it's quite nice""render on dawn 75, it's quite nice"
"(November) Frog by Geon. Render by PL23""Harbor by Kibou. Render by PL23"
Dalco 959 Mini
Color Versatility Renders
The tones are specifically chosen to be largely neutral and also balance each other to the point where they work in a harmony, and no color is overbalancing another.  This gives the set more flexibility across board designs, colors, and desk environments.  For those boards that are very hard to match, this set should at least be adequate or better on most.
Here are renders on multiple boards, in an array of colors that include ones very tough to match:
Color Versatility Gallery
Kitting:
Base Kit:
Description:
This has a large amount of support for various layouts that most people use.  There are a lot of debates about what the ideal kitting size is, and based on IC feedback, this works for most.
This ensures that the kit can maintain relevancy if people buy new keyboards (as tends to happen in this hobby....) or want to swap it around across different boards.
Given the longer lead times of GMK these days, it's even harder to predict which board layouts you'll be using when the set delivers, so for this reason a larger kitting is better tuned to the moment, especially given that this is meant to be a more versatile set.
Novelties:
Description:
These novelties are meant to evoke cooler days of late fall hikes and excursions into nature.  The idea was to keep them completely natural, no signs of people.  They're meant to put you in the mindset of a late fall hike, where it's just you experiencing nothing but nature.  There is a stillness and oncoming chill, yet there is so much life.
Bars:
Description:
These are some more space bars so you can hone that aesthetic, or support your more obscure layouts.  They match the alpha and accent colors.
Extensions:
Description:
This kit provides support for 40s layouts and other support for more esoteric layouts.
Was able to get everything people asked for in the IC.
NorDeUK
Description:
The PNW has a lot of landscape commonality with Northern Europe, so it makes sense there were a lot of requests for this.  I can't wait to visit some day.
"deskmats"
"cannon keys balance on some random rock that's "lichen" this scene""cannon keys balance on some random rock that's "lichen" this scene"
Nature DeskmatAbstract Fog Deskmat
"metal artisans"
All metal keycaps available from all vendors
Hibi Metal Artisan Keycaps
owl
abstract trees
Owl Keycap:
This is a milled solid brass keycap that's been PVD coated with a polished silver fininsh.  It uses the owl design from the novelties, which is milled into the surface with precision CNC machining.  The eyes are enamel filled and are luminecent, so they will glow if first given light.  This is a special one.
Abstract Trees Keycap:
Design Inspiration
This keycap is a custom design by Kate from Hibi created specially for GMK November Fog.  It is meant to evoke the forest theme, but not overtly be that.  Because of that, it's a design that could fit any situation, yet still call back to the theme of the set.  This is a machines aluminum keycap that's custom anodized to match the Panton of the accent color.  It has 11 ridges to represent the 11th month.
KeyLabs Metal Artisan Keycaps
R1 1u
R3 2.25u
Both keycaps are machined aluminum and anodized to match the pantone of the accent color.  Each keycap has parts that are milled more deeply and are filled with enamel color matched to the Pantone of the mod color.  The scenes are completed with laser etched designs.  I'm thrilled that KeyLabs is doing their first ever metal enter key as a collaboration with November Fog
R1 1u
R3 2.25u
"cables"
GCables
Custom connector options
Coiled or straight options
Purchase a custom G Cable
Luxe Cables
Laser engraved with the wolf/dog
This cable is designed with a colorway to complement the set to give it more of a deep forest feel on your desk.
Purchase a custom Luxe Cable
Artisan Collaborations
Upcoming
Upcoming
Giveaway Ended
Upcoming
Ongoing (Nov 8-14th)
Upcoming
Raffle Ended
Raffle Nov 12
Next Steps towards the Group Buy:
Step        Status
Complete physical color verificationDone
Post ICDone
Run Survey Done
Schedule with Vendors Done
Finalize Novelty Designs Done
DeskmatsDone
Finalize Kitting Done
Collaborations Done ...But more are always welcome
Thank you to everyone who filled out the IC, everyone on the discord and elsewhere who helped with feedback and encouragement to get to this point, especially the CK regulars crew.
Thank you to PL23 for helping with some renders and conversing about ideas.  Thank you to "the 10 person chat", DotMatrix, Milo, Kebob, Upas and Ana, and many more for all the feedback, encouragement, and help with questions.  A huge thanks to Chippy too, you helped me make this a reality with your help getting everything moving.
Get involved!
Join the discord
Follow my keyboard instagram
Contact me on discord: krugerlive#6903
Follow me on Twitch: krugerlive_
Expect updates to continue to flow in as we approach GB.
There are many exciting things in the works that will be announced soon.
Thanks and please let me know your feedback and thoughts!
Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=113865.0][img height=120]https://i.imgur.com/wIxce7f.png[/img][/url]
aldo tax
« Last Edit: Tue, 30 November 2021, 12:46:16 by krugerlive »
Offline krugerlive
Re: [IC] GMK November Fog
« Reply #1 on: Sun, 18 July 2021, 15:43:16 »
reserved
Updates:
-8/11 - Updated vendor status.  Will announce vendors and timing after labor day.  I bet you might be able to guess the planned month.
-9/24 - Major update with new novelties, deskmat design, vendor info, and GB dates.   Also a ton of new renders.  Also all the kitting changes I could reasonably fit in that were requested in the IC.
-10/11 - Added 2nd deskmat and updated kitting
-10/20 - Added Hibi caps and Collaborations section
« Last Edit: Wed, 20 October 2021, 17:38:40 by krugerlive »
Offline Chippy
  • sus chef
« Reply #2 on: Sun, 18 July 2021, 15:43:25 »
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #3 on: Sun, 18 July 2021, 15:44:33 »
Happy to see this finally come to life! Hope this set does great Kruger
Offline suyashr99
« Reply #4 on: Sun, 18 July 2021, 15:45:25 »
So glad to finally see something you’ve been working so hard on come to fruition. GLWIC
Offline supbeez
« Reply #5 on: Sun, 18 July 2021, 15:46:09 »
Sign me up. Love November fog
Offline kriegar
« Reply #6 on: Sun, 18 July 2021, 15:46:34 »
I love fog and fog related accessories.
Offline heptose
« Reply #7 on: Sun, 18 July 2021, 15:48:11 »
Another step closer to reality! Happy to see this in IC!
Offline saam
« Reply #8 on: Sun, 18 July 2021, 15:49:23 »
Amazing!
I love the colors. So happy you finally made it here after such hard work and effor.
I hope you have the greatest luck with IC and count me in for a set!  :thumb:
Sam E
Offline jollyrogerxx
« Reply #9 on: Sun, 18 July 2021, 15:49:39 »
I was born in November and I love fog so I'm in.
Offline Yuinth
« Reply #10 on: Sun, 18 July 2021, 15:51:46 »
It feels fresh & relaxing, love it.
Will get it for sure.
GLWIC & GB
Offline minmkim
« Reply #11 on: Sun, 18 July 2021, 15:54:22 »
Set is bussin bussin ong respectfully
Offline gypsyunit
« Reply #12 on: Sun, 18 July 2021, 15:57:59 »
need this expeditiously
Offline not tj
« Reply #13 on: Sun, 18 July 2021, 16:04:19 »
nice this set looks fire GLWIC
Offline HappyB0T
  • I'm a Piggie
« Reply #14 on: Sun, 18 July 2021, 16:18:32 »
Hey Krugerslive - this IC will need some refinement. Here are some items that stood out to me.
Base Kit
Some of the non alphas keys with 2 characters on them have alignment / character weight issues. I don't render myself but something is amiss.
Extension Kit
Backspace key is off in the render
Base Kit
2 Alternative Spacebars colors in the base will really drive up the cost of the base kit. Consider moving them out of base. The would make your set more accessible to the masses.
Color choices
3 pantone colors might drag out this IC quite a bit. Considering using stock colors would certainly speed up the turn around time. If not consider using RAL before Pantone since this is preferred from GMK
4191 c is pretty close to CC.
4230 c looks really really close to N9
Novelties
Pretty sure the owl would not pass GMK tolerances. Consider making sure they are within spec.
Hope this feedback finds you well.
Offline hkf
  • your #1 fan
« Reply #15 on: Sun, 18 July 2021, 16:19:18 »
I think the backspace legend on the extension kit looks a little bit too high. Similarly to the IOP in the base kit.
I would also like to see a R1 owl novelty.
Other than that its a solid set. Good work.
Offline aerospice
« Reply #16 on: Sun, 18 July 2021, 16:45:03 »
Saw your feedback post a while back, so really glad this project finally came into fruition! Only thing I'm a little worried about are the novelties since the lines might be a bit thin for GMK standards. All in all, the minimalist look to the design is great!
Offline kure_
« Reply #17 on: Sun, 18 July 2021, 17:04:16 »
Looks pretty cool man!
Offline MIGHTY CHICKEN
« Reply #18 on: Sun, 18 July 2021, 17:04:54 »
Nu bad
Offline Kebob
« Reply #19 on: Sun, 18 July 2021, 17:17:59 »
great to see this make it to IC after all the work, definitely will join in and looking forward to when it lands
Offline -boxes-
« Reply #20 on: Sun, 18 July 2021, 17:24:05 »
This looks fantastic.  Looking forward to it!
Offline mmayhem17
    • Steam profile
« Reply #21 on: Sun, 18 July 2021, 18:36:46 »
i like the colors and the theme, overall very nice IC.
Would you consider shinothrough caps?
Offline clickpig
  • naisu naisu naisu
« Reply #22 on: Sun, 18 July 2021, 18:45:48 »
daaaang this set is nice, colour selection is on point.
Offline krugerlive
« Reply #23 on: Sun, 18 July 2021, 19:17:58 »
Thanks everyone for the comments and feedback so far!
Regarding the novelties, yes they are a bit thin in some spots and I will be adjusting them.  I'm also expecting a set of new icons that should follow the same theme and be better, so that should be exciting.  The city ones will likely be by the same artist.
Also HappyBOT and hkf, thanks for catching the misaligned legend in the extensions, it's fixed now.
And yes! Shinethrough caps would be cool and i'll look to add them
« Last Edit: Mon, 19 July 2021, 18:39:31 by krugerlive »
Offline hayasaka
  • No.
« Reply #24 on: Sun, 18 July 2021, 19:45:15 »
really clean
Offline hottnucks
« Reply #25 on: Sun, 18 July 2021, 20:31:43 »
Shipping in November 2023
Offline DotMatrix
  • Charue Design
    • Charue Design
« Reply #26 on: Sun, 18 July 2021, 21:51:16 »
Looks great! I'm digging the color versatility gallery a ton!
Offline treeleaf64
    • treeleaf64
« Reply #27 on: Sun, 18 July 2021, 22:02:49 »
I hate November I hate the cold weather I hate the cloudy   I hate and I hate it
Everyone must pay the cat tax
Offline Skok
« Reply #28 on: Sun, 18 July 2021, 23:18:22 »
but its green?
Offline SmilingCurse
    • Twitch Channel
« Reply #29 on: Sun, 18 July 2021, 23:53:35 »
Oh this looks lovely...
Offline doggo1dance
« Reply #30 on: Mon, 19 July 2021, 01:28:04 »
well done with the really fleshed out IC! glwic, really excited to see the development of this set
Offline Marichu
« Reply #31 on: Mon, 19 July 2021, 09:22:21 »
This is awersome, the colors are very pleasing to the eye
Offline hkhawk
« Reply #32 on: Mon, 19 July 2021, 10:03:18 »
The owls are not what they seem
Offline Bushhawk
« Reply #33 on: Mon, 19 July 2021, 10:08:36 »
Greyish and depressing, just like all my birthdays... thanks November.
Jokes aside, it looks nice and the base kit is good.
Guess i'll cop.
Offline Cylent
  • Formerly cylentshadows
« Reply #34 on: Mon, 19 July 2021, 10:19:06 »
I like this and am glad to see it finally make it to IC!
My recommendations for improvements:
-change the orthographic scale to zoom in more on the renders, especially the novelties.
-while you're at it, please use kitting kit tilted
-kitting across the board needs to be cleaned up. 3 key 40s support in base would be nice
Note: I do not think you should use stock colors at this point.
Offline kindakeyboards
  • hi! im Milo and i make keyboards.
    • kinda.be
« Reply #35 on: Mon, 19 July 2021, 10:32:58 »
looking good man!
Offline sup3r170va
« Reply #36 on: Mon, 19 July 2021, 11:08:17 »
 Interesting set. Extension/40s kit looks odd. Shouldn’t it be icon only mods like the base? Also, good if there are some accent esc and enters.
Offline heyimpanda
« Reply #37 on: Mon, 19 July 2021, 12:26:17 »
:aldochefskiss:
Offline Bub
    • big bub's beepers
« Reply #38 on: Mon, 19 July 2021, 12:33:29 »
hey!!! nice to see this set come to life.
i think my only recommendation for you would be to commission some solid renders for your set. not that the ones in IC are bad... they show the product well, but i think really high quality renders will show off your color choices. the colors are really nice.
Offline krugerlive
« Reply #39 on: Mon, 19 July 2021, 12:42:43 »
@Bub, thanks for the feedback!  Yep, I will be commissioning better renders for the next steps.  I learned blender and did the renders myself for the IC, so while it was super fun to do and learn, they definitely aren't done by a professional.  (Also I will 100% be in on GMK Panels)
@sup3r170va  thanks for the kitting suggestions.  I'll do another pass at the 40s kit and better standardize the legends.  As for accent color keys in the kit, do you have recommendations about which keys would work best as the accents?  I'm very basic with my own keyboard choice and generally use standard or Alice layouts, so this is not an area I know extremely well.
@cylentshadows Thanks for the suggestions, I'll work on those improvements.  And yes, I agree, stock colors would not work with this unfortunately.  That was the first thing I checked when planning colors.  RAL didn't match as well as Pantone either.
@hkhawk ☕  :)  you picked up on a small theme within the theme
@treeleaf64  November is a very bad month for tree leafs, so I completely understand.
Offline Senpai_deezy
« Reply #40 on: Mon, 19 July 2021, 17:41:23 »
Amazing set by an amazing person, so much effort put in I love it, great job  :thumb:
Offline Cylent
« Reply #41 on: Mon, 19 July 2021, 18:22:15 »
Small note Krueger, you should use the quote function in geekhack rather than @ since geekhack doesn't do pings.
Offline kight
« Reply #42 on: Mon, 19 July 2021, 18:32:16 »
great job on this, GLWIC!
GB in november or bust
Offline krugerlive
« Reply #43 on: Mon, 19 July 2021, 18:37:23 »
Thanks!  Will do from now on.
Offline IOVERCALLHISTIOCYTES
« Reply #44 on: Mon, 19 July 2021, 21:44:18 »
I’d mentioned in discord that I wanted a piece of pie nov. just so long as my switch stems are ‘wrapped in plastic’ I’ll be good.
Offline Garner
« Reply #45 on: Wed, 21 July 2021, 04:06:53 »
Very tasteful and beautiful set. GL!
Offline Mecxs
« Reply #46 on: Wed, 21 July 2021, 08:02:29 »
Spacebar kit should be called Logs imo.
Offline see
« Reply #47 on: Wed, 21 July 2021, 11:50:23 »
This pleases me. It very much does. Though it's a shame it'll be running with GMK given their problematic lead times.
Still though, I love this set. Will be keeping a close look at it in the future.
Offline BaltO
« Reply #48 on: Wed, 21 July 2021, 12:05:20 »
I see the potential. I just dont think your first two 'Inspiration' pics match the set at all. The set feels much more muted and pale compared to those deep woodsy colors.
Offline MattVortex
« Reply #49 on: Wed, 21 July 2021, 12:24:04 »
The extensions kit is missing all the necessary keys for UK ISO support, it also requires R3 [#~] and R4 [\|]
