Author Topic: [IC] GMK Court  (Read 21483 times)
Offline tovbeast
[IC] GMK Court
« on: Mon, 19 July 2021, 16:06:09 »
A set that is inspired by the greats that have roamed the courts, I am very pleased to introduce GMK Court, the last set a tennis fan needs.
Contact me on Discord: tovbeast#6969
-- Colors--
-- Kitting --
Match Base
Grass Court Alphas
Wimbledon Stripes
Grass Stripes
Trophies Kit
Stadium Mat
-- Renders --
F1-8x
KBD67 Lite
-- Vendors --
KOREA/SEA: Swagkeys
-- Collaborations --
Please reach out on Discord if you would like to collab - tovbeast#6969
-- Thank you --
Thanks to my friend Jordan for giving me the amazing idea for this set, for Eg0 and Halo for bringing my vision to life, and to all of the amazing community members who gave feedback, advice, and encouragement on the way!
Renders by: eg0t1st1k4l#7777
Novelties and Deskmat by: Halo#2222
-- Change Log --
Posted IC on 7/19/21
Updated the kitting on 7/21/21
Finalized vendors on 7/23/21
Finialized kitting and finished novelties on 7/28/21
-- Signature --
Please consider adding this signature to your profile to support the set! Copy the code below and follow these steps:
 > Profile > Forum Profile > Signature > Paste
« Last Edit: Thu, 21 October 2021, 19:24:14 by tovbeast »
Offline Fraaaan
Re: [IC] GMK Court
« Reply #1 on: Mon, 19 July 2021, 16:13:47 »
Offline tovbeast
Re: [IC] GMK Court
« Reply #2 on: Mon, 19 July 2021, 16:29:18 »
Yeah, the sets are pretty similar but once the novelties are done it will differentiate it a lot!
Offline Ustinj
Re: [IC] GMK Court
« Reply #3 on: Mon, 19 July 2021, 16:34:56 »
Just gonna leave this here.
https://geekhack.org/index.php?topic=113736.0
They're similar, but different enough, this probably just means it's best to set the GB dates apart
Offline Olyz
Re: [IC] GMK Court
« Reply #4 on: Mon, 19 July 2021, 16:46:08 »
Are the accent arrows in the novelties?
Offline Steelbloo
Re: [IC] GMK Court
« Reply #5 on: Mon, 19 July 2021, 16:50:03 »
Would be interested to see custom text phrases for mods. Ex: Backspace could be "fault" and shift could be "serve" or something like that
Offline tovbeast
« Reply #6 on: Mon, 19 July 2021, 16:52:03 »
Great idea, I'll include that in the novelties!
Offline smshark
Re: [IC] GMK Court
« Reply #7 on: Mon, 19 July 2021, 16:58:09 »
I really do like the color choices and have wanted to see a re-run of GMK Royal Alpha. I have no concerns with the colors as it is a historical set that has been done a few different ways by different manus (similar to dolch and 9009), you should just be prepared for the comparison as the greens are the same and used in basically the same way, excluding alt alphas of course. https://geekhack.org/index.php?topic=91499.0
I'm definitely interested in the set though and good luck with IC! TY for 3-key 40s support in base as this hasn't been an option in runs of RA (to my knowledge) and could hit the spot for fans of that set as well.
« Last Edit: Mon, 19 July 2021, 17:13:51 by smshark »
Offline tovbeast
Re: [IC] GMK Court
« Reply #8 on: Mon, 19 July 2021, 16:59:52 »
Thanks for the feedback! I'm glad you like the colors!
Offline Cylent
  • Formerly cylentshadows
Re: [IC] GMK Court
« Reply #9 on: Mon, 19 July 2021, 17:04:46 »
I love tennis, but without the novelties the theme doesn't really come across for me. Also, I feel like stock color greens means that this set won't really match the Wimbledon grass, and that's pretty disappointing.
Hopefully when I see the novelties I'll see the theme come through on the keycaps.
Offline Entity.
  • Entity#1234
Re: [IC] GMK Court
« Reply #10 on: Mon, 19 July 2021, 17:07:48 »
Green, nice  :thumb:
Offline jabe8i
Re: [IC] GMK Court
« Reply #11 on: Mon, 19 July 2021, 17:19:40 »
Not really well versed in this topic, but what was the reason for you choosing stock gmk colors? Does that save on cost since it isn't custom?
Offline NoPunIn10Did
    • NoPunIn10Key
Re: [IC] GMK Court
« Reply #12 on: Mon, 19 July 2021, 17:27:05 »
If you’re including R2 Esc in base as a supplement to 3-key, you’re better off forcing the accent on that key.
Offline TRIGOZEN x TAO
  • Kanna + Keybort = Big Weeb
Re: [IC] GMK Court
« Reply #13 on: Mon, 19 July 2021, 17:30:02 »
This is not a copy at all LMAO, the greens are way different.
Offline FishyKeebs
  • hey
Re: [IC] GMK Court
« Reply #14 on: Mon, 19 July 2021, 17:30:34 »
i gotta say this does not remind me of tennis
Offline tovbeast
Re: [IC] GMK Court
« Reply #15 on: Mon, 19 July 2021, 17:31:45 »
I chose GMK stock because I wanted this to be a more affordable set.
Offline Kinesiologist
Re: [IC] GMK Court
« Reply #16 on: Mon, 19 July 2021, 19:24:44 »
I dont know much about tennis but this is a nice green set.
Offline //gainsborough
  • MATRIXの日常
Re: [IC] GMK Court
« Reply #17 on: Mon, 19 July 2021, 20:02:34 »
Oh man!  I had this idea during wimbledon, hahah.  You gotta add some purple to the kit!
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [IC] GMK Court
« Reply #18 on: Mon, 19 July 2021, 20:13:35 »
I suggest not offering child kits for child kits
Offline Arithmetics
Re: [IC] GMK Court
« Reply #19 on: Mon, 19 July 2021, 20:30:01 »
Yah not getting any tennis vibes
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Court
« Reply #20 on: Mon, 19 July 2021, 21:41:34 »
Yes, and can (but not always!) save time on production
Offline mymeepo
Re: [IC] GMK Court
« Reply #21 on: Mon, 19 July 2021, 21:52:22 »
Shouldn’t a tennis-based set have the yellow of the tennis ball as its accent color?
Offline doggo1dance
Re: [IC] GMK Court
« Reply #22 on: Mon, 19 July 2021, 22:00:09 »
if you think that and this is similar, you probably need to get your eyes checked for vision deficiency or check ur monitor's color calibration.
Offline MrBingo
Re: [IC] GMK Court
« Reply #23 on: Mon, 19 July 2021, 22:14:42 »
This looks kinda familiar
Offline Kwando
Re: [IC] GMK Court
« Reply #24 on: Tue, 20 July 2021, 19:25:46 »
Definitely would be interested!
Offline illusixn
  • Formerly illusixn
Re: [IC] GMK Court
« Reply #25 on: Tue, 20 July 2021, 19:56:12 »
no one asked but the Naomi Osaka doc is out on Netflix and it's pretty good
Offline Cylent
Re: [IC] GMK Court
« Reply #26 on: Tue, 20 July 2021, 21:33:40 »
GMK Court is literally GMK Classic Green + 1 stock color. Sure, the new stock color AE is on the mods and alpha legends instead of N7, and I agree that it should make this set sufficiently differentiated from Classic Green. However, the comparisons will be impossible to avoid.
Offline EdgeOfInfinity
Re: [IC] GMK Court
« Reply #27 on: Fri, 23 July 2021, 00:30:55 »
if you mirror the deskmat, your keeb will cover less of the focal point of the design
Offline pixelpusher
Re: [IC] GMK Court
« Reply #28 on: Fri, 23 July 2021, 00:55:26 »
Kinda looks like a less interesting Royal Alpha.  Maybe the novelties will make it pop
Offline XiXora
Re: [IC] GMK Court
« Reply #29 on: Tue, 27 July 2021, 20:42:03 »
A Wimbledon kit could add purple accents?!
Would love some 1.5U R4 Supers (+ extra 1u alt) for HHKB and/or Mac… can live with novelties though.
Offline rpiguy9907
Re: [IC] GMK Court
« Reply #30 on: Tue, 27 July 2021, 22:01:20 »
This set is dandy!
Offline tovbeast
Re: [IC] GMK Court
« Reply #31 on: Wed, 28 July 2021, 11:30:00 »
I just finalized the kitting and posted the novelties! Please let me know any feedback you have!
Offline XiXora
Re: [IC] GMK Court
« Reply #32 on: Wed, 28 July 2021, 12:38:24 »
If you're not going to do R4 1.5 Supers I need r4 1.5U Novelties, also for 1u novelties to be distinct from those 1.5U novelties as I use 7u HHKB layout with 1.5 OS key.
Offline matrixzj
Re: [IC] GMK Court
« Reply #33 on: Thu, 04 November 2021, 01:45:00 »
This GB was not started yet ?
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline rmendis
  • Artisan addict
Re: [IC] GMK Court
« Reply #34 on: Thu, 04 November 2021, 21:48:44 »
what happened to this GB?
Offline kkd_20
Re: [IC] GMK Court
« Reply #35 on: Fri, 05 November 2021, 00:42:09 »
What is that thing on spacebar?? Is that a net?? I dosent give me a net vibe. i thought it was a screen xD
Offline jagger27
  • ne 1.5U supers???
Re: [IC] GMK Court
« Reply #36 on: Fri, 05 November 2021, 07:51:26 »
lmao did they cancel this half baked crap?
Offline Mecxs
Re: [IC] GMK Court
« Reply #37 on: Fri, 05 November 2021, 08:22:14 »
What was half baked about it?
Offline tovbeast
Re: [IC] GMK Court
« Reply #38 on: Wed, 10 November 2021, 11:51:54 »
Forgot to post about this. GB was canceled due to low participation and all orders were refunded.
Offline Faceman76
Re: [IC] GMK Court
« Reply #39 on: Sat, 13 November 2021, 18:40:03 »
Participation has been lower in all GBs lately.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline krugerlive
Re: [IC] GMK Court
« Reply #40 on: Mon, 29 November 2021, 16:00:45 »
Bummed this GB didn't make it.  It's crazy how different sales are this year than last year.  It's very tough to run a set right now and most people don't appreciate all the complexities that go into it.  I hope this can come back some day, the work you did on it is excellent.
Re: [IC] GMK Court
« Reply #41 on: Mon, 29 November 2021, 18:36:27 »
this is the third try at a GMK CCnG or CCnG like set that has failed. i think the colorway is just doomed
Offline Anthixious
Re: [IC] GMK Court
« Reply #42 on: Tue, 30 November 2021, 12:40:52 »
Agreed, was stoked at getting this, love Green on White and vice versa sets. Hopefully it isn't doomed to be never ran like Puddsy said </3
Offline Cylent
Re: [IC] GMK Court
« Reply #43 on: Tue, 30 November 2021, 14:15:48 »
It ran and the GB was cancelled due to low sales.
Offline vishydesigns
Re: [IC] GMK Court
« Reply #44 on: Tue, 30 November 2021, 14:33:15 »
GB was pretty rushed, I feel like this was in ic for only like a month tops
Offline 1017BirckenThot
Re: [IC] GMK Court
« Reply #45 on: Tue, 30 November 2021, 15:17:46 »
Kono moment
Re: [IC] GMK Court
« Reply #46 on: Tue, 30 November 2021, 20:48:55 »
Kono moment
yeah im stupid, got this confused with another set
