Author Topic: [IC] GMK NICE  (Read 26527 times)
Offline mcheddadi
Re: [IC] GMK NICE
« Reply #50 on: Fri, 22 October 2021, 13:05:23 »
Nice.
Offline Meepergon
Re: [IC] GMK NICE
« Reply #51 on: Fri, 22 October 2021, 13:31:37 »
Nice.
actually a great color combo.
Offline Lysol_
Re: [IC] GMK NICE
« Reply #52 on: Fri, 22 October 2021, 21:30:55 »
nice
Offline baka jiken
Re: [IC] GMK NICE
« Reply #53 on: Fri, 22 October 2021, 23:10:26 »
Nice
Re: [IC] GMK NICE
« Reply #54 on: Fri, 22 October 2021, 23:50:55 »
this is..nice  :D
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] GMK NICE
« Reply #55 on: Sat, 23 October 2021, 03:31:07 »
Offline HappyB0T
  • I'm a Piggie
Re: [IC] GMK NICE
« Reply #56 on: Sat, 23 October 2021, 04:05:30 »
nice....
Offline Cirdec
Re: [IC] GMK NICE
« Reply #57 on: Sat, 23 October 2021, 04:36:27 »
nice
Offline Entity.
  • Entity#1234
Re: [IC] GMK NICE
« Reply #58 on: Sat, 23 October 2021, 11:43:47 »
nice
Offline lush_bunny
Re: [IC] GMK NICE
« Reply #59 on: Sat, 23 October 2021, 13:35:33 »
Nice
GLWIC!
Offline Cylent
  • Formerly cylentshadows
Re: [IC] GMK NICE
« Reply #60 on: Sat, 23 October 2021, 13:53:41 »
Offline Benedikt
Re: [IC] GMK NICE
« Reply #61 on: Sun, 24 October 2021, 09:51:33 »
nice
also perfect for a build I have in mind...
Offline cordoz
Re: [IC] GMK NICE
« Reply #62 on: Sun, 24 October 2021, 11:01:31 »
Nice indeed
Offline Chuuu
Re: [IC] GMK NICE
« Reply #63 on: Sun, 24 October 2021, 23:31:23 »
nice replies  ^-^
gonna revise the renders+kitting to say "Nice" instead of "NICE", and i'll work on a spacebar kit with 3u and accent keys. deskmat is being drafted :)
re: numpad, gonna wait more on ic feedback, but currently leaning towards leaving it out. i feel like i see more alice than 1800/similar layouts.
« Last Edit: Sun, 24 October 2021, 23:36:01 by Chuuu »
Offline Dyto69
  • 420 blaze it but dont forget 69
Re: [IC] GMK NICE
« Reply #64 on: Mon, 25 October 2021, 02:00:49 »
Nice
Offline unusuaL_
Re: [IC] GMK NICE
« Reply #65 on: Mon, 25 October 2021, 08:42:54 »
Nice.
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline Vorge
Re: [IC] GMK NICE
« Reply #66 on: Mon, 25 October 2021, 17:49:55 »
I dont want to like this, but I kinda do so...
Nice
Please consider using something else than GMK, current ETA is frightening to say the least.
Offline SwitchKeys
    • SwitchKeys
Re: [IC] GMK NICE
« Reply #67 on: Mon, 25 October 2021, 20:23:27 »
Nice
Most are in the same boat. Or you can take a risk on a new manu.
Offline alevyish
Re: [IC] GMK NICE
« Reply #68 on: Mon, 25 October 2021, 21:19:56 »
Nice
Give us a 69 metal artisan.
Offline napostrophe
Re: [IC] GMK NICE
« Reply #69 on: Tue, 26 October 2021, 10:58:56 »
nice
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Re: [IC] GMK NICE
« Reply #70 on: Sun, 31 October 2021, 03:08:17 »
nice
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline grayboards
Re: [IC] GMK NICE
« Reply #71 on: Sun, 31 October 2021, 10:25:16 »
nice
Offline Saru
Re: [IC] GMK NICE
« Reply #72 on: Sun, 31 October 2021, 16:59:13 »
nice
+1 to making numpad kit part of base kit and having a separate spacebar kit if this will be through GMK.
Offline AT
Re: [IC] GMK NICE
« Reply #73 on: Mon, 01 November 2021, 20:14:31 »
POG iS NICE :D
Offline vishydesigns
Re: [IC] GMK NICE
« Reply #74 on: Mon, 01 November 2021, 20:32:41 »
switch this over to dcs and its instabuy for me
Offline wt1155
Re: [IC] GMK NICE
« Reply #75 on: Mon, 01 November 2021, 22:11:04 »
nice  :thumb:
Re: [IC] GMK NICE
« Reply #76 on: Mon, 01 November 2021, 22:16:45 »
https://geekhack.org/index.php?topic=97936.0 remember the original, respect your elders
Offline kychiii
Re: [IC] GMK NICE
« Reply #77 on: Wed, 03 November 2021, 01:46:52 »
Nice
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] GMK NICE
« Reply #78 on: Wed, 03 November 2021, 11:51:15 »
nice
Offline Biscuit
Re: [IC] GMK NICE
« Reply #79 on: Wed, 03 November 2021, 14:18:07 »
nice
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK NICE
« Reply #80 on: Wed, 03 November 2021, 16:14:05 »
Base
Numpad
You can move the R1 1u End, PgDn keys from base to the numpad kit since they are only ever used together with the numpad on layouts such as 1800/CP/96-key.
There is a duplicate R1 1u Delete key in base which should be removed.
It appears that you have a R3 1.75u Enter key in base as part of 3-key 40s support. However, this is incorrect — the Enter should be 1.5u.
You may optionally add a 2.25u Shift to the base kit. This provides physical compatibility for 660 layouts.
Another optional addition would be two 1.5u Super keys together with a second 1u Alt. This is for Mac and OG HHKB bottom row setups.
« Last Edit: Wed, 03 November 2021, 16:20:55 by konstantin »
Offline windlabs
Re: [IC] GMK NICE
« Reply #81 on: Thu, 04 November 2021, 02:08:40 »
looks nice
Offline Bobatype
  • formerly bobasweatandtears
    • discord: bobatype
Re: [IC] GMK NICE
« Reply #82 on: Fri, 05 November 2021, 03:11:48 »
Nice
I like the inspiration.
I have some suggestions/considerations:
1) Change manufacturer from GMK (Expensive + long wait times). It would avoid the whole MOQ child kit debate on if it is worth including numpad into base kit or not
2) Novelty kit:
- Change NICE to Nice.
- Include at least 2 x 1.25u, and 2 x 1.5u novelties that say "Nice" for the bottom row.
- Reduce the number of 1u top row novelties that say 'Nice'. You have 6, which appears to be a bit excessive? I can understand having 4 for F5-8, but are you including another 2 for Esc/F13? Could change one of them have inverted colour scheme as an accent Esc key substitute? Also is there a need for 3 x 1u in the 2nd row from top, instead of just 2 for the XT-layout macro column coverage?
- Consider instead including 2 x 1u top row novelties: light gray legend on maroon (i.e. accent Esc key) that says 690 C, and conversely a maroon legend on gray that says 420 C. To directly reference your inspiration.
Offline Rik.caffeinated
Re: [IC] GMK NICE
« Reply #83 on: Sat, 06 November 2021, 02:19:23 »
Nice
Offline Sax_______
Re: [IC] GMK NICE
« Reply #84 on: Sat, 06 November 2021, 05:10:20 »
Could you change the Nice novelties to cherry font?
Offline azzipa
Re: [IC] GMK NICE
« Reply #85 on: Sat, 06 November 2021, 08:31:46 »
nice! colors work really well together. glwic  :thumb:
nicer: add two R4 1.5u Super (and another 1u Alt) for macos and hhkb. move numpad to base. add R1 “=“ to numpad. and R3 Function would be goat.
nicest: epbt, not gmk. then numpad kit and extension kit no problemo? (shorter lead time, less expensive, no moq on child kits, superior feel)
edit: nice®? who paid for the mold?
edit #2: why dalco 959 no have bs? (has 2 pipe keys)
« Last Edit: Mon, 15 November 2021, 09:34:16 by azzipa »
Offline BloremBipsum
  • Yes, I am a Dumb Ass Boi
Re: [IC] GMK NICE
« Reply #86 on: Thu, 11 November 2021, 09:24:58 »
nice
Offline //gainsborough
  • MATRIXの日常
Re: [IC] GMK NICE
« Reply #87 on: Thu, 11 November 2021, 21:10:37 »
Would be neat if the nice caps were each a different font.  My 2 cents.
Otherwise, nice.
