Author Topic: [IC] NoBoard | A 0% Keyboard  (Read 17300 times)
Offline Quadrum
    • Quadrum Labs
« on: Thu, 31 March 2022, 23:01:43 »
NoBoard
0% Keyboard by Quadrum Labs
DISCORD             IC FORM            CONTACT
For years, minimalists have sought to simplify the keyboard. Some tried smaller and simpler layouts, others implemented thin bezels. Low profile, Bluetooth, blank keycaps; the search for less continued. Some gave up entirely.
The quest for minimalism is no more.
Renders
Prototype Photos
Sound Test
Specs
0% Layout
Materials: 6063 Aluminum
Typing Angle: 7°
Front Height: 17.7mm*
Mounting Style: NoMount
Mass: 1.99kg
Plate Materials:
Not QMK or VIA Compatible
Layout:
Fill out the IC Form here!
Special Thanks
Skok, for the great renders :)
The one manufacturer that I presume was very confused.
*How was front height measured? NoClue.
« Last Edit: Fri, 01 April 2022, 15:40:44 by Quadrum »
Offline Quadrum
    • Quadrum Labs
Re: [IC] NoBoard | A 0% Keyboard
« Reply #1 on: Thu, 31 March 2022, 23:02:31 »
Reserved. :) And yes, I did actually get this made.
Offline shay350
« Reply #2 on: Thu, 31 March 2022, 23:05:18 »
ne qmk support avail
« Last Edit: Thu, 31 March 2022, 23:06:56 by shay350 »
Offline Lysol_
« Reply #3 on: Thu, 31 March 2022, 23:06:32 »
Offline Yuinth
« Reply #4 on: Thu, 31 March 2022, 23:07:08 »
Will there be an all copper edition?
Offline MIGHTY CHICKEN
« Reply #5 on: Thu, 31 March 2022, 23:07:29 »
How does this affect gaming performance?
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #6 on: Thu, 31 March 2022, 23:08:17 »
glad to see more wireless options in the community
Offline h40
    • h40.io
« Reply #7 on: Thu, 31 March 2022, 23:11:29 »
No soundtests? No way.
Offline linell
« Reply #8 on: Thu, 31 March 2022, 23:12:43 »
sheeeeesh this **** be looking mad bussin
bro this a **** set, just be thankful you even getting 1 base running fr
Offline kameron
« Reply #9 on: Thu, 31 March 2022, 23:14:48 »
does it thock :eek:
Offline Sissy
« Reply #10 on: Thu, 31 March 2022, 23:17:34 »
Not a fan of the top right blocker.
Offline nFaiz
« Reply #11 on: Thu, 31 March 2022, 23:18:10 »
in for 2
Offline Dunne
    • Dunne
« Reply #12 on: Thu, 31 March 2022, 23:19:00 »
wrist rest and keyboard, all-in-one? I'm in
Offline dededecline
    • Linktree
« Reply #13 on: Thu, 31 March 2022, 23:19:05 »
I am contractually required to ask for 3 key 40s support
Offline chrisw
« Reply #14 on: Thu, 31 March 2022, 23:24:22 »
i've noticed that there is only a wkl option, could you please consider wk? i find it hard to use boards that are lacking winkey
Offline Pylon
« Reply #15 on: Thu, 31 March 2022, 23:24:39 »
N E soundtest avail
Offline clickpig
  • naisu naisu naisu
« Reply #16 on: Thu, 31 March 2022, 23:25:42 »
big fan of the screwless and seamless design
Offline $W4GK!NG
  • Cars/Racing/Keyboards/Watches Enthusiast
    • Linktree
« Reply #17 on: Thu, 31 March 2022, 23:28:39 »
consider adding brass weight
Offline fruitykeeb
    • Storefront
« Reply #18 on: Thu, 31 March 2022, 23:31:27 »
forced split backspace definitely the move, consider 40s support
Offline bshendy
« Reply #19 on: Thu, 31 March 2022, 23:34:38 »
LOL GET CORRECTLY SIZED WINKEY BLOCKERS YOU DUM DUM
Offline Skok
« Reply #20 on: Thu, 31 March 2022, 23:38:35 »
Offline Zeroblade
    • Twitter
« Reply #21 on: Thu, 31 March 2022, 23:40:09 »
They say there's no such thing as endgame -- but I say to them, this is the solution:
This is the nogame
Offline kevinave
  • keebing it cool
« Reply #22 on: Thu, 31 March 2022, 23:40:36 »
Finally a true budget keyboard. following this project closely
Offline shima
  • keeb weeb
« Reply #23 on: Thu, 31 March 2022, 23:43:51 »
whats the bonkability of this
boards: anura
Offline TheInverseKey
  • You can run but you cannot hide!
« Reply #24 on: Thu, 31 March 2022, 23:44:39 »
Woah the total number of different switch support is amazing!
Offline ThereminGoat
« Reply #25 on: Thu, 31 March 2022, 23:44:51 »
What switches should I use for this board?
Offline lbassett21
  • Plastic and Metal Enthusiast
« Reply #26 on: Thu, 31 March 2022, 23:46:22 »
In the next revision, would you consider making it QMK, VIA, and VIAL compatible? Pls and thx <3
Discord: Bassett#0001 | Reddit: /u/lbassett_21 | Instagram: BassettKeebs
Current Collection:
Keyboards:
OTD 360 Corsa | Kira80 | FMJ 80 | Matrix 8xv2.0 | Matrix 8xv1.2og | IBM SSK 1395217 (Stock Trading) | Hiney TKL One PC | Hiney TKL One FNF | G81-3077SAU | G81-3007SAU | G80-9039HAAUS | HHKB Pro 2 Type S | Realforce 84ub |  Lunar 2 |  Sord KB-101 | Percent Canoe | G80-3190HSU | Alps64 | Xerox 6085 Keyboard | IBM 5576-001 | IBM Model M 1390131 | IBM Industrial Model M 1394946 | IBM Model M SSK 1393691 (SABRE) | IBM Model M 1393464 | HHKB Pro Hybrid Type S | Dell AT101 | Leading Edge DC3014 | IBM Model F AT | IBM Model F122 | G80-0693 | G80-0528 | G81-3100SDU | G80-1838HPU | DAS 2 (G80-3485LWNUS-2 | Texas Instruments Keyboard (SKCM Brown) | G80-9002LBBXX
Keycaps:
ESA-3000-HASR0 | G81-3077SAU | G81-3100SAU | BMOL 5206 UP (Desko Color) | BMOL 4000 U (Desko) | GMK Solarized Penumbra | Desko Black (1/10) | GMK Beta JS | IBM APL2 w/Box 1395624
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #27 on: Thu, 31 March 2022, 23:48:00 »
Love the minimalist layout!! Nice curves and hefty weight. I know some people might complain because of some weird ass keycaps support, but I love it!
BUT NO RGB??? Why you do this to me?
Offline Sturmtiger
« Reply #28 on: Thu, 31 March 2022, 23:48:35 »
Finally an actually interesting layout.
Offline mcmaxmcmc
« Reply #29 on: Thu, 31 March 2022, 23:49:53 »
As solid as it gets!
Offline zrrion
« Reply #30 on: Thu, 31 March 2022, 23:53:35 »
AlL mOdErN CuStOms ArE jUsT mEtAl ReCtAnGlEs WeDgEs
Offline HappyB0T
  • I'm a Piggie
« Reply #31 on: Thu, 31 March 2022, 23:58:05 »
can you add the Korn weight to this?
Offline chanchan
    • atxkb
« Reply #32 on: Fri, 01 April 2022, 00:19:01 »
This is what courage looks like. Designs like this push us to be better than we ever thought possible. Truly a masterpiece.
Offline nullinasou
« Reply #33 on: Fri, 01 April 2022, 00:24:39 »
can you open source the plate file plz?
Offline KingXF
    • YouTube
« Reply #34 on: Fri, 01 April 2022, 00:31:25 »
Based.
Offline Plasmak
« Reply #35 on: Fri, 01 April 2022, 00:40:03 »
I think it’s plateless.
Offline omnipotions
« Reply #36 on: Fri, 01 April 2022, 01:16:46 »
Any plans for a pink version?
Offline SeedyOne
« Reply #37 on: Fri, 01 April 2022, 01:29:05 »
Endgame personified  :))
Offline conternecticus
« Reply #38 on: Fri, 01 April 2022, 01:42:03 »
I love this!
Offline _ystem_
« Reply #39 on: Fri, 01 April 2022, 02:11:36 »
PCB support split left shift?
Offline Blamas
« Reply #40 on: Fri, 01 April 2022, 04:14:46 »
Finally, a keyboard that I don't have to wait a keyset for !
Offline Cujo26
« Reply #41 on: Fri, 01 April 2022, 04:17:00 »
Can't wait to see the reveiws for this! really promising as a gaming board
Please help I am trapped in your computing device
[url=https://geekhack.org/index.php?topic=112457.0]
Offline Cipulot
    • Website
« Reply #42 on: Fri, 01 April 2022, 05:01:45 »
Offline el_lento
« Reply #43 on: Fri, 01 April 2022, 05:04:49 »
Have you considered hiragana sublegends?
Offline ZavaZ86
« Reply #44 on: Fri, 01 April 2022, 06:14:37 »
This is peak kbdfans  :thumb:
Offline TjarleN
« Reply #45 on: Fri, 01 April 2022, 06:17:09 »
this would benefit from an internal weight, please consider
Offline LASERman Projects
  • Soldering is my native language.
« Reply #46 on: Fri, 01 April 2022, 06:36:17 »
Helps fighting gaming addiction tremendously!
Offline KuroTheCrazy
« Reply #47 on: Fri, 01 April 2022, 07:08:33 »
Could you change the typing angle? This would be perfect at 10.
Offline CD_Funny
« Reply #48 on: Fri, 01 April 2022, 07:42:47 »
just what I was looking for
Offline Quadrum
    • Quadrum Labs
« Reply #49 on: Fri, 01 April 2022, 10:15:14 »
....  NoStock  :))
Genuinely surprised and a bit concerned how many people seem to want this
