Author Topic: [IC] Haven 65| 06/17 update  (Read 79162 times)
Offline papamao
« on: Sat, 30 April 2022, 19:32:14 »
Build stream by Alexotos: https://www.twitch.tv/videos/1504930673
Hello Geekhack, This is PapaMaoddd from Atelier Haven
Here I am bringing you a board that was inspired by one of my favorite pieces of architecture in this world, Haven Huis designed by Zaha Hadid.
I was lucky enough to visit this masterpiece of architecture in person before the global pandemic and I was immediately shocked and realized why I was always into that building.
The diamond-cut like glass curtain walls and the hints of deconstructivism almost exploded my mind that I didn’t know any architecture could be this brilliant and impactful in person.
This style has been influenced me on my design preferences since then. Now, I have decided to bring this sort of design language into keyboard, another major part of my life.
Let’s come back to the word “haven”. Even though “Haven Huis” means “port building” in English, I still took “Haven” as the name of this board since “haven” in English, accurately describes what custom keyboards means in my life.
The process of building a custom board is like a resort to me since the daily life of a young architect is never easy. To me, building and typing on custom boards is just like a haven that shelters me from my exhausting daily life.
Now, here comes the Haven65
Degree and Front Height: 7.5 degrees with 18.6 mm front height
Mounting: Gasket
PCB: 1.2mm flex cut solder/ansi hotswap
Layout Support: Standard ANSI with 7u bottom row and split backspace and step caps
Colors: Burgundy, Gunmetal Grey, Violet, Silver and E-White
Projected MSRP: TBD, SE with alu weight <$330, FE with PVD Weight < $430
Vendor: TBD
Prototypes Pictures
Haven 65 is a leaf-spring gasket mounted 65% layout keyboard. My first ever customizable keyboard is a 65% and this layout is always my favorite, and that is why I decided to design a 65 as my first ever keyboard.
The front of the keyboard will feature a quite-thinner-than-average bezels comparing to many other 65% keyboard and there will be no extra decoration on the front since I really need every single key on the right-most column.
The sexiest part of Haven is on its sides, rear and back. There is a distinctive design, a triangular shaped cut on the two bottom rear corners of the keyboard and it really looks like a cantilever structure you can see on Haven Huis.
For the rest of the exterior part, I will let the photos speak for themselves.
PCB and Mounting Structure
The mounting of the plate and pcb utilizes gasket, one of the most popular mounting methods today and I added leaf spring to strengthen the bouncy feeling you get from typing.
The plate and pcb will be centered through the 3.5 poron so that the plate will not touch the aluminum shell of the keyboard.
The 1.2 mm pcb will feature a long flex cut in between r2 and r3 running from A all the way to Enter. The hot swappable pcb will also feature tsangan layout on r5 and split backspace.
Renders of color way
What will be changed for the possible upcoming group buy?
Bottom Case: the port for jst cable will be enlarged since the jst port on pcb could hit the bottom case easily on current version of the board.
The logo will be changed to a personal iteration of the word “Haven”. The logo on the current version of the board you see above will be moved to the bottom case of the board.
Then if you are interested in this keyboard, please click the discord link:https://discord.gg/KtGT4nDAtE
The GB in China is already started and there will be many more renders and photographs waiting for you in the discord server!
-Papamao
« Last Edit: Fri, 17 June 2022, 21:26:54 by papamao »
Offline papamao
Re: [IC] Haven 65
« Reply #1 on: Sat, 30 April 2022, 19:32:49 »
reserved
Offline DukeEsquire
Re: [IC] Haven 65
« Reply #2 on: Sat, 30 April 2022, 19:38:17 »
Awesome looking bottom design.
One comment I have is that you should consider removing the "Haven" text on the bottom and leaving just the outline of the building.
Offline itsadrianyo
Re: [IC] Haven 65
« Reply #3 on: Sat, 30 April 2022, 19:41:18 »
OMG thats so clean cant wait for the GB and glwic
Offline Ustinj
Re: [IC] Haven 65
« Reply #4 on: Sat, 30 April 2022, 20:22:05 »
That weight design is sick, glwic
Offline exusiailover79
  • winning
Re: [IC] Haven 65
« Reply #5 on: Sun, 01 May 2022, 02:07:11 »
if it actually hits the projected msrp im in that weight gets *****es
Offline MSA_Vision
Re: [IC] Haven 65
« Reply #6 on: Sun, 01 May 2022, 05:45:25 »
Seriously though, that bottom is fantastic! It’s one of the few 65% that has amazed me.
« Last Edit: Sun, 15 May 2022, 04:59:44 by MSA_Vision »
Sic Parvis Magna
Offline Rilow
Re: [IC] Haven 65
« Reply #7 on: Sun, 01 May 2022, 05:47:49 »
This looks amazing. Definitely in. GLWIC.
« Last Edit: Sun, 19 June 2022, 05:04:27 by Rilow »
Offline Porsha
  • Porshe best car
Re: [IC] Haven 65
« Reply #8 on: Sun, 01 May 2022, 11:58:41 »
The weight looks outstanding, glwic!
Offline Koniotaur
Re: [IC] Haven 65
« Reply #9 on: Sun, 01 May 2022, 15:21:16 »
Bottom is quite nice, shame that too is not as outstanding as the bottom piece which is gonna be seen less
Offline dvllpxe
Re: [IC] Haven 65
« Reply #10 on: Sun, 01 May 2022, 20:12:54 »
i agree with this. especially since the logo inside the bottom case is going to be on the bottom of the board. would be nice to have touches of flair on the top of the case as well. i feel like a badge would be fitting for this board. cheers and glwic!
Offline bshendy
Re: [IC] Haven 65
« Reply #11 on: Sun, 01 May 2022, 20:59:31 »
Board looks sexy! Only feedback I have after discussing it with the high council is seeing if there's a way to get an internal weight under the alphas and soft underglow with that overhang and lip on the weight. Not sure if it helps, but I think the underglow can help define the angles a bit more since it looks a bit muddy looking into the shadow from the side.
Offline Botty212
Re: [IC] Haven 65
« Reply #12 on: Mon, 02 May 2022, 01:51:28 »
I am definitely interested in this and will keep my eye out for future updates and infos.
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
Re: [IC] Haven 65
« Reply #13 on: Mon, 02 May 2022, 03:30:22 »
Take my money now!
Love the design, great work
Offline darthcapn
Re: [IC] Haven 65
« Reply #14 on: Mon, 02 May 2022, 13:17:16 »
The design looks rad! I love it! Glwgb! I'll try and get in if I can!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline lush_bunny
Re: [IC] Haven 65
« Reply #15 on: Tue, 03 May 2022, 12:34:46 »
Fellas, is it wrong to be sexually attracted to a keyboard?
Offline unusuaL_
Re: [IC] Haven 65
« Reply #16 on: Wed, 04 May 2022, 15:16:16 »
good job, inspiration is definitely coming through here  :thumb:
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline Iksion
Re: [IC] Haven 65
« Reply #17 on: Thu, 05 May 2022, 12:49:04 »
Very elegant solution.
KBD75v1 | Kira | Melody96 | TX75v2 | TX-CP | hbcp | Keycult No.2 rev.1 | NK65 | Duck Octagon v3 | Percent Volt | TX65v2 | KY-01 | Sunsetter | Mr. Suit | J-01 | Dolphin 2021 | Phase One 65 | KBD8x Mark ii
Offline Keeblet_257
Re: [IC] Haven 65
« Reply #18 on: Sat, 07 May 2022, 02:10:43 »
I dont know what looks more beautiful. The grey Haven with the pvd weight or the building you got the inspiration from
Offline infinitum
  • i buy expensive plastic
Re: [IC] Haven 65
« Reply #19 on: Mon, 09 May 2022, 09:58:09 »
very nice bottom. love the design
Offline LightsKeys
Re: [IC] Haven 65
« Reply #20 on: Tue, 10 May 2022, 08:06:32 »
Hello I am interested! Could someone please invite me to the discord as this link that was provided has now expired. Please and much thanks!
Offline Der8auer
Re: [IC] Haven 65
« Reply #21 on: Tue, 10 May 2022, 08:51:23 »
 :) Very elegant design
Offline papamao
Re: [IC] Haven 65
« Reply #22 on: Tue, 10 May 2022, 19:20:38 »
try this one
Offline Cookiecurls
Re: [IC] Haven 65
« Reply #23 on: Thu, 12 May 2022, 03:15:49 »
I really like this ❤️
Offline less_blank
Re: [IC] Haven 65
« Reply #24 on: Thu, 12 May 2022, 10:47:38 »
The bottom is really stunning, wish there was something to make the top down view more unique or interesting.
Offline LiquidDev
Re: [IC] Haven 65
« Reply #25 on: Sat, 14 May 2022, 15:05:38 »
reserved
Offline superjackie
Re: [IC] Haven 65
« Reply #26 on: Sat, 14 May 2022, 16:57:13 »
what's the dimensions
Offline LegendsWorks
  • thocc
Re: [IC] Haven 65
« Reply #27 on: Sun, 15 May 2022, 08:44:59 »
It would be nice if we have colour sample images and not renders, For the rest the board is pretty unique and the price is acceptable, GLWIC  :thumb:
Offline ddtj1100
Re: [IC] Haven 65
« Reply #28 on: Tue, 17 May 2022, 09:19:06 »
I love this design!
Offline superjackie
Re: [IC] Haven 65
« Reply #29 on: Wed, 18 May 2022, 21:01:55 »
Could you please list the reviewers and their review schedules when they're available? Thanks!
Offline joshbortguy
Re: [IC] Haven 65
« Reply #30 on: Thu, 19 May 2022, 19:24:36 »
love design, many angles
Offline ddtj1100
Re: [IC] Haven 65
« Reply #31 on: Fri, 20 May 2022, 22:00:56 »
Any reviewers and schedules?
Offline Keeblet_257
Re: [IC] Haven 65
« Reply #32 on: Sat, 21 May 2022, 12:54:29 »
there will be reviewers, but no names have been announced in the discord yet
Offline 8um8lebee
Re: [IC] Haven 65
« Reply #33 on: Sat, 21 May 2022, 13:31:42 »
Finally some new interesting designs for the bottom that actually takes some effort! Too many out there with plain bottom and a single logo engraving in the middle asking for $500 because "mah fit and finish".
Offline superjackie
Re: [IC] Haven 65
« Reply #34 on: Sat, 21 May 2022, 22:44:24 »
totally. this board's design is really sick and special, unlike many other boards that just engrave their logo and call it a special board
Offline superjackie
Re: [IC] Haven 65
« Reply #35 on: Fri, 03 June 2022, 00:30:19 »
glwic! go wkl.
Offline fortissim2
Re: [IC] Haven 65
« Reply #36 on: Fri, 03 June 2022, 08:34:53 »
Holy cow this looks amazing!!! GLWIC :)
Offline superjackie
Re: [IC] Haven 65
« Reply #37 on: Thu, 09 June 2022, 12:22:30 »
i hope there are more people prefer hotswap wkl 65%.
Alexotos Haven review tomorrow! 10PM EST.
« Last Edit: Wed, 15 June 2022, 01:32:35 by superjackie »
Offline superjackie
Re: [IC] Haven 65| 06/17 update
« Reply #38 on: Sat, 18 June 2022, 11:25:59 »
Alex's review is pretty epico. Haven GB when? Plate material options?
Offline shendoo
  • *RAUGHS*
« Reply #39 on: Sat, 16 July 2022, 17:18:27 »
Just saw Alex's stream! I'm in !! When is the GB date?
Offline Keeblet_257
« Reply #40 on: Sun, 17 July 2022, 10:28:02 »
more review untis are being shipped out and after the reviews GB will start, if I remember correctly
Offline Mike2046
« Reply #41 on: Sun, 17 July 2022, 11:40:32 »
The weight looks intriguing. However, the mounting is simple gasket. No leaf springs involved.
Offline Homiezoned
« Reply #42 on: Sun, 17 July 2022, 11:47:37 »
That Violet is  :p
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #43 on: Sun, 17 July 2022, 16:45:51 »
This is actually very beautiful. I'll try to keep my eye on this since it seems to be happening soon.
Current Boards: Aaru TKL (Old Dark Sand) | Drop + Planck (Purple) | Mr Suit WKL (Black w/Gold Chamfers) | Sangeo60 (Black) | KBD67Lite (White) | D45 (E-Grey) | Wind X (Pink) | NCR 80 (Beige) | QK65 (Dark Green) |Av4 Claymore | TGR x Monokei Tomo (Suave Blue) | Heracles80 (Holy White) | Snake60 (Rust) | Array (E-White) | Capsule (E-White) | QK75 (E-White) | | QK80 (Black) | Envoy 65 (Clear PC) | Mode Sonnet (Ice Blue) | Cycle 7 (Lavender, E-White) | Neo70 (Retro White, Black) | Reflection (Chocolate) | Matra Alice 90 (Glossy Red) | Haven TKL (Silver/Red) | Baldur64 (Black) | XOX70 (Bonsai) | SWISS | Cycle 80 (Zeal)| QK80 MKII (Pink) | Polygon 7 (Grey) | QK75N (Smile Yellow) | Han80 (Beige) | THE BASE (Black) | NV-70 (Silver) | Matrix Carnival (Asagao Purple)
Offline Something_Magical
« Reply #44 on: Tue, 23 August 2022, 18:05:28 »
Love the design and the price is reasonable as well! GL with IC,  I'll buy one when it comes to international GB
Offline superjackie
« Reply #45 on: Tue, 30 August 2022, 11:57:59 »
more reviews coming. can't wait!
Offline LMarci
« Reply #46 on: Fri, 09 September 2022, 11:49:14 »
That bottom is gorgeous
Offline corry29
« Reply #47 on: Mon, 12 September 2022, 06:36:26 »
Hello, I’m a little confused with the color names options on keyspensory,
Which one is for the Black or Dark Gray? “dark” “oblivion”?
Offline Hiiro_XoXo
« Reply #48 on: Tue, 13 September 2022, 19:18:04 »
Forgot which review I saw but it was mentioned that if you moved the keyboard, the pcb hits the case, causing some ticking. Any plans to fix pcb fitment?
Offline irithyll
« Reply #49 on: Tue, 13 September 2022, 19:30:51 »
He's considering adding silicone socks free of cost to avoid such issues.
