Author Topic: Phantom Custom Keyboard Group Buy (CLOSED)  (Read 485232 times)
Offline tsangan
  • 1000/600
« Reply #450 on: Sat, 26 November 2011, 20:03:44 »
My hero <3
Keyboardless
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #451 on: Sat, 26 November 2011, 20:06:26 »
I just don't know how much it would cost to make one.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #452 on: Sat, 26 November 2011, 20:12:22 »
The cardboard case needs a wiki article!  Looks like an awesome hack.
Offline tsangan
  • 1000/600
« Reply #453 on: Sat, 26 November 2011, 20:19:55 »
Quote from: litster;459370
Cost is not an issue for custom cases!!!!!!
Keyboardless
Offline NumberJ
« Reply #454 on: Sat, 26 November 2011, 21:21:19 »
Quote from: tsangan;459379
Seconded.
Offline litster
« Reply #455 on: Sat, 26 November 2011, 21:36:16 »
Well, don't get your hope too high.  I don't know if this is a good design yet,  and what quality it would turn out to be.
Offline tsangan
  • 1000/600
« Reply #456 on: Sat, 26 November 2011, 22:03:48 »
Quote from: litster;459412
prototype cost would go into the cost of the casing for everyone, im sure after 3-4 prototype it will be perfected, and acrylic you can't really go wrong
Keyboardless
Offline TheProfosist
  • Custom Layouts Only!
« Reply #457 on: Sat, 26 November 2011, 23:02:32 »
Quote from: litster;459094
PH7BIT updated in 2nd post.
I believe the picture and pcb dont match
Offline litster
« Reply #458 on: Sat, 26 November 2011, 23:05:18 »
Quote from: TheProfosist;459448
How so?
« Reply #459 on: Sat, 26 November 2011, 23:10:21 »
Quote from: litster;459451
How so?
plate
the plate is correct bu the picture is wrong as the left **** is in the wrong place
also is there any way that you could design a plate for me as in 7bit with ISO style left shift
Offline litster
« Reply #460 on: Sat, 26 November 2011, 23:39:25 »
LOL!  I have a bug in one of the layouts.  I will have to fix it or it would look goofy.
I don't know if we can make another plate.  PrinsValium would have to do it.  And adding another plate would introduce more complexity for ordering, inventory, shipping, and potentially opening up to other people wanting their own plate designs.  honestly, as one of the organizers, I think this group buy is getting too complicated.  You should work it out with 7bit to see if you can share the same plate design with him.
« Reply #461 on: Sat, 26 November 2011, 23:43:08 »
Quote from: litster;459460
no im only asking for the file I will get on my own if needed
« Reply #462 on: Sun, 27 November 2011, 01:41:21 »
Quote from: hashbaz;459376
I'm gonna go with that for sure now, until an acrylic case is made (I'll do it by hand if I have to!)
It's either that or tack welding feet directly onto the plate with a car battery.
Offline litster
« Reply #463 on: Sun, 27 November 2011, 02:03:24 »
I did the cardboard case as a prove of concept.  It is pretty easy to make it if you have a keyboard and can open it up.  I turned the top case upside down and used a pencil to trace the cutouts on a piece of cardboard.  Then I just cut the holes out with a cutter.  For the 2rd layer, you need a few of them if your cardboards are not thick enough.  And you need to have the 3rd layout as you need to make room for the teensy controller or the Filco USB cable connector.  It is a little more problematic to make it work for Filco because Filco's controller takes up space north of the arrow key switches, so layer 2 is a little thicker than it would be for Phantom, and would make the strip between the function keys and the number keys on the top layer a little floppy because it is not laying on the mounting plate.  For the Phantom the top layer could lay flat on the metal mounting plate.  But I haven't figured out what to do with the LED holes.  The smaller the Phantom's LEDs are, the better.  If they are too big, then there is no room for the holes on the thin strip.
Ah, wait!  With transparent acrylic, I don't need holes!  How close to the PCB can the LEDs be?  If they are below the mounting plate, then I don't need LED holes at all.
Offline Minskleip
« Reply #464 on: Sun, 27 November 2011, 11:12:59 »
Quote from: 7bit;458973
7BIT layout is not ISO (1.25 Shift followed by 1 unit ) and not ANSI (2.25 units Shift).
One way would be to make a long hole to have the opprtunity to mount the 2 switches at nay position you like. The clips whoich hold them on the mount plate are on top and bottom, so this should not be too much of a problem, but I'm only a layout expert, no mountplate expert.
Because I prefer to have a larger Shift key. The other key serves as Shift Word which in emacs just holds shift until I hit space or return. Also, the whole thing becomes a little bit more symmetric.
What's the function in Emacs called for shift word?
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
Offline tsangan
  • 1000/600
« Reply #465 on: Sun, 27 November 2011, 13:49:09 »
Are you suppose to get a email confirmation from Phantom?
Keyboardless
Offline litster
« Reply #466 on: Sun, 27 November 2011, 13:51:50 »
This is a 7bit question :-).  When was the last time you submitted an order PM to PHANTOM?  I sent an order update to PHANTOM a few days ago and got an updated invoice within a couple hours, IIRC.
Offline 7bit
  • MX1A-G1DW
« Reply #467 on: Sun, 27 November 2011, 14:04:23 »
Quote from: Minskleip;459578
SHIFT LOCK, but it turns back to normal when I hit SPACE or RETURN.
Example:
[Shift Word]SPH/TERMINAL 1
[Shift Word]SPH/POS 2
[Shift Word]SPH/SPACE 2
[Shift Word]SHIFT [Shift Word]LOCK, but it turns back to normal when I hit [Shift Word]SPACE or [Shift Word]RETURN.
Buy key caps here: Round 5
Buy switches here: CherryMX
« Reply #468 on: Sun, 27 November 2011, 16:39:34 »
Quote from: litster;459496
Mouser has some 1mm wide LED's which should work pretty well if you tip them over.
http://www.mouser.com/Optoelectronics/LED-Indication/Standard-LED-Through-Hole/_/N-75pv5?P=1z0rxq6
I was planning on lighting up the underside of the board anyway, so you can see if scroll lock is on by looking for the light coming through the bottom
Offline dux
« Reply #469 on: Sun, 27 November 2011, 16:41:28 »
I still haven't got time to measure the plu. But I am doing something, here is the proof:
How to open the plu
How to open the PLU.
Don't use any keypullers on the original PLU keycaps, because you will pull some of the nipples of the switches out. Use the method from the video.
Offline Minskleip
« Reply #470 on: Mon, 28 November 2011, 13:42:19 »
Quote from: 7bit;459632
Example:
Is this some kind of Linux specific?
« Reply #471 on: Mon, 28 November 2011, 19:39:00 »
Quote from: dux;459717
How to open the plu
Opened the Rosewills that I have almost the same way.
Offline Tarkoon
« Reply #472 on: Tue, 29 November 2011, 03:39:40 »
The plate for PHISO125 seems to be wrong, because I see no ISO enter there, but an ANSI one...
And the left shift is wrong too...
Offline 7bit
  • MX1A-G1DW
« Reply #473 on: Tue, 29 November 2011, 07:45:57 »
Quote from: Minskleip;460118
No, it is Emacs-7bit edition specific :-)
I did not yet find a way to make this system wide.
I'm not sure if it is possible to do it in the Teensy controller ....
Offline Minskleip
« Reply #474 on: Tue, 29 November 2011, 08:35:17 »
Quote from: 7bit;460597
Hehe ok.
I'm planning to add such features. Just have to add 'modes' to the firmware so every feature I add is not a dirty hack :)
I've already added shift lock with led and simple macros.
Offline hashbaz
  • Grand Ancient One
« Reply #475 on: Tue, 29 November 2011, 09:02:27 »
Modes?  Now you're speaking my language (vim user here).  I'm going to have a lot of fun hacking on the Teensy, methinks.
Offline Minskleip
« Reply #476 on: Tue, 29 November 2011, 09:16:21 »
Quote from: hashbaz;460628
Like in normal mode everything you type is sent to the computer, but in shift lock mode the controller checks each key first and for instance turns off shift if a shift key is pressed.
Or in shift word mode space reverts to normal mode.
Offline bpiphany
« Reply #477 on: Tue, 29 November 2011, 14:35:52 »
Quote from: alaricljs;458285
I'm pretty certain that the Filco connecters are JST not Molex and that ebay is a source for the correct cable end.  That PCB mount connector is a match, however the Filco uses a surface mount version of it (this one is thru-hole).  Hope that helps.
I tried the Molex connectors with my Filco cables. The are not the same, the color is different for one thing. But they seem to fit perfectly, even the little latches hook on like they should.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #478 on: Tue, 29 November 2011, 14:40:05 »
Not surprising that the 2 companies have compatible connectors.  Glad that there's an alternative because of that.
Filco w/ Imsto thick PBT
Offline litster
« Reply #479 on: Tue, 29 November 2011, 14:47:00 »
We should be able to get Cherry stabilizers, potentially Costar stablizers from taobao.  The problem is we can't get metal bars for stablizers especially the long ones for 6.25x and 7.0x spacebars.  Anyone knows the size of these metal bars and if we could bend/cut our own?
Offline ishtob
« Reply #480 on: Wed, 30 November 2011, 17:44:46 »
I've been cutting my own from rods I get from the hobby shop, you just need a wire cutter and 2 pliers
Offline litster
« Reply #481 on: Wed, 30 November 2011, 22:17:48 »
Meet the Phantom... case.
Need to eat dinner.  More pictures later.
Offline hashbaz
  • Grand Ancient One
« Reply #482 on: Wed, 30 November 2011, 22:27:40 »
Looks awesome litster!  So the next step in this project is the PCB/plate prototypes, right?  TheProfosist, did the 7bit layout/plate questions get settled?
And do we have any guesstimate of when money will actually be collected?  Trying to manage my keyboard budget here...
Offline litster
« Reply #483 on: Wed, 30 November 2011, 22:31:43 »
I learned a lot doing the cut myself tonight.  And I now have more questions and logistic issues to resolve.  First test plates should be done this week. If things go well, we could be ordering test PCBs next week.  But we are still a little ways away from collecting money.
Offline hashbaz
  • Grand Ancient One
« Reply #484 on: Wed, 30 November 2011, 22:32:33 »
Little ways as in weeks or months?
Offline litster
« Reply #485 on: Wed, 30 November 2011, 22:33:12 »
I say at least 1.5 months away.
Offline hashbaz
  • Grand Ancient One
« Reply #486 on: Wed, 30 November 2011, 22:34:03 »
Sounds good, thanks.
« Reply #487 on: Wed, 30 November 2011, 23:56:36 »
Quote from: hashbaz;461703
No I dont think the plate thing got settled. I believe someone brought up the idea of making the plate so that the left shift could be on the inside or the out side. If that cant be done I still want left shift on the outside like ISO I would at least like a plate design that I can submit and get cut myself as I assume not that many people want the layout that I do. The only reason that I ask about this is because the two people and I would prefer the left shift to be on the outside like ISO.
Also I know that we might have a acrylic case now but it would stil be good to know if the PLU has the same case as a Filco. Also do we have any possible prices on a complete Acrylic case?
« Last Edit: Thu, 01 December 2011, 00:00:02 by TheProfosist »
Offline litster
« Reply #488 on: Thu, 01 December 2011, 00:00:27 »
Yes, we will get you the plate dxf files.  Either we make the change for you, or you can make the change.  It should be fairly easy.
« Reply #489 on: Thu, 01 December 2011, 00:03:16 »
Quote from: litster;461746
Thanks alot, It would be great if you could make the changes as I have no experience and dont have the time to gain it currently. Now I can finalize both my Phantom 7bit and DOX layouts and should be able to start a DOX soon.
« Last Edit: Thu, 01 December 2011, 00:05:51 by TheProfosist »
Offline litster
« Reply #490 on: Thu, 01 December 2011, 00:19:38 »
A couple more pictures:
Thing I need to do or think about:
- 2nd layer needs to be a tad thicker for Filco.  Not a problem with the actual Phantom.
- lower screws count from 11 to 8, don't really need that many screws.
- right now the PCB is sitting on the bottom layer.  A better way to do this is to glue a few acrylic posts to support the plate instead.  Need to engrave the post positions.  Notices the PCB has already scratched the bottom layer.  If we do this, the 3rd layer needs to be thicker.
- need to move the cable cut out to center.  I underestimated how long the cable is.
- the second layer needs to be a tad wider and longer than it is now.  maybe 0.5mm.  Right now it is a super tight fit.  Need final plate and PCB to determined final size.
- Need to back legs.  Currently it is too flat.
- The top layer is OK, but I can move some key holes a little bit to center the holes to  keycaps.  Need to way for the final plate cut to determine final key hole locations.
Round out the inside corners for the 3rd layer.
- I need better screws.  Please, any suggestions for better screws?  these from Lowe's sucks.  They are too long and I had to Dremel them.
- I got my Teensy today.  The 3rd layer's thickness is perfect.
- should we make the case both Phantom and Filco compatible?
- as much as I have cut out, the case is HEAVY!  Is that good?
- the Phantom wording took a long time to cut, especially because that layer is so thick, the laser need to run slower to cut it.  It barely cut through.  For the final version, I don't think the word Phantom will be cut.  Maybe engraved.
« Last Edit: Thu, 01 December 2011, 10:09:41 by litster »
Offline kaiserreich
  • HHKB Elite
« Reply #491 on: Thu, 01 December 2011, 00:28:18 »
So now the keyboard case will be in acrylic?
I'm not a fan of transparent cases, just acrylic keyboard roofs.
I have not work with acrylic before, but is it possible to add color to it?
Offline slueth
« Reply #492 on: Thu, 01 December 2011, 00:33:09 »
Yes
Offline litster
« Reply #493 on: Thu, 01 December 2011, 00:35:50 »
You could use colored acrylic, I suppose.  The same drawing could be use to watercut aluminum plates, just like the mounting plate.  But cutting aluminum plates could be more expensive.  I am not sure.  Will need to check with BiNiaRiS to see if his shop could do it.  Some of the acrylic layers are as thick as half an inch.  Not sure how much that would cost with watercutting aluminum.
But with aluminum, you could anodize it to interesting colors.
Offline litster
« Reply #494 on: Thu, 01 December 2011, 00:38:37 »
Quote from: ishtob;461555
So it is doable.  That is good.  What is the diameter for the rods?
Offline kaiserreich
  • HHKB Elite
« Reply #495 on: Thu, 01 December 2011, 00:39:43 »
I just realized I mentioned the wrong kind of color.
What I meant by color, is for the acrylic to be completely opaque, will this be troublesome?
Offline litster
« Reply #496 on: Thu, 01 December 2011, 00:40:03 »
Quote from: TheProfosist;461750
You will need to ask PrinsValium to do that change for you.  I know how to do it in QCAD, but I don't know for sure where to move/change for the switch locations.
Offline litster
« Reply #497 on: Thu, 01 December 2011, 00:45:14 »
Quote from: kaiserreich;461777
Take a look here: http://www.tapplastics.com/shop/category.php?bid=49
There are opaque colors to choose from.  Now that I know how to make one for myself, I don't yet know how to mass produce it and still have an affordable price.  But the time I have the final drawing, this will have cost me over $200 just in material, due to trial and errors.
We still have time.  Next up is the mounting plate, and then PCBs.  Thing are coming togther though.  I am super excited that my drawing and design actually works.  and that I am totally exhausted mentally... :-)
« Reply #498 on: Thu, 01 December 2011, 01:34:12 »
Litster, you're gonna make the OTD guys jealous for once. Excellent case!
Offline bpiphany
« Reply #499 on: Thu, 01 December 2011, 03:22:43 »
Quote from: Tarkoon;460550
Litster I think you simply uploaded the wrong screenshot, PHISO125 and PHANSI125 both are the same image.
Quote from: TheProfosist;461741
This has been done I think. You should have the dxf litster, could you please update the second post? Tell me if there is something more I need to do...
