Author Topic: GH60 prototype betatesting [Call for layouts, GUI testing]  (Read 265360 times)
Offline domoaligato
Re: GH60 prototype betatesting [Call for layouts, GUI testing]
« Reply #450 on: Thu, 16 May 2013, 17:14:26 »
I want to make
FN + Esc = ~
Shift + Esc = `
You can't really do this, because ~ and ` is one code. If you're holding shift, your OS will interpret ~/` as ~, not `...
You can do the opposite though.
Set fn to go to layer 1 on press and layer 0 on release, set shift the same. On layer 1 inherit all the keys from layer 0 and redefine esc to be ~/`
On layer 1 inherit all keys from layer 0 and redefine esc ti
Thanks komar!
Offline domoaligato
« Reply #451 on: Tue, 28 May 2013, 15:36:51 »
Could the gh60 software have a option added to export the generated hex file?
This way we could make backups of the firmware and flash it manually and/or share the completed firmware with others?
Offline engicoder
« Reply #452 on: Tue, 28 May 2013, 16:23:03 »
Komar already created a version that does this...
http://geekhack.org/index.php?topic=37570.msg827049#msg827049
Offline domoaligato
« Reply #453 on: Tue, 28 May 2013, 17:50:28 »
Thanks! I do not know how I missed that. :(
Offline domoaligato
« Reply #454 on: Sat, 06 July 2013, 13:41:12 »
komar does your firmware have a debug mode?
Offline komar007
    • komar's blog
« Reply #455 on: Sat, 06 July 2013, 13:48:01 »
No, it doesn't. What would the debug mode do? I was thinking about implementing one where it sends the current layer number to the GUI and the GUI presents the actual keycodes on this layer. Any other ideas?
Offline Tranquilite
« Reply #456 on: Sat, 06 July 2013, 14:22:19 »
The most useful keyboard debug feature for me is in hasu's firmware where you can enable debug print statements. Very useful for making sure the parts of code you are working on are executing as expected.
Offline komar007
    • komar's blog
« Reply #457 on: Sat, 06 July 2013, 14:38:12 »
Oh, you mean for development. It can be done, sure.
Offline domoaligato
« Reply #458 on: Sat, 06 July 2013, 17:31:13 »
this is what I was thinking of.
Offline komar007
    • komar's blog
« Reply #459 on: Sun, 07 July 2013, 10:32:04 »
GH60 rev. B prototype dimensions
EDIT: I decided to move this to the original GH60 development thread: http://geekhack.org/index.php?topic=34959.msg954124#msg954124
« Last Edit: Mon, 08 July 2013, 12:48:20 by komar007 »
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #460 on: Tue, 09 July 2013, 14:42:00 »
I will go with this layout...
It fixes most things I didn't like on the Poker or on standard keyboards:
1. Capslock
As most other people I never really used Capslock, so I replaced it with "DEL" on my Poker, but on my GH60 layout I will use it as secondary Layer modifier -> It's easy to locate and doesn't interfere much with the assigned 3rd layer buttons (most important the arrow buttons which would be used with the right hand while left presses the layer button).
2. Right Winkey
I never used the right winkey (right "ALT" and "CTRL" not that much either) so I removed the key, put "MENU" and "CTRL" one position to the left, and used the rightmost key as Layer button. Again, it's location is easy to find and it doesn't infer much with the assigned 2nd layer buttons (most important the WASD nav cluster which would be used with the left hand while the right presses the layer button).
3. Arrow keys
These are placed bottom right (as supposed to be) displaced one button to the left so they don't use the shift for "UP" as on the poker. They can be used by either by pressing Layer2 with the right pinky (while the other fingers press the arrow keys) or by pressing Layer3 with the left hand, whatever fits the situation best (single quick taps or continuous presses like when cycling through something).
4. Nav keys
I put these on WASD, mainly because it's position is easy to locate (if you game... and don't use one of the less common gaming key bindings). Also it's possible to use these keys along with the arrow keys without much interference.
5. Delete key and Backspace
I never liked that "\|" is assigned to a non 1x1 key which is also in a relative prominent position (outer edge between enter and backspace, wtf!?), also I really liked how the HKKB uses its position for "DEL/Backspace" (takes just some hours getting used to it) so I picked up that idea but gave delete a separate key (by splitting backspace) and put it top right, left to it I put the tilde/grave key (its imo a much better position for it than on FN+Esc as all other "signs" are on the num row and right side of the board as well). Considered putting backspace on the top right corner and "DEL" where "\|" was, but I think that backspace should get the bigger key and that "DEL" should be on the other end of "ESC".
6. Numberpad keys
On Layer3 I put the numpad numbers in the numrow (what a sentence, huh?) simply because some applications I use demand numpad inputs (numrow keys wont work).
7. Umlauts and Add-Ons
As I'm from Euroland I sometimes need Umlauts, so I put em on appropriate keys on Layer3. I also added Pause/Print on "P" and a taskmanager shortcut on "TAB".
« Last Edit: Tue, 09 July 2013, 14:48:39 by TheSoulhunter »
A Ghost From The Past
Offline Kdash
« Reply #461 on: Fri, 13 September 2013, 03:08:09 »
Hello,guys! I made that PCB on my country. depend on pcbcart_gh60_rev_b_v2 version. when I received the PCB and SMT components and I assembled all together. I flash the  ukbdc_gh60-0.2_rc2.hex and  ukbdc_gh60-0.1.hex firmwares and it does't work... And the ukbdc_gh60-0.2_rc2_std_layout.hex firmware I flashed it can work but the "8, I. K, M"(col9) key can't work. Can any one help me ?
sorry for my poor english  :)
« Last Edit: Fri, 13 September 2013, 03:49:49 by Kdash »
Offline jen1982
« Reply #462 on: Fri, 13 September 2013, 03:34:03 »
I also met upstairs this problem.!!!!
Offline hasu
  • @tmk
« Reply #463 on: Fri, 13 September 2013, 04:11:38 »
Checked rev B schematic and found its pin configuration diffesr from rev A! Firmware of rev A is incompatibile to rev B PCB.
RevB use PB7 for col9(8,I,K,M) instead of PB0 of RevA. You need to change source and build firmware.
Rev A PCB won't be supported by future release of firmware anymore?
« Last Edit: Fri, 13 September 2013, 04:16:47 by hasu »
Offline Kdash
« Reply #464 on: Fri, 13 September 2013, 04:26:39 »
thank you for your reply! So i need to modify the source code and build my own version of firmware? I did the rev B PCB.
« Last Edit: Fri, 13 September 2013, 05:06:24 by Kdash »
Offline hasu
  • @tmk
« Reply #465 on: Fri, 13 September 2013, 05:36:34 »
Kdash,
Right.
I think you got rev B gerber files from this komar's blog page. I downloaded, checked the gerbers and confirmed it uses PB7 for col9.
http://blog.komar.be/projects/gh60-programmable-keyboard/
I guess you need change this line, replace B0 with B7.
https://github.com/komar007/ukbdc/blob/master/platforms.c#L49
Offline domoaligato
« Reply #466 on: Fri, 13 September 2013, 08:46:10 »
Can rev a be copied to a new folder so that development of rev b doesn't overwrite it? Please :D
« Last Edit: Mon, 16 September 2013, 12:29:09 by domoaligato »
Offline Kdash
« Reply #467 on: Fri, 13 September 2013, 11:50:41 »
Kdash,
Right.
Thank you! hasu~ I fix it, and it works correctly.  I can't build the komar's version ,so I modify your source code I find it and change it.
 Yes! It works!
« Reply #468 on: Fri, 13 September 2013, 11:52:46 »
The Rev B design is the final design?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #469 on: Fri, 13 September 2013, 13:22:38 »
IN the GB thread, WFD did say he wanted to make a few changes, I'll wait for the team to reply.
Offline komar007
    • komar's blog
« Reply #470 on: Thu, 19 September 2013, 03:02:45 »
Hi,
sorry for the delays, I've just come back from holidays.
I'm slowly catching up with life, so bear with me.
As you've correctly noticed, the topology of the board has changed slightly, so the firmware needs an update.
Of course the old rev. A will still be supported by the official firmware.
It's also good to hear people are producing rev. B boards themselves
Rev. B is the final design (electrically speaking), only minor mechanical changes will be made, so rev. C will be firmware-compatible.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #471 on: Thu, 19 September 2013, 09:10:44 »
Hi,
Very good news! I can't want to test Rev B!
Offline MOZ
  • Busy making stuff
« Reply #472 on: Thu, 19 September 2013, 10:13:00 »
I will shamelessly ask if anyone has extra PCB with/without components.
Offline gropingmantis
« Reply #473 on: Thu, 19 September 2013, 17:39:00 »
In the GUI how do us funny ISO types work out which numbers apply to which positions? For example |\ and ~# and split backspace.
I mean I've modified the .xml but what switch numbers should relate to which keys?
« Last Edit: Thu, 19 September 2013, 18:32:00 by gropingmantis »
Offline komar007
    • komar's blog
« Reply #474 on: Fri, 20 September 2013, 06:27:40 »
Good question.
The layouts have a few levels of indirection.
First of all every switch is connected to some row and some column. These correspond to inputs and outputs of the microcontroller.
In the firmware, the lowest I/O layer handles these hardware pins by assigning numbers to them. Next, the matrix scanning module is configured by passing a list of pin numbers for columns and a list for rows, so each switch is represented by the column and row numbers (which can be converted to particular pin numbers and later to microcontroller ports). In order to simplify things and provide compatibility of layouts between different revisions of the board, the keys are assigned numbers (so each row-col pair becomes a simple number).
You can see the matrix number to col-row pairs assignment and row and column list to pin numbers assignment here: https://github.com/komar007/ukbdc/blob/master/main_gh60.c#L20-L29 (this is for rev. A)
As you can compare with the GUI, between the left shift and the next key, I left one number (43), so that the order is kept sensible for ISO, and also there is one number omitted between right shift and the preceding key and between enter and preceding key.
As for split backspace, the extra key will have to have a higher number (64 I suppose, since the last one is 63 so far), because it wasn't taken into account before. This is not available in the firmware yet, because I don't have the rev. B board yet;)
This way the old layouts will be compatible with the new revision and it's possible to create an ISO/ANSI combo layout which works correctly on both physical layouts.
I hope this clears things a bit.
Offline hasu
  • @tmk
« Reply #475 on: Fri, 20 September 2013, 12:40:51 »
It is good news for betatesters with their Rev A PCB!
Thank you, komar.
« Reply #476 on: Fri, 20 September 2013, 13:49:27 »
Yes that makes it much clearer. Thanks kormar.
Offline Kdash
« Reply #477 on: Fri, 20 September 2013, 19:20:07 »
 :thumb: Well done!
I modified the tmk_keyboard's source code,and build the rev B version's firmware. I tested it  and it works very fine. Thank you~
and  I will test your layout programming GUI in another day ~
Offline Kdash
« Reply #478 on: Tue, 24 September 2013, 10:24:44 »
Hi komar, My friend wired the leds himself, but he found the blacklight dose not work and he also found the lcol14 connected with the GPIO2  in your PCB design. so he can't simply wired the leds, he cut the connection, the blacklight works fine..  is it a bug or meaning other things?
Offline komar007
    • komar's blog
« Reply #479 on: Tue, 24 September 2013, 10:34:27 »
Unfortunately, this is an error:(
It will be fixed in the final revision. For rev. B, either Fn led will work or the last column of backlight:/
Cutting is not necessary with correct handling in the firmware.
Offline Kdash
« Reply #480 on: Tue, 24 September 2013, 10:42:12 »
Thank you! I got it~ :thumb:
Offline Kdash
« Reply #481 on: Wed, 30 October 2013, 09:42:06 »
Hi komar, how can i add the Mute, Volume Up or Volume Down key using your GUI tools?
Offline komar007
    • komar's blog
« Reply #482 on: Wed, 30 October 2013, 10:11:26 »
As far as I know the volume controls are available in the Consumer Page (0x0C). Adding support for these requires changing the HID report descriptor.
We still need a sensible solution for this. We either have to split the key bitmap between a couple most-frequently used pages (currently there's just one - keyboard page (0x07)) or generate the descriptor each time for a particular layout. But none of these are implemented yet in the firmware.
Offline Kdash
« Reply #483 on: Wed, 30 October 2013, 11:05:05 »
Ok, I see.
I simply modified the source code but it does't work..
so..  wait for your good news  :thumb: or I'll  try to modify it other days~ :p
Offline komar007
    • komar's blog
« Reply #484 on: Wed, 30 October 2013, 11:10:02 »
You can take the current HID report descriptor, and use the USB HID tool (don't remember the name now, but there is a program which simplifies creation of descriptors) and split it up in such a way that instead of some higher codes (preferably those unused) it includes the Consumer Page. Then you can use those codes to achieve what you want. It will require some documentation reading though.
Offline komar007
    • komar's blog
« Reply #485 on: Fri, 08 November 2013, 09:55:58 »
Okay,
rev. A testing is over now. Please check out the new thread: http://geekhack.org/index.php?topic=50685.0
Offline yasuo
  • spanengan puyeng newbie
« Reply #486 on: Sun, 08 December 2013, 09:08:00 »
My layout :D
I want SW1:swap bs>space,SW2:swap caps>enter
Logitech MK220 Colemak DH
« Reply #487 on: Sun, 08 December 2013, 09:32:26 »
My layout :D
I think he means layouts that can actually be built with the GH60...
Offline yasuo
« Reply #488 on: Sun, 08 December 2013, 10:42:20 »
My layout :D
yep,thanks
Offline Manchias
« Reply #489 on: Tue, 02 December 2014, 09:57:10 »
Please help,
After I run inf-wizard, there are 4 devices came out, but none of them with vid 16c0 and pid 047c. Instead of that :
Any idea ?
Offline komar007
    • komar's blog
« Reply #490 on: Tue, 02 December 2014, 10:03:45 »
Please help,
Any idea ?
Please write the revision of PCB, where you bought it and the revision of firmware (if you installed it yourself).
Offline Manchias
« Reply #491 on: Tue, 02 December 2014, 11:57:33 »
Please help,
Any idea ?
Once again, sorry for spaming your topic, blog and email.
My pcb is rev B. I got it from taobao.com and I did not installed it myself. I just try to apply poker layout into your pcb somehow it doesn't work. I spent like a week browse around to find solution but most of my friends haven't own a GH60 before.
Offline hasu
  • @tmk
« Reply #492 on: Tue, 02 December 2014, 12:07:08 »
Your board doesn't have official firmware, just install it.
Offline komar007
    • komar's blog
« Reply #493 on: Tue, 02 December 2014, 12:12:28 »
Please help,
Any idea ?
Yup.
Try installing the newest firmware from here: https://geekhack.org/index.php?topic=50685.0
using instructions from here: https://geekhack.org/index.php?topic=37570.msg717519#msg717519 (bottom of the post)
Also, you might have tried to send a broken layout file.
It's hard to tell if that could brick the board, but I don't have any error-checking of the layout file format, so if the file contains garbage, it might make the keyboard do unpredictable stuff, and almost certainly make it impossible to send new layout. In this case, firmware re-flash is the only option.
« Last Edit: Tue, 02 December 2014, 12:15:07 by komar007 »
Offline Manchias
« Reply #494 on: Sat, 06 December 2014, 06:50:26 »
Thank you for your help Komar.
« Last Edit: Sat, 06 December 2014, 07:00:56 by Manchias »
Offline komar007
    • komar's blog
« Reply #495 on: Sat, 06 December 2014, 07:25:11 »
No problem.
Have you fixed the board?
Offline Manchias
« Reply #496 on: Sat, 06 December 2014, 07:43:59 »
No problem.
I already re-flash the firmware. However, there is little problem with mapping key using rev B gui.
I copied USB folder from previous version for Win 7, replace base_firmware.hex with ukbdc_gh60_revB-0.3-dev. After gui.py, the layout came out with 4 extra button with id: 40,64,54,43. I deleted them in gh60.xml. But when I load poker.lay, and hit the programming button, this is what I get from the cmd screen:
« Last Edit: Sat, 06 December 2014, 11:29:21 by Manchias »
Offline komar007
    • komar's blog
« Reply #497 on: Sat, 06 December 2014, 16:03:26 »
No problem.
The extra buttons are supposed to be there, they are used for other physical layouts.
As for programming, I know it's hard to force the GUI to run on windows, and I can't do anything about it so far.
This might not be very helpful, but the best option is to run the program in any linux distribution, and it should work correctly.
Offline Manchias
« Reply #498 on: Tue, 09 December 2014, 02:35:30 »
No problem.
I used linux, try to mapping key. But same mistake like Windows.
ubuntu@ubuntu:~/Desktop/ukbdc_gui$ sudo python3 gui.py
Exception in Tkinter callback
Traceback (most recent call last):
  File "/usr/lib/python3.3/tkinter/__init__.py", line 1478, in __call__
    return self.func(*args)
  File "gui.py", line 939, in <lambda>
    command = lambda: command("program"),
  File "gui.py", line 847, in on_menu_action
    u.program_layout(binary)
  File "/home/ubuntu/Desktop/ukbdc_gui/ukbdc_lib/ukbdc.py", line 188, in program_layout
    raise RuntimeError("device returned status: %s" % Status.name(s))
RuntimeError: device returned status: unexpected cont packet
This is list of my device, in Linux, may I know how to point the py.gui program to 16c0:047c
Bus 002 Device 003: ID 8087:07da Intel Corp.
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 04f2:b370 Chicony Electronics Co., Ltd
Bus 001 Device 003: ID 138a:003d Validity Sensors, Inc.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 03f0:ae07 Hewlett-Packard
Bus 003 Device 003: ID 045e:0039 Microsoft Corp. IntelliMouse Optical
Bus 003 Device 002: ID 16c0:047c Van Ooijen Technische Informatica Teensy Keyboard
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Thank you for your time.
Offline komar007
    • komar's blog
« Reply #499 on: Tue, 09 December 2014, 04:20:01 »
This is weird. It's clearly communicating with the keyboard but there's a protocol error. That's different than windows, where there was no communication at all, the program wasn't recognizing the keyboard at all.
Have you tried programming with the provided gh60b.lay file? Does this work?
