Author Topic: GHpad FTW (10-Key Pad for GH60)  (Read 715168 times)
0 Members and 7 Guests are viewing this topic.
Offline regack
Re: GHpad FTW (10-Key Pad for GH60)
« Reply #1000 on: Tue, 11 February 2014, 14:51:41 »
I made a layout using hasu's firmware on the 4x6 that I cut into a 4x5. The diode for S20 I had to mount opposite of all of the others (I think it's S20?).
I'm pretty sure I fixed all of those things in one of the most recent revisions, but none of the PCBs were made with those fixes  :(
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #1001 on: Tue, 11 February 2014, 14:54:49 »
Follow this, this is definitely correct:
Hopefully, regack will correct the silkscreen in the next revision.
Offline MOZ
  • Busy making stuff
« Reply #1002 on: Tue, 11 February 2014, 14:56:00 »
I just checked the latest revission from github, it still has the wrong silkscreen.
Offline phatdood9
« Reply #1003 on: Tue, 11 February 2014, 14:57:04 »
Yea, that image I generated was the latest from the repo
The direction that moz pointed out is def. the one working for me
Oh S20? I mounted them all the same, except reverse for S5
I'll mess around with it when I am at home tonight, its just a shot with the heat gun.
Offline regack
« Reply #1004 on: Tue, 11 February 2014, 15:07:32 »
Yes, it seems I never uploaded the fixed one.  The one I have here is .3 instead of .2.  I'll try to get to that tonight.
You're right, it was S5 that was messed up, I had to dig through to find it. Nevermind what I said then.
« Last Edit: Tue, 11 February 2014, 15:16:56 by regack »
Offline MOZ
  • Busy making stuff
« Reply #1005 on: Tue, 11 February 2014, 15:15:44 »
Excellent!
Offline Smasher816
  • HHKB Master
« Reply #1006 on: Tue, 18 February 2014, 22:38:30 »
I'll have to keep an eye on this thread as more get built. If anyone happens to have an extra Atmega I would love to take it off your hands, they are impossible to find online right now.
http://octopart.com/atmega32u4-au-atmel-10466143
Offline justnits
« Reply #1007 on: Tue, 18 February 2014, 23:32:46 »
will there be full LED keys implementation for this?
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline Smasher816
  • HHKB Master
« Reply #1008 on: Wed, 19 February 2014, 11:55:17 »
Full LED lighting would require a new PCB with spots for extra leads and resistors. So I would assume if someone decided to work on that it would have to be as a new project (or possibly revision).
« Reply #1009 on: Wed, 19 February 2014, 15:18:09 »
Still haven't build mine yet :(
Offline dragonxx21
« Reply #1010 on: Fri, 21 February 2014, 22:50:08 »
Anyone figure out how to get LEDs working?
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline whiskytango
  • Don't touch the trim
« Reply #1011 on: Fri, 21 February 2014, 22:55:14 »
I'm only using the numlock led and it is working. I didn't see the point in the other three.
Offline dragonxx21
« Reply #1012 on: Fri, 21 February 2014, 23:11:51 »
Like it is working by default? I'm trying to figure out how to get mine working :P What did you use to make your firmware?
Keyboards Owned:
Offline whiskytango
« Reply #1013 on: Fri, 21 February 2014, 23:36:27 »
yeah, mine was working by default. I used metalliqaz's easy avr firmware.
Possible that your physical connections are not correct? You have to have led legs in right order and have to have a through hole resistor int he right place.
Offline dragonxx21
« Reply #1014 on: Sat, 22 February 2014, 00:19:08 »
Through hole resistors? I believe they came with SMD ones and not through hole.
Keyboards Owned:
« Reply #1015 on: Sat, 22 February 2014, 00:20:46 »
Does anyone have any extra brass standoffs for the moz GHPad case, I never got those. :(
Offline dragonxx21
« Reply #1016 on: Sat, 22 February 2014, 00:26:29 »
Just going to double check... For the LEDs does the square signify the anode or the cathode end?
Keyboards Owned:
Offline whiskytango
« Reply #1017 on: Sun, 23 February 2014, 00:10:26 »
See this post. It did not come with a resistor for the numlock led since the resistor value depends on which led we use. We are supposed to source our own through hole resistor for this.
Now look at the render in this post and the pic of the PCB in this post. See how there are holes for resistors under S1, S6, S11, and S16? To make numlock LED work, you need a resistor in the holes under S1.
I am pretty sure the square is for cathode. If you look the the pic in this post you can follow the traces and see that the round pad on S1 connects to the resistor hole while the square pad connects to another square pad which makes it common. So it looks like round is for anode and square for cathode
Edit: MOZ is right, the square is anode. I just pulled out my actual GHPad and looked at it.
« Last Edit: Sun, 23 February 2014, 08:34:11 by whiskytango »
Offline dragonxx21
« Reply #1018 on: Sun, 23 February 2014, 01:42:55 »
Ah yeah how did I not even notice that. I wonder if it's alright that I've been plugging it in without resistors in there :P Guess I'll have to go out and get some. Guess I'll have to dig through the thread a bit to figure out what resistors I'll need to pick up for the LEDs unless someone already knows.
Keyboards Owned:
Offline MOZ
  • Busy making stuff
« Reply #1019 on: Sun, 23 February 2014, 01:52:52 »
Square is anode
Offline whiskytango
« Reply #1020 on: Sun, 23 February 2014, 13:50:56 »
So on this design, the resistors are connected AFTER the LED in the circuit? That is, the vcc goes to LED anode first, then the LED cathode is connected to the resistor, and the resistor goes to ground through the controller chip? So the controller chip does not control when voltage is applied but rather when the LED circuit is grounded? After following all the traces, this is what I think is going on, just trying to confirm. I am obviously still learning here, and this I find fascinating.
Sorry about the wrong answer earlier, dragon. Glad MOZ was paying attention.
« Reply #1021 on: Sun, 23 February 2014, 14:00:10 »
I probably have your standoffs, Ray. If I do, I'll pop them in the mail to you. Sorry about that.
Offline Smasher816
  • HHKB Master
« Reply #1022 on: Sun, 23 February 2014, 14:02:55 »
The Atmega is finally back in stock on mouser! :D
I guess that means the last part I need is the PCB. Should I be talking with jdcarpe or phatdood9?
« Reply #1023 on: Sun, 23 February 2014, 14:24:45 »
phatdood9 has all the 4x5 PCBs he ordered, besides mine and agodinhost's. :)
« Reply #1024 on: Sun, 23 February 2014, 16:13:22 »
Thanks JD :thumb:
Offline MOZ
  • Busy making stuff
« Reply #1025 on: Mon, 24 February 2014, 01:37:25 »
That is correct, the I/O pins on the controller sink the current and pull it low to turn the LEDs on.
Here is the schematic:
« Reply #1026 on: Mon, 24 February 2014, 21:29:23 »
55548-0
Offline whiskytango
« Reply #1027 on: Mon, 24 February 2014, 22:00:04 »
cool ray, what is that on the left? 4x5 ghpad?
« Reply #1028 on: Mon, 24 February 2014, 22:03:44 »
Yes.
Offline MOZ
  • Busy making stuff
« Reply #1029 on: Mon, 24 February 2014, 23:48:33 »
Looking good!
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #1030 on: Tue, 25 February 2014, 17:07:56 »
Good news!
I received the PCBs this last Friday.
Thanks JD!
 :thumb:
So, anyone already built this keypad using the I2C?
Or I'll be the lab rat?
I'm a lazy bum lab rat ...
 :D
Offline daerid
    • Rossipedia
« Reply #1031 on: Thu, 27 February 2014, 11:08:51 »
I have decided I want to put one of these together. Where can I purchase the parts necessary? Has there been a GB for this already?
Offline whiskytango
« Reply #1032 on: Thu, 27 February 2014, 11:20:48 »
no group buy yet. phatdood9 may still have some extra PCBs from the latest round of prototypes that were ordered. regack's github has a parts list in it that you can order from mouser or digikey
just fyi, phatdood told me he has been crazy busy with work, so he probably won't be able to answer you very quickly.
MOZ had the first prototype acrylic cases made. Not sure if he's taking on any more orders for them or not right now. He has an IC posted somewhere for a potential acrylic case GB
Offline daerid
    • Rossipedia
« Reply #1033 on: Thu, 27 February 2014, 11:29:24 »
Dude you are awesome. Thanks.
Offline phatdood9
« Reply #1034 on: Sat, 01 March 2014, 04:43:55 »
Hi guys, work has been pretty crazy recently. I just got the remaining 4x5s out.
Unfortunately I don't have any 4x5 pcbs left. You guys will have to do another order. I wouldn't recommend going w/ seeedstudio, these PCBs are not the best quality.
Offline phatdood9
« Reply #1035 on: Sat, 01 March 2014, 04:46:34 »
What firmware are you using w/ the 4x5?
I haven't had time to look at it recently, but I was having some issues previously w/ the tmk firmware and the bottom row.
« Reply #1036 on: Sat, 01 March 2014, 06:48:12 »
I'll shoot you a PM.
Offline phatdood9
« Reply #1037 on: Sat, 01 March 2014, 08:12:00 »
Thanks spamray, I actually figured it out myself. It was mostly user error. Everything seems is working nicely :)
« Reply #1039 on: Tue, 06 May 2014, 15:33:49 »
Anyone get one of these?
http://item.taobao.com/item.htm?spm=2013.1.0.0.OEDdax&id=38746408917&scm=1007.10039.737.0&pvid=ca181b91-0128-468d-9de5-58403815de91
Holy ****, yes I am.
If only I didn't lose that 1 ****ing SMD part for C1 mine would be built and functional right now T_______________T
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #1043 on: Tue, 06 May 2014, 17:18:32 »
Bhiner usually. No bad experiences yet.
Is he CONUS? If not, should we bundle an order if there are a few of us orderings? I'm happy to volunteer.
« Reply #1044 on: Tue, 06 May 2014, 22:05:25 »
bhiner is a forwarding company, I've used them before as well. When I loaded that taobao page up it only showed the red case as an option. I'd rather have black.
Offline boardcolletor
    • hardware and accessories for computers and pad
« Reply #1045 on: Tue, 06 May 2014, 22:20:37 »
em...
« Last Edit: Tue, 06 May 2014, 22:29:00 by boardcolletor »
Love geekhack
mainboard, mouse, keyboard
hardware recovery and others
« Reply #1046 on: Tue, 06 May 2014, 22:20:57 »
It seems we can not get it from Taobao seller directly.
Anyone use the same item on this site as follow? can be shipped by EMS, China Post, DHL.
http://www.pabbos.com/38746408917.shtml
I am not sure.
« Last Edit: Tue, 06 May 2014, 22:29:47 by boardcolletor »
Love geekhack
Offline whitevivian
« Reply #1047 on: Tue, 06 May 2014, 22:26:32 »
You can try.  It accepts Paypal.
usb and keyboards collecter
My tumblr for data recovery
computer data recovery
« Reply #1048 on: Tue, 06 May 2014, 22:30:51 »
No. It can not support Paypal.
Love geekhack
« Reply #1049 on: Tue, 06 May 2014, 22:30:58 »
I am not sure.
Still only has 'Red' as an option. :(
