Author Topic: The Living Soldering Thread  (Read 2487481 times)
Re: The Living Soldering Thread
« Reply #2500 on: Mon, 16 February 2015, 09:53:34 »
Is it ok to use a cheap $15 iron + solder kit for a single 60% keyboard job?
That would all depend on how competent you are at soldering.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #2501 on: Mon, 16 February 2015, 10:06:01 »
And also what you plan on soldering. If it is all through hole and no LEDs(in case you need to desolder) and if you don't need to desolder at all, then I think it would work.
Offline meow a cat
  • Resistance is futile.
« Reply #2502 on: Mon, 16 February 2015, 13:43:09 »
Does anyone have any suggestions for a good wire for handwiring a keyboard? New at this. But my Hakko is out for delivery today.  ;D
I want to order some in case I lift a pad or something, and I need to wire a trace by hand. I was also thinking about buying a Planck kit too.
Boards:
« Reply #2503 on: Mon, 16 February 2015, 13:51:29 »
Kinda hard to find this info, since it was posted in comments on a reddit thread.
http://www.reddit.com/r/MechanicalKeyboards/comments/2vx98k/photos_planckatomic_inspired_cartesian_longboard/colq1o9
Quote from: fog
Glad you noticed the wire. I have stopped using standard ribbon cables for these hand builds. I had some old rainbow colored bundled IDE cables that I tore apart and was cannibalizing for use building circuits and realized that I preferred it's gauge, so I ordered some of this [30AWG blue hookup wire from mouser http://www.mouser.com/ProductDetail/OK-Industries/R30B-0100/?qs=kjdRZtHFUmlRP7B8cvTVWw%3D%3D. It absolutely wouldn't stand up to any repeated flexing at the point of solder, but it's ideal for me in any sort of static unmoving configuration like this.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2504 on: Mon, 16 February 2015, 14:41:10 »
Quote from: fog
Isn't 30AWG pretty small for this?  I would expect something closer to like 26AWG hookup wire to be nicer to work with.
I know a bunch of people have been using magnet wire for hand wiring projects.
Offline fknraiden
« Reply #2505 on: Mon, 16 February 2015, 17:25:14 »
Maybe someone can shed some light on this. What should I be using to clean up the residual flux/gunk left over on the board once it's all together?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2506 on: Mon, 16 February 2015, 19:26:00 »
Isopropyl / rubbing alcohol as high of concentration as you can find, I personally wouldn't recommend anything less than 90% and won't use anything less than 70%.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2507 on: Mon, 16 February 2015, 20:10:18 »
This and a toothbrush.
Offline heedpantsnow
  • Old enough to know better
« Reply #2508 on: Mon, 16 February 2015, 20:23:53 »
I don't recommend you brush your teeth with high-percentage isopropyl alcohol sir.  Just sayin.
I'm back.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2509 on: Mon, 16 February 2015, 20:25:39 »
Ya. Not sure I would either. Probably would be awful. Haha.
Offline fknraiden
« Reply #2510 on: Mon, 16 February 2015, 20:54:26 »
thank you, i dont know what i would have done without you. +1
Offline meow a cat
« Reply #2511 on: Tue, 17 February 2015, 06:14:25 »
Quote from: fog
Quote from: fog
Thanks for the link and advice guys, I will look into 30 and 26 AWG hookup wire.
Really stoked to build my first complete board. I just did a little work on my Phantom, I think I did really well for my first ever solder job. No scorch marks on the PCB, and I don't think I ended up with a cold solder joint. I think I used just enough solder too.
The Hakko FX888D is really easy to work with. It heats up crazy fast! Really high quality all around, pretty pleased with it.
Could someone confirm for me that these are the right diodes for building most boards? I need to replace one on my Phantom.
http://ca.mouser.com/ProductDetail/Fairchild-Semiconductor/1N4148/?qs=sGAEpiMZZMudZehw8RjeZWbu6z6oTQTL
Boards:
Offline bpiphany
« Reply #2512 on: Fri, 20 February 2015, 05:58:13 »
I will dig out the thermocouples I have at an appropriate time.. Meanwhile, yesterday I got some inspiration to finally do some planned upgrades to my toaster =) Added some more insulation, some extra mass and rigidity, removed some wires I didn't use, and the very slow thermocouple I had put in it. I also built the solid state relay with its potentiometer into a unit with a wall socket. My multimeter probes fits snugly into that black cable. Now I'll have a power index through the output voltage =D Up until a particular day in my life I was unaware of what the voltage across the potentiometer was, then I found out it is enough to tickle. Today I measured, and it is the full 224-two-holes-in-the-wall output. No more holding the potentiometer by the wires while turning it, yay for safety!
So I finally got a read-your-thermocouple-thing-a-mingy and hooked it up to be able to do some logging. I followed my regular recipe for toasting my controllers. The results are here.
http://deskthority.net/workshop-f7/toaster-smd-re-flow-oven-t6861.html#p210768
Offline jorgenslee
« Reply #2513 on: Sat, 21 February 2015, 10:51:52 »
Will the solder expire? I purchase a solder from geekhackers.org last year but due to GB delays I might not be able to assemble on time. Will I still be able to use the solder after a year I have purchase it?
Offline Melvang
« Reply #2514 on: Sat, 21 February 2015, 22:49:34 »
Yes, the solder will be fine.  The flux has a shelf life, but the solder will be ok.  Somebody else might be able to provide a bit more insight than me.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #2515 on: Sun, 22 February 2015, 10:56:28 »
Baking solder i got baking solder!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2516 on: Sun, 22 February 2015, 11:29:16 »
I have used solder that was a bit older before I got some kester 44 from mkawa and it was fine.  I used a little bit of flux with it because the rosin did not flow quite as well as I would like, but it still worked.  It is definitely easier with fresh new solder, but the older solder worked fine.  If you have a little extra flux to help out if you dont like the flow, that is good too.  :)
Offline fknraiden
« Reply #2517 on: Sun, 22 February 2015, 17:52:40 »
maybe someone can point me in the right direction, im looking for some smd componants for my board. one is marked 4700, i think its a resistor at 470ohm. the other i cant get any info on anywhere. its marked t4, and sideways an 18. i think thats the diode.
EDIT: also, fuction row doens't work, and its only showing up as atmel device and has to be "started" everytime.
« Last Edit: Sun, 22 February 2015, 20:13:42 by fknraiden »
Offline hasu
  • @tmk
« Reply #2518 on: Mon, 23 February 2015, 21:53:51 »
I finally assembled my reflow oven controller, it is very simple, just with button and buzzer, no LCD. I monitor temperature in serial console during reflow. Looks like it works :D
https://github.com/tmk/HeadlessReflowOven
Offline bpiphany
« Reply #2519 on: Mon, 23 February 2015, 22:44:39 »
Arrgh, you are beating me to it.. I've been busy building a larger oven as well. Mine comes with a surprise though. When it's finished that is. I'm waiting for a relay and some wiring to arrive from ebay before I can finish it. This Chinese holiday thing is killing me =)
Looking good by the way.
« Last Edit: Mon, 23 February 2015, 23:54:40 by bpiphany »
Offline hasu
  • @tmk
« Reply #2520 on: Mon, 23 February 2015, 23:37:01 »
Haha, I'm looking forward to that surprise!
And yeah, Chinese new year really depress our hobby, my PCB production also will be slowed down by a month.
Offline bpiphany
« Reply #2521 on: Tue, 24 February 2015, 08:29:07 »
Ok, this is a preview for now. I'm mostly done, looking forward to mess around with the controlling of the beast once it is finished =)
http://deskthority.net/workshop-f7/the-oven-t10016.html
(Want to say that thing you said again, mkawa?)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #2522 on: Wed, 25 February 2015, 14:14:55 »
Nice work hasu!
Looking forward to The Oven bpiphany.
Offline alexofthewest
« Reply #2523 on: Thu, 26 February 2015, 19:11:51 »
I am looking to start modding various electronic devices I have including my poker 2. In the short term I want to swap out my browns with ergo clears and would like some advice on what soddering iron I should look at, but I also want to use it on an RC car I am working on, so perhaps different tips needs to be an option?
What soldering iron should I get (I STRONGLY prefer amazon prime if that's an option)
edit: After reading a lot of this thread a lot of people reccomend the hakko fx888d and some mentioned this: "http://www.edsyn.com/product/CL1481-K.html"   how does the soldering iron in this kit compare to the Hakko?
« Last Edit: Thu, 26 February 2015, 20:50:23 by alexofthewest »
Offline Ngt
« Reply #2524 on: Fri, 27 February 2015, 09:00:28 »
I consider buying this soldering iron in order to try soldering for the first time. I don't want to invest too much money in it as I don't know if I'll like it or not.
http://www.amazon.fr/STATION-SOUDAGE-150-450%C2%B0C-Appareils-%C3%A9lectroniques/dp/B0043QOAV2/ref=sr_1_9?ie=UTF8&qid=1425047744&sr=8-9&keywords=fer+%C3%A0+souder
What do you guys think of this model? I'm sorry the link is in french. I didn't find any options to switch the language of the page. I guess you could use Google page translation.
I looked into the cheap package shown in the OP but I'm not sure they ship worldwide plus it might cost me a bit.
Offline azhdar
  • Praise the AZERTY god
« Reply #2525 on: Fri, 27 February 2015, 09:40:52 »
It's the one I got , I'll show you tuesday :p
Azerty Propagandiste
Offline Ngt
« Reply #2526 on: Fri, 27 February 2015, 10:45:01 »
Oh cool. Do you like it so far? No problem to signal?
Offline fknraiden
« Reply #2527 on: Fri, 27 February 2015, 19:07:18 »
burnt out some smaller stuff while removing leds. could anyone help me find parts highlighted in the attached image? i think i have found the correct diodes marked in blue, but i'm trying to find the smaller brown/tan colored whatevers marked in the other colors. they look like the same thing but one stands taller than the other. please and thank you =P
92237-0
My understanding is i dont need the 470ohm resistors if im not doing leds and i'd only need them on the specific keys if i did want a capslock
Offline hasu
  • @tmk
« Reply #2528 on: Fri, 27 February 2015, 19:17:24 »
I think that chip is ATMega32U4 and cap highlighted with yellow line is connected to pin 6 and green one to pin 44. If this is correct yellow cap should be 1uF(datasheet says 10% torlerant is needed) and green one is decoule cap which is OK with general 0.1uF.
It is a bit difficutl to see size of them but both looks to me like 1608(metric)/0603(imperial).
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2530 on: Sat, 28 February 2015, 12:24:44 »
« Reply #2531 on: Sat, 28 February 2015, 12:40:49 »
Lol sold by same company!
I'm back.
Offline ctm
  • Hello, world!
« Reply #2532 on: Sun, 01 March 2015, 21:10:16 »
A noob question: is it necessary to clean up flux after soldering? I changed a few switches in my keyboard and there is some flux left on the PCB (I use a solder that has flux in the middle). Its appearance matches rosin flux I find on Google image. Will the remaining flux on PCB affects the functionality of the keyboard in long term?
Coming:
Ellipse Model F F62.
Offline fknraiden
« Reply #2533 on: Sun, 01 March 2015, 21:12:20 »
yes and no. some solder is "no clean" and will be fine. but its always safe to just take an old toothbrush and clean it with rubbing alcohol.(will make everything slightly sticky)
Offline phoenix1234
« Reply #2534 on: Sun, 01 March 2015, 21:14:48 »
Unless the flux is acid or corrosive flux, you don't need to clean the residue.
The Kester 44 solder that is selling on GH has non-corrosive and non-conductive flux, so you don't really need to clean it after soldered.
I like linear switches
Offline ctm
  • Hello, world!
« Reply #2535 on: Sun, 01 March 2015, 21:29:45 »
Thank you! Kester 44 looks like what I found in the lab and used in soldering my keyboard, as I remember. So I think I will just leave the flux there. Though it's not pretty, it's inside the case and I rarely see it. I am too lazy to find a solvent to clean it up ;D (I also doubt if there is any solvent in the lab).
Coming:
Offline phishy
« Reply #2536 on: Mon, 02 March 2015, 20:02:25 »
Silly question but i just tried soldering for the first time (good thing i bought extra switches and diodes....but the solder joint for each switch needs to be AFTER the diode, correct?  I effed up and soldering the lead from one diode to right before the diode for the next switch in the row.
« Reply #2537 on: Wed, 04 March 2015, 13:30:15 »
A picture would help a lot.  Are you soldering a hand-wired matrix?  PCB?  I think I understand what you're asking but don't want to make assumptions, so pictures help a lot.
Offline phishy
« Reply #2538 on: Mon, 09 March 2015, 06:41:52 »
I got it all figured out.  I was soldering a matrix.
Now im waiting for some soderon magnet wire because I don't see how people have enough patience to strip down regular wire to tie in all the columns of a matrix.  Sitting there with wire strippers and a razor blade takes 4everrrrr.
Offline azhdar
« Reply #2539 on: Tue, 10 March 2015, 17:01:40 »
One of the switch wasn't working (pressing it or doing a contact onto the solder points, so I desoldered it and I still can't see what's wrong:
Note: the 2 points were working before I tested the pcb when received, not working anymore sadly.
Can you guys help me?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2540 on: Tue, 10 March 2015, 17:38:45 »
I don't see anything wrong.  One thing I want to make sure you understand is that you MUST put LEDs in those sip sockets BEFORE you solder or you will spend hours trying to get LEDs in there after.  Pro tip...  :P
Edit: So if you manually connect those two it will not register the key press?  If that is the case it seems that the pad has somehow disconnected from the trace.  You will have to connect the pad to the destination of the trace then.
Edit2: Your missing a diode.  That is probably the problem...
« Last Edit: Tue, 10 March 2015, 17:41:28 by swill »
Offline azhdar
« Reply #2541 on: Tue, 10 March 2015, 19:03:11 »
Damn I must have broke the diode when soldering somehow, very good catch swill.
I looked on the board for one I could re-use , could I use this one (considering I'll never put a switch on that position) :
sorry ultra potato
Is there something special to know when working on this kind of diodes?
« Reply #2542 on: Tue, 10 March 2015, 19:22:16 »
sorry ultra potato
Ew.  Desoldering SMD=misery in my experience.  Maybe others have some tips for you.
I'm back.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2543 on: Tue, 10 March 2015, 20:31:05 »
sorry ultra potato
I'm on my phone, so its hard to tell anything.  You have to pay attention to polarity when working diodes (not sure if you soldered them originally).  There is a right and wrong direction. They basically work like a one way valve.
I don't know that matrix, so I don't know if you will break the matrix if you remove it. I suspect you may break a row or a column if you remove it. Someone with more experience may be able to help you better.
If you do decide to remove it, you will have to be pretty careful because its easy suck them up and lose them with the solder sucker. I would recommend placing the edge of the sucker on the diode when you suck so it does not try to pull it off. Also, only suck one side, but get it as clean as possible. Then try to heat the other side and slide it off the pad with tweezers. I think that's the most controlled way to get them off with limited tools. You have to basically detach the first side to make this work though.
Hope that helps.
Offline azhdar
« Reply #2544 on: Wed, 11 March 2015, 01:32:15 »
Damn how do I know which type of diode I need? What pictures could I take so you guys can help me out?
Almost certainly stupid question, but I have those : http://www.gonskeyboardworks.com/electric-parts/15-resistorssmd-100-pcs.html
133Ω , I can't use them as diodes right?
Offline fknraiden
« Reply #2545 on: Wed, 11 March 2015, 02:14:54 »
I recently ordered some diodes in 2 case sizes and when I get home I'll find out which one correct and reply with a Mouser link. They are sad, not through hole like gon's.
Offline hasu
  • @tmk
« Reply #2546 on: Wed, 11 March 2015, 02:42:02 »
You can sepecuate it from size of PCB pads but you better supply information about what your PCB exactly is. Hopefully sechematic and PCB design files are prefered.
Apparently you can't those, because those are resistors, not diodes. You will see ghost keys if you use those resistors.
Offline azhdar
« Reply #2547 on: Wed, 11 March 2015, 02:59:34 »
I contacted someone that might have info onto the electronics of this PCB (redScarfIII 96).
Thanks for all your answers !
Offline azhdar
« Reply #2548 on: Wed, 11 March 2015, 04:07:08 »
Offline swill
  • builder & enabler
    • swillkb.com
