Author Topic: GH60 100% Open Source Acrylic Case IC  (Read 580884 times)
Offline Badwrench
  • ummmm.....I forgot
Re: GH60 100% Open Source Acrylic Case IC
« Reply #200 on: Mon, 28 October 2013, 13:27:49 »
That looks really good.  Are those 2mm sheets?
The smoked grey is 2.25mm and the green is 2.75mm.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #201 on: Mon, 28 October 2013, 13:33:35 »
Thanks for posting these lovely pics.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #202 on: Mon, 28 October 2013, 13:41:00 »
Awesome pics!
Great job Moz, really cool design.
Please, I wanna cut this drawing but I'm wondering at here if we do really need all these 5 layers for the bottom part - I would love to get it as thinner as possible ...
Offline JPG
  • Model F is my new passion!
« Reply #203 on: Mon, 28 October 2013, 14:15:56 »
Do you have more pictures of the green acrylic? I am very interested in it and would like to see it if possible!
Sure, just took this for you:
Hum, thx for the pics! Still hard to tell what it would look with green as top and bottom layer.
And smoke for middle layer or white? Decisions!
At least there's still time to get decided!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #204 on: Mon, 28 October 2013, 14:21:06 »
Very much, acrylic can be drilled very easily, just got to know how.
Use the bits used for wood, apply moderate pressure, not too fast and not too slow.
He should tape both sides too and drill through the tape, no?
Offline Badwrench
« Reply #205 on: Mon, 28 October 2013, 15:20:10 »
Yup, this exactly.
Offline debt4lyfe
  • time puts a gun in every hand
« Reply #206 on: Wed, 30 October 2013, 14:59:33 »
Kdash mentioned in the gh60 thread that this case isn't (yet) poker compatible? Is this correct and are changes planned?
http://geekhack.org/index.php?topic=41464.msg1095900#msg1095900
Offline MOZ
  • Busy making stuff
« Reply #207 on: Wed, 30 October 2013, 18:10:57 »
I think that would be the because kdash used an older revision, once I get some time, I will upload the latest revision.
Offline Kdash
« Reply #208 on: Wed, 30 October 2013, 20:49:51 »
Yes, MOZ.
I download the 60per.dwg file (http://geekhack.org/index.php?topic=44382.msg1034343#msg1034343) and made one on my own. it fits GH60 PCB very well.
and Poker II PCB with plate can't fits well, because of the poker II plate's size is much bigger than the PCB's.
I think it fits all the PCB without plate, like poker I and pure.
Offline vorn
« Reply #209 on: Mon, 04 November 2013, 07:25:45 »
(Attachment Link)             (Attachment Link)
How amazing would this case be for the Cherry Replica Set (http://geekhack.org/index.php?topic=50292.0)!!!
With "white, orange, orange, orange, white" layers.
Offline dgreekstallion
  • B.S. Fiend
« Reply #210 on: Tue, 05 November 2013, 21:09:36 »
Make it a case for my Model F-122 and we have a deal... ;)
Recent keyboard fanatic.
Model F-122 convert.
Offline debt4lyfe
« Reply #211 on: Wed, 06 November 2013, 19:52:24 »
so Sprit's acrylic case group buy has started.
http://geekhack.org/index.php?topic=50579.0
Can you describe the pros/cons of this case in comparison? Any reason I shouldn't just buy that one now? I suppose it might be easier to customize your case for my previously mentioned modding purposes but I don't see why I couldn't use either one.
On yours, I could create more space by adding layers, but on sprit's, i could probably stack washers or something between the layers at the screw holes.
« Last Edit: Wed, 06 November 2013, 19:53:58 by debt4lyfe »
Offline MOZ
  • Busy making stuff
« Reply #212 on: Wed, 06 November 2013, 23:53:54 »
I'm not going to get into comparisons, that case does look higher quality and thus you do pay more, it looks great.
I don't know about it's design so I can't comment on whether it is customizable or not.
Offline Alpsie
« Reply #213 on: Wed, 25 February 2015, 14:10:01 »
Oh this is a really old thread.
I hope it is alright that i bring it back up the list.
MOZ, from reading the thread, it did not seem that you have updated the cad to be fully compatible with poker 2. Is it still in the works ?
