Author Topic: HHKB Pro 2 Love  (Read 577792 times)
Offline Ovrclck
  • Romans 8:38-39
Re: HHKB Pro 2 Love
« Reply #1600 on: Sat, 20 February 2016, 21:09:08 »
I sold my HHKB and bought a RF 87u 55g. Did I make a huge mistake? (I really did love my HHKB)
You'll be back  ;D
HHKB Pro 2 | HHKB Pro 2 Type-S | IBM Model M | 2x Dell AT101W
Offline Otesanek
Re: HHKB Pro 2 Love
« Reply #1601 on: Sat, 20 February 2016, 21:14:34 »
You'll be back  ;D
Yeah, I think I will too. I wanted to try the 55g RF though. Maybe I will just harvest the domes for that sweet 55g HHKB.
Offline raymogi
Re: HHKB Pro 2 Love
« Reply #1602 on: Sat, 20 February 2016, 21:16:31 »
You'll be back  ;D
That is exactly why you bought the 55g RF for. 55g HHKB is heaven.
Please feed my addiction.
Offline Otesanek
Re: HHKB Pro 2 Love
« Reply #1603 on: Sat, 20 February 2016, 23:02:14 »
You'll be back  ;D
Looks like I need to save up another $200 for a white HHKB
Offline raymogi
Re: HHKB Pro 2 Love
« Reply #1604 on: Sat, 20 February 2016, 23:05:52 »
It's $200 well spent I assure you.
Offline Ovrclck
  • Romans 8:38-39
Re: HHKB Pro 2 Love
« Reply #1605 on: Sat, 20 February 2016, 23:18:52 »
Absolutely!
Re: HHKB Pro 2 Love
« Reply #1606 on: Sat, 20 February 2016, 23:36:57 »
So today I made a decision to rip open my less than 1 moth old HHLB Pro 2 in black... I modified it a bit and swapped out the Yopre switches with Nova Touch switches. And I have to say for not knowing WTF I was doing I did a bang up JOB!!! All switches were swapped minus the Space bar, because the NT stabilizers did not fit like the Topre ones. Only thing that is a bit off obviously is the key caps themselves. Don't have the same dimension of keys.
Don't hate though! I left my Type S untouched!
Yopre. That's a new one.
Thorpe rulez!1!!
Re: HHKB Pro 2 Love
« Reply #1607 on: Sun, 21 February 2016, 01:28:13 »
Goofing around with Pixlr (online ghetto Photoshop) and came up with some stuff:
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1608 on: Sun, 21 February 2016, 01:29:48 »
that is dope!
Offline Otesanek
Re: HHKB Pro 2 Love
« Reply #1609 on: Sun, 21 February 2016, 01:37:05 »
A E S T H E T I C
Offline Altis
Re: HHKB Pro 2 Love
« Reply #1610 on: Sun, 21 February 2016, 16:52:03 »
Despite the faults that the HHKB has, I've found that I can't stop using it except for gaming.
Like any addiction... you don't realize you're hooked until you try to stop.  :-X
Offline alexjd99
  • oozing through the cells of one's own construction
Re: HHKB Pro 2 Love
« Reply #1611 on: Sun, 21 February 2016, 16:54:30 »
Really digging the cyan and bottom purple one, they look sick  :thumb:
10/10 would buy posters of this
Offline illitirit
Re: HHKB Pro 2 Love
« Reply #1612 on: Sun, 21 February 2016, 22:12:34 »
Just silenced and lubed my board with hypersphere rings and krytox 206/1506.
I was extremely hesitant to lube my board since the first time I did it with EK mech lube 2 i absolutely hated it.
I have a new found appreciation for my HHKB now, its heavenly with the hypersphere + krytox combo.
Small sound clip :
Offline Vittra
  • Airflow Optimizer
Re: HHKB Pro 2 Love
« Reply #1613 on: Sun, 21 February 2016, 22:17:22 »
I thought it was the lack of the arrow cluster and heavy Windows OS use that caused my displeasure with the HHKB Pro 2, but upon reflecting on nubbinator's post... it's actually the crippling nihilistic revelations of this mortal shell.
REALFORCE FOR MY SHORT MEANINGLESS LIFE
Filco MJ Linear R LE TKL
Offline derb2k2
  • Something of a Topre ****..
Re: HHKB Pro 2 Love
« Reply #1614 on: Sun, 21 February 2016, 23:09:17 »
Wooo! I've got the same mods but still, I love hearing it on this video. Was the krytox thick or thin? Viscosity?
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline illitirit
Re: HHKB Pro 2 Love
« Reply #1615 on: Sun, 21 February 2016, 23:12:39 »
was the thick version.  Really changed up my 55g HHKB with the hypersphere rings.  I wonder how extra thick lube would feel like on this board.
Offline illitirit
Re: HHKB Pro 2 Love
« Reply #1616 on: Sun, 21 February 2016, 23:15:36 »
Btw i noticed you have a fc660c, as do i.  After modding my HHKB i cant even touch my FC660c anymore, did you have the same feeling?
The fc660c stock just feels gross now vs my HHKB, i cant use it lol.
Offline lootbag
Re: HHKB Pro 2 Love
« Reply #1617 on: Sun, 21 February 2016, 23:41:49 »
I owned an FC660C for 1 week and sold it haha.
Didn't like the layout and did not like the feel either.
Offline Crossfire
Re: HHKB Pro 2 Love
« Reply #1618 on: Mon, 22 February 2016, 03:50:32 »
Small sound clip :
How did you lube yours? Just the sliders? Just the stems? Or both? :)
Offline Diokhan
Re: HHKB Pro 2 Love
« Reply #1619 on: Mon, 22 February 2016, 04:12:33 »
55g as well?
Offline illitirit
Re: HHKB Pro 2 Love
« Reply #1620 on: Mon, 22 February 2016, 06:19:15 »
Small sound clip :
lubed only slider housing rails.  I took my time to do every slider housing correctly and really got into every nook and cranny
Offline Crossfire
Re: HHKB Pro 2 Love
« Reply #1621 on: Mon, 22 February 2016, 07:09:02 »
I guess as long as the slider travel surface is done with proper lube, there should not be any major difference between lubing the slider rails or slider housings. Thanks for the info, can't wait to do it myself too.
I think that a thick layer of lube on the stabilizer wire and the plastic connection points of the spacebar stab will also eliminite/dampen the rattle a bit, will try and report. Any experiences about that?
Offline Ovrclck
  • Romans 8:38-39
Re: HHKB Pro 2 Love
« Reply #1622 on: Mon, 22 February 2016, 12:49:16 »
Really? I play BF4 and Dayz with no worries. Granted, I don't need much function key work.  Might pickup a Realforce 87U All-45g though.
« Last Edit: Mon, 22 February 2016, 13:00:16 by Ovrclck »
Offline CoolGrayAJ
Re: HHKB Pro 2 Love
« Reply #1623 on: Mon, 22 February 2016, 13:37:27 »
As if I couldn't love my HHKB any more... my first keycaps! Cross-post, I know... but I'm just so damn excited!!!
    HHKB         Razer BlackWidow     Steelseries 6gv2         Logitech G710+
                   Evil Geniuses Edition   MX Red & Brown
Offline Vittra
  • Airflow Optimizer
Re: HHKB Pro 2 Love
« Reply #1624 on: Mon, 22 February 2016, 13:49:53 »
n/a
« Last Edit: Mon, 22 February 2016, 13:56:00 by Vittra »
Offline chroness
  • HHKB Fanboy
Re: HHKB Pro 2 Love
« Reply #1625 on: Mon, 22 February 2016, 14:11:28 »
Are these dyed? or did you switch out the slider?
Cup is love, Cup is life
Offline CoolGrayAJ
Re: HHKB Pro 2 Love
« Reply #1626 on: Mon, 22 February 2016, 14:27:29 »
Dyed :)
Offline Corsa1r
Re: HHKB Pro 2 Love
« Reply #1627 on: Mon, 22 February 2016, 16:48:34 »
That's beautiful!
Ducky Shine 4 - Mx Blues // Ganss G.S-87 - Mx Browns // Type-S HHKB 45g // FC660M - Mx Reds // FC980M Silent Pink // Aula F75 Ice Veins // Rainy75 MMD Vivians
Offline alexjd99
Re: HHKB Pro 2 Love
« Reply #1628 on: Mon, 22 February 2016, 17:27:15 »
Damn, that purple esc is sick. I wouldn't mind a whole board that color  :))
Offline CoolGrayAJ
Re: HHKB Pro 2 Love
« Reply #1629 on: Mon, 22 February 2016, 17:45:07 »
Here's a closer look at the pinks. They really do give it a pop it didn't originally have <33333333
BONUS: The quickstrike/prototype Butcher's Boy Nutria and Golemfish Fugu by Eat_the_food
Offline crickclackman
Re: HHKB Pro 2 Love
« Reply #1630 on: Tue, 23 February 2016, 10:08:36 »
Great job!
Offline derb2k2
Re: HHKB Pro 2 Love
« Reply #1631 on: Tue, 23 February 2016, 11:12:54 »
I'm actually enjoying the plate-mountedness of the FC66C. I had the RF55g but couldn't really enjoy it for long since I sold it.
I would say that the FC660C is a damn good topre board but the layout doesn't work well enough for me to be my driver, which is what I wanted due to its arrow cluster. I will be getting a RF45g uniform soon.
HHKB reigns supreme, no doubt!!
Offline Hypersphere
Re: HHKB Pro 2 Love
« Reply #1632 on: Tue, 23 February 2016, 12:04:12 »
@illitirit: Thanks for the video. Your HHKB has an exquisite sound. The combination of Silencing Rings and a careful lube job seems to work best for damping unwanted noise and bringing out the thock sound of the board. So far, I have gotten my best results using Superlube 51010 oil, but I would also like to try Krytox oil if I can determine just the right viscosity.
@derb2k2: I had a similar experience with the FC660C. I enjoyed the solidity, but I gave it away because of the layout and form factor. I enjoy 60% and TKL, but I haven't been able to warm up to any board in the twilight zone between 60% and TKL.
Offline robbles
Re: HHKB Pro 2 Love
« Reply #1633 on: Tue, 23 February 2016, 14:14:41 »
Crosspost from https://geekhack.org/index.php?topic=79852
But my halfshell came in! My first Topre artisan.
129299-0
How does one become so interested in a thing like keyboards? When you realize you use a keyboard more than any other tool in your life.
Offline Diokhan
Re: HHKB Pro 2 Love
« Reply #1634 on: Tue, 23 February 2016, 15:16:01 »
Looking good!
Can't wait for mine to come in
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #1635 on: Tue, 23 February 2016, 15:40:02 »
Brought mine to work today. Today has been a good day.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1636 on: Tue, 23 February 2016, 18:56:15 »
Get anothre hhkb man!
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #1637 on: Tue, 23 February 2016, 18:59:02 »
I might. I have a sleeve coming for mine, so I may just carry it back and forth.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1638 on: Tue, 23 February 2016, 19:00:54 »
No sleeve will suffice! just get another hhkb mang!
Offline whmeltonjr
Re: HHKB Pro 2 Love
« Reply #1639 on: Tue, 23 February 2016, 19:01:58 »
My keyboard fund is currently REKT, so a second one will have to wait. Especially if I win more Bros when the Reaper/Gamer invoices go out.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1640 on: Tue, 23 February 2016, 19:11:55 »
@whlmtonjr I hope that you'll lose the raffle so you could buy another hhkb
Offline illitirit
Re: HHKB Pro 2 Love
« Reply #1641 on: Tue, 23 February 2016, 23:05:05 »
I think the krytox lube i used 105 / 1506 mixture is a bit too thin for the stabilizers even though i purchased the thick version.  When I lubed my board I actually took apart all the stabilized keys and removed whatever stock lube comes from the factory.  I then put a thin layer over all contact points with the krytox mixture.  The lube in my opinion is a TAD runny for stabilzers but still works perfectly fine.
I was getting a bit of spacebar rattle and my enter key i could hear ringing.  The lube at least alleviated that annoyance, but I cant help in my head think that an extra thick lube would feel better on the stabilizers.
I think the thick version is perfect for alpha keys.
Offline Crossfire
Re: HHKB Pro 2 Love
« Reply #1642 on: Wed, 24 February 2016, 00:31:26 »
I'll crosspost my gpl205 findings here:
I had a rattly spacebar on my type-s and I mean it rattled a lot and it was annoyingly loud. I've applied some gpl205 with a brush, quite a thick layer and spread it out between contacts of stab wire and the plastic places. Now, the spacebar is firm, no noise, not even moving when tapped on the bar - perfect. I've applied a very thin layer on the rails of the switches and it's even more smoother and the thock is evident but really silent, so in the office it can't bother the coworkers...but the gorgeus feel is there, oh man :)
For me, the board is now perfect, I guess those little problems with stabs shouldn't be there at all when coming out of the factory...stock grease vs. krytox...can't believe the difference! So yeah, lubed board is really that better! :thumb:
« Last Edit: Wed, 24 February 2016, 14:18:02 by Crossfire »
Offline waone567
Re: HHKB Pro 2 Love
« Reply #1643 on: Wed, 24 February 2016, 12:07:46 »
I dont know if this the right thread but I promised myself if I win the RnG bro topre caps I will join this cult. so here I am if anyone want to sell their hhkb pro 2 (black, unmodified and in europe) hit me up.  :thumb:
Offline derb2k2
Re: HHKB Pro 2 Love
« Reply #1644 on: Wed, 24 February 2016, 14:48:51 »
Demik?? Is that you?  :))
@Hypersphere yep. To be honest though, with your rings and medium krytox lube, typing on the FC660 is one of the best typing experiences I've ever had. Right up there with HHKB. I will be doing the same for my incoming RF45g soon so I'm looking forward to it.
Offline Fullcream
Re: HHKB Pro 2 Love
« Reply #1645 on: Wed, 24 February 2016, 19:31:14 »
Hello, not sure if anyone remembers but I created a bit of a bamboozle a few pages back when telling everyone my initial experience with the hhkb type S. The reactions were very warranted and I would like to update people on my new opinion of the HHKB. My new non type S arrived a while ago and I have concluded that the hhkb IS scratchy, as others have also said before, however it does not matter and I somehow really like it's scratchiness. I now prefer it to plate mounted Topre. It has a nice bouncy feeling, like the upstroke is stronger. I also like the sound. Besides all that it does have some superior feeling to it that I can't quite describe. It just seems as others have described: "fun".
All I had to do was silence it, lubricate the spacebar stabilizers because it rattled quite a bit and add pbt spacebar. Here is a video I made if you want to hear it:
HHKB
Offline Altis
Re: HHKB Pro 2 Love
« Reply #1646 on: Wed, 24 February 2016, 21:29:13 »
That's pretty much how I described it in my HHKB vs Realforce 87U review in the Reviews section.
The 87U is smoother and more consistent sounding, as well as more quiet.
However, the HHKB has more character and is simply more fun to use. The exception is when I tire of the function layout for using the nav keys as I don't think that it's set up efficiently.
Offline bocahgundul
  • a seal
Re: HHKB Pro 2 Love
« Reply #1647 on: Wed, 24 February 2016, 21:31:45 »
@derb2k2 I'm the apostle of church of topretology. Come join us
Offline Crossfire
Re: HHKB Pro 2 Love
« Reply #1648 on: Thu, 25 February 2016, 00:28:33 »
HHKB
Lubing the switch rails with a thin layer makes it so much smoother...no scratchiness whatsover.
+1 on lubing the stabs with krytox,  I can't believe the difference too. :thumb:
Offline Oxid
  • resin rash and glitter
Re: HHKB Pro 2 Love
« Reply #1649 on: Thu, 25 February 2016, 01:01:05 »
I need to get in on this lubing. I also need to hypersphere the HHKB, i'd love to see how those two feel together, because they sound beautiful (in the lubed/sphered HHKB typing test videos i've seen)
