Author Topic: Topre switch w/ MX Compatible Stem.....  (Read 160052 times)
Offline Polymer
Re: Topre switch w/ MX Compatible Stem.....
« Reply #350 on: Thu, 09 January 2014, 00:15:59 »
I think a lot of people when first trying Topre when they've made that switch to Cherry MX, think it feels too much like Rubber Dome which turns them off a bit...but there is a reason why so many people start liking it after awhile...
I really like Topre for typing..it is just enjoyable to use..and for work that is what I like to use...
Gaming wise though..I've tried and tried but there is something that bothers me about it and something that feels right about Cherry...which is why I use both switches...Maybe it the feel when I mash or spam a key or something...or the fact that it feels easier to do that on Cherry..I'm not 100% sure..
« Reply #351 on: Thu, 09 January 2014, 01:52:01 »
Can't wait to see the price on these. Not super happy about the 45g or the size (I really want a poker layout topper board), but if it's cheapish, CM has a buy from me.
I have already come to the conclusion that CM is probably going to have to keep the prices low even if they don't want to, since they are putting it out there as a gaming keyboard and presumably most mechanical keyboards are bought by gamers I don't see how a gamer can justify a big price tag without your standard gamer backlighting. I am thinking they should ask $110-$120 for it, if it's higher I don't see how they can sell it to your average person. Just think QFR vs Filco for pricing hopefully.
even $200 is fine by me. f660c is at that price, and this is better
Wow, its neat that you've gotten to try both of them already.
 :rolleyes:
form factor is better. You get the more common tkl vs the irregular shape of the 660 and the hhkb.
The CM topre is better because it takes cherry caps, meaning all those cherry mx GBs can be used on it vs 660c or hhkb
opinions != facts
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #352 on: Thu, 09 January 2014, 01:57:27 »
 :rolleyes:
opinions != facts
Death to the non believers!!!
Offline Zeal
    • Zeal Generation Inc.
« Reply #353 on: Thu, 09 January 2014, 03:03:29 »
Here's a pic of the "stabilizers"
Photo credits: CM Bram @Deskthority
edit: bleh already posted a couple pages back.
how does the other two stems sit on the stabilizer switches? Does it fit on the other side of the semi-circle?
« Last Edit: Thu, 09 January 2014, 03:07:34 by Zeal »
Offline terran5992
  • One With The Cup Rubber
« Reply #354 on: Thu, 09 January 2014, 03:16:19 »
Hmm looks like it uses normal topre stabilizers
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #355 on: Thu, 09 January 2014, 03:25:06 »
Yeah i'm guessing they've just made inserts for the caps like Costar does. Good news for people wanting to strip these for parts hopefully.
Offline Linkbane
« Reply #356 on: Thu, 09 January 2014, 11:12:55 »
The stabilizer appears to have sort of clamps or grips on the side which would hold onto the keycap, but I'm not certain. Otherwise I wouldn't know how it stays on the key.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline MJ45
  • HHKB Pro
« Reply #357 on: Thu, 09 January 2014, 11:44:24 »
I believe the the key stem is attached in the switch center only the other two just rest on the nubs in the center of the opening, that move with the center stem. The notches are clearance for ribs that support the cherry style stem. On Topre caps all of the stabilized keys have only 1 stem with the exception of the spacebar. But in order to accommodate cherry keys 2 additional posts I think that's how they did it.
Offline Linkbane
« Reply #358 on: Thu, 09 January 2014, 12:25:19 »
That's exactly what I meant, hah. The center stem is the same, while the extra two are used as grips for the extra stems on both sides. I wonder how it feels..
Offline IPT
  • Formerly projectD
« Reply #359 on: Thu, 09 January 2014, 12:59:31 »
prob pretty similar to how realforce feels.
I know the spacebar has those types of stabs on my rf
Offline quake4mhg
« Reply #360 on: Sat, 11 January 2014, 03:18:51 »
Offline kelske
  • The North Borders
« Reply #361 on: Sat, 11 January 2014, 03:37:18 »
Let's get down to brass tacks here...
Who's pulling one of these apart and selling off plungers for $10 a piece? I'll take one, Gumrot is hungry for my HHKB  ^-^
Offline Abortion0
« Reply #362 on: Sun, 12 January 2014, 00:04:54 »
Damn can't wait for these things, can anyone with a topre keyboard tell me how they are for starcraft? (I know they aren't supposed to be the best, but I remember seeing one of the Korean pros with a realforce 87u a whil back and he seemed to be just fine.)
Offline terran5992
« Reply #363 on: Sun, 12 January 2014, 00:06:30 »
Its all about preference
Offline Linkbane
« Reply #364 on: Sun, 12 January 2014, 01:10:52 »
Some pros use clicky switches or rubber domes, which are supposed to be the worst for gaming, but they're fine too. The effect isn't particularly significant; experience on this site will tell you that it's really all about personal preference.
« Reply #365 on: Sun, 12 January 2014, 01:16:22 »
i hope they don't ruin these boards by giving them full back lighting.
so ****ing tacky.
Offline Coreda
« Reply #366 on: Sun, 12 January 2014, 04:28:59 »
So the OP was in the end teasing about the CM Novatouch? Would be worthwhile updating the thread title perhaps.
« Reply #367 on: Sun, 12 January 2014, 12:30:36 »
so ****ing tacky.
Can you even do backlighting on topre?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #368 on: Sun, 12 January 2014, 12:31:39 »
so ****ing tacky.
You can
Offline Sniping
« Reply #369 on: Sun, 12 January 2014, 13:37:58 »
so ****ing tacky.
But the LED placement is off to the side, it would be hard to make backlighting look even under the keycaps.
You can
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #370 on: Sun, 12 January 2014, 16:30:00 »
so ****ing tacky.
It is not backlit. That is specified in one of the videos at the very end.  They brought it up as a potential negative of the board, but the details are there.
Offline Oobly
« Reply #371 on: Mon, 13 January 2014, 13:47:56 »
I guess it's time for me to start saving.. Let's see.
1. Buy HHKB Pro JP
2. Buy CM Novatouch
3. Swap stems from Novatouch to HHKB while lubing and silent modding
4. Install alternate controller board with Hasu's TMK firmware
5. Put Blank black Cherry profile PBT caps on from Ivan's GB....
6. Enjoy oneness with cup rubber AND cherry profile PBT on a custom layout.....  :thumb:
Of course that will be a rather expensive HHKB, but....
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Linkbane
« Reply #372 on: Mon, 13 January 2014, 14:21:07 »
1. Buy HHKB Pro JP
2. Buy CM Novatouch
I'm actually super excited to know about the pricing on these. I think that CM can't price it too highly, because the consumers aren't all just geekhack members, so hopefully this will be our chance to get affordable Topre. And then I can try that dental band mod and not be sad that I can't get an HHKB.
« Reply #373 on: Mon, 13 January 2014, 14:31:53 »
I want that full size 55g board they were talking about.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #374 on: Tue, 14 January 2014, 05:45:46 »
HHKB with 55g rubber with Cherry mx stems lubed and silenced= Heaven
Offline terran5992
« Reply #375 on: Tue, 14 January 2014, 06:33:37 »
The novatouch should be relatively cheap
I would guess its below the $200 mark
Offline bueller
  • MX baller
« Reply #376 on: Tue, 14 January 2014, 06:35:33 »
Did you finally buy one?
Offline Air tree
« Reply #377 on: Tue, 14 January 2014, 06:56:15 »
About too! I still have to make up my mind if i want to  buy a phone (I don't have one) or a HHKB this month. Hard choice.
Offline yasuo
  • spanengan puyeng newbie
« Reply #378 on: Tue, 14 January 2014, 07:05:36 »
Feel will different......
modding dental band+Orings :))
Logitech MK220 Colemak DH
Offline damorgue
    • Personal portfolio
« Reply #379 on: Tue, 14 January 2014, 07:09:08 »
I feel as if a big part of why people like Topre switches is because of the fine tolerances and excellent build quality which comes with their high price. I am not saying that CM won't succeed in making a copy, but if they make them cheaper then odds are that the build quality won't be as excellent and they won't spend the same meticulous attention to detail. If they aren't as perfect and a slight wobble and scratchiness is introduced, that can essentially make or break the impression of the Topre switch since I believe that to be the reason why a lot of people like them.
Edit: Read this description for instance
I believe that getting it absolutely right will be crucial to its popularity.
« Last Edit: Tue, 14 January 2014, 07:11:37 by damorgue »
Offline 1pq
  • Hipster Doofus
« Reply #380 on: Tue, 14 January 2014, 08:29:20 »
lol if you keep talking about dat cup rubber with experiencing the oneness you might be a little disappointed when you get your HHKB. It honestly took me about a month for me to like my 660C
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline do_Og@n
« Reply #381 on: Tue, 14 January 2014, 09:22:26 »
Is it bad that I only want the full size so I can get more 55gr Topre spings for my F660c?
« Reply #382 on: Tue, 14 January 2014, 09:24:43 »
You need domes....not springs...
Offline keymaster
  • Topre Revolution Theorist
« Reply #383 on: Tue, 14 January 2014, 09:26:40 »
That's my guess, too. CM tends to put out affordable products, even in the upper tiers. I'm going to guess it will be around $150.
Offline do_Og@n
« Reply #384 on: Tue, 14 January 2014, 09:26:50 »
Yeah those...more rubber nips!!!  :p
« Reply #385 on: Tue, 14 January 2014, 09:30:21 »
Maybe even better with rebates.....I'm looking at you NEWEGG!! :P
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #386 on: Tue, 14 January 2014, 14:25:36 »
This I would love to see. Instabuy, if so. If this does happen, I wonder how RF will deal with it. I understand that HHKB has the different form factor, but RF, even if they are higher quality, it'll be hard to persuade people to buy their keyboards for $90-110 more.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #387 on: Tue, 14 January 2014, 16:27:10 »
I would definitely buy the CM topre board, especially if its TKL or 60%.
Not necessary to convert to HHKB, because too much work/$$$. Also aren't the sizes non standard on the HHKB?
What sets would you need to buy to equip a HHKB with MX caps?
« Reply #388 on: Tue, 14 January 2014, 16:30:32 »
A tsangan set and a 1.75x right shift.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #389 on: Tue, 14 January 2014, 16:31:52 »
You'd need a tsangan kit.
And I would bet, priced right, people would buy the stem swapped novatouches here.  Hell, I plan to use mine as a second keyboard after the swap.
Good thing one includes the other.
« Reply #390 on: Tue, 14 January 2014, 16:34:12 »
Really? I didn't know that.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #391 on: Tue, 14 January 2014, 16:44:56 »
TekSyndicate just released a video on this thing, and you actually get to hear the thing at certain points. Sounds decent.
Also, strange how easily that cap popped off...
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #392 on: Tue, 14 January 2014, 16:45:55 »
omgg can't wait to try it with thick pbt
« Reply #393 on: Tue, 14 January 2014, 16:46:37 »
Stems are probably loose. Same problem the 3D printed stems have/had.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #394 on: Tue, 14 January 2014, 16:49:05 »
Agreed. Wanna put thick PBTs and GMK on there. Maybe even SA.
Ah, I see. Would hate to have to sticky tape mod on all of the switches :(
« Last Edit: Tue, 14 January 2014, 16:50:40 by VesperSAINT »
Offline SigLogical
  • 5 prototypes built
« Reply #395 on: Tue, 14 January 2014, 18:46:12 »
is it just me or is the capslock and scroll lock gonna have it's own backlit? because the printing looks very different from looking at the Capslock keycaps at 1:17
HHKB Pro Hybrid Type-S
Offline Linkbane
« Reply #396 on: Tue, 14 January 2014, 21:08:13 »
Off-topic but what's that in your signature?
« Reply #397 on: Tue, 14 January 2014, 21:09:47 »
Looks like and OSU! score
Offline Linkbane
« Reply #398 on: Tue, 14 January 2014, 21:11:18 »
Ooh, coolio. My cynical side is in incredulity that they wouldn't put some sort of self-advertising logo on it.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #399 on: Tue, 14 January 2014, 22:13:02 »
I have been SO good. I haven't bought a new keyboard in almost a year now. But an MX-compatible Topre? Resistance is futile. Just futile.
Well played, Carter, well played.
I am looking forward to yet another keyboard in the house. Hopefully there won't be any from OTHER vendors!
Good job.
 - Ron I samwisekoi
