TMK converters translate various old keyboard protocol into USB so that you can use your old keyobard with modern computer.
Feel free to post any questions and suggestions in this threadAll converters are regularly in stock as of 2025-07.
Converters| Converter | Supported keyboard | Connector | USB | Price | Description |
| IBMPC[AT/XT] | AT, XT, PS/2* | DIN-5(180°) | Type-C | $36 | You can use adapter for PS/2 keyboard and mouse |
| IBMPC[Terminal] | AT with CodeSet3 | DIN-5(240°) | Type-C | $36 | Suits for IBM Terminal Keyboard Model F122 (and Model M122?) |
| IBMPC[PS/2] | PS/2, AT*, XT* | Mini-DIN-6 | Type-C | $34 | You can use adapter for AT and XT.(XT Type1 is not supported) Also with Y-splitter cable you can use two devices. |
| ADB | ADB(Apple and others) | Mini-DIN-4 | Type-C | $34 | Mouse is also supported. |
| NeXT | NeXT non-ADB | Mini-DIN-5 | Type-C | $34 | Mouse is also supported. |
| X68K | Sharp X68000 | Mini-DIN-7 | Type-C | $34 | |
| PC98 | NEC PC9800 | Mini-DIN-8 | Type-C | $34 | |
| SUN | SUN | Mini-DIN-8 | Type-C | $34 | Suits for Type-4, Type-5 and Type-6(non-USB) keyboards. Mouse is also supported. |
| Archimedes | Archimedes | Mini-DIN-6 | Type-C | $34 | For Acorn Archimedes keyboards |
| M0110[Phone] | Apple M0110,M0110A | Modular 4P4C | Micro-B | $47 | Shipped with phone handset cable(Crossover) like this. You cannot use original Apple keyboard cable with this. |
| M0110[Original] | Apple M0110,M0110A | Modular 4P4C | Micro-B | $47 | Shipped without cable. You need healthy original Apple keyboard cable(Straight). |
| IBM4704 | IBM4704 | DE-9(DB-9) | Micro-B | $44 | Connector with Imperial-pitch threaded studs |
| NEWS | NEWS(Sony) | DE-9(DB-9) | Type-C | $44 | Connector with Metric-pitch threaded studs |
| USB-USB | USB HID Boot | USB Type-A | Type-A | $60 | Check this also to place an order. |
Converters with Mini-DIN and DIN connector look like this.
How to orderEmail me to let me know which converter you want and your country. I'll send you Paypal invoice soon.
My email is:
hasu@tmk-kbd.comShippingPlease check this
notes for shipping cost.
Payment Paypal Invoice will be sent to your email. You'll be able to make a payment with credit card on Palpal even if you don't have Paypal account.
Lead TimeThe converters will be shipped usually in several working days and you will receive email with tracking number from Japan Post. Check
junk mail folder of your email used for the payment first if you can't find the email from Japan Post. Email me if you don't get tracking number within 10 working days after payment.
Online Keymap EditorYou can edit keymap on TMK Keymap Editor with web browser. Google Chrome is recommended web browser for this.
http://www.tmk-kbd.com/tmk_keyboard/editor/AvailabilityIBMPC: ○
ADB: ○
NeXT: ○
X68K: ○
PC98: ○
SUN: ○
Archimedes: ○
M0110: ○
IBM4704: ○
NEWS: ○
USB-USB: ○
How to flash firmwareKeymap Editor has
'Flash on Web' feature and you can flash firmware directlry in web browser now.(2025-04-02)
To turn into flash mode press tiny button on converter PCB.
MicrocontrollerUSB-USB and IBMPC:
ATMega32u4Other converters:
ATMega32u2(You will see/use microcontroller name in flash tool.)
See this for detail:
https://github.com/tmk/tmk_keyboard/wiki#flash-firmwareTMK firmwareConverter firmware source codes are available here.
https://github.com/tmk/tmk_keyboard/converterSupport & FAQhttps://github.com/tmk/tmk_keyboard/wikiUpdates2015/05/26 Ordered MAX3421e chips for USB-USB
2015/07/13 Updated M0110 keymap editor(for Rev.1)
2015/07/15 [USB to USB] Added locking key indicator support and fix for rollover error
2015/11/02 [USB to USB] restocked
2016/01/13 Added keymapeditor for USB to USB Converter
2016/03/18
[IBM4704] Converter for internal connection is available2016/04/11 Revised prices(USB-USB: 50->55, M0110/IBM4704: 40-> 42, MiniDIN: 30->32)
2016/05/07 new IBM 4704 external converter
2016/08/16 Revised price of M0110 converter 42->45
2016/09/17 Keymap editor is available for USB-USB, ADB, PS/2, M0110 and NeXT now
2016/09/30 Keymap editor is available for IBM4704 now
2017/05/08 Keymap editor is available for X68000 now
2017/06/06 Added note for shipping to Canada
2018/01/19
Fix lag problem on ADB-USB converter
2018/04/27 Added keymap editor support for
IBM4704 50-key.
2018/07/06 Updated firmware of USB-USB converter
to fix startup issue2018/09/08 Shipping to Canada is no problem now. Removed caveat.
2020-04-22 New
IBMPC convererter firmware is available for PS/2 and Terminal converter.
2020-04-22 Keymap Editor is available for SUN converer now.
2021-03-29 Revised shipping rate
2021-04-15 Reorganized content of first page
2023-11-23 Update Sony NEWS converter. USB connector is Type-C now.
2024-01-28 Update note for shipping
2024-10-13
Reimplement NeXT converter and add mouse support
2025-04-02 Add 'Flash on Web' feature
Old descriptions:
ConvertersMini-DIN type Converters These coverters are equivalent in terms of hardware except for Mini-DIN connector.
Its dimension is around 27mm * 41mm and height is 18mm including Mini-DIN connector.
ADB Converter(4pin)For Apple ADB keyboards.
https://geekhack.org/index.php?topic=14290.0TMK keymap editor is available.for
ADB ConverterMini-DIN 4P connector for ADB
NeXT Converter(5pin)https://github.com/tmk/tmk_keyboard/tree/master/converter/next_usbTMK keymap editor is available.for
NeXT ConverterMini-DIN 5P connector for NeXT
PS/2 Converter(6pin)https://geekhack.org/index.php?topic=14618.0TMK keymap editor is available.for
PS/2 ConverterMini-DIN 6P connector for PS/2
Now new ibmpc_usb converter firmware is also available for PS/2 Converter. 2020-04-22
http://www.tmk-kbd.com/tmk_keyboard/editor/#ibmpc_usbhttps://geekhack.org/index.php?topic=103648.0Sharp X68000(X68K) Converter(7pin)https://geekhack.org/index.php?topic=29060.0TMK keymap editor is available.for
X68000(X68K) ConverterMini-DIN 7P connector for X68K
SUN Converter(8pin) SUN Type-4 and Type-5 keyboard would be supported.
https://geekhack.org/index.php?topic=105671.0https://github.com/tmk/tmk_keyboard/tree/master/converter/sun_usbMini-DIN 8P connector for SUN
Keymap Editor is now available. 2020-04-22
http://www.tmk-kbd.com/tmk_keyboard/editor/#sun_usbNEC PC9800(PC98) Converter(8pin)https://github.com/tmk/tmk_keyboard/tree/master/converter/pc98_usbMini-DIN 8P connector for PC98
IBM Terminal Converter(pin6)IBMPC/AT Code Set 3 converter
https://geekhack.org/index.php?topic=27272.0Now new ibmpc_usb converter firmware is also available for the converter. 2020-04-22
http://www.tmk-kbd.com/tmk_keyboard/editor/#ibmpc_usbhttps://geekhack.org/index.php?topic=103648.0Apple Macintosh M0110 ConverterThis supports Macintosh 128K/512K keyboard(M0110), keypad(M0120) and Mac Plus keyboard(M0110A).
https://geekhack.org/index.php?topic=24965.0The converter looks like the pic and includes detachable coiled 4P4C cable. The cable supplied with the converter, it is a 4P4C telephone handset calble which differs from original Apple keyboard cable. Note that
you *cannot* use Apple keyboard cable with this converter, it may damage your keyboard with reverse polarity power lines. Please refer to this for detail.
https://en.wikipedia.org/wiki/Modular_connector#4P4CDimensions of the converter is around 27mm*59mm*16mm excluding cable.
4P4C plug and socket for M0110 Converter
TMK keymap editor is available.New editor(recommended):
for
M0110(Mac 128K/512K)for
M0110A(Mac Plus)You can hook up M0110 and M0120 to the converter at same time. Note that you have to use
original Apple keyobard cable to connect between the two keyboards.
IBM4704 Converterhttps://geekhack.org/index.php?topic=54706.0Converter for all of IBM4704 variants(50, 62, 77, 107-key) as well as 102-key Alps switch models(Pingmaster).
IBM capacitive switch model P/N: 6019273, 6019284, 6019303, 6020218
Alps switch model P/N: 5954339, 6112883, 6112884, 6341739, 6113442
Its dimension is around 32mm*64mm*18mm.
IBM Capacitive switch 62/77/107-key 50-key(new!)for
Alps switch 102-keySony NEWS converterhttps://geekhack.org/index.php?topic=25759.0More
TMK keymap editor is not available yet.Design FilesConverter PCB design files are available, you can make it yourself.
Converter PCB for Min-DIN typehttps://github.com/tmk/keyboard_converterConverter PCB for USB to USBhttps://github.com/tmk/USB2USB_ConverterOld ConvertersNot available anymore, but TMK firmware still supports these converters.
If you are one of these and have trouble with them contact me, I can help you.
Rev.1 Converter
