Author Topic: Kailh BOX Switches Crack and Stress Keycap Stems  (Read 279223 times)
Offline Photoelectric
Re: Kailh BOX Switches Crack and Stress Keycap Stems
« Reply #100 on: Sun, 29 July 2018, 14:22:22 »
MX Clears fit fine within caps.  There used to be an issue with earlier Signature Plastics DSA sets that could latch onto an MX Clear stem so tightly that you could pull out the stem from the switch when removing a keycap.  But I think that's been fixed on SP's end for a while.  MX Clears don't crack keycaps.
Offline Giorgio
« Reply #101 on: Sun, 29 July 2018, 14:44:06 »
****ed my shift key up. Box Blacks.
 :confused: I can't see the crack. Can someone point it out to me?
Has anyone had MX clears crack their stems? My clears are a much, much tighter fit than my box reds.
Look at the measurements.
Offline Bella_Hwang
  • * Commercial Vendor
    • www.kailhswitch.com
« Reply #102 on: Sun, 29 July 2018, 22:34:35 »
I made a post on Reddit after seeing this thread with some findings regarding some on the issues with the Kailh Box stem sizes. Although it is a low sample size, I am sure more people will start measuring there stems and find similar results.
https://www.reddit.com/r/MechanicalKeyboards/comments/91u9d4/kailh_box_switch_stem_measurements_and_possible/
Hi,I'm Bella from Kailh,actually when we got the message about the keycap crack,we urge the QA to random inspect the box stem of our stock,our datasheet as the post,haven't thicken to 1.40. could i Know when you get the switches and where you buy it?
Dongguan City Kaihua Electronics Co,Ltd
http://www.kailhswitch.com
http://www.kailh.com
Email:sales12@kailh.com
Offline Bella_Hwang
« Reply #103 on: Mon, 30 July 2018, 01:24:16 »
Hi Bella_Hwang,
I've taken some measurements of my Box Royal Hako True switches I got from Novelkeys a few weeks back.
You can find the measurements here: https://www.keebtalk.com/t/kailh-box-switch-stem-measurements-and-possible-problems/2926/16?u=manofinterests
I will be taking more measurements with sample sizes of at least 60 this weekend for the various box switches I have. Some have GMK sets with very small cracks, and some seem fine.
Hi,thanks for your kindly message,we'll notice the issue
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #104 on: Mon, 30 July 2018, 01:42:57 »
Hi Bella_Hwang,
If it turns out to be some kinds of QA issues where you release a massive amount of faulty switches (abnormal stem size) into the market, would you perform a recall on those from your supplier (like NovelKeys)?
Sent from my SM-G955U using Tapatalk
Offline Poesjuh
« Reply #105 on: Mon, 30 July 2018, 04:59:15 »
I highly doubt it. Not only are there a lot of measurements out there already that really make it appear box stems are bigger. Plus, I actually have two different kinds of box blacks, both have the problem.
Look at the part where the led would be
Offline MehAdviceGuy
« Reply #106 on: Mon, 30 July 2018, 06:41:45 »
Speaking of measurements!
I have compiled a list of stem thicknesses of different switches that people has provided to me.
You can take a look at it here if anyone is interested: https://docs.google.com/spreadsheets/d/1Wc59WnMRJs0gVBrOyh2bRQcPl28yL7lim-p-N0l1daQ/edit?usp=sharing
If you have some measurements of stems then send them my way and i will update the list with what you give to me.
I also trimmed the BOX part of a BOX Jade keyswitch to see if the stem size widened at the end, I can say that on my sample size of one that it does not widen or narrow at the end.
Offline otanishock
  • ファーストラブ
« Reply #107 on: Mon, 30 July 2018, 06:49:00 »
Thank you so much for the list. Now that we are able to compare the stem sizes of box switches to their Cherry counterparts', its no deniable that the stems on box switches are consistently larger than what they should've been.
Offline ideus
  • Björkö.
« Reply #108 on: Mon, 30 July 2018, 07:39:32 »
Hi,I'm Bella from Kailh,actually when we got the message about the keycap crack...
There is an MD order for Kailh "Heavy" switches that is scheduled to be shipped in September. Will it be fixed? or Will those switches be certified that they will not break key cap stems?
Please be sure that you fix the wider stems. You shall review your specification considering the reported stems broken. The key cap set's cannot be the final go/no-go gages for oversized switch stems.
Offline LevelSteam
« Reply #109 on: Mon, 30 July 2018, 09:09:31 »
I actually ordered a pair of high precision calipers just to look into this more myself, so I'll update here with a table of what I find too. I think I also have at least one of each of the box switches from a sampler pack so I'll be able to check them each out.
Offline mgsickler
« Reply #110 on: Mon, 30 July 2018, 11:41:28 »
Offline voight-kampff
« Reply #111 on: Mon, 30 July 2018, 12:25:10 »
I have got a workaround for the problem, if one has some loved box switches.
Just put a metal keycap a few times on the box switch, and the stem will be a little tighter.
I used a cheap metal keycap which I got from ebay.
« Last Edit: Mon, 30 July 2018, 13:21:39 by voight-kampff »
Offline Giorgio
« Reply #112 on: Mon, 30 July 2018, 13:12:24 »
Here is my update. Sorry for just linking to reddit - https://www.reddit.com/r/MechanicalKeyboards/comments/935f6l/box_switch_updates_from_novelkeys/
Please read this carefully and thoroughly. I am only speaking on behalf of NovelKeys, and somewhat Kaihua (Kailh) with the information that I have been given. Please do not ask me questions about unrelated topics on this other than the BOX switches, or ask about other companies.
Some background and current information
BOX switches currently have an x axis that is 1.32mm (+- .02mm tolerance). According to Kailh's internal testing, their switches have all been in that spec.
BOX switches' x axis, however, is wider than most other MX style switches. Some users have reported higher measurements (I just got in a really nice set of calipers. All my testing shows that these are within the tolerances), but Kailh's official word is that the switches they have measured have been within spec.
The reason that the BOX switch has a 1.32mm X axis is because DAREU asked Kaihua to widen the BOX switch from 1.3mm to 1.32mm. At the time, DAREU was really the only company that was buying BOX switches. Because of this, Kaihua agreed to change the dimensions for DAREU.
Tolerances within keycaps are unknown, and there have been reports of this varying greatly.
NovelKeys has halted all BOX switch sales
Going forward
I have talked to Kaihua for quite some length about all of these issues. They have agreed to change the stems to 1.3mm (+- .02mm tolerance) for at least my orders.
This means that all current (NovelKeys) Massdrop orders and Novelias will be getting a 1.3mm (=- .02mm) x axis switch.
In regards to (NovelKeys) MD orders, I actually am receiving the switches I ordered today. I have already placed the corrected order and will eat the costs.
This will delay the batch of NovelKeys x Kailh BOX switches (this is the drop that had Dark Yellow, Pale Blue, Navy, and Jade switches). It shouldnt delay the other rounds.
In regards to Novelias, I actually am receiving the switches today as well. I have placed a replacement order for the updated stems.
This may cause a slight delay to this order.
Regarding my stock - I will slowly be getting replacements in for all my stock. This will take some time, and I currently do not have an ETA on this. Current stock may be relisted at some point, but I will have to figure some more things out for that.
Offline Kevadu
« Reply #113 on: Mon, 30 July 2018, 13:20:52 »
While I'm glad that the problem is being addressed that's little comfort for those of us who already own a bunch of box switches...
I'm also curious why DareU requested a thicker X stem in the first place.
Offline PoochZag
« Reply #114 on: Mon, 30 July 2018, 13:49:15 »
Will there be some kind of visual indicator of the new stems?  In the future it could be really difficult telling the difference when buying used boards or switches, and not everyone is going to have nice calipers to verify the difference in a few hundredths of millimeters
Edit: Just saw on the Reddit post that this is uncertain as of now
TX-CP, TX60, Campine Mk. III, Mira SE
Offline ideus
  • Björkö.
« Reply #115 on: Mon, 30 July 2018, 14:43:56 »
Any upcoming Kailh order should include a cheap metal keycap as reworking tool. Just to be sure it will not brake any expensive keycap set.
Offline portbaron
« Reply #116 on: Mon, 30 July 2018, 14:53:53 »
Well this is good news, at least steps are being taken. I'll want to get a hold of one of those 'reworking' tools because I really like box clicks I have now.
| LIVING THE 1800 LIFE |
Offline pixelpusher
« Reply #117 on: Mon, 30 July 2018, 15:05:07 »
This is brilliant.  You would save me a ton of money if it works.  I'm wondering if someone could manufacture a metal one specifically to slim down box switches?
Offline mkarlsson
« Reply #118 on: Mon, 30 July 2018, 17:33:04 »
Great idea! Have to get one of those for my jades.
Offline ideus
  • Björkö.
« Reply #119 on: Mon, 30 July 2018, 20:10:19 »
Please do so. A sort of cutter or grinder in the shape of a key cap stem may do wonders as a rework tooling.
Offline Giorgio
« Reply #120 on: Tue, 31 July 2018, 03:08:35 »
It's impossible to get any precision with such a tool. You'll do 50 keycaps perfectly, and the other 50 will be too lose or too thick.
Offline mkarlsson
« Reply #122 on: Tue, 31 July 2018, 13:00:47 »
Going forward
Hi Giorgio,
I am not an engineer and may be totally wrong but...wouldn't it be safer to go with something like 1.28 mm? this way having error tolerances of +-0.02 you could end up with 1.26 or 1.30. Going for 1.30 could end up with 1.28 or 1.32 which would have the same problem that we currently have. Am I wrong?
Offline Giorgio
« Reply #124 on: Tue, 31 July 2018, 14:39:09 »
Going forward
Hi Giorgio,
Sorry for not quoting correctly. It wasn't written by me.
Offline mkarlsson
« Reply #125 on: Tue, 31 July 2018, 14:47:38 »
Going forward
Hi Giorgio,
Oh sorry... to mgsickler then
Offline ptiede
« Reply #126 on: Tue, 31 July 2018, 17:22:47 »
According to Mike 1.3 is the same as the Kailh speed switches which haven't shown any issues.
On another note, something else Mike said that seems emminently reasonable is there is evidence that part of what's going on isn't just that the spec was 1.32 but that the gmk caps have much looser tolerances for the cross size and those can get pretty small. So the stems cracks when you have a larger box stem and a narrow cap.
« Last Edit: Tue, 31 July 2018, 17:25:50 by ptiede »
Offline ideus
  • Björkö.
« Reply #127 on: Tue, 31 July 2018, 17:25:58 »
On another note there is evidence that part of what's going on isn't just that the spec was 1.32 but that the gmk caps have much looser tolerances for the cross size and those can get pretty small. So the stems cracks when you have a larger box stem and a narrow cap.
If the were true it may happen with other switches and not only with Kailh's.
Offline ptiede
« Reply #128 on: Tue, 31 July 2018, 17:30:56 »
On another note, there is evidence that part of what's going on isn't just that the spec was 1.32 but that the gmk caps have much looser tolerances for the cross size and those can get pretty small. So the stems cracks when you have a larger box stem and a narrow cap.
Maybe, but not necessarily. 1.34 may be the limit where the GMK tolerances start to go haywire. The thing is nobody knows what gmk's tolerances are since they haven't told anyone yet, and that information isn't readily available. But at the end of the day, this whole thing is a mess and there are probably many factors that are going into the stems cracking.
Offline mkarlsson
« Reply #129 on: Tue, 31 July 2018, 17:35:24 »
I still think is risky going to the limit at 1.32. I was just suggesting why not going to a safer size closer to standard cherry switches.
Offline ptiede
« Reply #130 on: Tue, 31 July 2018, 17:49:14 »
I think their point is none of kailhs non-box switches have cracked stems. So they are just making box stems have the same average thickness at the non box ones so it really isn't risky. Actually the box ones will now have tighter tolerances than non-box. That is, speeds are 1.30±0.03 and the new box stems will be 1.30±0.02
« Last Edit: Tue, 31 July 2018, 17:52:13 by ptiede »
Offline ideus
  • Björkö.
« Reply #131 on: Tue, 31 July 2018, 19:12:47 »
Kailh's cross design is not MX COMPATIBLE as it is designed now. It is oversized and out of actual MX stack of tolerances. The only option is to retooled it down to standard MX tolerances.
« Last Edit: Tue, 31 July 2018, 19:15:04 by ideus »
Offline ptiede
« Reply #132 on: Tue, 31 July 2018, 20:00:07 »
That's not what I said... Im sorry if it reads like that. All I said was that there may be a few factors in the stems cracking. One of course are the Kailh stems, it just may not be the only but it is definitely a large part.
Offline chuckdee
« Reply #133 on: Tue, 31 July 2018, 21:43:13 »
« Reply #134 on: Wed, 01 August 2018, 01:51:19 »
We now have people reporting in that XDA Keycaps have started to stretch and crash from BOX switches: https://www.reddit.com/r/MechanicalKeyboards/comments/93jwkq/psa_xda_caps_will_break_on_box_switches/
I have also heard that cheap keycaps should be having issues. (I have destroyed some from a old AJAZZ keyboard by putting the keycaps on BOX Jade switches.)
Offline Giorgio
« Reply #135 on: Wed, 01 August 2018, 01:53:57 »
Yeah. GMK never had a problem in 30 years, and suddenly kailh appears and teaches us how to do keycaps. And switches. After making those switches bigger.
« Reply #136 on: Wed, 01 August 2018, 02:03:49 »
Its wonderful how they change stuff, others stuff break, and they start accusing others of not having their tolerances in check. Fun times to have just put a board together with BOX Jade's...
Offline Giorgio
« Reply #137 on: Wed, 01 August 2018, 02:25:41 »
Yeah, sure. 0.01mm of difference, that's 10 microns. No thanks. I'll box them and pack them.
Just think that with a temperature difference of 50 degrees celsius (like going from summer to winter), a length of 1.3mm of ABS becomes 0.00702mm larger, supposing that they're using the highest quality of abs available.
So the thermal expansion is equal to the new tolerances set by kailh (0.01mm vs 0.007mm which is a difference smaller than 40%), thus making the new tolerance absolutely insignificant and useless.
You leave your keyboard by the window in summer or winter? Boom, keycaps explode. This is aggravated by the fact that you have to take into account the fact that keycaps become smaller and bigger faster than the stem, and that have a bigger surface.
1.3mm * 50 degrees celsius * 108 Linear Temperature Expansion Coefficient /1000000= 0.00702mm
1.3*50*108/1000000
« Last Edit: Wed, 01 August 2018, 02:29:01 by Giorgio »
Offline KHAANNN
« Reply #138 on: Wed, 01 August 2018, 03:43:51 »
201185-0
I ordered these from Aliexpress, but I don't think the seller's going to ship, and it's a very slim chance that any of them would even have the ability to file inside the box stem - I've checked so many possible file's - none of them were that slim
The metal keycap idea is awesome, indeed if someone produces a metal part designed to slim down stems, that would be beyond awesome
Actually, we can design the part, and order it from Shapeways, with a sand-blasted material, the sand-blasting should turn the part into a grinder
Unrelated, DareU, more like, FYourKeycapsFU, with the amount of bad karma they got now, their lives will probably be ruined forever
« Reply #139 on: Wed, 01 August 2018, 03:46:15 »
Why not just remove the box part with a razor blade?
Offline KHAANNN
« Reply #140 on: Wed, 01 August 2018, 03:52:01 »
I assume they are not designed to work that way, haven't tested, let me know if you make it work (It needs to be wobble-free etc.)
« Reply #141 on: Wed, 01 August 2018, 07:36:45 »
I'll try my circumcised BOX jade tonight and give you a update on how much it wobbles. But again, that is a sample size of one.
Offline ptiede
« Reply #142 on: Wed, 01 August 2018, 08:28:21 »
Ok so I am not affiliated with kailh or have anything do with them. So don;t put my words in their mouth.
1.3*50*108/1000000
Cool you calculated a linear thermal expansion coefficient and assumed it applies to a range of 50 degrees. But also your calculation doesn't even apply like you said it did. So you have a 50 degree spread. That means you want the temperature in your house to be fifty degrees warmer than in Kailh's factory when they do their measurement. So let's assume that Kaihua's factory is at 15 degrees Celcius (way lower than the average ambient temperature but ok) then your house must be 65 degrees Celcius...
I am NOT saying Kailh isn't at fault here, of course, they are, I can see with my own two eyes that stems are cracking. The point I was trying to make was that not every stem is cracking, so some tolerances are too loose or there is a compounding issue here. Like some of GMK's caps are a little smaller than normal and combined with the Kailh switches that are on the larger size of the tolerances can lead to cracking. Materials science isn't easy. Also, there is a massive selection bias in this reporting. People are only going to report if their caps cracked (as they should it is still way too common),
Offline Giorgio
« Reply #143 on: Wed, 01 August 2018, 10:28:29 »
LOL.
It's an isotropic material so any other coefficient is a combination of it.
And about the 50 degrees. That's obviously a simplification, but it's no unreal at all. Considering that they measure their mold when it's cold. And that when it's hot for the heat of plastic, it becomes bigger.  But hey, maybe I found where the problem lies.
But that's just to show that thermal expansion and their new tolerances are in the same order of magnitude. And that's what's important when you talk about superimposing different effects.
Offline Brammm87
« Reply #144 on: Fri, 03 August 2018, 03:18:24 »
Just took keycaps of 5 boards with BOX switches (black, white, brown and navy), no cracks but all showed signs of stress on the stems... This ****ing blows.
pls gief bbv2
Offline Giorgio
« Reply #145 on: Fri, 03 August 2018, 03:30:30 »
Mother of god. I can't imagine how upset I would be in seeing thousands of my dollars at risk for the gross incompetence of a third party.
Offline Brammm87
« Reply #146 on: Fri, 03 August 2018, 03:43:24 »
I'm trying to be reasonable. It looks like all keycaps will be able to go back on boards and I never really intended to resell caps (I'm in this hobby for the collecting aspect). I am however considering trying to get my money back, or at least my switches replaced once the manufacturing process has been updated. I really love my box blacks and whites (not a big fan of the browns and navy's so far).
pls gief bbv2
Offline ideus
  • Björkö.
« Reply #147 on: Fri, 03 August 2018, 07:37:47 »
This information may be of interest here. It is the answer I got from MD's customer service on the BOZ switches's latest drop, that it is scheduled to be shipped in one and a half month or so.
Marriah D. (Massdrop Community Support)
[size=0pt]Aug 2, 9:42 AM PDT [/size]
[size=0pt]........
 Marriah here. Thank you for contacting Massdrop Community Support. I understand your concern with the recent issues with BOZ switches and I will be happy to provide more information.
 At this time, Novelkeys and Kailh are aware of this problem and are working on getting the switches corrected. It has been communicated that they are working on getting this issue fixed prior to this drops shipment date in order to ensure that members receive the corrected versions of the BOX switches.
 If a delay does occur, we will be sure to communicate this out to members as soon as we are aware.
 I hope this information is helpful. Please feel free to reach back out with any other questions or concerns.
 Best Wishes,
[/size]
 [size=0pt]Marriah[/size]
« Last Edit: Fri, 03 August 2018, 08:05:32 by ideus »
Offline Giorgio
« Reply #148 on: Fri, 03 August 2018, 09:56:36 »
[size=0pt]........
 Best Wishes,
[/size]
Doesn't matter. All the "fixed" stems are still completely wrong if the do what they said.
Offline ptiede
« Reply #149 on: Fri, 03 August 2018, 10:38:20 »
[size=0pt]........
 Best Wishes,
[/size]
You have zero actual evidence to support that claim. In fact, there is evidence against it. Kailh is again just changing the box stems to match their other ones. My Kailh Halo stems don't crack or stretch my caps, so why would the box ones? Like you have an argument why it may work, and hey maybe it is a decent one, but again what matters is what we see in the real world and so far we have no evidence that Kailh's other stems are cracking caps.
