Author Topic: E6.5 - 65% custom keyboard (GROUP BUY FINISHED )  (Read 328210 times)
Offline cyyz
Re: E6.5 - 65% custom keyboard (Last shipping Group )
« Reply #750 on: Fri, 20 September 2019, 22:49:52 »
Edit-figured it out
« Last Edit: Sat, 21 September 2019, 11:13:11 by cyyz »
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #751 on: Sat, 21 September 2019, 04:34:36 »
So I'm gonna be building up my E6.5 between today & tomorrow, but have a few questions. I want to use the gasket mount, but have heard of some gasket mounted boards not working with GMK screw-in stabilizers. Is that the case with this board or will I be fine using them? I do have a set of Cherry clip in PCB mount stabilizers, but would much prefer to use the screw in ones if possible. Also I am planning on using MK Ultra plate & case foams with this build. Will the plate foam interfere with the gasket at all? I figure that is not as big as an issue as the stabilizers since I can just trim the edges of the foam back to allow room for the gasket if need be, or even just drop the plate foam & go with the sorbothane strut mod. Anyways, any info from anybody who has built theirs already with the gasket mounting would be highly appreciated!
Offline Auxo
  • Formerly CJD_Anthony
« Reply #752 on: Sat, 21 September 2019, 04:46:13 »
I used GMK screw in stabs and the gasket works perfectly fine, not sure about how the mk ultra plate and case foam would affect it though.
Offline Rob27shred
« Reply #753 on: Sat, 21 September 2019, 04:58:04 »
Awesome news there, thanks for the heads up! Yeah not sure about the foam yet myself, but I got options there. Cut the foam back or just use the sorbothane strut mod so I don't gotta worry about anything being by the edges of the plate.
Offline _ODIN_
« Reply #754 on: Sat, 21 September 2019, 09:53:40 »
Built my E-White E6.5 yesterday. I am impressed.
Switches: Burgundy Pandas (Krytox 203; 60g springs)
Keycaps: SA Vilebloom
226764-0226766-1226768-2226770-3226772-4226774-5226776-6
« Last Edit: Sat, 21 September 2019, 09:56:44 by _ODIN_ »
Offline Rob27shred
« Reply #755 on: Sat, 21 September 2019, 10:58:40 »
(Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link)
So clean, love it man! I didn't know you could get these without the arrow blocker, I went for the WKL case, but I really like it without any blockers too!
Offline _ODIN_
« Reply #756 on: Sat, 21 September 2019, 14:02:30 »
Thank you!
I really like the symmetry of the 1.5/1.5/7/1.5/1.5 bottom row.
Gesendet von meinem H8416 mit Tapatalk
Offline bball2
Re: E6.5 - 65% custom keyboard (Start shipping )
« Reply #757 on: Sat, 21 September 2019, 19:50:37 »
To my understanding, if you're using the gasket, you do not secure it to the top piece. The gasket should kinda friction fit the plate and pcb combo into the case.
For the error message you're getting, that means that the .json file you're using is meant for https://kbfirmware.com/ not qmk config.
Thanks, kbfirmware did the trick!
Also I removed the screws attaching the plate to the top half and didn't make a difference, so I'm assuming that's the proper way to install it if you're using the gasket.
PS. For anyone who is having trouble flashing with the qmk toolbox, you have to press and hold the button on the backside of the pcb for three seconds before the keyboard is recognized as an HID device. Then you can flash using the compiled hex file generated from kbdfirmware.
Here's a pic of my completed build:
Polycarb version - red half plate + wathet / dark red badge
T1 tactile switches
EnjoyPBT extended w/ Torll / Icono
« Last Edit: Sat, 21 September 2019, 20:07:45 by bball2 »
Offline JubJubCity
« Reply #758 on: Sat, 21 September 2019, 19:58:30 »
Sweet thanks for the info, just paid my invoice looking forward to building this.
Offline cattharsis
« Reply #759 on: Sat, 21 September 2019, 20:23:13 »
just FYI, you dont have to use the hexfile from kbdfirmware if you dont want to. Theres support for E6.5 now on config.qmk.fm.
Offline Rob27shred
« Reply #760 on: Sat, 21 September 2019, 20:24:04 »
Thank you!
I agree, I have the same bottom row setup on my RedscarfII+ ver.c & think it not only looks better than the setup using a 6.25u spacebar, but feels better too!
Offline foo4542
« Reply #761 on: Sun, 22 September 2019, 03:36:18 »
Another sick board!
226833-0
« Last Edit: Sun, 22 September 2019, 03:44:27 by foo4542 »
Offline wowja
« Reply #762 on: Sun, 22 September 2019, 16:09:44 »
Man, so jealous. I want a PC case with PC plate. I missed this GB and the Think6.5!
Offline excluisve
  • Making & Thinking.
Re: E6.5 - 65% custom keyboard (GROUP BUY FINISHED)
« Reply #763 on: Wed, 25 September 2019, 08:53:25 »
Thanks for everyone ,Gb finished .
sorry for the delay, exclusive will do it better next time ,hope my keyboard become you exclusively one !!
Let us meet next time
Thanks again to all orders and my friends
Offline jacky
« Reply #764 on: Wed, 25 September 2019, 09:02:16 »
Great job again ! :thumb:
Offline ever9415
    • EVER STORY
« Reply #765 on: Wed, 25 September 2019, 09:09:44 »
I received it safely.
Thank you for sending me well. ^^
« Last Edit: Wed, 25 September 2019, 09:11:34 by ever9415 »
Offline ptiede
« Reply #766 on: Wed, 25 September 2019, 14:32:56 »
You did a great job! There were so many boards this round.
Offline bball2
« Reply #767 on: Wed, 25 September 2019, 16:23:54 »
A little late, but great communication and great quality product! No complaints from me  :thumb:
Offline Rob27shred
« Reply #768 on: Wed, 25 September 2019, 16:29:21 »
Thanks again for the smooth GB & extra communication you did with me to make sure you had my address right! The delay is really nothing to apologize about IMO, it was a very small one & was done to ensure the quality of the product. Nothing wrong with that at all! Honestly this was one of the smoothest, worry free GBs I've participated in. Looking forward to your future designs & would not hesitate to buy another board through you! :thumb:
Offline LuiKang
Re: E6.5 - 65% custom keyboard (GROUP BUY FINISHED )
« Reply #769 on: Sat, 28 September 2019, 06:28:04 »
Type test on alu top and pc bottom
Offline koenoe
    • My YouTube channel
« Reply #770 on: Sat, 28 September 2019, 08:15:34 »
Thank you very much for this smooth Group Buy. It's been a good one and I'm very happy with the board. Also I'd like to highlight the unboxing process, which was an amazing experience! I felt like a little kid unboxing a birthday or Christmas present. Thanks again, and can't wait to join your next one :-)
Offline mrpetrov
« Reply #771 on: Sat, 28 September 2019, 08:41:40 »
I have the PC e6.5 with rose gold rear and badge. Would anyone be interested in swapping their alu case for a pc case?
Offline itunesacc
« Reply #772 on: Sat, 28 September 2019, 11:48:19 »
Everyone! If you willing to sell this keyboard, plz PM me!!!
Offline victorpre
« Reply #773 on: Sat, 28 September 2019, 14:08:07 »
Any extras available? :)
Offline click clack jack
« Reply #774 on: Sat, 28 September 2019, 14:18:17 »
Exclusive is a TOP TIER gb runner!
The box, the ano qual, the orginization, etc etc!
Offline Rob27shred
« Reply #775 on: Sat, 28 September 2019, 14:47:56 »
Looks great OP & gives me a little preview on mine! I went with the dark red WKL alum. case to pair with Jamon as well. However I went with e-white accents (nameplate & weight) cause I really like the look of Jamon with both white & black accents with the white spacebar. Other than that I plan on doing the same layout so we're pretty much E6.5 bros!
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #776 on: Sun, 29 September 2019, 09:48:28 »
« Last Edit: Sun, 29 September 2019, 09:59:46 by cldskt »
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline excluisve
« Reply #777 on: Mon, 30 September 2019, 08:39:42 »
Sort some pic and video sharing here :
https://imgur.com/a/P9tWgmH
Thanks to those orders :
Have much video so that not all post
« Last Edit: Mon, 30 September 2019, 08:46:41 by excluisve »
Offline excluisve
« Reply #778 on: Mon, 30 September 2019, 08:40:23 »
Thanks to sharing those great pic !
Offline excluisve
« Reply #779 on: Mon, 30 September 2019, 08:40:43 »
Full album: https://imgur.com/a/7DwPZcd
« Last Edit: Mon, 30 September 2019, 08:44:37 by excluisve »
Offline Mcnos
    • GMK Fuyu
« Reply #780 on: Mon, 30 September 2019, 09:05:40 »
Offline Fallakin
« Reply #781 on: Tue, 01 October 2019, 08:29:34 »
Invite link is dead, got a new one?
(Used to be in there and mistakenly left the server cleaning up what I'm joined to in Discord)
Offline Vov
« Reply #782 on: Tue, 01 October 2019, 12:40:20 »
https://discord.gg/CvwbHd
1.2 og | 2.0 add | Fallacy | Alpha65 | Ojou | Orion v2.5 | Kei | FMJ Poker | GSKT-00 | Unikorn 2.1
Offline Fallakin
« Reply #783 on: Tue, 01 October 2019, 12:44:34 »
Thank you!
Offline BIG_BUCKNUT
« Reply #784 on: Tue, 01 October 2019, 12:52:47 »
If anyone has an extra nameplate they're willing to part with please let me know. Looking for gold or rose gold.
Offline Tekniqs
« Reply #785 on: Fri, 04 October 2019, 21:47:08 »
anyone have an extra name plate? blank or the 'normal' exclusive name.
Offline Rob27shred
« Reply #786 on: Sun, 06 October 2019, 14:18:49 »
227717-0
Finally got around to building mine!
Offline Rob27shred
« Reply #787 on: Sat, 12 October 2019, 13:49:37 »
Finally got VIA working with mine today thanks to the always awesome LightningXI! Now that I got it going I figured it would be a good ideal to post the links to the latest version of VIA that supports the E6.5 & the .hex file that allows VIA to recognize your E6.5 here for others who couldn't find them like me.
E6.5 VIA.hex - https://cdn.discordapp.com/attachments/555079607250976798/615866051988815872/exclusive_e65_VIA.hex
Latest version of VIA - https://github.com/olivia/via-config/releases/latest
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #788 on: Thu, 17 October 2019, 01:44:14 »
Are the details on how to QMK configure this anywhere? What is the microcontroller for example.
Offline neon_tom
« Reply #789 on: Thu, 17 October 2019, 06:36:54 »
https://github.com/qmk/qmk_firmware/tree/master/keyboards/exclusive/e65
Everything you need should be in here.
Offline Tyson
« Reply #790 on: Thu, 17 October 2019, 13:14:06 »
I somehow misplaced my screws for the nameplate and the screws for the top mount option, is it possible to buy the screws again?
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #791 on: Tue, 19 November 2019, 11:39:05 »
symbiosis finally came and I finished my build. It came out absolutely gorgeous ;D
« Last Edit: Tue, 19 November 2019, 11:42:02 by elmo »
Offline PocketAces
« Reply #792 on: Sat, 07 December 2019, 08:16:17 »
Yeah soo that white and rose gold is probably my dream board. Unfortunately I didn’t even know about this hobby when this went into group buy lol.
Any word on another round? Or maybe extras from this round?
Orrrrr if you want to sell me your white/rose gold, DM me!
Offline Sic_Alpha
« Reply #793 on: Sat, 07 December 2019, 13:15:35 »
His GB for E8.5 was just extended and should still be open.  Would be quick about it if you want it though.
https://geekhack.org/index.php?topic=103520.0;topicseen
Offline Egobean
« Reply #794 on: Sun, 29 December 2019, 17:31:49 »
me personally im only into the 65% keyboards i wish i got in this one when it happened.
Offline Egobean
« Reply #795 on: Sun, 16 February 2020, 17:13:27 »
if anyone is willing to sell their e6.5 keyboard pm me please :)
Offline ElKapitain
« Reply #796 on: Sat, 22 February 2020, 10:39:59 »
I'm also willing to buy one, reach out on reddit if you are interested to sell :) u/C4pitain
Offline excluisve
« Reply #797 on: Tue, 17 March 2020, 11:43:57 »
Offline Rob27shred
« Reply #798 on: Tue, 17 March 2020, 12:03:28 »
http://bit.ly/33rWi8w PCB release
Awesome, thanks for doing a batch of these E! I've been wanting to do a linear build for my E6.5, but really didn't want to desolder my current setup it in it to do so. No more worries now for those of us who didn't order any extra PCBs or plates! Just ordered myself a PCB, PC plate, & fresh gasket. When will PP invoices be going out for these?
« Last Edit: Tue, 24 March 2020, 14:01:24 by Rob27shred »
Offline nephlock
« Reply #799 on: Tue, 17 March 2020, 12:10:33 »
Do these PCBs also include the the side RGB lights the originals had?
