Are your eyes bleeding? You can always change your theme.
Do these have a date of manufacture somewhere?
I do think it could use a logo somewhere though. It looks pretty plain.
Are you sure it is a CM? It seems like the mStone Groove87 from IDFactory, though the keycaps are definitely CM.I hope it is a new design, or maybe just the OEM screwed the branding, and it is just one of a kind. Either way it is nice.
so how can we be sure that if we order a QF rapid that we'll be getting one without branding?
I will try and check exactly which ones amazon has, but there is definitely more coming.
I like the CM storm branding over the arrow buttons, kind of dislike the one over at the ESC key and the one on the "front".
Quote from: Deekin on Mon, 03 September 2012, 09:58:28I like the CM storm branding over the arrow buttons, kind of dislike the one over at the ESC key and the one on the "front".Yea, that spot is definitely too empty without the branding. Like something should be there, but it isn't.
I think they should just put the logo where filco does on tenkeyless boards. It obviously works
I wonder if the newegg/amazon boards are updated.
any branding on the top?
At this point in time we are unable to verify each individual retailers/etailers stock. If you contact me directly(PM) I can direct you with the correct direction for the newest board.
and still has a great price and build!
