I have finally have time to take apart my RF to inspect the spacebar to see what is the cause of the loud sound,
and I found that the stabilizer's housing is shaky in all direction, include up down, left right and top bottom....
so I decide to try to make it more secured on plate by sticking some 3M tape on plate,
decide to use 3M tape simply because it is easy reversible, no harm to plastic nor metal plate, nor even the paint on the plate...
So I tried to apply some tape on it, and immediately found that it is not enough with only one layer.
I try more layers on to try secure the stabilizer's housing... and actually one of the side needed less than the other,
one of the side I put 2 layers, but the other side, I applied 4 layers..
Any way, the spacebar is now much more quiet, compare to the first video on the first post here.
Hope this will help out those who think the sound is annoying.
