Author Topic: Majestouch 3  (Read 15905 times)
Offline KuhnTang
  • Game of Thrones
Re: Majestouch 3
« Reply #50 on: Fri, 04 January 2013, 16:13:30 »
How do I unsubscribe from a thread?  ie, I don't want to see this thread when I click (new).
Offline alaricljs
  • I be WOT'ing all day...
Re: Majestouch 3
« Reply #51 on: Fri, 04 January 2013, 16:18:34 »
There's a forum for that, but you click Notifications in the top menu bar and check the box to the far right of said thread listing, and then unnotify.
Filco w/ Imsto thick PBT
Offline KuhnTang
  • Game of Thrones
Re: Majestouch 3
« Reply #52 on: Fri, 04 January 2013, 16:30:34 »
I tried that, however, nothing is in that menu.  I've never subscribed to this thread, it only notifies me because I've posted in this thread, therefore I can't unsubscribe somehow.
Offline TotalChaos
  • Indy Game Coder
Re: Majestouch 3
« Reply #53 on: Mon, 21 January 2013, 13:18:01 »
You can check out any time you like,
but you can never leave  :eek:
Re: Majestouch 3
« Reply #54 on: Mon, 21 January 2013, 13:29:34 »
say wha?
Offline Leslieann
Re: Majestouch 3
« Reply #55 on: Mon, 21 January 2013, 15:27:05 »
Detachable cables are nice, but also a (repairable) weak point. Make it detach like it does now, and connect the usb port to case, if done right, you could have it either way and without stressing the board. I believe Cooler Master does this.
USB hub, unpowered is only good for a mouse, maybe a media reader. Hubs can create issues as they draw power themseleves and would likely only be usb 1.1 or usb 2.0. A single USB 3.0 passthrough would be nice and convenient, but would require split cable. There is simply no way to do this cheap and cleanly, in my opinion.
You could do non-invasive media keys.
I would like to see better key/hole alignment, but the biggest thing is get rid of the pad printing. ABS, PBT, Double shot, whatever, you shouldn't get pad printing at this price.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline tauburn
Re: Majestouch 3
« Reply #56 on: Mon, 21 January 2013, 15:42:44 »
I think it would be nice if they sold them without keycaps for a discount. Lots of people would be immediately replacing the stock caps with PBT, but i'm not sure how much of a niche market that would be.
Offline TheSoulhunter
  • Thorpelicious!
Re: Majestouch 3
« Reply #57 on: Mon, 21 January 2013, 16:07:34 »
PBT keycaps...
Offline ComradeSniper
  • HHKB Pro
Re: Majestouch 3
« Reply #58 on: Mon, 21 January 2013, 18:00:00 »
I wouldn't say it would be any more of a niche market than a Filco keyboard itself is.
Offline Vintage
Re: Majestouch 3
« Reply #59 on: Mon, 21 January 2013, 18:01:37 »
Filco barebones owuld be pretty cool.
But WASD will fill that void pretty well i'm sure.
CM QFR w/ MX Reds  | Logitech G900
Offline volatilecoffee
  • Formerly ybnrmalatall
  • I don't feel any certain way.
Re: Majestouch 3
« Reply #60 on: Mon, 21 January 2013, 19:35:39 »
-redacted
« Last Edit: Tue, 11 January 2022, 23:44:42 by ybnrmalatall »
Linear gang needs to rise up against the tactile hipsters.
Offline CeeSA
Re: Majestouch 3
« Reply #61 on: Tue, 22 January 2013, 06:42:03 »
1. programable Controller (3 Layers)
2. detachable USB
in my personal wishlist for me: never buy a keyboard without a programable controller anymore....
Offline tauburn
Re: Majestouch 3
« Reply #62 on: Tue, 22 January 2013, 12:47:35 »
it would also be nice if they would put out a white keyboard that is actually white and not beige/off-white
Offline link_tree
Re: Majestouch 3
« Reply #63 on: Tue, 22 January 2013, 13:02:13 »
I actually like their beige color keyboards better then a pure white but it is hard to find keycaps matching this color unfortunately.
Offline XTF
Re: Majestouch 3
« Reply #64 on: Tue, 22 January 2013, 13:39:16 »
What can be done with such a controller that can't be done by the OS?
Offline link_tree
Re: Majestouch 3
« Reply #65 on: Tue, 22 January 2013, 15:28:16 »
you can do everything by the OS but with a controller you can take your settings with you if you happen to switch computer and also you are not relying on some external software that's running in the background.
some care some doesn't. I for one don't see much use to it, but if I'll decide in the future to switch my layout to something like dvorak, it might come in handy. though it isn't very likely.
Offline zoolzoo
Re: Majestouch 3
« Reply #66 on: Tue, 22 January 2013, 17:49:49 »
PBT keycaps...
Agreed, PBT stock caps would be nice at the MJ price point.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline aznsilvrboy
Re: Majestouch 3
« Reply #67 on: Tue, 22 January 2013, 20:28:56 »
Detachable USB cord, stock PBT keycaps option, backlight, media keys, extra USB ports.
Offline vardhana
Re: Majestouch 3
« Reply #68 on: Wed, 23 January 2013, 02:34:44 »
In Japan, Majestouch 2 Convertible is available.
Convertible has DIP switches, detachable USB cable.
I think Maje 3 must have these functions at least and more functions are needed to differentiate.
Offline llovro
Re: Majestouch 3
« Reply #69 on: Wed, 23 January 2013, 16:31:32 »
Gold plated usb
/thread
  • Thorpelicious!
Re: Majestouch 3
« Reply #70 on: Thu, 24 January 2013, 05:07:14 »
- Remapping before booting the OS (BIOS etc.)
- Full remapping capability without additional software (less bloat)
- Being able to remap keys that cant be remapped by simply using a different layout file (Ctrl, Alt, Win, Shift...)
